74LVC125AD,112
74LVC125AD,112
    NEXPERIA(安世)
    SOIC14_150MIL
    接口(驱动器/接收器/收发器) 1.2~3.6V 8.65 x 3.90mm 14Pins 24mA 3-State SO14_150MIL
74LVC125AD,112 数据手册
74LVC125A Quad buffer/line driver with 5 V tolerant input/outputs; 3-state Rev. 7 — 11 April 2013 Product data sheet 1. General description The 74LVC125A consists of four non-inverting buffers/line drivers with 3-state outputs (nY) that are controlled by the output enable input (nOE). A HIGH at nOE causes the outputs to assume a high-impedance OFF-state. Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to the outputs. 2. Features and benefits      5 V tolerant inputs/outputs for interfacing with 5 V logic Wide supply voltage range from 1.2 V to 3.6 V CMOS low power consumption Direct interface with TTL levels Complies with JEDEC standard:  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A (2.3 V to 2.7 V)  JESD8-C/JESD36 (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-B exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC125AD 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm; body thickness 1.47 mm SOT108-1 74LVC125ADB 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LVC125APW 40 C to +125 C TSSOP14 74LVC125ABQ 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin SOT762-1 quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 4. Functional diagram 2 1A 1 1OE 5 2A 4 2OE 1Y 3 2 2Y 1 6 1 3 EN1 5 6 4 9 3A 3Y 8 9 10 3OE 12 4A 8 10 4Y 11 nY nA 12 11 13 4OE 13 nOE mna229 mna228 Fig 1. Logic symbol 74LVC125A Product data sheet Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 mna227 Fig 3. Logic diagram © Nexperia B.V. 2017. All rights reserved 2 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 5. Pinning information 14 VCC 1A 2 13 4OE 1Y 3 12 4A terminal 1 index area 2Y 6 9 3A GND 7 8 3Y 3 4 125 2A 5 GND(1) 2Y 6 10 3OE 12 4A 11 4Y 10 3OE 9 8 5 1Y 2OE 3Y 2A 13 4OE 7 11 4Y 4 2 GND 125 2OE 1A 14 VCC 1 1 1OE 1OE 5.1 Pinning 3A 001aad046 Transparent top view 001aad045 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 4. Pin configuration for SO14 and (T)SSOP14 Fig 5. Pin configuration for DHVQFN14 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE, 3OE, 4OE 1, 4, 10, 13 data enable input (active LOW) 1A, 2A, 3A, 4A 2, 5, 9, 12 data input 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function selection[1] Inputs Output nOE nA nY L L L L H H H X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 3 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current output voltage VO IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature [1] Conditions VI < 0 V [1] Min Max Unit 0.5 +6.5 V 50 - mA 0.5 +6.5 V - 50 mA output HIGH or LOW-state [2] 0.5 VCC + 0.5 V output 3-state [2] 0.5 +6.5 V - 50 mA - 100 mA 100 - mA - 500 mW 65 +150 C VO > VCC or VO < 0 V VO = 0 V to VCC Tamb = 40 C to +125 C [3] The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] The output voltage ratings may be exceeded if the output current ratings are observed. [3] For SO14 packages: above 70 C derate linearly with 8 mW/K. For (T)SSOP14 packages: above 60 C derate linearly with 5.5 mW/K. For DHVQFN14 packages: above 60 C derate linearly with 4.5 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions functional VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate 74LVC125A Product data sheet Min Typ Max Unit 1.65 - 3.6 V 1.2 - - V 0 - 5.5 V output HIGH or LOW state 0 - VCC V output 3-state 0 - 5.5 V 40 - +125 C VCC = 2.3 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 4 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions Min HIGH-level input voltage VIH VCC = 1.2 V VOH HIGH-level output voltage LOW-level output voltage Max Min Unit Max 1.08 - - 1.08 - V - - 0.65  VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V 0.12 V - - 0.12 - - - 0.35  VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC  0.2 - - VCC  0.3 - V 1.2 - - 1.05 - V 0.35  VCC V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 3.6 V IO = 4 mA; VCC = 1.65 V VOL 40 C to +125 C 0.65  VCC VCC = 1.65 V to 1.95 V LOW-level input VCC = 1.2 V voltage VCC = 1.65 V to 1.95 V VIL Typ[1] IO = 8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = 12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = 18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = 24 mA; VCC = 3.0 V 2.2 - - 2.0 - V IO = 100 A; VCC = 1.65 V to 3.6 V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V VI = VIH or VIL II input leakage current VCC = 3.6 V; VI = 5.5 V or GND - 0.1 5 - 20 A IOZ OFF-state output current VI = VIH or VIL; VCC = 3.6 V; VO = 5.5 V or GND - 0.1 5 - 20 A IOFF power-off VCC = 0.0 V; VI or VO = 5.5 V leakage current - 0.1 10 - 20 A ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 10 - 40 A ICC additional supply current per input pin; VI = VCC  0.6 V; IO = 0 A; VCC = 2.7 V to 3.6 V - 5 500 - 5000 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 4.0 - - - pF [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C. 