74HCT7540D,118
74HCT7540D,118
    NEXPERIA(安世)
    SO-20_12.8X7.5MM
    缓冲器,反向 1 元件 8 位每元件 三态 Output 20-SO
74HCT7540D,118 数据手册
74HC7540; 74HCT7540 Octal Schmitt trigger buffer/line driver; 3-state; inverting Rev. 5 — 26 May 2016 Product data sheet 1. General description The 74HC7540; 74HCT7540 is an 8-bit inverting buffer/line driver with Schmitt-trigger inputs and 3-state outputs. The device features two output enables (OE1 and OE2). A HIGH on OEn causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. 2. Features and benefits  Input levels:  For 74HC7540: CMOS level  For 74HCT7540: TTL level  Inverting outputs  Low-power dissipation  Complies with JEDEC standard no. 7 A  Multiple package options  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC7540D Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 74HCT7540D 74HC7540DB 74HC7540; 74HCT7540 Nexperia Octal Schmitt trigger buffer/line driver; 3-state; inverting 4. Functional diagram           $
74HCT7540D,118 价格&库存
很抱歉,暂时无法提供与“74HCT7540D,118”相匹配的价格&库存,您可以联系我们找货
