74HC366; 74HCT366
Hex buffer/line driver; 3-state; inverting
Rev. 5 — 2 February 2016
Product data sheet
1. General description
The 74HC366; 74HCT366 is a hex inverting buffer/line driver with 3-state outputs
controlled by the output enable inputs (OEn). A HIGH on OEn causes the outputs to
assume a high impedance OFF-state. Inputs include clamp diodes. This enables the use
of current limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Inverting outputs
Input levels:
For 74HC366: CMOS level
For 74HC366: TTL level
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Specified from 40 C to +85 C and from 40 C to +125 C
Multiple package options
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74HC366D
40 C to +125 C
SO16
plastic small outline package; 16 leads; body width 3.9 mm SOT109-1
74HC366PW
40 C to +125 C
TSSOP16
plastic thin shrink small outline package; 16 leads; body
width 4.4 mm
74HCT366D
40 C to +125 C
SO16
74HCT366DB
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads; body width
5.3 mm
SOT338-1
TSSOP16
width 4.4 mm
SOT403-1
74HC366
SOT403-1
74HCT366
74HCT366PW 40 C to +125 C
74HC366; 74HCT366
Nexperia
4. Functional diagram
2(
2(
2(
2(
DDI
Fig 1.
Functional diagram
(1
Fig 2.
DDI
Logic symbol
EXIIHUOLQHGULYHU
DDI
Fig 3.
IEC logic symbol
9&&
2(
2(
*1'
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
EXIIHUOLQHGULYHU
DDI
Fig 4.
Logic diagram
74HC_HCT366
Product data sheet
All information provided in this document is subject to legal disclaimers.
2 of 20
Nexperia B.V. 2017. All rights reserved
74HC366; 74HCT366
Nexperia
5. Pinning information
5.1 Pinning
+&7
2(
9&&
2(
*1'
DDI
Fig 5.
Pin configuration
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
OE1, OE2
1, 15
output enable input (active LOW)
1A, 2A, 3A, 4A, 5A, 6A
2, 4, 6, 10, 12, 14
data input
1Y, 2Y, 3Y, 4Y, 5Y, 6Y
3, 5, 7, 9, 11, 13
data output
GND
8
ground (0 V)
VCC
16
supply voltage
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
OE1
OE2
nA
nY
L
L
L
H
L
L
H
L
X
H
X
Z
H
X
X
Z
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state.
74HC_HCT366
Product data sheet
3 of 20
74HC366; 74HCT366
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
0.5
+7
V
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
mA
IO
output current
VO = 0.5 V to (VCC + 0.5 V)
35
mA
ICC
supply current
70
mA
IGND
ground current
70
mA
Tstg
storage temperature
total power dissipation
Ptot
65
+150
C
SO16 package
[1]
500
mW
SSOP16 package
[2]
500
mW
TSSOP16 package
[2]
500
mW
[1]
For SO16 packages: Ptot derates linearly with 8 mW/K above 70 C.
[2]
For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
8. Recommended operating conditions
Table 5.
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise and fall rate
74HC_HCT366
Product data sheet
Conditions
74HC366
74HCT366
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
VCC
V
VCC
VCC
V
40
+25
+125
40
+25
+125
C
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
4 of 20
74HC366; 74HCT366
Nexperia
9. Static characteristics
Table 6.
Static characteristics 74HC366
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max Unit
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
V
Tamb = 25 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
VCC = 2.0 V
0.8
0.5
VCC = 4.5 V
2.1
1.35 V
VCC = 6.0 V
2.8
1.8
IO = 20 A; VCC = 2.0 V
1.9
2.0
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
V
IO = 6.0 mA; VCC = 4.5 V
3.98
4.32
V
IO = 7.8 mA; VCC = 6.0 V
5.48
5.81
V
V
V
0.1
V
HIGH-level output voltage VI = VIH or VIL
V
LOW-level output voltage VI = VIH or VIL
II
input leakage current
0.15
0.26 V
0.16
0.26 V
VI = VCC or GND; VCC = 6.0 V
0.1 A
IOZ
OFF-state output current
VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V
0.5 A
ICC
supply current
VI = VCC or GND; IO = 0 A; VCC = 6.0 V
8.0
A
CI
input capacitance
3.5
pF
Tamb = 40 C to +85 C
VIH
VIL
VOH
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35 V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.84
V
5.34
V
74HC_HCT366
Product data sheet
5 of 20
74HC366; 74HCT366
Nexperia
Table 6.
