74HC365; 74HCT365
Hex buffer/line driver; 3-state
Rev. 4 — 27 January 2016
Product data sheet
1. General description
The 74HC365; 74HCT365 is a hex buffer/line driver with 3-state outputs controlled by the
output enable inputs (OEn). A HIGH on OEn causes the outputs to assume a high
impedance OFF-state. Inputs include clamp diodes. This enables the use of current
limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Inverting outputs
Input levels:
For 74HC365: CMOS level
For 74HC365: TTL level
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Specified from 40 C to +85 C and from 40 C to +125 C
Multiple package options
3. Ordering information
Table 1.
Type number
74HC365D
Package
Temperature range Name
Description
40 C to +125 C
SO16
plastic small outline package; 16 leads; body width 3.9 mm SOT109-1
Version
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads; body width
5.3 mm
SOT338-1
40 C to +125 C
TSSOP16
plastic thin shrink small outline package; 16 leads; body
width 4.4 mm
SOT403-1
74HCT365D
74HC365DB
74HCT365DB
74HC365PW
74HCT365PW
74HC365; 74HCT365
Nexperia
4. Functional diagram
2(
2(
2(
(1
2(
DDD
DDD
Fig 1.
Functional diagram
Fig 2.
Logic symbol
EXIIHUOLQHGULYHU
DDD
Fig 3.
IEC logic symbol
9&&
2(
2(
*1'
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
DDD
Fig 4.
Logic diagram
74HC_HCT365
Product data sheet
All information provided in this document is subject to legal disclaimers.
2 of 20
Nexperia B.V. 2017. All rights reserved
74HC365; 74HCT365
Nexperia
5. Pinning information
5.1 Pinning
+&7
2(
9&&
2(
*1'
DDD
Fig 5.
Pin configuration
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
OE1
1
output enable input 1 (active LOW)
1A
2
data input 1
1Y
3
data output 1
2A
4
data input 2
2Y
5
data output 2
3A
6
data input 3
3Y
7
data output 3
GND
8
ground (0 V)
4Y
9
data output 4
4A
10
data input 4
5Y
11
data output 5
5A
12
data input 5
6Y
13
data output 6
6A
14
data input 6
OE2
15
output enable input 2 (active LOW)
VCC
16
supply voltage
74HC_HCT365
Product data sheet
3 of 20
74HC365; 74HCT365
Nexperia
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
OE1
OE2
nA
nY
L
L
L
L
L
L
H
H
X
H
X
Z
H
X
X
Z
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
supply voltage
VCC
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
VO = 0.5 V to (VCC + 0.5 V)
IIK
Min
Max
0.5
+7
Unit
V
mA
mA
IO
output current
35
mA
ICC
supply current
70
mA
IGND
ground current
70
mA
Tstg
storage temperature
total power dissipation
Ptot
65
+150
C
SO16 package
[2]
500
mW
SSOP16 package
[3]
500
mW
TSSOP16 package
[3]
500
mW
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO16 packages: Ptot derates linearly with 8 mW/K above 70 C.
[3]
For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
74HC_HCT365
Product data sheet
4 of 20
74HC365; 74HCT365
Nexperia
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC365
74HCT365
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
input voltage
VCC
VCC
V
output voltage
VCC
VCC
V
VCC
supply voltage
VI
VO
Tamb
ambient temperature
t/V
input transition rise and fall rate
40
+25
+125
40
+25
+125
VCC = 2.0 V
625
ns/V
C
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
Static characteristics 74HC365
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max Unit
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
Tamb = 25 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
VCC = 6.0 V
4.2
3.2
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35 V
VCC = 6.0 V
2.8
1.8
HIGH-level output voltage VI = VIH or VIL
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
V
IO = 6.0 mA; VCC = 4.5 V
3.98
4.32
V
IO = 7.8 mA; VCC = 6.0 V
5.48
5.81
V
V
V
V
0.15
0.26 V
0.16
0.26 V
LOW-level output voltage VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
0.1 A
IOZ
OFF-state output current
VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V
0.5 A
ICC
supply current
VI = VCC or GND; IO = 0 A; VCC = 6.0 V
8.0
A
CI
input capacitance
3.5
pF
74HC_HCT365
Product data sheet
5 of 20
74HC365; 74HCT365
Nexperia
Table 6.
