74LVC126APW,118
74LVC126APW,118
    NEXPERIA(安世)
    TSSOP14_5X4.4MM
    IC BUF NON-INVERT 3.6V 14TSSOP
74LVC126APW,118 数据手册
74LVC126A Quad buffer/line driver with 5 V tolerant input/outputs; 3-state Rev. 9 — 21 August 2018 Product data sheet 1. General description The 74LVC126A consists of four non-inverting buffers/line drivers with 3-state outputs, which are controlled by the output enable input (nOE). A LOW at nOE causes the outputs to assume a high-impedance OFF-state. Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to the outputs. 2. Features and benefits • • • • • • • 5 V tolerant inputs/outputs for interfacing with 5 V logic Wide supply voltage range from 1.2 V to 3.6 V CMOS low power consumption Direct interface with TTL levels Complies with JEDEC standard: • JESD8-7A (1.65 V to 1.95 V) • JESD8-5A (2.3 V to 2.7 V) • JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115B exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC126AD -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LVC126ADB -40 °C to +125 °C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74LVC126APW -40 °C to +125 °C TSSOP14 plastic thin small outline package; 14 leads; body width 4.4 mm SOT402-1 74LVC126ABQ -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm SOT762-1 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 4. Functional diagram 2 1A 1 1OE 5 2A 4 2OE 9 3A 10 3OE 12 4A 13 4OE 1Y 3 2 1 1 2Y 6 5 6 4 3Y 8 9 8 10 4Y 11 12 11 13 mna235 Fig. 1. mna236 Logic symbol Fig. 2. IEC logic symbol nY nA nOE Fig. 3. 3 EN1 mna234 Logic diagram 5. Pinning information 1 terminal 1 index area 1A 2 13 4OE 1Y 3 12 4A 2OE 4 126 2A 5 GND(1) 2Y 6 2 13 4OE 1Y 3 12 4A 2OE 4 11 4Y 2A 5 10 3OE 2Y 6 9 3A GND 7 8 3Y Pin configuration SOT108-1 (SO14), SOT337-1 (SSOP14) and SOT402-1 (TSSOP14) 74LVC126A Product data sheet 10 3OE 3A 001aac983 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. aaa-012622 Fig. 4. 11 4Y 9 8 1A 3Y 14 VCC 7 1 GND 74LVC126A 1OE 14 VCC 1OE 5.1. Pinning Fig. 5. Pin configuration SOT762-1 (DHVQFN14) All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 2 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE, 3OE, 4OE 1, 4, 10, 13 data enable input (active HIGH) 1A, 2A, 3A, 4A 2, 5, 9, 12 data input 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state Output Inputs nOE nA nY H L L H H H L X Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit -0.5 +6.5 V -50 - [1] -0.5 +6.5 V mA VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V - ±50 VO output voltage output HIGH or LOW-state [2] -0.5 VCC + 0.5 V output 3-state [2] -0.5 +6.5 V - ±50 mA - 100 mA -100 - mA -65 +150 °C - 500 mW IO output current ICC supply current IGND ground current Tstg storage temperature Ptot total power dissipation [1] [2] [3] VI < 0 V VO = 0 V to VCC [3] Tamb = -40 °C to +125 °C mA The minimum input voltage ratings may be exceeded if the input current ratings are observed. The output voltage ratings may be exceeded if the output current ratings are observed. For SO14 packages: above 70 °C the value of Ptot derates linearly with 8 mW/K. For (T)SSOP14 packages: above 60 °C the value of Ptot derates linearly with 5.5 mW/K. For DHVQFN14 packages: above 60 °C the value of Ptot derates linearly with 4.5 mW/K. 74LVC126A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 3 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC 1.65 - 3.6 V 1.2 - - V 0 - 5.5 V output HIGH or LOW state 0 - VCC V output 3-state 0 - 5.5 V -40 - +125 °C supply voltage functional VI input voltage VO output voltage Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate VCC = 1.65 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage Conditions -40 °C to +85 °C VCC = 1.2 V 74LVC126A Product data sheet Min Typ [1] Max Min Max Unit 1.08 - - 1.08 - V 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 1.2 V - - 0.12 - 0.12 V VCC = 1.65 V to 1.95 V - - 0.35VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC - 0.2 - - VCC - 0.3 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = -8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = -18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = -24 mA; VCC = 3.0 V 2.2 - - 2.0 - V IO = 100 μA; VCC = 1.65 V to 3.6 V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V VCC = 1.65 V to 1.95 V HIGH-level output VI = VIH or VIL voltage IO = -100 μA; VCC = 1.65 V to 3.6 V LOW-level output voltage -40 °C to +125 °C 0.35VCC V VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 4 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Min Typ [1] Max Min Max Unit II input leakage current VCC = 3.6 V; VI = 5.5 V or GND - ±0.1 ±5 - ±20 μA IOZ OFF-state output current VI = VIH or VIL; VCC = 3.6 V; VO = 5.5 V or GND - ±0.1 ±5 - ±20 μA IOFF power-off leakage VCC = 0 V; VI or VO = 5.5 V current - ±0.1 ±10 - ±20 μA ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 10 - 40 μA ΔICC additional supply current per input pin; VCC = 1.65 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 5 500 - 5000 μA CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 4.0 - - - pF [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 8. Symbol Parameter Conditions tpd nA to nY; see Fig. 6 propagation delay -40 °C to +85 °C Min Typ [1] Max Min Max - 11.0 - - - ns VCC = 1.65 V to 1.95 V 1.5 5.2 10.8 1.5 12.6 ns VCC = 2.3 V to 2.7 V 1.0 2.8 5.6 1.0 6.6 ns VCC = 2.7 V 1.5 2.7 5.2 1.5 6.5 ns VCC = 3.0 V to 3.6 V 1.0 2.4 4.7 1.0 6.0 ns - 15.0 - - - ns VCC = 1.65 V to 1.95 V 2.4 6.7 12.9 2.4 15.0 ns VCC = 2.3 V to 2.7 V 2.0 3.8 7.1 2.0 8.3 ns VCC = 2.7 V 1.5 3.1 6.3 1.5 8.0 ns VCC = 3.0 V to 3.6 