74HC366PW-Q100,118
74HC366PW-Q100,118
    NEXPERIA(安世)
    TSSOP-16
    类型:缓冲器,反相 电源电压:2V~6V 输出类型:三态 低电平输出电流(IOL):7.8mA 高电平输出电流(IOH):7.8mA
74HC366PW-Q100,118 数据手册
74HC366-Q100; 74HCT366-Q100 Hex buffer/line driver; 3-state; inverting Rev. 1 — 7 August 2012 Product data sheet 1. General description The 74HC366-Q100; 74HCT366-Q100 is a hex inverter/line driver with 3-state outputs controlled by the output enable inputs (OEn). A HIGH on OEn causes the outputs to assume a high impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. The 74HC366-Q100; 74HCT366-Q100 is functionally identical to: • 74HC365-Q100; 74HCT365-Q100, but has inverted outputs This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Inverting outputs  Input levels:  For 74HC366-Q100: CMOS level  For 74HC366-Q100: TTL level  Complies with JEDEC standard no. 7A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC366D-Q100 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC366PW-Q100 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HCT366D-Q100 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HCT366PW-Q100 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HC366-Q100 74HCT366-Q100 4. Functional diagram 2 4 6 10 12 1A 1Y 2A 2Y 3A 3Y 4A 4Y 5A 5Y 6A 14 6Y 3 1Y 2A 2Y 3A 3Y 4A 4Y 2 3 5A 5Y 4 5 6 7 6A 6Y 10 9 12 11 14 13 7 1 15 11 13 OE2 OE1 OE2 001aaf583 Functional diagram 74HC_HCT366_Q100 Product data sheet & EN 9 OE1 1 15 Fig 1. 1A 5 Fig 2. 001aaf581 Logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 001aaf582 Fig 3. IEC logic symbol © Nexperia B.V. 2017. All rights reserved 2 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting buffer/line driver 1 VCC 1A 1Y OE1 OE2 GND 2A 3A 4A 5A 6A buffer/line driver 2 2Y buffer/line driver 3 3Y buffer/line driver 4 4Y buffer/line driver 5 5Y buffer/line driver 6 6Y 001aaf584 Fig 4. Logic diagram 5. Pinning information 5.1 Pinning +&4 +&74 2(   9&& $   2( <   $ $   < <   $ $   < <   $ *1'   < DDD Fig 5. Pin configuration 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 3 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting 5.2 Pin description Table 2. Pin description Symbol Pin Description OE1 1 output enable input 1 (active LOW) 1A 2 data input 1 1Y 3 data output 1 2A 4 data input 2 2Y 5 data output 2 3A 6 data input 3 3Y 7 data output 3 GND 8 ground (0 V) 4Y 9 data output 4 4A 10 data input 4 5Y 11 data output 5 5A 12 data input 5 6Y 13 data output 6 6A 14 data input 6 OE2 15 output enable input 2 (active LOW) VCC 16 supply voltage 6. Functional description Table 3. Function table[1] Control Input Output OE1 OE2 nA nY L L L H L L H L X H X Z H X X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 4 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current VO = 0.5 V to (VCC + 0.5 V) - 35 mA ICC supply current - 70 mA IGND ground current - 70 mA Tstg storage temperature 65 +150 C Ptot total power dissipation SO16 package [1] - 500 mW TSSOP16 package [2] - 500 mW [1] For SO16 packages: Ptot derates linearly with 8 mW/K above 70 C. [2] For TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC366-Q100 Min Typ 74HCT366-Q100 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 5 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting 9. Static characteristics Table 6. Static characteristics 74HC366-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit Tamb = 25 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V - - - IO = 20 A; VCC = 2.0 V 1.9 2.0 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - V IO = 20 A; VCC = 2.0 V - 0 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 V HIGH-level output voltage VI = VIH or VIL LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 0.5 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V CI input capacitance - - 8.0 A - 3.5 - pF VCC = 2.0 V 1.5 - - V Tamb = 40 C to +85 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V HIGH-level output voltage VI = VIH or VIL 74HC_HCT366_Q100 Product data sheet IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 6.0 mA; VCC = 4.5 V 3.84 - - V IO = 7.8 mA; VCC = 6.0 V 5.34 - - V All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 6 of 19 Nexperia 74HC366-Q100; 74HCT366-Q100 Hex buffer/line driver; 3-state; inverting Table 6. Static characteristics 74HC366-Q100 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VOL Conditions Min Typ Max Unit IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 6.0 mA; VCC = 4.5 V - - 0.33 V IO = 7.8 mA; VCC = 6.0 V - - 0.33 V LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V; - - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 5.