74LV244PW,112
74LV244PW,112
    NEXPERIA(安世)
    TSSOP20_6.5X4.4MM
    接口(驱动器/接收器/收发器) IC BUF NON-INVERT 5.5V 20TSSOP
74LV244PW,112 数据手册
74LV244 Octal buffer/line driver; 3-state Rev. 4 — 1 March 2016 Product data sheet 1. General description The 74LV244 is a low-voltage Si-gate CMOS device and is pin and function compatible with 74HC244 and 74HCT244. The 74LV244 is an octal non-inverting buffer/line driver with 3-state outputs. The output enable inputs 1OE and 2OE control the 3-state outputs. A HIGH on nOE causes the outputs to assume a high impedance OFF-state. The 74LV244 is identical to the 74LV240 but has non-inverting outputs. 2. Features and benefits         Wide operating voltage: 1.0 V to 5.5 V Optimized for low voltage applications: 1.0 V to 3.6 V Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V Typical VOLP (output ground bounce) < 0.8 V at VCC = 3.3 V; Tamb = 25 C Typical VOHV (output VOH undershoot) > 2 V at VCC = 3.3 V; Tamb = 25 C Complies with JEDEC standard no. 7A Multiple package options ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV244D 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74LV244DB 40 C to +125 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm 74LV244PW 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT339-1 SOT360-1 74LV244 Nexperia Octal buffer/line driver; 3-state 4. Block diagram           $
74LV244PW,112 价格&库存
很抱歉,暂时无法提供与“74LV244PW,112”相匹配的价格&库存,您可以联系我们找货
