74HC365-Q100; 74HCT365-Q100
Hex buffer/line driver; 3-state
Rev. 1 — 2 August 2012
Product data sheet
1. General description
The 74HC365-Q100; 74HC365-Q100 is a hex buffer/line driver with 3-state outputs
controlled by the output enable inputs (OEn). A HIGH on OEn causes the outputs to
assume a high impedance OFF-state. Inputs include clamp diodes. This enables the use
of current limiting resistors to interface inputs to voltages in excess of VCC.
The 74HC365-Q100; 74HCT365-Q100 is functionally identical to:
• 74HC366-Q100; 74HCT366-Q100, but has non-inverting outputs
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Inverting outputs
Input levels:
For 74HC365-Q100: CMOS level
For 74HC365-Q100: TTL level
Complies with JEDEC standard no. 7A
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74HC365D-Q100
40 C to +125 C
SO16
plastic small outline package; 16 leads; body width 3.9 SOT109-1
mm
74HC365PW-Q100
40 C to +125 C
TSSOP16 plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
40 C to +125 C
SO16
74HC365-Q100
SOT403-1
74HCT365-Q100
74HCT365D-Q100
74HCT365PW-Q100 40 C to +125 C
mm
body width 4.4 mm
SOT403-1
4. Functional diagram
2(
2(
2(
2(
DDD
Fig 1.
Functional diagram
74HC_HCT365_Q100
Product data sheet
Fig 2.
(1
DDD
Logic symbol
All information provided in this document is subject to legal disclaimers.
DDD
Fig 3.
IEC logic symbol
Nexperia B.V. 2017. All rights reserved
2 of 19
Nexperia
EXIIHUOLQHGULYHU
9&&
2(
2(
*1'
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
DDD
Fig 4.
Logic diagram
5. Pinning information
5.1 Pinning
+&4
+&74
2(
9&&
2(
*1'
DDD
Fig 5.
Pin configuration
74HC_HCT365_Q100
Product data sheet
3 of 19
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
OE1
1
output enable input 1 (active LOW)
1A
2
data input 1
1Y
3
data output 1
2A
4
data input 2
2Y
5
data output 2
3A
6
data input 3
3Y
7
data output 3
GND
8
ground (0 V)
4Y
9
data output 4
4A
10
data input 4
5Y
11
data output 5
5A
12
data input 5
6Y
13
data output 6
6A
14
data input 6
OE2
15
output enable input 2 (active LOW)
VCC
16
supply voltage
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
OE1
OE2
nA
nY
L
L
L
L
L
L
H
H
X
H
X
Z
H
X
X
Z
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state.
74HC_HCT365_Q100
Product data sheet
4 of 19
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7
V
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
mA
IO
output current
VO = 0.5 V to (VCC + 0.5 V)
35
mA
ICC
supply current
70
mA
IGND
ground current
70
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
SO16 package
[1]
500
mW
TSSOP16 package
[2]
500
mW
[1]
For SO16 packages: Ptot derates linearly with 8 mW/K above 70 C.
[2]
For TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC365-Q100
Min
Typ
74HCT365-Q100
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise and fall rate
74HC_HCT365_Q100
Product data sheet
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
5 of 19
Nexperia
9. Static characteristics
Table 6.
Static characteristics 74HC365-Q100
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
Tamb = 25 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
V
IO = 6.0 mA; VCC = 4.5 V
3.98
4.32
V
IO = 7.8 mA; VCC = 6.0 V
5.48
5.81
V
V
V
V
0.15
0.26
V
0.16
0.26
V
HIGH-level output voltage VI = VIH or VIL
LOW-level output voltage VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
0.1
A
IOZ
OFF-state output current
VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V
0.5
A
ICC
supply current
VI = VCC or GND; IO = 0 A; VCC = 6.0 V
CI
input capacitance
8.0
A
3.5
pF
VCC = 2.0 V
1.5
V
Tamb = 40 C to +85 C
VIH
VIL
VOH
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
74HC_HCT365_Q100
Product data sheet
5.9
V
3.84
V
5.34
V
6 of 19
Nexperia
Table 6.