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 80 A Tamb = 40 C to +125 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 6.0 mA; VCC = 4.5 V 3.7 - - V IO = 7.8 mA; VCC = 6.0 V 5.2 - - V IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 6.0 mA; VCC = 4.5 V - - 0.4 V IO = 7.8 mA; VCC = 6.0 V - - 0.4 V A HIGH-level output voltage VI = VIH or VIL LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 10.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 160 Min Typ Max Unit A Table 7. Static characteristics 74HCT366-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = 25 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V 74HC_HCT366_Q100 Product data sheet IO = 20 A 4.4 4.5 - V IO = 6.0 mA 3.98 4.32 - V All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 7 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting Table 7. Static characteristics 74HCT366-Q100 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A - 0 0.1 V II input leakage current VI = VCC or GND; VCC = 5.5 V IO = 6.0 mA - 0.16 0.26 V - - 0.1 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND per input pin; other inputs at GND or VCC; IO = 0 A; VCC = 5.5 V - - 0.5 A ICC supply current - - 8.0 A ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; IO = 0 A pins nA - 100 360 A pin OE1 - 100 360 A VI = VCC or GND; IO = 0 A; VCC = 5.5 V pin OE2 CI input capacitance - 90 320 A - 3.5 - pF Tamb = 40 C to +85 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 - - V IO = 6.0 mA 3.84 - - V IO = 20 A - - 0.1 V IO = 6.0 mA - - 0.33 V - - 1.0 A 5.0 A VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND per input pin; other inputs at GND or VCC; IO = 0 A; VCC = 5.5 V ICC supply current ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; IO = 0 A VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 80 A pins nA - - 450 A pin OE1 - - 450 A pin OE2 - - 400 A Tamb = 40 C to +125 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 - - V IO = 6.0 mA 3.7 - - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A - - 0.1 V IO = 6.0 mA - - 0.4 V VOL II input leakage current IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND per input pin; other inputs at GND or VCC; IO = 0 A; VCC = 5.5 V 74HC_HCT366_Q100 Product data sheet VI = VCC or GND; VCC = 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 - - 1.0 A - - 10.0 A © Nexperia B.V. 2017. All rights reserved 8 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting Table 7. Static characteristics 74HCT366-Q100 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 160 A ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; IO = 0 A pins nA - - 490 A pin OE1 - - 490 A pin OE2 - - 441 A 10. Dynamic characteristics Table 8. Dynamic characteristics 74HC366-Q100 Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Figure 8. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V - 33 100 ns VCC = 4.5 V - 12 20 ns VCC = 5 V; CL = 15 pF - 10 - ns VCC = 6.0 V - 10 17 ns VCC = 2.0 V - 44 150 ns VCC = 4.5 V - 16 30 ns VCC = 6.0 V - 13 26 ns VCC = 2.0 V - 55 150 ns VCC = 4.5 V - 20 30 ns VCC = 6.0 V - 16 26 ns VCC = 2.0 V - 14 60 ns VCC = 4.5 V - 5 12 ns VCC = 6.0 V - 4 10 ns - 30 - pF VCC = 2.0 V - - 125 ns VCC = 4.5 V - - 25 ns - - 21 ns VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns VCC = 6.0 V - - 33 ns Tamb = 25 C tpd ten tdis tt CPD propagation delay enable time disable time transition time power dissipation capacitance nA to nY; see Figure 6 OEn to nY; see Figure 7 OEn to nY; see Figure 7 [1] [2] [3] [4] see Figure 6 per buffer; VI = GND to VCC [5] nA to nY; see Figure 6 [1] Tamb = 40 C to +85 C tpd propagation delay VCC = 6.0 V ten enable time 74HC_HCT366_Q100 Product data sheet OEn to nY; see Figure 7 All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 [2] © Nexperia B.V. 2017. All rights reserved 9 of 19 Nexperia 74HC366-Q100; 74HCT366-Q100 Hex buffer/line driver; 3-state; inverting Table 8. Dynamic characteristics 74HC366-Q100 …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Figure 8. Symbol Parameter tdis tt disable time transition time Conditions Min Typ Max Unit VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns VCC = 6.0 V - - 33 ns VCC = 2.0 V - - 75 ns VCC = 4.5 V - - 15 ns VCC = 6.0 V - - 13 ns OEn to nY; see Figure 7 [3] [4] see Figure 6 Tamb = 40 C to +125 C tpd propagation delay nA to nY; see Figure 6 [1] VCC = 2.0 V - - 150 ns VCC = 4.5 V - - 30 ns - - 26 ns VCC = 6.0 V ten enable time OEn to nY; see Figure 7 [2] VCC = 2.0 V - - 225 ns VCC = 4.5 V - - 45 ns - - 38 ns VCC = 6.0 V tdis disable time OEn to nY; see Figure 7 [3] VCC = 2.0 V - - 225 ns VCC = 4.5 V - - 45 ns - - 38 ns VCC = 2.0 V - - 90 ns VCC = 4.5 V - - 18 ns VCC = 6.0 V - - 15 ns VCC = 6.0 V tt [1] transition time [4] see Figure 6 tpd is the same as tPHL and tPLH. