74HCT367PW,112
74HCT367PW,112
    NEXPERIA(安世)
    TSSOP-16
    十六进制缓冲器/线路驱动器;3 态
74HCT367PW,112 数据手册
74HC367; 74HCT367 Hex buffer/line driver; 3-state Rev. 3 — 17 October 2016 Product data sheet 1. General description The 74HC367; 74HCT367 is a hex buffer/line driver with 3-state outputs controlled by the output enable inputs (nOE). A HIGH on nOE causes the outputs to assume a high impedance OFF-state. Inputs include clamp diodes. It enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Input levels:  For 74HC367: CMOS level  For 74HCT367: TTL level  3-state outputs  Complies with JEDEC standard no. 7 A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC367D Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm 74HCT367D 74HC367DB 74HCT367DB 74HC367PW 74HCT367PW SOT338-1 SOT403-1 74HC367; 74HCT367 Nexperia Hex buffer/line driver; 3-state 4. Functional diagram       $ < $ < $ < $ <      2( $ < $ <             (1 (1  2(     DDD DDD Fig 1. Logic symbol 74HC_HCT367 Product data sheet Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 October 2016 © Nexperia B.V. 2017. All rights reserved 2 of 18 74HC367; 74HCT367 Nexperia Hex buffer/line driver; 3-state RQHEXIIHUOLQHGULYHU $ 9&& < 2( *1' $ < $ < $ < $ < 2( $ < DDD Fig 3. Logic diagram 74HC_HCT367 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 October 2016 © Nexperia B.V. 2017. All rights reserved 3 of 18 74HC367; 74HCT367 Nexperia Hex buffer/line driver; 3-state 5. Pinning information 5.1 Pinning +& +&7 2(   9&& $   2( <   $ $   < <   $ $ < *1'  +& +&7 2(   9&& $   2( <   $ $   < <   $ $   < <   $ *1'   <   $   <  DDD Fig 4. < DDD Pin configuration SO16 Fig 5. Pin configuration (T)SSOP16 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 15 output enable input (active LOW) 1A, 2A, 3A, 4A, 5A, 6A 2, 4, 6, 10, 12, 14 data input 1Y, 2Y, 3Y, 4Y, 5Y, 6Y 3, 5, 7, 9, 11, 13 bus output GND 8 ground (0 V) VCC 16 supply voltage 6. Functional description Table 3. Function table[1] Input Output nOE nA nY L L L L H H H X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 74HC_HCT367 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 October 2016 © Nexperia B.V. 2017. All rights reserved 4 of 18 74HC367; 74HCT367 Nexperia Hex buffer/line driver; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current 0.5 V < VO < VCC + 0.5 V - 35 mA ICC supply current - 70 mA IGND ground current 70 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 500 mW [1] Conditions SO16, SSOP16 and TSSOP16 packages [1] Min Max 0.5 +7 Unit V For SO16 packages: Ptot derates linearly with 8 mW/K above 70 C. For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC367 74HCT367 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V input voltage 0 - VCC 0 - VCC V output voltage 0 - VCC 0 - VCC V VCC supply voltage VI VO Tamb ambient temperature t/V input transition rise and fall rate 74HC_HCT367 Product data sheet 40 +25 +125 40 +25 +125 VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 October 2016 © C Nexperia B.V. 2017. All rights reserved 5 of 18 74HC367; 74HCT367 Nexperia Hex buffer/line driver; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V 74HC367 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V LOW-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 6.0 V; VO = VCC or GND - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A CI input capacitance - 3.5 - - - - - pF 74HC_HCT367 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 October 2016 © Nexperia B.V. 2017. All rights reserved 6 of 18 74HC367; 74HCT367 Nexperia Hex buffer/line driver; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max 74HCT367 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = 6 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 5.5 V; VO = VCC or GND - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A - - 8.0 - 80 - 160 A ICC additional per input pin; supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A 1OE, nA inputs - 100 360 - 450 - 490 A 2OE input - 90 324 - 405 - 441 A - 3.5 - - - - - pF CI input capacitance 74HC_HCT367 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 October 2016 © Nexperia B.V. 2017. All rights reserved 7 of 18 74HC367; 74HCT367 Nexperia Hex buffer/line driver; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 8. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) VCC = 2.0 V - 28 95 120 145 ns VCC = 4.5 V - 10 19 24 29 ns VCC = 5.0 V; CL = 15 pF - 8 - - - ns - 8 16 20 25 ns VCC = 2.0 V - 44 150 190 225 ns VCC = 4.5 V - 16 30 38 45 ns - 13 26 33 38 ns VCC = 2.0 V - 55 150 190 225 ns VCC = 4.5 V - 20 30 38 45 ns - 16 26 33 38 ns VCC = 2.0 V - 14 60 75 90 ns VCC = 4.5 V - 5 12 15 18 ns - 4 10 13 15 ns - 30 - - - pF - 14 25 31 38 ns 74HC367 tpd propagation delay nA to nY; see Figure 6 [1] VCC = 6.0 V ten enable time nOE to nY; see Figure 7 [2] VCC = 6.0 V tdis disable time nOE to nY; see Figure 7 [3] VCC = 6.0 V tt transition time [4] see Figure 6 VCC = 6.0 V CPD power dissipation per buffer; VI = GND to VCC capacitance [5] 74HCT367 tpd propagation delay nA to nY; see Figure 6 [1] VCC = 4.5 V - 11 - - - ns ten enable time nOE to nY; VCC = 4.5 V; see Figure 7 VCC = 5.0 V; CL = 15 pF [2] - 16 35 44 53 ns tdis disable time nOE to nY; VCC = 4.5 V; see Figure 7 [3] - 21 35 44 53 ns VCC = 4.5 V; see Figure 6 [4] - 5 12 15 18 ns tt transition time 74HC_HCT367 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 October 2016 © Nexperia B.V. 2017. All rights reserved 8 of 18 74HC367; 74HCT367 Nexperia Hex buffer/line driver; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 8. Symbol Parameter power dissipation per buffer; VI = GND to VCC  1.5 V capacitance CPD [1] 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) - 32 - - - [5] pF tpd is the same as tPHL and tPLH. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPHZ and tPLZ. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 11. Waveforms 9, Q$LQSXW 90 90 *1' W3/+ W3+/ 92+ Q
74HCT367PW,112
1. 物料型号:74HC/HCT367 2. 器件简介:74HC/HCT367是一款双D触发器,具有独立的时钟输入和使能端,用于同步或异步操作。 3. 引脚分配: - 1: Q1(输出) - 2: Q1' - 3: /Q1(输出) - 4: D1(数据输入) - 5: CLK1(时钟输入) - 6: /1G(使能端) - 7: Q2(输出) - 8: Q2' - 9: /Q2(输出) - 10: D2(数据输入) - 11: CLK2(时钟输入) - 12: /2G(使能端) - 13: GND(地) - 14: VCC(电源) 4. 参数特性: - 电源电压范围:2V至6V - 工作温度范围:-40°C至+85°C - 触发器类型:D触发器 - 使能端:有 5. 功能详解:74HC/HCT367的每个D触发器都可以独立工作,具有同步复位和置位功能,支持边沿触发和电平触发。 6. 应用信息:适用于需要数据同步、存储和时序控制的数字电路,如计数器、寄存器、状态机等。 7. 封装信息:SO14和DIP14两种封装形式。
74HCT367PW,112 价格&库存
很抱歉,暂时无法提供与“74HCT367PW,112”相匹配的价格&库存,您可以联系我们找货
