74LVC1G34-Q100
Single buffer
Rev. 2 — 9 December 2016
Product data sheet
1. General description
The 74LVC1G34-Q100 provides a low-power, low-voltage single buffer.
The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of
this device in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
Schmitt trigger action at all inputs makes the circuit highly tolerant of slower input rise and
fall times.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant inputs for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V).
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
74LVC1G34-Q100
Nexperia
Single buffer
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1G34GW-Q100
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74LVC1G34GV-Q100
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G34GW-Q100
YN
74LVC1G34GV-Q100
YN
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
DDF
Fig 1.
Logic symbol
DDF
DDF
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram
6. Pinning information
6.1 Pinning
/9&*4
QF
*1'
9&&
DDD
Fig 4.
Pin configuration SOT353-1 and SOT753
74LVC1G34_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
74LVC1G34-Q100
Nexperia
Single buffer
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
n.c.
1
not connected
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
7. Functional description
Table 4.
Function table[1]
Input
Output
A
Y
L
L
H
H
[1]
H = HIGH voltage level;
L = LOW voltage level.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
mA
50
Active mode
[1][2]
0.5
VCC + 0.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
100
mA
100
mA
250
mW
65
+150
C
VO > VCC or VO < 0 V
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
74LVC1G34_Q100
Product data sheet
mA
3 of 13
74LVC1G34-Q100
Nexperia
Single buffer
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
VO
VCC = 0 V; Power-down mode
VO
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
Min
Typ
Max
0.65 VCC
V
10. Static characteristics
Table 7.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Tamb = 40 C to +85
VIH
VIL
VOH
Conditions
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
VCC = 1.65 V to 1.95 V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC
V
LOW-level output voltage
74LVC1G34_Q100
Product data sheet
0.35 VCC V
0.7
V
0.8
V
0.3 VCC
V
VI = VIH or VIL
IO = 100 A; VCC = 1.65 V to 5.5 V
VOL
Unit
C[1]
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
1.54
V
IO = 8 mA; VCC = 2.3 V
1.9
2.15
V
IO = 12 mA; VCC = 2.7 V
2.2
2.50
V
IO = 24 mA; VCC = 3.0 V
2.3
2.62
V
IO = 32 mA; VCC = 4.5 V
3.8
4.11
V
0.10
V
0.07
0.45
V
0.12
0.30
V
0.17
0.40
V
0.33
0.55
V
0.39
0.55
V
VI = VIH or VIL
4 of 13
74LVC1G34-Q100
Nexperia
Single buffer
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
[2]
Min
Typ
Max
Unit
0.1
1
A
II
input leakage current
VCC = 0 V to 5.5 V; VI = 5.5 V or GND
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 5.5 V
0.1
2
A
ICC
supply current
VCC = 1.65 V to 5.5 V; IO = 0 A;
VI = 5.5 V or GND
0.1
4
A
ICC
additional supply current
VCC = 2.3 V to 5.5 V; VI = VCC 0.6 V;
IO = 0 A
5
500
A
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
4
pF
0.65 VCC
V
1.7
V
[2]
VIH
VIL
VOH
2.0
V
0.7 VCC
V
0.8
V
0.3 VCC
V
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
0.10
V
0.70
V
0.45
V
0.60
V
0.80
V
0.80
V
0.7
V
VI = VIH or VIL
VOL
0.35 VCC V
VI = VIH or VIL
II
1
A
IOFF
2
A
ICC
supply current
VI = 5.5 V or GND
4
A
ICC
IO = 0 A
500
A
[1]
All typical values are measured at Tamb = 25 C.
[2]
These typical values are measured at VCC = 3.3 V.
74LVC1G34_Q100
Product data sheet
5 of 13
74LVC1G34-Q100
Nexperia
Single buffer
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 6.
Symbol Parameter
40 C to +85 C
Conditions
power dissipation
capacitance
CPD
Unit
Min
Max
Min
Max
1.0
4.0
8.6
1.0
11.0
ns
0.5
2.6
4.4
0.5
5.6
ns
VCC = 2.7 V
0.5
2.3
4.5
0.5
5.6
ns
VCC = 3.0 V to 3.6 V
0.5
2.0
4.1
0.5
5.2
ns
0.5
1.6
3.2
0.5
4.1
ns
15
pF
[2]
propagation delay A to Y; see Figure 5
tpd
40 C to +125 C
Typ[1]
[3]
VI = GND to VCC; VCC = 3.3 V
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V, and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. Waveforms
9,
90
$LQSXW
*1'
W 3+/
W 3/+
92+
90
很抱歉,暂时无法提供与“74LVC1G34GW-Q100H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.65414
- 50+0.53052
- 150+0.46872
- 500+0.42237
- 3000+0.38528
- 6000+0.36674
