74LVC245AD,112
74LVC245AD,112
    NEXPERIA(安世)
    SO20
    安世 74LVC_LVCH245A SO20 1.2-3.6V
74LVC245AD,112 数据手册
74LVC245A; 74LVCH245A Octal bus transceiver; 3-state Rev. 9 — 11 September 2018 Product data sheet 1. General description The 74LVC245A; 74LVCH245A are 8-bit transceivers featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The device features an output enable (OE) input for easy cascading and a send/receive (DIR) input for direction control. OE controls the outputs so that the buses are effectively isolated. Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to the outputs. These features allow the use of these devices in mixed 3.3 V and 5 V applications. The 74LVCH245A bus hold on data inputs eliminates the need for external pull-up resistors to hold unused inputs. 2. Features and benefits • • • • • • • • • • 5 V tolerant inputs/outputs for interfacing with 5 V logic Wide supply voltage range from 1.2 V to 3.6 V CMOS low-power consumption Direct interface with TTL levels Inputs accept voltages up to 5.5 V High-impedance when VCC = 0 V Bus hold on all data inputs (74LVCH245A only) Complies with JEDEC standard: • JESD8-7A (1.65 V to 1.95 V) • JESD8-5A (2.3 V to 2.7 V) • JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115B exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Specified from -40 °C to +85 °C and -40 °C to +125 °C 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state 3. Ordering information Table 1. Ordering information Type number Package 74LVC245AD Temperature range Name Description Version -40 °C to +125 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 -40 °C to +125 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 -40 °C to +125 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 -40 °C to +125 °C DHVQFN20 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 × 4.5 × 0.85 mm 74LVCH245AD 74LVC245ADB 74LVCH245ADB 74LVC245APW 74LVCH245APW 74LVC245ABQ 74LVCH245ABQ SOT764-1 4. Functional diagram 1 DIR OE 2 B0 3 19 3EN1 3EN2 1 14 A5 13 A6 B6 9 G3 2 B5 8 15 A4 B4 7 1 16 A3 B3 6 17 A2 B2 5 18 A1 B1 4 19 A0 12 A7 B7 11 3 17 4 16 5 15 6 14 7 13 8 12 9 Logic diagram 74LVC_LVCH245A Product data sheet 11 mna175 mna174 Fig. 1. 18 2 Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 2 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state 5. Pinning information 5.1. Pinning 1 DIR terminal 1 index area 1 20 VCC A0 2 19 OE A1 3 18 B0 A2 4 17 B1 A3 5 16 B2 A4 6 15 B3 A5 7 14 B4 A6 8 13 B5 A7 9 12 B6 GND 10 11 B7 19 OE A1 3 18 B0 A2 4 17 B1 A3 5 16 B2 A4 6 15 B3 A5 7 14 B4 A6 8 A7 9 GND(1) 13 B5 12 B6 001aak293 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. 001aak292 Fig. 3. 2 GND 10 DIR A0 B7 11 74LVC245A 74LVCH245A 20 VCC 74LVC245A 74LVCH245A Pin configuration SOT163-1 (SO20), SOT339-1 (SSOP20) and SOT360-1 (TSSOP20) Fig. 4. Pin configuration SOT764-1 (DHVQFN20) 5.2. Pin description Table 2. Pin description Symbol Pin Description DIR 1 direction control A0, A1, A2, A3, A4, A5, A6, A7 2, 3, 4, 5, 6, 7, 8, 9 data input/output GND 10 ground (0 V) B0, B1, B2, B3, B4, B5, B6, B7 18, 17, 16, 15, 14, 13, 12, 11 data input/output OE 19 output enable input (active LOW) VCC 20 supply voltage 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high impedance OFF-state. Inputs Inputs/outputs OE DIR An Bn L L An = Bn inputs L H inputs Bn = An H X Z Z 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 3 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V - ±50 mA VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage output HIGH or LOW [2] -0.5 VCC + 0.5 V output 3-state [2] -0.5 +6.5 V - ±50 mA VI < 0 V [1] IO output current ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [3] VO = 0 V to VCC mA Tamb = -40 °C to +125 °C [3] The minimum input voltage ratings may be exceeded if the input current ratings are observed. The output voltage ratings may be exceeded if the output current ratings are observed. For SO20 packages: above 70 °C derate linearly with 8 mW/K. For (T)SSOP20 packages: above 60 °C derate linearly with 5.5 mW/K. For DHVQFN20 packages: above 60 °C derate linearly with 4.5 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC Conditions Min Typ Max Unit 1.65 - 3.6 V 1.2 - 3.6 V 0 - 5.5 V output HIGH or LOW 0 - VCC V output 3-state 0 - 5.5 V -40 - +125 °C supply voltage functional VI input voltage VO output voltage Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate VCC = 1.2 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 4 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL Conditions Tamb = -40 °C to +85 °C HIGH-level input VCC = 1.2 V voltage VCC = 1.65 V to 1.95 V LOW-level input voltage HIGH-level output voltage Min Typ [1] Max Tamb = Unit -40 °C to +125 °C Min Max 1.08 - - 