74HC7541D-Q100J
74HC7541D-Q100J
    NEXPERIA(安世)
    SOIC20_300MIL
    IC BUFFER NON-INVERT 6V 20SO
74HC7541D-Q100J 数据手册
74HC7541-Q100; 74HCT7541-Q100 Octal Schmitt trigger buffer/line driver; 3-state Rev. 1 — 24 March 2014 Product data sheet 1. General description The 74HC7541-Q100; 74HCT7541-Q100 is an 8-bit buffer/line driver with Schmitt-trigger inputs and 3-state outputs. The device features two output enables (OE1 and OE2). A HIGH on OEn causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Non-inverting outputs  Low-power dissipation  Input levels:  For 74HC7541-Q100: CMOS level  For 74HCT7541-Q100: TTL level  Complies with JEDEC standard no. 7A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Ordering information Table 1. Ordering information Type number 74HC7541D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74HCT7541D-Q100 74HC7541PW-Q100 74HCT7541PW-Q100 74HC74541-Q100; 74HCT7541-Q100 Nexperia Octal Schmitt trigger buffer/line driver; 3-state 4. Functional diagram 2 3 4 5 A0 Y0 A1 Y1 A2 Y2 A3 Y3 18 17 16 15 1 19 6 7 8 9 1 19 Y4 A4 A5 Y5 A6 Y6 A7 Y7 Fig 1. EN 14 13 12 11 OE1 OE2 & 2 18 3 17 4 16 5 15 6 14 7 13 8 12 9 11 aaa-000085 aaa-000084 Logic symbol Fig 2. IEC logic symbol 5. Pinning information 5.1 Pinning +&4 +&74 +&4 +&74 2(  $   9&&  2( 2(  $   9&&  2( $  $
74HC7541D-Q100J 价格&库存
很抱歉,暂时无法提供与“74HC7541D-Q100J”相匹配的价格&库存,您可以联系我们找货