V 1.0 3.1 5.7 1.0 7.5 ns - 8.0 - - - ns VCC = 1.65 V to 1.95 V 1.0 3.3 10.0 1.0 11.5 ns VCC = 2.3 V to 2.7 V 0.5 1.8 5.6 0.5 6.5 ns VCC = 2.7 V 1.5 3.4 6.7 1.5 8.5 ns VCC = 3.0 V to 3.6 V 1.3 2.5 6.0 1.3 7.5 ns [2] VCC = 1.2 V ten enable time nOE to nY; see Fig. 7 [2] VCC = 1.2 V tdis disable time nOE to nY; see Fig. 7 VCC = 1.2 V 74LVC126A Product data sheet -40 °C to +125 °C Unit [2] All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 5 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state Symbol Parameter Conditions -40 °C to +85 °C Min Typ [1] Max Min Max - - 1.0 - 1.5 ns VCC = 1.65 V to 1.95 V - 6.0 - - - pF VCC = 2.3 V to 2.7 V - 9.3 - - - pF VCC = 3.0 V to 3.6 V - 12.2 - - - pF tsk(o) output skew time VCC = 3.0 V to 3.6 V [3] CPD power dissipation capacitance per buffer; VI = GND to VCC [4] [1] [2] [3] [4] -40 °C to +125 °C Unit Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL × VCC × fo) = sum of the outputs 10.1. Waveforms and test circuit VI VM nA input GND tPHL tPLH VOH VM nY output VOL mna237 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. The input nA to output nY propagation delays VI VM nOE input GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPHZ VOH output HIGH-to-OFF OFF-to-HIGH tPZH VY VM GND outputs enabled outputs disabled outputs enabled mna684 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. 3-state enable and disable times 74LVC126A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 6 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state Table 8. Measurement points Supply voltage Input Output VCC VM VM VX VY VCC < 2.7 V 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V VCC ≥ 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 8. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 1.65 V to 1.95 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 2.3 V to 2.7 V VCC ≤ 2 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 74LVC126A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 7 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74LVC126A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 8 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm D SOT337-1 E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp L 7 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.4 0.9 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT337-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 10. Package outline SOT337-1 (SSOP14) 74LVC126A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 9 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 11. Package outline SOT402-1 (TSSOP14) 74LVC126A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 10 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 12. Package outline SOT762-1 (DHVQFN14) 74LVC126A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 11 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC126A v.9 20180821 Product data sheet - Modifications: • • 74LVC126A v.8 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74LVC126A v.8 20140408 Modifications: • 74LVC126A v.7 20111209 Modifications: • 74LVC126A v.6 20110926 74LVC126A v.5 - 74LVC126A v.7 - 74LVC126A v.6 Product data sheet - 74LVC126A v.5 20030228 Product specification - 74LVC126A v.4 74LVC126A v.4 20020308 Product specification - 74LVC126A v.3 74LVC126A v.3 19980428 Product specification - 74LVC126A v.2 74LVC126A v.2 19970801 Product specification - 74LVC126A v.1 74LVC126A v.1 19961226 Product specification - - 74LVC126A Product data sheet Product data sheet Legal pages updated. Product data sheet Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 12 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC126A Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 13 / 14 74LVC126A Nexperia Quad buffer/line driver with 5 V tolerant input/outputs; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................4 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 5 10.1. Waveforms and test circuit........................................ 6 11. Package outline.......................................................... 8 12. Abbreviations............................................................ 12 13. Revision history........................................................12 14. Legal information......................................................13 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 August 2018 74LVC126A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 21 August 2018 © Nexperia B.V. 2018. All rights reserved 14 / 14 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC126ABQ,115 74LVC126AD,112 74LVC126ADB,112 74LVC126ADB,118 74LVC126AD,118 74LVC126APW,112 74LVC126APW,118 74LVC126APW/AUJ 74LVC126AD/AUJ
74LVC126APW,118 价格&库存
很抱歉,暂时无法提供与“74LVC126APW,118”相匹配的价格&库存,您可以联系我们找货
74LVC126APW,118
  • 1+2.44326
  • 5+1.95461
  • 10+1.73471
  • 25+1.49853
  • 100+1.24606
  • 122+1.23792
  • 250+1.11576
  • 500+1.05060
  • 1000+1.00174
  • 5000+0.92844
  • 62500+0.92029
74LVC126APW,118
  • 1+2.378051+0.30736
  • 5+1.905935+0.24634
  • 10+1.6961110+0.21922
  • 25+1.4600525+0.18871
  • 100+1.20651100+0.15594
  • 250+1.08411250+0.14012
  • 500+1.02291500+0.13221
  • 1000+0.970451000+0.12543
  • 5000+0.900515000+0.11639
  • 62500+0.8917762500+0.11526
74LVC126APW,118
  • 1+1.32330
  • 10+0.97890
  • 100+0.83900
  • 1000+0.69920
74LVC126APW,118
    74LVC126APW,118
    • 1+2.290711+0.29608
    • 10+1.5598210+0.20161
    • 25+1.3782625+0.17814
    • 100+1.18158100+0.15272
    • 250+1.08731250+0.14054
    • 500+1.03057500+0.13320
    • 1000+0.983781000+0.12716
    库存:707