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 5 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 8. Symbol Parameter propagation delay tpd 40 C to +85 C Conditions Min Max Min Max - 12.0 - - - ns VCC = 1.65 V to 1.95 V 1.5 5.4 11.0 1.5 12.8 ns VCC = 2.3 V to 2.7 V 1.0 2.9 5.7 1.0 6.7 ns VCC = 2.7 V 1.5 2.8 5.5 1.5 7.0 ns VCC = 3.0 V to 3.6 V 1.0 2.5 4.8 1.0 6.0 ns - 16.0 - - - ns nA to nY; see Figure 6 [2] VCC = 1.2 V enable time ten nOE to nY; see Figure 7 [2] VCC = 1.2 V VCC = 1.65 V to 1.95 V 1.0 5.0 12.2 1.0 14.2 ns VCC = 2.3 V to 2.7 V 0.5 2.9 6.8 0.5 7.9 ns VCC = 2.7 V 1.5 3.1 6.6 1.5 8.5 ns 1.0 2.3 5.4 1.0 7.0 ns - 7.0 - - - ns VCC = 1.65 V to 1.95 V 2.2 4.6 7.5 2.2 8.7 ns VCC = 2.3 V to 2.7 V 0.5 2.6 4.2 0.5 5.0 ns VCC = 2.7 V 1.5 3.1 5.0 1.5 6.5 ns VCC = 3.0 V to 3.6 V 1.0 3.2 4.6 1.0 6.0 ns - - 1.0 - 1.5 ns VCC = 3.0 V to 3.6 V disable time tdis nOE to nY; see Figure 7 [2] VCC = 1.2 V tsk(o) power dissipation capacitance CPD [1] [2] output skew time 40 C to +125 C Unit Typ[1] VCC = 3.0 V to 3.6 V [3] per buffer; VI = GND to VCC [4] VCC = 1.65 V to 1.95 V - 6.0 - - - pF VCC = 2.3 V to 2.7 V - 9.4 - - - pF VCC = 3.0 V to 3.6 V - 12.4 - - - pF Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [3] [4] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 6 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 11. AC waveforms VI VM nA input GND tPHL tPLH VOH VM nY output VOL mna230 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. The input nA to output nY propagation delays VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs disabled outputs enabled mna362 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. Table 8. 3-state enable and disable times Measurement points Supply voltage Input Output VCC VI VM VM 1.2 V VCC 0.5  VCC 0.5  VCC 1.65 V to 1.95 V VCC 0.5  VCC 0.5  VCC 2.3 V to 2.7 V VCC 0.5  VCC 0.5  VCC 2.7 V 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 7 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC VI RL VO G DUT RT RL CL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 8. Table 9. Test circuit for measuring switching times Test data Supply voltage Input VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC  2 ns 30 pF 1 k open 2  VCC GND 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k open 2  VCC GND 2.3 V to 2.7 V VCC  2 ns 30 pF 500  open 2  VCC GND 2.7 V 2.7 V  2.5 ns 50 pF 500  open 2  VCC GND 3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  open 2  VCC GND 74LVC125A Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 8 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 9 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm D SOT337-1 E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp L 7 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.4 0.9 8o o 0 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT337-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig 10. Package outline SOT337-1 (SSOP14) 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 10 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 11. Package outline SOT402-1 (TSSOP14) 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 11 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT762-1 14 terminals; body 2.5 x 3 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 6 y y1 C v M C A B w M C b L 1 7 Eh e 14 8 13 9 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 3.1 2.9 1.65 1.35 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT762-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 12. Package outline SOT762-1 (DHVQFN14) 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 12 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge MM Machine Model HBM Human Body Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC125A v.7 20130411 Product data sheet - 74LVC125A v.6 Modifications: • Features list corrected (errata) 74LVC125A v.6 20130305 Product data sheet - 74LVC125A v.5 74LVC125A v.5 20120208 Product data sheet - 74LVC125A v.4 74LVC125A v.4 20030507 Product specification - 74LVC125A v.3 74LVC125A v.3 20020308 Product specification - 74LVC125A v.2 74LVC125A v.2 19980428 Product specification - 74LVC125A v.1 74LVC125A v.1 19970801 Product specification - - 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 13 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LVC125A Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 14 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LVC125A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 11 April 2013 © Nexperia B.V. 2017. All rights reserved 15 of 16 74LVC125A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 AC waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 April 2013 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC125ABQ,115 74LVC125AD,112 74LVC125ADB,112 74LVC125ADB,118 74LVC125AD,118 74LVC125APW,112 74LVC125APW,118 74LVC125AD/AUJ 74LVC125APW/AUJ
74LVC125AD,112 价格&库存
很抱歉,暂时无法提供与“74LVC125AD,112”相匹配的价格&库存,您可以联系我们找货
74LVC125AD,112
    • 114+0.80346114+0.09685
    • 570+0.79971570+0.09640
    • 1710+0.799701710+0.09640
    • 4275+0.799684275+0.09639
    • 11400+0.7996611400+0.09639
    库存:2166
