74LVC1G16GMH
74LVC1G16GMH
    NEXPERIA(安世)
    X2-DFN1409-6
    IC缓冲非反转5.5V XSON6_1X1.45MM
74LVC1G16GMH 数据手册
74LVC1G16 Single buffer Rev. 2 — 12 October 2016 Product data sheet 1. General description The 74LVC1G16 provides a low-power, low-voltage single buffer. The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. Schmitt trigger action at all inputs makes the circuit highly tolerant of slower input rise and fall times. 2. Features and benefits             Wide supply voltage range from 1.65 V to 5.5 V 5 V tolerant inputs for interfacing with 5 V logic High noise immunity Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V). ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V 24 mA output drive (VCC = 3.0 V) CMOS low power consumption Latch-up performance exceeds 250 mA Direct interface with TTL levels Inputs accept voltages up to 5 V Multiple package options Specified from 40 C to +85 C and 40 C to +125 C 74LVC1G16 Nexperia Single buffer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G16GW 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G16GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74LVC1G16GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G16GW Yr 74LVC1G16GM Yr 74LVC1G16GF Yr [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $ <    $ DDF Fig 1. < DDF Logic symbol Fig 2. DDF IEC logic symbol Fig 3. Logic diagram 6. Pinning information 6.1 Pinning /9&* QF  $  *1'  /9&*   9&& QF   9&& $   QF *1'   < < DDD 7UDQVSDUHQWWRSYLHZ DDD Fig 4. Pin configuration SOT353-1 (TSSOP5) 74LVC1G16 Product data sheet Fig 5. Pin configuration SOT886 and SOT891 (XSON6) All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 October 2016 © Nexperia B.V. 2017. All rights reserved 2 of 14 74LVC1G16 Nexperia Single buffer 6.2 Pin description Table 3. Pin description Symbol Pin n.c. Description TSSOP5 XSON6 1 1 not connected A 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 7. Functional description Table 4. Function table[1] Input Output A Y L L H H [1] H = HIGH voltage level; L = LOW voltage level. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions Min Max Unit 0.5 +6.5 V 50 - [1] 0.5 +6.5 VI < 0 V mA VI input voltage IOK output clamping current VO > VCC or VO < 0 V - 50 VO output voltage Active mode [1][2] 0.5 VCC + 0.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA VO = 0 V to VCC V mA IO output current ICC supply current - 100 mA IGND ground current 100 - mA Ptot total power dissipation - 250 mW Tstg storage temperature 65 +150 C Tamb = 40 C to +125 C [3] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For TSSOP5 package: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 package: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 74LVC1G16 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 October 2016 © Nexperia B.V. 2017. All rights reserved 3 of 14 74LVC1G16 Nexperia Single buffer 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC VO VCC = 0 V; Power-down mode 0 - 5.5 VO 40 - +125 C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V Min Typ Max 0.65  VCC - - V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 VIH VIL VOH Conditions HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - LOW-level output voltage VCC = 2.3 V to 2.7 V - - 0.7 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VI = VIH or VIL VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 1.2 1.54 - V IO = 8 mA; VCC = 2.3 V 1.9 2.15 - V IO = 12 mA; VCC = 2.7 V 2.2 2.50 - V IO = 24 mA; VCC = 3.0 V 2.3 2.62 - V IO = 32 mA; VCC = 4.5 V 3.8 4.11 - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - 0.07 0.45 V IO = 8 mA; VCC = 2.3 V - 0.12 0.30 V IO = 12 mA; VCC = 2.7 V - 0.17 0.40 V IO = 24 mA; VCC = 3.0 V - 0.33 0.55 V VI = VIH or VIL IO = 32 mA; VCC = 4.5 V II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V 74LVC1G16 Product data sheet 0.35  VCC V VCC = 2.7 V to 3.6 V IO = 100 A; VCC = 1.65 V to 5.5 V VOL Unit C[1] [2] All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 October 2016 - 0.39 0.55 V - 0.1 5 A - 0.1 10 A © Nexperia B.V. 2017. All rights reserved 4 of 14 74LVC1G16 Nexperia Single buffer Table 7. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions ICC supply current VCC = 1.65 V to 5.5 V; IO = 0 A; VI = 5.5 V or GND ICC additional supply current VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A CI input capacitance VCC = 3.3 V; VI = GND to VCC [2] Min Typ Max Unit - 0.1 10 A - 5 500 A - 4 - pF Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL VOH HIGH-level output voltage 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 0.95 - - V IO = 8 mA; VCC = 2.3 V 1.7 - - V IO = 12 mA; VCC = 2.7 V 1.9 - - V IO = 24 mA; VCC = 3.0 V 2.0 - - V IO = 32 mA; VCC = 4.5 V 3.4 - - V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V LOW-level output voltage VOL 0.35  VCC V VCC = 1.65 V to 1.95 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND - - 100 A IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - - 200 A ICC supply current VCC = 1.65 V to 5.5 V; IO = 0 A; VI = 5.5 V or GND - - 200 A ICC additional supply current VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - - 5000 A [1] All typical values are measured at Tamb = 25 C. [2] These typical values are measured at VCC = 3.3 V. 74LVC1G16 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 October 2016 © Nexperia B.V. 2017. All rights reserved 5 of 14 74LVC1G16 Nexperia Single buffer 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 7. Symbol Parameter 40 C to +85 C Conditions power dissipation capacitance CPD Unit Min Max Min Max VCC = 1.65 V to 1.95 V 1.0 4.0 8.6 1.0 11.0 ns VCC = 2.3 V to 2.7 V 0.5 2.6 4.4 0.5 5.6 ns VCC = 2.7 V 0.5 2.3 4.5 0.5 5.6 ns VCC = 3.0 V to 3.6 V 0.5 2.0 4.1 0.5 5.2 ns VCC = 4.5 V to 5.5 V 0.5 1.6 3.2 0.5 4.1 ns - 15 - - - pF [2] propagation delay A to Y; see Figure 6 tpd 40 C to +125 C Typ[1] VI = GND to VCC; VCC = 3.3 V [3] [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V, and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 12. Waveforms 9, 90 $LQSXW *1' W 3+/ W 3/+ 92+ 90
74LVC1G16GMH 价格&库存
很抱歉,暂时无法提供与“74LVC1G16GMH”相匹配的价格&库存,您可以联系我们找货
