74LVC1G07-Q100
Buffer with open-drain output
Rev. 3 — 28 January 2019
Product data sheet
1. General description
The 74LVC1G07-Q100 provides the non-inverting buffer.
The output of this device is an open drain and can be connected to other open-drain outputs to
implement active-LOW wired-OR or active-HIGH wired-AND functions.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a
mixed 3.3 V and 5 V environment.
Schmitt-trigger action at all inputs makes the circuit tolerant for slower input rise and fall time.
This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry
disables the output, preventing the damaging backflow current through the device when it is
powered down.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °sC
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
• JESD8-7 (1.65 V to 1.95 V)
• JESD8-5 (2.3 V to 2.7 V)
• JESD8-B/JESD36 (2.7 V to 3.6 V)
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
-24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
74LVC1G07-Q100
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVC1G07GW-Q100
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
74LVC1G07GV-Q100
-40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74LVC1G07GS-Q100
-40 °C to +125 °C
XSON6
extremely thin small outline package; no leads; SOT1202
6 terminals; body 1.0 x 1.0 x 0.35 mm
4. Marking
Table 2. Marking
Type number
Marking code [1]
74LVC1G07GW-Q100
VS
74LVC1G07GV-Q100
V07
74LVC1G07GS-Q100
VS
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Y
A
Y
A
A
GND
mna624
mna623
Fig. 1.
Y
Logic symbol
Fig. 2.
IEC logic symbol
Fig. 3.
mna591
Logic diagram
6. Pinning information
6.1. Pinning
74LVC1G07
n.c.
1
A
2
GND
3
5
4
74LVC1G07
VCC
Y
n.c.
1
6
VCC
A
2
5
n.c.
GND
3
4
Y
001aag422
001aab622
Fig. 4.
Pin configuration SOT353-1 (TSSOP5)
and SOT753 (SC-74A)
74LVC1G07_Q100
Product data sheet
Transparent top view
Fig. 5.
Pin configuration SOT1202 (XSON6)
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 12
74LVC1G07-Q100
Nexperia
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
TSSOP5 and SC-74A
XSON6
n.c.
1
1, 5
not connected
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
VCC
5
6
supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
Input A
Output Y
L
L
H
Z
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO < 0 V
VO
output voltage
Active mode
Power-down mode; VCC = 0 V
Min
Max
Unit
-0.5
+6.5
V
-50
-0.5
+6.5
-50
[1]
-0.5
+6.5
V
[1]
-0.5
+6.5
V
50
mA
VI < 0 V
[1]
V
mA
IO
output current
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
VO = 0 V to 6.5 V
mA
Tamb = -40 °C to +125 °C
[2]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP5 and SC-74A packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 package: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
74LVC1G07_Q100
Product data sheet
3 / 12
74LVC1G07-Q100
Nexperia
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC
supply voltage
1.65
5.5
V
VI
input voltage
V
VO
output voltage
V
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
Active mode
V
-40
+125
°C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
10. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
VIL
VOL
HIGH-level
input voltage
LOW-level
input voltage
LOW-level
output voltage
74LVC1G07_Q100
Product data sheet
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 2.7 V to 3.6 V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
VCC = 1.65 V to 1.95 V
0.35VCC
0.35VCC
V
0.7
0.7
V
0.8
0.8
V
0.3VCC
0.3VCC
V
IO = 100 μA;
VCC = 1.65 V to 5.5 V
0.10
0.10
V
IO = 4 mA; VCC = 1.65 V
0.45
0.70
V
IO = 8 mA; VCC = 2.3 V
0.30
0.45
V
IO = 12 mA; VCC = 2.7 V
0.40
0.60
V
IO = 24 mA; VCC = 3.0 V
0.55
0.80
V
IO = 32 mA; VCC = 4.5 V
0.55
0.80
V
VI = VIH or VIL
4 / 12
74LVC1G07-Q100
Nexperia
Symbol Parameter
Conditions
-40 °C to +85 °C
Unit
Min
Typ[1]
Max
Min
Max
±0.1
±1
±1
μA
±0.1
±2
±2
μA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
IOZ
OFF-state
output current
VI = VIH or VIL;
VO = VCC or GND; VCC = 5.5 V
IOFF
power-off
VI or VO = 5.5 V; VCC = 0 V
leakage current
±0.1
±2
±2
μA
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
μA
ΔICC
additional
supply current
per pin; VI = VCC - 0.6 V;
IO = 0 A; VCC = 2.3 V to 5.5 V
5
500
500
μA
CI
input
capacitance
VCC = 3.3 V; VI = GND to VCC
5.0
pF
[1]
[2]
[2]
-40 °C to +125 °C
[2]
All typical values are measured at Tamb = 25 °C.