Static characteristics 74HC365-Q100 …continued
Symbol Parameter
VOL
Conditions
Min
Typ
Max
Unit
0.1
V
0.1
V
0.1
V
0.33
V
0.33
V
II
VI = VCC or GND; VCC = 6.0 V;
1.0
A
IOZ
5.0
A
ICC
supply current
80
A
Tamb = 40 C to +125 C
VIH
VIL
VOH
VOL
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
0.1
V
0.1
V
0.1
V
0.4
V
0.4
V
A
II
1.0
IOZ
10.0 A
ICC
supply current
160
Min
Typ
Max
Unit
A
Table 7.
Static characteristics 74HCT365-Q100
Symbol Parameter
Conditions
Tamb = 25 C
VIH
HIGH-level input voltage VCC = 4.5 V to 5.5 V
2.0
1.6
V
VIL
1.2
0.8
V
VOH
HIGH-level output
voltage
VI = VIH or VIL; VCC = 4.5 V
74HC_HCT365_Q100
Product data sheet
IO = 20 A
4.4
4.5
V
IO = 6.0 mA
3.98
4.32
V
7 of 19
Nexperia
Table 7.
Static characteristics 74HCT365-Q100 …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VOL
LOW-level output
voltage
IO = 20 A
V
II
VI = VCC or GND; VCC = 5.5 V
IO = 6.0 mA
0.16
0.26
V
0.1
A
IOZ
OFF-state output current VI = VIH or VIL; VO = VCC or GND per input pin; other
inputs at GND or VCC; IO = 0 A; VCC = 5.5 V
0.5
A
ICC
supply current
8.0
A
ICC
additional supply current VI = VCC 2.1 V; other inputs at VCC or GND; IO = 0 A
pins nA
100
360
A
pin OE1
100
360
A
VI = VCC or GND; IO = 0 A; VCC = 5.5 V
pin OE2
CI
input capacitance
90
324
A
3.5
pF
VIH
2.0
V
VIL
0.8
V
VOH
HIGH-level output
voltage
IO = 20 A
4.4
V
IO = 6.0 mA
3.84
V
IO = 20 A
0.1
V
IO = 6.0 mA
0.33
V
1.0
A
5.0
A
VOL
LOW-level output
voltage
II
IOZ
ICC
supply current
ICC
80
A
pins nA
450
A
pin OE1
450
A
pin OE2
405
A
VIH
2.0
V
VIL
0.8
V
VOH
HIGH-level output
voltage
IO = 20 A
4.4
V
IO = 6.0 mA
3.7
V
LOW-level output
voltage
IO = 20 A
0.1
V
IO = 6.0 mA
0.4
V
VOL
II
IOZ
74HC_HCT365_Q100
Product data sheet
1.0
A
10.0
A
8 of 19
Nexperia
Table 7.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
ICC
supply current
160
A
ICC
pins nA
490
A
pin OE1
490
A
pin OE2
441
A
10. Dynamic characteristics
Table 8.
Dynamic characteristics 74HC365-Q100
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Figure 8.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
30
95
ns
VCC = 4.5 V
11
19
ns
VCC = 5 V; CL = 15 pF
9
ns
VCC = 6.0 V
9
16
ns
VCC = 2.0 V
47
150
ns
VCC = 4.5 V
17
30
ns
VCC = 6.0 V
14
26
ns
VCC = 2.0 V
61
150
ns
VCC = 4.5 V
22
30
ns
VCC = 6.0 V
18
26
ns
VCC = 2.0 V
14
60
ns
VCC = 4.5 V
5
12
ns
VCC = 6.0 V
4
10
ns
40
pF
VCC = 2.0 V
120
ns
VCC = 4.5 V
24
ns
ns
VCC = 2.0 V
190
ns
VCC = 4.5 V
38
ns
VCC = 6.0 V
33
ns
Tamb = 25 C
tpd
ten
tdis
tt
CPD
propagation delay
enable time
disable time
transition time
power dissipation
capacitance
nA to nY; see Figure 6
OEn to nY; see Figure 7
[1]
[2]
[3]
[4]
see Figure 6
per buffer; VI = GND to VCC
[5]
[1]
tpd
propagation delay
VCC = 6.0 V
ten
enable time
74HC_HCT365_Q100
Product data sheet
[2]
9 of 19
Nexperia
Table 8.