Static characteristics 74HC365 …continued
Symbol Parameter
Conditions
Min
Typ
Max Unit
Tamb = 40 C to +85 C
VIH
VIL
VOH
VOL
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35 V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.84
V
5.34
V
0.1
V
0.1
V
0.1
V
0.33 V
0.33 V
II
VI = VCC or GND; VCC = 6.0 V;
1.0 A
IOZ
5.0 A
ICC
supply current
80
A
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
Tamb = 40 C to +125 C
VIH
VIL
VOH
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35 V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
74HC_HCT365
Product data sheet
6 of 20
74HC365; 74HCT365
Nexperia
Table 6.
Symbol Parameter
VOL
Conditions
Min
Typ
Max Unit
0.1
V
0.1
V
0.1
V
0.4
V
V
0.4
II
1.0 A
IOZ
10.0 A
ICC
supply current
160
A
Min
Typ
Max
Unit
2.0
1.6
V
1.2
0.8
V
IO = 20 A
4.4
4.5
V
IO = 6.0 mA
3.98
4.32
V
IO = 20 A
V
IO = 6.0 mA
0.16
0.26
V
Table 7.
Static characteristics 74HCT365
Symbol Parameter
Conditions
Tamb = 25 C
VIH
HIGH-level input voltage VCC = 4.5 V to 5.5 V
VIL
VOH
HIGH-level output
voltage
VI = VIH or VIL; VCC = 4.5 V
LOW-level output
voltage
VOL
II
0.1
A
IOZ
OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V
0.5
A
ICC
supply current
8.0
A
ICC
additional supply current VI = VCC 2.1 V; other inputs at VCC or GND; IO = 0 A
CI
VI = VCC or GND; VCC = 5.5 V
VI = VCC or GND; IO = 0 A; VCC = 5.5 V
pins nA
100
360
A
pin OE1
100
360
A
pin OE2
90
324
A
3.5
pF
2.0
V
0.8
V
input capacitance
VIH
VIL
VOH
HIGH-level output
voltage
IO = 20 A
4.4
V
IO = 6.0 mA
3.84
V
0.1
V
0.33
V
1.0
A
5.0
A
LOW-level output
voltage
II
IOZ
VOL
IO = 20 A
IO = 6.0 mA
74HC_HCT365
Product data sheet
7 of 20
74HC365; 74HCT365
Nexperia
Table 7.
Static characteristics 74HCT365 …continued
Symbol Parameter
Conditions
Min
Typ
Max
ICC
supply current
ICC
Unit
80
A
pins nA
450
A
pin OE1
450
A
pin OE2
405
A
2.0
V
0.8
V
VIH
VIL
VOH
HIGH-level output
voltage
IO = 20 A
4.4
V
IO = 6.0 mA
3.7
V
IO = 20 A
0.1
V
IO = 6.0 mA
0.4
V
1.0
A
10.0 A
LOW-level output
voltage
II
IOZ
ICC
supply current
160
A
ICC
pins nA
490
A
pin OE1
490
A
pin OE2
441
A
VOL
74HC_HCT365
Product data sheet
8 of 20
74HC365; 74HCT365
Nexperia
10. Dynamic characteristics
Table 8.
Dynamic characteristics 74HC365
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Figure 8.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
30
95
ns
VCC = 4.5 V
11
19
ns
Tamb = 25 C
tpd
ten
tdis
tt
CPD
propagation delay
enable time
disable time
transition time
power dissipation
capacitance
nA to nY; see Figure 6
[1]
VCC = 5 V; CL = 15 pF
9
ns
VCC = 6.0 V
9
16
ns
VCC = 2.0 V
47
150
ns
VCC = 4.5 V
17
30
ns
VCC = 6.0 V
14
26
ns
VCC = 2.0 V
61
150
ns
VCC = 4.5 V
22
30
ns
VCC = 6.0 V
18
26
ns
VCC = 2.0 V
14
60
ns
VCC = 4.5 V
5
12
ns
VCC = 6.0 V
4
10
ns
40
pF
VCC = 2.0 V
120
ns
VCC = 4.5 V
24
ns
ns
VCC = 2.0 V
190
ns
VCC = 4.5 V
38
ns
33
ns
VCC = 2.0 V
190
ns
VCC = 4.5 V
38
ns
33
ns
VCC = 2.0 V
75
ns
VCC = 4.5 V
15
ns
VCC = 6.0 V
13
ns
OEn to nY; see Figure 7
[2]
[3]
[4]
see Figure 6
per buffer; VI = GND to VCC
[5]
[1]
tpd
propagation delay
VCC = 6.0 V
ten
enable time
[2]
VCC = 6.0 V
tdis
disable time
[3]
VCC = 6.0 V
tt
transition time
74HC_HCT365
Product data sheet
[4]
see Figure 6
9 of 20
74HC365; 74HCT365
Nexperia
Table 8.
