74HC541PW,112
74HC541PW,112
    NEXPERIA(安世)
    TSSOP20_6.5X4.4MM
    接口(驱动器/接收器/收发器) IC BUFFER NON-INVERT 6V 20TSSOP
74HC541PW,112 数据手册
74HC541; 74HCT541 Octal buffer/line driver; 3-state Rev. 4 — 3 March 2016 Product data sheet 1. General description The 74HC541; 74HCT541 is an octal non-inverting buffer/line driver with 3-state outputs. The device features two output enables (OE1 and OE2). A HIGH on OEn causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Non-Inverting outputs  Complies with JEDEC standard no. 7A  Input levels:  For 74HC541: CMOS level  For 74HCT541: TTL level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC541D Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74HCT541D 74HC541DB 74HCT541DB 74HC541PW 74HCT541PW 74HC541; 74HCT541 Nexperia Octal buffer/line driver; 3-state 4. Functional diagram     $
74HC541PW,112 价格&库存
很抱歉,暂时无法提供与“74HC541PW,112”相匹配的价格&库存,您可以联系我们找货