Static characteristics 74HC366 …continued
Symbol Parameter
VOL
Conditions
Min
Typ
Max Unit
0.1
V
0.1
V
0.1
V
0.33 V
0.33 V
II
VI = VCC or GND; VCC = 6.0 V;
1.0 A
IOZ
5.0 A
ICC
supply current
80
A
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
V
Tamb = 40 C to +125 C
VIH
VIL
VOH
VOL
VCC = 2.0 V
0.5
VCC = 4.5 V
1.35 V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
0.1
V
0.1
V
0.1
V
0.4
V
0.4
V
1.0 A
10.0 A
II
IOZ
ICC
supply current
74HC_HCT366
Product data sheet
160
A
6 of 20
74HC366; 74HCT366
Nexperia
Table 7.
Static characteristics 74HCT366
Symbol Parameter
Conditions
Min
Typ
Max
Unit
2.0
1.6
V
1.2
0.8
V
IO = 20 A
4.4
4.5
V
IO = 6.0 mA
3.98
4.32
V
Tamb = 25 C
VIH
HIGH-level input voltage VCC = 4.5 V to 5.5 V
VIL
VOH
HIGH-level output
voltage
VI = VIH or VIL; VCC = 4.5 V
VOL
LOW-level output
voltage
IO = 20 A
V
IO = 6.0 mA
0.16
0.26
V
0.1
A
II
VI = VCC or GND; VCC = 5.5 V
IOZ
OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V
0.5
A
ICC
supply current
8.0
A
ICC
additional supply current VI = VCC 2.1 V; other inputs at VCC or GND; IO = 0 A
pins nA
100
360
A
pin OE1
100
360
A
VI = VCC or GND; IO = 0 A; VCC = 5.5 V
90
320
A
3.5
pF
2.0
V
0.8
V
IO = 20 A
4.4
V
IO = 6.0 mA
3.84
V
IO = 20 A
0.1
V
IO = 6.0 mA
0.33
V
1.0
A
5.0
A
80
A
pins nA
450
A
pin OE1
450
A
pin OE2
400
A
pin OE2
CI
input capacitance
VIH
VIL
VOH
HIGH-level output
voltage
VOL
LOW-level output
voltage
II
IOZ
ICC
supply current
ICC
74HC_HCT366
Product data sheet
7 of 20
74HC366; 74HCT366
Nexperia
Table 7.
Static characteristics 74HCT366 …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
2.0
V
0.8
V
IO = 20 A
4.4
V
IO = 6.0 mA
3.7
V
IO = 20 A
0.1
V
IO = 6.0 mA
0.4
V
A
VIH
VIL
VOH
HIGH-level output
voltage
LOW-level output
voltage
VOL
II
1.0
IOZ
10.0 A
ICC
supply current
ICC
160
A
pins nA
490
A
pin OE1
490
A
pin OE2
441
A
10. Dynamic characteristics
Table 8.
Dynamic characteristics 74HC366
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Figure 8.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
33
100
ns
VCC = 4.5 V
12
ns
Tamb = 25 C
tpd
ten
tdis
tt
propagation delay
enable time
disable time
transition time
74HC_HCT366
Product data sheet
nA to nY; see Figure 6
[1]
VCC = 5 V; CL = 15 pF
10
ns
VCC = 6.0 V
10
17
ns
VCC = 2.0 V
44
150
ns
VCC = 4.5 V
16
30
ns
VCC = 6.0 V
13
26
ns
VCC = 2.0 V
55
150
ns
VCC = 4.5 V
ns
VCC = 6.0 V
16
26
ns
VCC = 2.0 V
14
60
ns
VCC = 4.5 V
5
12
ns
VCC = 6.0 V
4
10
ns
OEn to nY; see Figure 7
[2]
[3]
[4]
see Figure 6
8 of 20
74HC366; 74HCT366
Nexperia
Table 8.