Dynamic characteristics 74HC365 …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
145
ns
VCC = 4.5 V
29
ns
25
ns
VCC = 2.0 V
225
ns
VCC = 4.5 V
45
ns
38
ns
VCC = 2.0 V
225
ns
VCC = 4.5 V
45
ns
38
ns
VCC = 2.0 V
90
ns
VCC = 4.5 V
18
ns
VCC = 6.0 V
15
ns
propagation delay
tpd
[1]
VCC = 6.0 V
enable time
ten
[2]
VCC = 6.0 V
disable time
tdis
[3]
VCC = 6.0 V
transition time
tt
[1]
tpd is the same as tPHL and tPLH.
[2]
ten is the same as tPZH and tPZL.
[3]
tdis is the same as tPHZ and tPLZ.
[4]
tt is the same as tTHL and tTLH.
[5]
[4]
see Figure 6
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
Table 9.
Dynamic characteristics 74HCT365
Symbol Parameter
Conditions
Min
Typ
Max
14
25
Unit
Tamb = 25 C
tpd
propagation delay
[1]
VCC = 4.5 V
ns
11
ns
ten
enable time
OEn to nY; VCC = 4.5 V; see Figure 7
[2]
18
35
ns
tdis
disable time
[3]
23
35
ns
transition time
VCC = 4.5 V; see Figure 6
[4]
5
12
ns
power dissipation
capacitance
per buffer; VI = GND to (VCC 1.5 V)
[5]
40
pF
tt
CPD
74HC_HCT365
Product data sheet
10 of 20
74HC365; 74HCT365
Nexperia
Table 9.
Dynamic characteristics 74HCT365 …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
tpd
propagation delay
nA to nY; VCC = 4.5 V; see Figure 6
[1]
31
ns
ten
enable time
[2]
44
ns
[3]
44
ns
[4]
15
ns
[1]
38
ns
[2]
53
ns
[3]
53
ns
[4]
18
ns
disable time
tdis
transition time
tt
propagation delay
tpd
enable time
ten
disable time
tdis
transition time
tt
[1]
[2]
[3]
[4]
[5]
11. Waveforms
9,
Q$LQSXW
90
90
*1'
W3+/
W3+/
92+
Q
很抱歉,暂时无法提供与“74HCT365PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.23498
- 10+2.94006
- 25+2.60614
- 100+2.26409
- 250+2.09306
- 500+2.00347
- 2500+1.85688
- 25000+1.80801
- 国内价格 香港价格
- 1+4.218501+0.54499
- 10+2.9699510+0.38369
- 25+2.6505425+0.34243
- 100+2.30062100+0.29722
- 250+2.13433250+0.27574
- 500+2.03381500+0.26275
- 1000+1.964831000+0.25384
- 国内价格 香港价格
- 1+4.204301+0.54340
- 10+2.9586010+0.38240
- 25+2.6471025+0.34220
- 100+2.41960100+0.31280
- 250+2.23990250+0.28950
- 500+2.13210500+0.27560
- 1000+2.048201000+0.26480
- 2500+1.856602500+0.24000
- 5000+1.808705000+0.23380
- 国内价格 香港价格
- 690+4.63278690+0.59851
- 1000+4.273471000+0.55209
- 10000+3.8094210000+0.49214
- 100000+3.19212100000+0.41239
- 国内价格 香港价格
- 1+4.049771+0.52319
- 10+2.8602010+0.36951
- 25+2.5365725+0.32770
- 100+2.20419100+0.28476
- 250+2.03801250+0.26329
- 500+1.95054500+0.25199
- 2500+1.810592500+0.23391
- 25000+1.7581125000+0.22713
- 国内价格 香港价格
- 2500+1.863372500+0.24073
- 5000+1.810755000+0.23393
- 7500+1.784437500+0.23053
- 12500+1.7552412500+0.22676
- 17500+1.7381817500+0.22456
- 25000+1.7217825000+0.22244
