74HCT368DB,118
74HCT368DB,118
    NEXPERIA(安世)
    SSOP16_208MIL
    IC BUFFER INVERT 5.5V 16SSOP
74HCT368DB,118 数据手册
74HC368; 74HCT368 Hex buffer/line driver; 3-state; inverting Rev. 3 — 9 August 2016 Product data sheet 1. General description The 74HC368; 74HCT368 is a hex inverting buffer/line driver with 3-state outputs controlled by the output enable inputs (nOE). A HIGH on nOE causes the outputs to assume a high impedance OFF-state. Inputs include clamp diodes enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Input levels:  For 74HC368: CMOS level  For 74HCT368: TTL level  Inverting 3-state outputs  Complies with JEDEC standard no. 7 A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC368D Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm 74HCT368D 74HC368DB 74HCT368DB 74HCT368PW SOT338-1 SOT403-1 74HC368; 74HCT368 Nexperia Hex buffer/line driver; 3-state; inverting 4. Functional diagram       $ < $ < $ < $ <    < $ <          2( $     (1  (1  2(     DDD Fig 1. Logic symbol DDD Fig 2. IEC logic symbol 9&& $ < 2( *1' $ < $ < $ < $ < 2( $ < DDD Fig 3. Logic diagram 74HC_HCT368 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 August 2016 © Nexperia B.V. 2017. All rights reserved 2 of 16 74HC368; 74HCT368 Nexperia Hex buffer/line driver; 3-state; inverting 5. Pinning information 5.1 Pinning +& +&7 2(   9&& $   2( <   $ $   < <   $ $   < <   $ *1'   +& +&7 < 2(  $   9&&  2( <   $ $   < <   $ $   < <   $ *1'   DDD DDD Fig 4. < Pin configuration SO16 Fig 5. Pin configuration (T)SSOP16 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 15 output enable input (active LOW) 1A, 2A, 3A, 4A, 5A, 6A 2, 4, 6, 10, 12, 14 data input 1Y, 2Y, 3Y, 4Y, 5Y, 6Y 3, 5, 7, 9, 11, 13 bus output GND 8 ground (0 V) VCC 16 supply voltage 6. Functional description Table 3. Function table[1] Input Output nOE nA nY L L H L H L H X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 74HC_HCT368 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 August 2016 © Nexperia B.V. 2017. All rights reserved 3 of 16 74HC368; 74HCT368 Nexperia Hex buffer/line driver; 3-state; inverting 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current 0.5 V < VO < VCC + 0.5 V - 35 mA ICC supply current - 70 mA IGND ground current 70 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 500 mW [1] Conditions SO16, SSOP16 and TSSOP16 packages [1] Min Max 0.5 +7 Unit V For SO16 packages: Ptot derates linearly with 8 mW/K above 70 C. For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC368 74HCT368 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V input voltage 0 - VCC 0 - VCC V output voltage 0 - VCC 0 - VCC V VCC supply voltage VI VO Tamb ambient temperature t/V input transition rise and fall rate 74HC_HCT368 Product data sheet 40 +25 +125 40 +25 +125 VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 August 2016 © C Nexperia B.V. 2017. All rights reserved 4 of 16 74HC368; 74HCT368 Nexperia Hex buffer/line driver; 3-state; inverting 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V 74HC368 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V LOW-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 6.0 V; VO = VCC or GND - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A CI input capacitance - 3.5 - - - - - pF 74HC_HCT368 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 August 2016 © Nexperia B.V. 2017. All rights reserved 5 of 16 74HC368; 74HCT368 Nexperia Hex buffer/line driver; 3-state; inverting Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max 74HCT368 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = 6 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 5.5 V; VO = VCC or GND - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A - - 8.0 - 80 - 160 A ICC additional per input pin; supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A 1OE, nA inputs - 100 360 - 450 - 490 A 2OE inputs - 90 324 - 405 - 441 A - 3.5 - - - - - pF CI input capacitance 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; for load circuit, see Figure 8. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) 74HC368 tpd [1] propagation delay nA to nY; see Figure 6 74HC_HCT368 Product data sheet VCC = 2.0 V - 30 95 120 145 ns VCC = 4.5 V - 11 19 24 29 ns VCC = 5.0 V; CL = 15 pF - 9 - - - ns VCC = 6.0 V - 9 16 20 25 ns All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 August 2016 © Nexperia B.V. 2017. All rights reserved 6 of 16 74HC368; 74HCT368 Nexperia Hex buffer/line driver; 3-state; inverting Table 7. Dynamic characteristics …continued GND = 0 V; for load circuit, see Figure 8. Symbol Parameter ten enable time 25 C Conditions Min Typ Max Max (85 C) Max (125 C) VCC = 2.0 V - 41 150 190 225 ns VCC = 4.5 V - 15 30 38 45 ns - 12 26 33 38 ns VCC = 2.0 V - 55 150 190 225 ns VCC = 4.5 V - 20 30 38 45 ns - 16 26 33 38 ns VCC = 2.0 V - 14 60 75 90 ns VCC = 4.5 V - 5 12 15 18 ns - 4 10 13 15 ns - 30 - - - pF - 13 24 30 36 ns nOE to nY; see Figure 7 [2] VCC = 6.0 V disable time tdis nOE to nY; see Figure 7 [3] VCC = 6.0 V transition time tt [4] see Figure 6 VCC = 6.0 V power dissipation capacitance CPD 40 C to +125 C Unit per buffer; VI = GND to VCC [5] 74HCT368 [1] propagation delay nA to nY; tpd see Figure 6 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF - 11 - - - ns - 17 35 44 53 ns 20 35 44 53 ns ten enable time nOE to nY; VCC = 4.5 V; see Figure 7 [2] tdis disable time nOE to nY; VCC = 4.5 V; see Figure 7 [3] - tt transition time VCC = 4.5 V; see Figure 6 [4] - 5 12 15 18 ns CPD power dissipation capacitance per buffer; VI = GND to VCC  1.5 V [5] - 30 - - - pF [1] tpd is the same as tPHL and tPLH. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPHZ and tPLZ. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 74HC_HCT368 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 August 2016 © Nexperia B.V. 2017. All rights reserved 7 of 16 74HC368; 74HCT368 Nexperia Hex buffer/line driver; 3-state; inverting 11. Waveforms 9, 90 90 Q$LQSXW *1' W3+/ 92+ W3/+  90 Q
74HCT368DB,118
物料型号:74HC/HCT368 器件简介:74HC/HCT368 是 Nexperia 公司生产的 8 位串行输入、并行输出移位寄存器。
引脚分配:该器件有 16 个引脚,包括数据输入、时钟输入、存储寄存器时钟输入、输出使能、串行数据输入、并行数据输入/输出、清除输入、电源和地。
参数特性:工作电压范围为 2V 至 6V,工作温度范围为 -40°C 至 85°C,封装类型包括 SOIC、TSSOP、DIP 等。
功能详解:74HC/HCT368 支持串行数据输入,可实现数据的串行移位和并行输出,具有清除功能,可清除所有存储寄存器。
应用信息:广泛应用于数据缓冲、信号分配、数据传输等场景。
封装信息:提供 SOIC、TSSOP、DIP 等多种封装形式,以适应不同的应用需求。
74HCT368DB,118 价格&库存
很抱歉,暂时无法提供与“74HCT368DB,118”相匹配的价格&库存,您可以联系我们找货