These typical values are measured at VCC = 3.3 V.
11. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7.
Symbol Parameter
tpd
CPD
[1]
[2]
[3]
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
1.0
2.6
6.7
1.0
8.4
ns
0.5
1.7
5.5
0.5
7.0
ns
VCC = 2.7 V
0.5
2.3
4.7
0.5
6.0
ns
VCC = 3.0 V to 3.6 V
0.5
2.2
4.2
0.5
5.5
ns
0.5
1.6
3.5
0.5
4.5
ns
7.0
pF
propagation delay A to Y; see Fig. 6
[2]
power dissipation VI = GND to VCC; VCC = 3.3 V [3]
capacitance
Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
tpd is the same as tPLZ and tPZL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL x VCC x fo) = sum of outputs.
74LVC1G07_Q100
Product data sheet
5 / 12
74LVC1G07-Q100
Nexperia
11.1. Waveforms and test circuit
VI
VM
A input
GND
t PZL
t PLZ
VCC
Y output
VM
VX
VOL
mna626
Measurement points are given in Table 9.
VOL is the typical output voltage level that occurs with the output load.
Fig. 6.
The input (A) to output (Y) propagation delays
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
1.65 V to 1.95 V
0.5VCC
0.5VCC
VOL + 0.15 V
2.3 V to 2.7 V
0.5VCC
0.5VCC
VOL + 0.15 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
3.0 V to 3.6 V
1.5 V
1.5 V
VOL + 0.3 V
4.5 V to 5.5 V
0.5VCC
0.5VCC
VOL + 0.3 V
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
mna616
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 7.
Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPZL, tPLZ
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
2VCC
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
2VCC
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
6V
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
6V
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
2VCC
74LVC1G07_Q100
Product data sheet
VEXT
Load
6 / 12
74LVC1G07-Q100
Nexperia
12. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
Fig. 8.
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Package outline SOT353-1 (TSSOP5)
74LVC1G07_Q100
Product data sheet
7 / 12
74LVC1G07-Q100
Nexperia
Plastic surface-mounted package; 5 leads
SOT753
D
B
E
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
Fig. 9.
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Package outline SOT753 (SC-74A)
74LVC1G07_Q100
Product data sheet
8 / 12
74LVC1G07-Q100
Nexperia
XSON6: extremely thin small outline package; no leads;
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
1. Including plating thickness.
2. Visible depending upon used manufacturing technology.
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Fig. 10. Package outline SOT1202 (XSON6)
74LVC1G07_Q100
Product data sheet
9 / 12
74LVC1G07-Q100
Nexperia
13. Abbreviations
Table 11. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVC1G07_Q100 v.3
20190128
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74LVC1G07GS-Q100 (SOT1202) added.
74LVC1G07_Q100 v.2
20161207
Modifications:
74LVC1G07_Q100 v.1
20130523
74LVC1G07_Q100
Product data sheet
74LVC1G07_Q100 v.2
Product data sheet
74LVC1G07_Q100 v.1
Table 7: The maximum limits for leakage current and supply current have changed.
Product data sheet
10 / 12
74LVC1G07-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74LVC1G07_Q100
Product data sheet
11 / 12
74LVC1G07-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 3
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................4
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................5
11.1. Waveforms and test circuit........................................ 6
12. Package outline.......................................................... 7
13. Abbreviations............................................................ 10
14. Revision history........................................................10
15. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 28 January 2019
74LVC1G07_Q100
Product data sheet
12 / 12
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC1G07GW-Q100H 74LVC1G07GV-Q100H 74LVC1G07GS-Q100H