Dynamic characteristics 74HC365-Q100 …continued
Symbol Parameter
tdis
tt
disable time
transition time
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
190
ns
VCC = 4.5 V
38
ns
VCC = 6.0 V
33
ns
VCC = 2.0 V
75
ns
VCC = 4.5 V
15
ns
VCC = 6.0 V
13
ns
[3]
[4]
see Figure 6
tpd
propagation delay
[1]
VCC = 2.0 V
145
ns
VCC = 4.5 V
29
ns
25
ns
VCC = 6.0 V
ten
enable time
[2]
VCC = 2.0 V
225
ns
VCC = 4.5 V
45
ns
38
ns
VCC = 6.0 V
tdis
disable time
[3]
VCC = 2.0 V
225
ns
VCC = 4.5 V
45
ns
38
ns
VCC = 2.0 V
90
ns
VCC = 4.5 V
18
ns
VCC = 6.0 V
15
ns
VCC = 6.0 V
tt
[1]
transition time
[4]
see Figure 6
tpd is the same as tPHL and tPLH.
[2]
ten is the same as tPZH and tPZL.
[3]
tdis is the same as tPHZ and tPLZ.
[4]
tt is the same as tTHL and tTLH.
[5]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC_HCT365_Q100
Product data sheet
10 of 19
Nexperia
Table 9.
Dynamic characteristics 74HCT365-Q100
Symbol Parameter
Conditions
Min
Typ
Max
Unit
14
25
ns
Tamb = 25 C
tpd
propagation delay
[1]
VCC = 4.5 V
11
ns
ten
enable time
OEn to nY; VCC = 4.5 V; see Figure 7
[2]
18
35
ns
tdis
disable time
[3]
23
35
ns
transition time
VCC = 4.5 V; see Figure 6
[4]
5
12
ns
power dissipation
capacitance
per buffer; VI = GND to (VCC 1.5 V)
[5]
40
pF
nA to nY; VCC = 4.5 V; see Figure 6
[1]
31
ns
[2]
44
ns
tt
CPD
tpd
ten
propagation delay
enable time
tdis
disable time
[3]
44
ns
tt
transition time
[4]
15
ns
[1]
38
ns
tpd
propagation delay
ten
enable time
[2]
53
ns
tdis
disable time
[3]
53
ns
[4]
18
ns
tt
[1]
transition time
[2]
[3]
[4]
[5]
74HC_HCT365_Q100
Product data sheet
11 of 19
Nexperia
11. Waveforms
9,
Q$LQSXW
90
90
*1'
W3+/
W3+/
92+
Q
很抱歉,暂时无法提供与“74HC365D-Q100,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.970261+0.90348
- 10+4.9517710+0.64185
- 25+4.4524325+0.57712
- 100+3.90068100+0.50561
- 250+3.63747250+0.47149
- 500+3.47858500+0.45089
- 1000+3.435751000+0.44534
- 国内价格
- 1+6.66360
- 200+2.58120
- 500+2.49480
- 1000+2.45160
- 国内价格 香港价格
- 2500+2.496542500+0.32360
- 5000+2.429565000+0.31492
- 7500+2.396027500+0.31057
- 12500+2.3588412500+0.30575
- 17500+2.3371217500+0.30294
- 25000+2.3162325000+0.30023
- 国内价格 香港价格
- 461+6.90879461+0.89551
- 512+6.21884512+0.80608
- 1000+5.735121000+0.74338
- 10000+5.1130610000+0.66275
- 100000+4.28394100000+0.55528
- 国内价格 香港价格
- 1+6.048901+0.78410
- 10+4.2163010+0.54650
- 25+3.7731025+0.48910
- 100+3.28200100+0.42540
- 250+3.04240250+0.39440
- 500+2.89870500+0.37580
- 1000+2.778901000+0.36020
- 2500+2.467502500+0.31990
- 5000+2.407605000+0.31210