Dynamic characteristics 74HC366 …continued
Symbol Parameter
CPD
power dissipation
capacitance
Conditions
Min
Typ
Max
30
pF
VCC = 2.0 V
125
ns
VCC = 4.5 V
25
ns
VCC = 6.0 V
21
ns
VCC = 2.0 V
190
ns
VCC = 4.5 V
38
ns
VCC = 6.0 V
33
ns
VCC = 2.0 V
190
ns
VCC = 4.5 V
38
ns
VCC = 6.0 V
33
ns
VCC = 2.0 V
75
ns
VCC = 4.5 V
15
ns
VCC = 6.0 V
13
ns
per buffer; VI = GND to VCC
[5]
[1]
Unit
tpd
ten
tdis
tt
propagation delay
enable time
disable time
transition time
[2]
[3]
[4]
see Figure 6
tpd
propagation delay
[1]
VCC = 2.0 V
150
ns
VCC = 4.5 V
30
ns
26
ns
VCC = 6.0 V
ten
enable time
[2]
VCC = 2.0 V
225
ns
VCC = 4.5 V
45
ns
38
ns
VCC = 6.0 V
tdis
disable time
74HC_HCT366
Product data sheet
[3]
VCC = 2.0 V
225
ns
VCC = 4.5 V
45
ns
VCC = 6.0 V
38
ns
9 of 20
74HC366; 74HCT366
Nexperia
Table 8.
Symbol Parameter
tt
[1]
transition time
Conditions
Min
Typ
Max
Unit
[4]
see Figure 6
VCC = 2.0 V
90
ns
VCC = 4.5 V
18
ns
VCC = 6.0 V
15
ns
tpd is the same as tPHL and tPLH.
[2]
ten is the same as tPZH and tPZL.
[3]
tdis is the same as tPHZ and tPLZ.
[4]
tt is the same as tTHL and tTLH.
[5]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
Table 9.
Dynamic characteristics 74HCT366
Symbol Parameter
Conditions
Min
Typ
Max
Unit
13
24
ns
Tamb = 25 C
tpd
propagation delay
[1]
VCC = 4.5 V
11
ns
ten
enable time
OEn to nY; VCC = 4.5 V; see Figure 7
[2]
16
35
ns
tdis
disable time
[3]
ns
transition time
VCC = 4.5 V; see Figure 6
[4]
5
12
ns
power dissipation
capacitance
per buffer; VI = GND to (VCC 1.5 V)
[5]
30
pF
nA to nY; VCC = 4.5 V; see Figure 6
[1]
30
ns
[2]
44
ns
44
ns
15
ns
tt
CPD
tpd
ten
propagation delay
enable time
tdis
disable time
[3]
tt
transition time
[4]
74HC_HCT366
Product data sheet
10 of 20
74HC366; 74HCT366
Nexperia
Table 9.
Dynamic characteristics 74HCT366 …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
tpd
propagation delay
[1]
36
ns
ten
enable time
[2]
53
ns
[3]
53
ns
[4]
18
ns
disable time
tdis
transition time
tt
[1]
[2]
[3]
[4]
[5]
11. Waveforms
9,
Q$LQSXW
90
90
*1'
W 3+/
W 3/+
92+
Q
很抱歉,暂时无法提供与“74HCT366D,653”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+11.80440
- 10+10.48680
- 30+9.76320
- 100+8.94240
- 500+8.57520
- 1000+8.41320
- 国内价格 香港价格
- 1+7.312881+0.95033
- 10+5.2011010+0.67590
- 25+4.6793925+0.60810
- 100+4.10620100+0.53361
- 250+3.83297250+0.49811
- 500+3.66864500+0.47675
- 1000+3.641671000+0.47325
- 国内价格
- 1+11.28328
- 10+8.11510
- 25+7.39881
- 100+6.33996
- 250+5.66320
- 500+5.12898
- 1000+4.94452
