74LVC126A-Q100
Quad buffer/line driver with 5 V tolerant input/outputs; 3-state
Rev. 2 — 21 August 2018
Product data sheet
1. General description
The 74LVC126A-Q100 consists of four non-inverting buffers/line drivers with 3-state outputs, which
are controlled by the output enable input (nOE). A LOW at nOE causes the outputs to assume a
high-impedance OFF-state.
Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to
the outputs.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
5 V tolerant inputs/outputs for interfacing with 5 V logic
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low power consumption
Direct interface with TTL levels
Complies with JEDEC standard:
• JESD8-7A (1.65 V to 1.95 V)
• JESD8-5A (2.3 V to 2.7 V)
• JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74LVC126APW-Q100 -40 °C to +125 °C
TSSOP14
plastic thin small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74LVC126ABQ-Q100 -40 °C to +125 °C
DHVQFN14 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
14 terminals; body 2.5 × 3 × 0.85 mm
74LVC126AD-Q100
SOT762-1
74LVC126A-Q100
Nexperia
4. Functional diagram
2
1A
1
1OE
5
2A
4
2OE
9
3A
10
3OE
12
4A
13
4OE
1Y
3
2
1
1
2Y
6
5
6
4
3Y
8
9
8
10
4Y
11
12
11
13
mna235
Fig. 1.
mna236
Logic symbol
Fig. 2.
IEC logic symbol
nY
nA
nOE
Fig. 3.
3
EN1
mna234
Logic diagram
5. Pinning information
5.1. Pinning
1
terminal 1
index area
1A
2
13 4OE
1Y
3
12 4A
2OE
4
11 4Y
2A
5
10 3OE
2Y
6
9
3A
GND
7
8
3Y
Pin configuration SOT108-1 (SO14) and
SOT402-1 (TSSOP14)
74LVC126A_Q100
Product data sheet
4
2A
5
2Y
6
11 4Y
GND(1)
10 3OE
9
3A
aaa-012465
Transparent top view
(1) This is not a supply pin. The substrate is
attached to this pad using conductive die attach
material. There is no electrical or mechanical
requirement to solder this pad. However, if it is
soldered, the solder land should remain floating or
be connected to GND.
aaa-012464
Fig. 4.
2OE
8
14 VCC
13 4OE
12 4A
3Y
1
3
7
1OE
2
1Y
GND
74LVC126A-Q100
1A
14 VCC
1OE
74LVC126A-Q100
Fig. 5.
Pin configuration SOT762-1 (DHVQFN14)
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 13
74LVC126A-Q100
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1OE, 2OE, 3OE, 4OE
1, 4, 10, 13
data enable input (active HIGH)
1A, 2A, 3A, 4A
2, 5, 9, 12
data input
1Y, 2Y, 3Y, 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3. Function selection
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state
Output
Inputs
nOE
nA
nY
H
L
L
H
H
H
L
X
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+6.5
V
-50
[1]
-0.5
+6.5
V
mA
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO > VCC or VO < 0 V
±50
VO
output voltage
output HIGH or LOW-state
[2]
-0.5
VCC + 0.5
V
output 3-state
[2]
-0.5
+6.5
V
±50
mA
100
mA
-100
mA
-65
+150
°C
500
mW
IO
output current
ICC
supply current
IGND
ground current
Tstg
storage temperature
Ptot
total power dissipation
[1]
[2]
[3]
VI < 0 V
VO = 0 V to VCC
[3]
Tamb = -40 °C to +125 °C
mA
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
The output voltage ratings may be exceeded if the output current ratings are observed.
For SO14 packages: above 70 °C the value of Ptot derates linearly with 8 mW/K.
For TSSOP14 packages: above 60 °C the value of Ptot derates linearly with 5.5 mW/K.
For DHVQFN14 packages: above 60 °C the value of Ptot derates linearly with 4.5 mW/K.
74LVC126A_Q100
Product data sheet
3 / 13
74LVC126A-Q100
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC
1.65
3.6
V
1.2
V
V
output HIGH or LOW state
VCC
V
output 3-state
V
-40
+125
°C
supply voltage
functional
VI
input voltage
VO
output voltage
Tamb
ambient temperature
in free air
Δt/ΔV
input transition rise and fall rate
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
Conditions
-40 °C to +85 °C
VCC = 1.2 V
74LVC126A_Q100
Product data sheet
Min
Typ [1]
Max
Min
Max
Unit
1.08
1.08
V
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
VCC = 1.2 V
0.12
0.12
V
VCC = 1.65 V to 1.95 V
0.35VCC
0.7
0.7
V
0.8
0.8
V
VCC - 0.2
VCC - 0.3
V
IO = -4 mA; VCC = 1.65 V
1.2
1.05
V
IO = -8 mA; VCC = 2.3 V
1.8
1.65
V
IO = -12 mA; VCC = 2.7 V
2.2
2.05
V
IO = -18 mA; VCC = 3.0 V
2.4
2.25
V
IO = -24 mA; VCC = 3.0 V
2.2
2.0
V
IO = 100 μA;
VCC = 1.65 V to 3.6 V
0.2
0.3
V
IO = 4 mA; VCC = 1.65 V
0.45
0.65
V
IO = 8 mA; VCC = 2.3 V
0.6
0.8
V
IO = 12 mA; VCC = 2.7 V
0.4
0.6
V
IO = 24 mA; VCC = 3.0 V
0.55
0.8
V
HIGH-level output VI = VIH or VIL
voltage
IO = -100 μA;
LOW-level output
voltage
-40 °C to +125 °C
0.35VCC V
VI = VIH or VIL
4 / 13
74LVC126A-Q100
Nexperia
Symbol Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Min
Typ [1]
Max
Min
Max
Unit
II
input leakage
current
VCC = 3.6 V; VI = 5.5 V or GND
±0.1
±5
±20
μA
IOZ
OFF-state output
current
VI = VIH or VIL; VCC = 3.6 V;
VO = 5.5 V or GND
±0.1
±5
±20
μA
IOFF
power-off leakage VCC = 0 V; VI or VO = 5.5 V
current
±0.1
±10
±20
μA
ICC
supply current
VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.1
10
40
μA
ΔICC
additional supply
current
per input pin;
VCC = 1.65 V to 3.6 V;
VI = VCC - 0.6 V; IO = 0 A
5
500
5000
μA
CI
input capacitance
VCC = 0 V to 3.6 V;
VI = GND to VCC
4.0
pF
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C.