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPHZ and tPLZ. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 10 of 19 Nexperia 74HC366-Q100; 74HCT366-Q100 Hex buffer/line driver; 3-state; inverting Table 9. Dynamic characteristics 74HCT366-Q100 Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Figure 8. Symbol Parameter Conditions Min Typ Max Unit - 13 24 ns Tamb = 25 C tpd propagation delay nA to nY; see Figure 6 [1] VCC = 4.5 V VCC = 5 V; CL = 15 pF - 11 - ns ten enable time OEn to nY; VCC = 4.5 V; see Figure 7 [2] - 16 35 ns tdis disable time OEn to nY; VCC = 4.5 V; see Figure 7 [3] - 20 35 ns transition time VCC = 4.5 V; see Figure 6 [4] - 5 12 ns power dissipation capacitance per buffer; VI = GND to (VCC  1.5 V) [5] - 30 - pF nA to nY; VCC = 4.5 V; see Figure 6 [1] - - 30 ns OEn to nY; VCC = 4.5 V; see Figure 7 [2] - - 44 ns tt CPD Tamb = 40 C to +85 C tpd ten propagation delay enable time tdis disable time OEn to nY; VCC = 4.5 V; see Figure 7 [3] - - 44 ns tt transition time VCC = 4.5 V; see Figure 6 [4] - - 15 ns nA to nY; VCC = 4.5 V; see Figure 6 [1] - - 36 ns Tamb = 40 C to +125 C tpd propagation delay ten enable time OEn to nY; VCC = 4.5 V; see Figure 7 [2] - - 53 ns tdis disable time OEn to nY; VCC = 4.5 V; see Figure 7 [3] - - 53 ns VCC = 4.5 V; see Figure 6 [4] - - 18 ns tt [1] transition time tpd is the same as tPHL and tPLH. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPHZ and tPLZ. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 11 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting 11. Waveforms VI nA input VM VM GND t PHL t PLH VOH nY output VM VM VOL t THL t TLH 001aaf585 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Propagation delay data input (nA) to output (nY) and output transition time VI VM VM OEn input GND tPLZ tPZL VCC nY output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY nY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled 001aaf586 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. Table 10. 3-state enable and disable times Measurement points Type Input Output VM VM VX VY 74HC366-Q100 0.5VCC 0.5VCC 0.1  VCC 0.9  VCC 74HCT366-Q100 1.3 V 1.3 V 0.1  VCC 0.9  VCC 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 12 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 11. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistor S1 = Test selection switch Fig 8. Table 11. Load circuitry for measuring switching times Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC366-Q100 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT366-Q100 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 13 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 14 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 10. Package outline SOT403-1 (TSSOP16) 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 15 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting 13. Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MM Machine Model MIL Military 14. Revision history Table 13. Revision history Document ID Release date 74HC_HCT366_Q100 v.1 20120807 74HC_HCT366_Q100 Product data sheet Data sheet status Change notice Supersedes Product data sheet - - All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 16 of 19 74HC366-Q100; 74HCT366-Q100 Nexperia Hex buffer/line driver; 3-state; inverting 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT366_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 17 of 19 Nexperia 74HC366-Q100; 74HCT366-Q100 Hex buffer/line driver; 3-state; inverting No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT366_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 August 2012 © Nexperia B.V. 2017. All rights reserved 18 of 19 Nexperia 74HC366-Q100; 74HCT366-Q100 Hex buffer/line driver; 3-state; inverting 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 07 August 2012 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC366PW-Q100,118 74HCT366D-Q100,118 74HC366D-Q100,118 74HCT366PW-Q100,11
74HC366PW-Q100,118 价格&库存
很抱歉,暂时无法提供与“74HC366PW-Q100,118”相匹配的价格&库存,您可以联系我们找货
74HC366PW-Q100,118
    • 1+4.87630
    • 10+3.95670
    • 30+3.49690
    • 100+3.03710
    • 500+2.75880
    • 1000+2.61360
    库存:2495
    74HC366PW-Q100,118
    • 1+5.296281+0.68496
    • 10+3.7437010+0.48417
    • 25+3.3520325+0.43351
    • 100+2.92278100+0.37800
    • 250+2.71832250+0.35156
    • 500+2.59522500+0.33564
    • 1000+2.535871000+0.32796
    库存:1154