1.08 - V 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 1.2 V - - 0.12 - 0.12 V VCC = 1.65 V to 1.95 V - - 0.35VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC - 0.2 - - VCC - 0.3 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = -8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = -18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = -24 mA; VCC = 3.0 V 2.2 - - 2.0 - V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V [2] - ±0.1 ±5 - ±20 μA [3] - ±0.1 ±5 - ±20 μA 0.35VCC V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 3.6 V LOW-level output VI = VIH or VIL voltage IO = 100 μA; VCC = 1.65 V to 3.6 V II input leakage current IOZ OFF-state output VI = VIH or VIL; current VO = 5.5 V or GND; VCC = 3.6 V IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0.0 V - ±0.1 ±10 - ±20 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 3.6 V - 0.1 10 - 40 μA ΔICC additional supply per input pin; VI = VCC - 0.6 V; current IO = 0 A; VCC = 2.7 V to 3.6 V - 5 500 - 5000 μA CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 4.0 - - - pF CI/O input/output capacitance - 10 - - - pF 74LVC_LVCH245A Product data sheet VI = 5.5 V or GND; VCC = 3.6 V VCC = 0 V to 3.6 V; VI = GND to VCC All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 5 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state Symbol Parameter IBHL bus hold LOW current IBHH bus hold HIGH current Conditions Tamb = -40 °C to +85 °C VCC = 1.65; VI = 0.58 V Min Max - - 10 - μA - - 25 - μA VCC = 3.0; VI = 0.8 V 75 - - 60 - μA -10 - - -10 - μA -30 - - -25 - μA [4][5] VCC = 2.3; VI = 1.7 V VCC = 1.95 V bus hold LOW overdrive current V = 2.7 V CC VCC = 1.95 V bus hold HIGH overdrive current V = 2.7 V CC VCC = 3.6 V [1] [2] [3] [4] [5] [6] Max 30 [4][6] VCC = 3.6 V IBHHO Typ [1] 10 VCC = 3.0; VI = 2.0 V IBHLO Min VCC = 2.3; VI = 0.7 V VCC = 1.65; VI = 1.07 V [4][5] Tamb = Unit -40 °C to +125 °C [4][6] -75 - - -60 - μA 200 - - 200 - μA 300 - - 300 - μA 500 - - 500 - μA -200 - - -200 - μA -300 - - -300 - μA -500 - - -500 - μA All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. The bus hold circuit is switched off when VI ˃ VCC allowing 5.5 V on the input terminal. For I/O ports the parameter IOZ includes the input leakage current. Valid for data inputs of bus hold parts only (74LVCH245A). Note that control inputs do not have a bus hold circuit. The specified sustaining current at the data input holds the input below the specified VI level. The specified overdrive current at the data input forces the data input to the opposite input state. 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 6 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 7. Symbol Parameter tpd propagation delay Conditions Tamb = -40 °C to +85 °C Min Typ [1] Max Min Max - 17.0 - - - ns VCC = 1.65 V to 1.95 V 1.5 6.5 14.6 1.5 16.9 ns VCC = 2.3 V to 2.7 V 1.0 3.4 7.6 1.0 8.7 ns VCC = 2.7 V 1.5 3.4 7.3 1.5 9.5 ns 1.5 2.9 6.3 1.5 8.0 ns - 22.0 - - - ns VCC = 1.65 V to 1.95 V 1.9 8.3 19.5 1.9 22.5 ns VCC = 2.3 V to 2.7 V 1.5 4.6 10.7 1.5 12.4 ns VCC = 2.7 V 1.5 4.8 9.5 1.5 12.0 ns VCC = 3.0 V to 3.6 V 1.5 3.7 8.5 1.5 11.0 ns - 12.0 - - - ns VCC = 1.65 V to 1.95 V 2.9 5.5 12.3 2.9 14.2 ns VCC = 2.3 V to 2.7 V 1.0 3.1 7.1 1.0 8.2 ns VCC = 2.7 V 1.5 3.9 8.0 1.5 10.0 ns VCC = 3.0 V to 3.6 V 1.7 3.6 7.0 1.7 9.0 ns - - 1.0 - 1.5 ns VCC = 1.65 V to 1.95 V - 7.7 - - - pF VCC = 2.3 V to 2.7 V - 11.3 - - - pF VCC = 3.0 V to 3.6 V - 14.4 - - - pF nAn to nBn; nBn to nAn; see Fig. 5 [2] VCC = 1.2 V VCC = 3.0 V to 3.6 V ten enable time nOE to nAn, nBn; see Fig. 6 [2] VCC = 1.2 V tdis disable time nOE to nAn, nBn; see Fig. 6 [2] VCC = 1.2 V tsk(o) output skew time CPD power dissipation capacitance [1] [2] [3] [4] Tamb = Unit -40 °C to +125 °C [3] per input; VI = GND to VCC [4] Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V and 3.3 V respectively. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL × VCC × fo) = sum of the outputs. 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 7 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state 10.1. Waveforms and test circuit VI An, Bn input VM VM GND tPLH tPHL VOH VM Bn, An output VM VOL mna176 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. Input (An, Bn) to output (Bn, An) propagation delays and output transition times VI OE input VM GND t PLZ t PZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL t PHZ VOH t PZH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs enabled outputs disabled mna367 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. Enable and disable times Table 8. Measurement points Supply voltage VM Input VCC VI VX VY 1.2 V 0.5 × VCC VCC VOL + 0.15 V VOH - 0.15 V 1.65 V to 1.95 V 0.5 × VCC VCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V 0.5 × VCC VCC VOL + 0.15 V VOH - 0.15 V 2.7 V 1.5 V 2.7 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 1.5 V 2.7 V VOL + 0.3 V VOH - 0.3 V 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 8 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 7. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 1.65 V to 1.95 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 2.3 V to 2.7 V VCC ≤ 2 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 9 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state 11. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e bp detail X w M 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 0.043 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT163-1 (SO20) 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 10 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm D SOT339-1 E A X c HE y v M A Z 20 11 Q A2 pin 1 index A (A 3) A1 θ Lp L 1 10 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 7.4 7.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.9 0.5 8o 0o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT339-1 Fig. 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Package outline SOT339-1 (SSOP20) 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 11 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 10. Package outline SOT360-1 (TSSOP20) 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 12 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 x 4.5 x 0.85 mm B D SOT764-1 A A A1 E c detail X terminal 1 index area terminal 1 index area e1 C e b 2 9 v w C A B C y1 C y L 1 10 Eh e 20 11 19 12 X Dh 0 2.5 5 mm scale Dimensions (mm are the original dimensions) Unit mm A(1) A1 b max 1.00 0.05 0.30 nom 0.90 0.02 0.25 min 0.80 0.00 0.18 c D(1) Dh E(1) Eh e e1 L v 0.2 4.6 4.5 4.4 3.15 3.00 2.85 2.6 2.5 2.4 1.15 1.00 0.85 0.5 3.5 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT764-1 --- MO-241 --- sot764-1_po European projection Issue date 03-01-27 14-12-12 Fig. 11. Package outline SOT764-1 (DHVQFN20) 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 13 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC_LVCH245A v.9 20180911 - Modifications: • • • • Product data sheet 74LVC_LVCH245A v.8 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74LVC245ABX and 74LVCH245ABX (SOT1045-2) removed. Package outline drawing of SOT764-1 updated. 74LVC_LVCH245A v.8 20130628 Modifications: • 74LVC_LVCH245A v.7 20120405 Modifications: • 74LVC_LVCH245A v.6 20111125 Modifications: • 74LVC_LVCH245A v.5 20090825 Product data sheet - 74LVC_LVCH245A v.4 74LVC_LVCH245A v.4 20090703 Product data sheet - 74LVC_LVCH245A v.3 74LVC_LVCH245A v.3 20030507 Product specification - 74LVC245A_74LVCH245A v.2 74LVC245A_74LVCH245A v.2 20020620 Product specification - 74LVC245A_74LVCH245A v.1 74LVC245A_74LVCH245A v.1 19971219 Product specification - - 74LVC_LVCH245A Product data sheet Product data sheet - 74LVC_LVCH245A v.7 For type numbers 74LVC245ABX and 74LVCH245ABX DHXQFN20U (SOT1045-1) has changed to DHXQFN20 (SOT1045-2). Product data sheet - 74LVC_LVCH245A v.6 Table note 4 of Table 6: corrected (errata) Product data sheet - 74LVC_LVCH245A v.5 Table 4, Table 5, Table 6, Table 7, and Table 9: values added for lower voltage ranges. All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 14 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC_LVCH245A Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 15 / 16 74LVC245A; 74LVCH245A Nexperia Octal bus transceiver; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 7 10.1. Waveforms and test circuit........................................ 8 11. Package outline........................................................ 10 12. Abbreviations............................................................ 14 13. Revision history........................................................14 14. Legal information......................................................15 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 September 2018 74LVC_LVCH245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 11 September 2018 © Nexperia B.V. 2018. All rights reserved 16 / 16 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC245AD 74LVCH245AD 74LVCH245ADB 74LVCH245APW 74LVC245APW 74LVC245ABQ,115 74LVC245AD,112 74LVC245ADB,112 74LVC245ADB,118 74LVC245AD,118 74LVC245APW,112 74LVC245APW,118 74LVCH245ABQ,115 74LVCH245AD,112 74LVCH245ADB,112 74LVCH245ADB,118 74LVCH245AD,118 74LVCH245APW,112 74LVCH245APW,118 74LVC245ABX,115 74LVCH245ABX,115 74LVCH245APW/AUJ 74LVC245APW/AUJ
74LVC245AD,112 价格&库存
很抱歉,暂时无法提供与“74LVC245AD,112”相匹配的价格&库存,您可以联系我们找货
74LVC245AD,112
    • 1+4.41720
    • 10+3.57480
    • 30+3.15360
    • 100+2.73240
    • 500+2.48400
    • 1000+2.35440