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 8.
Symbol Parameter
Conditions
tpd
nA to nY; see Fig. 6
propagation delay
-40 °C to +85 °C
Min
Typ [1]
Max
Min
Max
11.0
ns
1.5
5.2
10.8
1.5
12.6
ns
1.0
2.8
5.6
1.0
6.6
ns
VCC = 2.7 V
1.5
2.7
5.2
1.5
6.5
ns
VCC = 3.0 V to 3.6 V
1.0
2.4
4.7
1.0
6.0
ns
15.0
ns
2.4
6.7
12.9
2.4
15.0
ns
2.0
3.8
7.1
2.0
8.3
ns
VCC = 2.7 V
1.5
3.1
6.3
1.5
8.0
ns
1.0
3.1
5.7
1.0
7.5
ns
8.0
ns
1.0
3.3
10.0
1.0
11.5
ns
0.5
1.8
5.6
0.5
6.5
ns
VCC = 2.7 V
1.5
3.4
6.7
1.5
8.5
ns
1.3
2.5
6.0
1.3
7.5
ns
[2]
VCC = 1.2 V
ten
enable time
nOE to nY; see Fig. 7
[2]
VCC = 1.2 V
tdis
disable time
VCC = 1.2 V
74LVC126A_Q100
Product data sheet
-40 °C to +125 °C Unit
[2]
5 / 13
74LVC126A-Q100
Nexperia
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
Typ [1]
Max
Min
Max
1.0
1.5
ns
6.0
pF
9.3
pF
12.2
pF
tsk(o)
output skew time
[3]
CPD
power dissipation
capacitance
per buffer; VI = GND to VCC
[4]
[1]
[2]
[3]
[4]
Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
2
Σ(CL × VCC × fo) = sum of the outputs
10.1. Waveforms and test circuit
VI
VM
nA input
GND
tPHL
tPLH
VOH
VM
nY output
VOL
mna237
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 6.
The input nA to output nY propagation delays
VI
VM
nOE input
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
VOH
output
HIGH-to-OFF
OFF-to-HIGH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
mna684
Fig. 7.
3-state enable and disable times
74LVC126A_Q100
Product data sheet
6 / 13
74LVC126A-Q100
Nexperia
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
VCC < 2.7 V
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
VCC ≥ 2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
VM
VM
10 %
0V
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 8.
Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
Load
VEXT
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.2 V
VCC
≤ 2 ns
30 pF
1 kΩ
open
2 × VCC
GND
1.65 V to 1.95 V
VCC
≤ 2 ns
30 pF
1 kΩ
open
2 × VCC
GND
2.3 V to 2.7 V
VCC
≤ 2 ns
30 pF
500 Ω
open
2 × VCC
GND
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
74LVC126A_Q100
Product data sheet
7 / 13
74LVC126A-Q100
Nexperia
11. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
A2
Q
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig. 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT108-1 (SO14)
74LVC126A_Q100
Product data sheet
8 / 13
74LVC126A-Q100
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
D
SOT402-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 10. Package outline SOT402-1 (TSSOP14)
74LVC126A_Q100
Product data sheet
9 / 13
74LVC126A-Q100
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
14 terminals; body 2.5 x 3 x 0.85 mm
B
D
SOT762-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
v
w
b
2
6
C A B
C
y
y1 C
L
1
7
14
8
Eh
e
k
13
9
Dh
X
k
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
1
A1
b
0.05 0.30
0.02 0.25
0.00 0.18
4 mm
scale
c
D(1)
Dh
E(1)
Eh
e
e1
0.2
3.1
3.0
2.9
1.65
1.50
1.35
2.6
2.5
2.4
1.15
1.00
0.85
0.5
2
k
L
v
0.2
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
SOT762-1
References
IEC
JEDEC
JEITA
sot762-1_po
European
projection
Issue date
15-04-10
15-05-05
MO-241
Fig. 11. Package outline SOT762-1 (DHVQFN14)
74LVC126A_Q100
Product data sheet
10 / 13
74LVC126A-Q100
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVC126A_Q100 v.2
20180821
Product data sheet
Modifications:
74LVC126A_Q100 v.1
74LVC126A_Q100
Product data sheet
74LVC126A_Q100 v.1
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
20140526
Product data sheet
11 / 13
74LVC126A-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74LVC126A_Q100
Product data sheet
12 / 13
74LVC126A-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................2
5.1. Pinning.........................................................................2
5.2. Pin description............................................................. 3
6. Functional description................................................. 3
7. Limiting values............................................................. 3
8. Recommended operating conditions..........................4
9. Static characteristics....................................................4
10. Dynamic characteristics............................................ 5
10.1. Waveforms and test circuit........................................ 6
11. Package outline.......................................................... 8
12. Abbreviations............................................................ 11
13. Revision history........................................................11
14. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 21 August 2018
74LVC126A_Q100
Product data sheet
13 / 13
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC126AD-Q100J 74LVC126APW-Q100J 74LVC126ABQ-Q100X
