74LVC3G17GN,115
74LVC3G17GN,115
    NEXPERIA(安世)
    XSON8
    三路同相施密特触发器,具有5 V容限输入
74LVC3G17GN,115 数据手册
74LVC3G17 Triple non-inverting Schmitt trigger with 5 V tolerant input Rev. 13 — 27 November 2018 Product data sheet 1. General description The 74LVC3G17 provides three non-inverting buffers with Schmitt trigger input. It is capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of the 74LVC3G17 as a translator in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing a damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • Wide supply voltage range from 1.65 V to 5.5 V 5 V tolerant input/output for interfacing with 5 V logic High noise immunity ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V ±24 mA output drive (VCC = 3.0 V) CMOS low-power consumption Latch-up performance exceeds 250 mA Direct interface with TTL levels Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Applications • Wave and pulse shapers for highly noisy environments 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC3G17DP -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm SOT505-2 74LVC3G17DC -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 74LVC3G17GT -40 °C to +125 °C XSON8 plastic extremely thin small outline package; no leads; 8 terminals; body 1 × 1.95 × 0.5 mm SOT833-1 74LVC3G17GF -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 × 1 × 0.5 mm SOT1089 74LVC3G17GM -40 °C to +125 °C XQFN8 plastic, extremely thin quad flat package; no leads; SOT902-2 8 terminals; body 1.6 × 1.6 × 0.5 mm 74LVC3G17GN -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.2 × 1.0 × 0.35 mm SOT1116 74LVC3G17GS -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 × 1.0 × 0.35 mm SOT1203 5. Marking Table 2. Marking codes Type number Marking code [1] 74LVC3G17DP V17 74LVC3G17DC V17 74LVC3G17GT V17 74LVC3G17GF VV 74LVC3G17GM V17 74LVC3G17GN VV 74LVC3G17GS VV [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 6. Functional diagram 1A 1Y 3Y 3A 2A 2Y A Logic symbol 74LVC3G17 Product data sheet 001aab109 001aah861 001aah860 Fig. 1. Y Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 Fig. 3. Logic diagram (one gate) © Nexperia B.V. 2018. All rights reserved 2 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input 7. Pinning information 7.1. Pinning 74LVC3G17 1A 1 8 VCC 3Y 2 7 1Y 2A 3 6 3A GND 4 5 2Y 001aab106 Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) 74LVC3G17 74LVC3G17 1A 1 7 1 3A 2Y 7 1A 2 6 3Y 3 5 2A 1Y 2A 3 6 3A GND 4 5 2Y 001aac023 Transparent top view Fig. 5. VCC 1Y 4 2 VCC GND 3Y 8 terminal 1 index area 8 Fig. 4. Pin configuration SOT833-1, SOT1089, SOT1116 and SOT1203 (XSON8) Fig. 6. 001aag404 Transparent top view Pin configuration SOT902-2 (XQFN8) 7.2. Pin description Table 3. Pin description Symbol Pin Description SOT505-2, SOT765-1, SOT833-1, SOT1089, SOT1116 and SOT1203 SOT902-2 1A, 2A, 3A 1, 3, 6 7, 5, 2 data input GND 4 4 ground (0 V) 1Y, 2Y, 3Y 7, 5, 2 1, 3, 6 data output VCC 8 8 supply voltage 8. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Input Output nA nY L L H H 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 3 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage Active mode VI < 0 V [1] Power-down mode; VCC = 0 V Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V - ±50 mA mA [1] -0.5 [1][2] -0.5 +6.5 V - ±50 mA IO output current ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW Min Max Unit 1.65 5.5 V [1] [2] [3] VO = 0 V to VCC VCC + 0.5 V Tamb = -40 °C to +125 °C [3] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K. For XSON8 and XQFN8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 10. Recommended operating conditions Table 6. Operating conditions Symbol Parameter Conditions VCC supply voltage VI input voltage 0 5.5 V VO output voltage 0 VCC V Tamb ambient temperature -40 +125 °C 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 4 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input 11. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = -40 °C to +85 °C Min Typ [1] Max Min Max - - 0.1 - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.3 - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.55 - 0.80 V VCC - 0.1 - - VCC - 0.1 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 0.95 - V IO = -8 mA; VCC = 2.3 V 1.9 - - 1.7 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 1.9 - V IO = -24 mA; VCC = 3.0 V 2.3 - - 2.0 - V IO = -32 mA; VCC = 4.5 V 3.8 - - 3.4 - V - ±0.1 ±1 - ±1 μA - ±0.1 ±2 - ±2 μA [2] - 0.1 4 - 4 μA [2] - 5 500 - 500 μA - 3.5 - - - pF LOW-level output VI = VT+ or VTvoltage IO = 100 μA; VCC = 1.65 V to 5.5 V VOL VOH VI = VT+ or VT- HIGH-level output voltage IO = -100 μA; VCC = 1.65 V to 5.5 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V ΔICC additional supply VI = VCC - 0.6 V; IO = 0 A; current VCC = 2.3 V to 5.5 V CI input capacitance [1] [2] Tamb = Unit -40 °C to +125 °C [2] All typical values are measured at Tamb = 25 °C. These typical values are measured at VCC = 3.3 V. 11.1. Transfer characteristics Table 8. Transfer characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VT+ positive-going threshold voltage 74LVC3G17 Product data sheet Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max VCC = 1.8 V 0.70 1.10 1.50 0.70 1.70 V VCC = 2.3 V 1.00 1.40 1.80 1.00 2.00 V VCC = 3.0 V 1.30 1.76 2.20 1.30 2.40 V VCC = 4.5 V 1.90 2.47 3.10 1.90 3.30 V VCC = 5.5 V 2.20 2.91 3.60 2.20 3.80 V see Fig. 7 and Fig. 8 All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 5 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input Symbol Parameter VT- -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max VCC = 1.8 V 0.25 0.61 0.90 0.25 1.10 V VCC = 2.3 V 0.40 0.80 1.15 0.40 1.35 V VCC = 3.0 V 0.60 1.04 1.50 0.60 1.70 V VCC = 4.5 V 1.00 1.55 2.00 1.00 2.20 V VCC = 5.5 V 1.20 1.86 2.30 1.20 2.50 V VCC = 1.8 V 0.15 0.49 1.00 0.15 1.20 V VCC = 2.3 V 0.25 0.60 1.10 0.25 1.30 V VCC = 3.0 V 0.40 0.73 1.20 0.40 1.40 V VCC = 4.5 V 0.60 0.92 1.50 0.60 1.70 V VCC = 5.5 V 0.70 1.02 1.70 0.70 1.90 V see Fig. 7 and Fig. 8 negative-going threshold voltage VH [1] Conditions (VT+ - VT-); see Fig. 7, Fig. 8 and Fig. 9 hysteresis voltage All typical values are measured at Tamb = 25 °C. 11.2. Waveforms transfer characteristics VO VI VT+ VH VT- VO VI VH VT- Fig. 7. VT+ Transfer characteristic 74LVC3G17 Product data sheet mnb155 VT+ and VT- limits at 70 % and 20 %. mnb154 Fig. 8. Definition of VT+, VT- and VH All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 6 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input mnb156 50 ICC (mA) mnb071 14 (1) 40 ICC (mA) 12 30 10 20 8 6 (2) 10 4 0 2 0 0 0.5 1 1.5 VI (V) Typical transfer characteristic 3 4 5 VCC (V) 6 (1) Positive-going edge. (2) Negative-going edge. Linear change of VI between 0.8 V to 2.0 V. All values given are typical unless otherwise specified. 2 VCC = 3.0 V. Fig. 9. 2 Fig. 10. Average ICC as a function of VCC 12. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 12. Symbol Parameter tpd propagation delay CPD [1] [2] [3] power dissipation capacitance Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max VCC = 1.65 V to 1.95 V 1.5 5.6 10.5 1.5 13.1 ns VCC = 2.3 V to 2.7 V 1.0 3.7 6.5 1.0 8.5 ns VCC = 2.7 V 1.0 3.8 6.5 1.0 8.5 ns VCC = 3.0 V to 3.6 V 1.0 3.6 5.7 1.0 7.1 ns VCC = 4.5 V to 5.5 V 1.0 2.7 4.3 1.0 5.4 ns - 16.3 - - - pF nA to nY; see Fig. 11 [2] per buffer; VCC = 3.3 V; VI = GND to VCC [3] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. tpd is the same as tPLH and tPHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of outputs. 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 7 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input 12.1. Waveforms and test circuit VI nA input VM VM GND tPLH tPHL VOH VM nY output VM VOL mnb072 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 11. The input (nA) to output (nY) propagation delays and the output transition times Table 10. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5 × VCC 0.5 × VCC 2.3 V to 2.7 V 0.5 × VCC 0.5 × VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5 × VCC 0.5 × VCC VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 11. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 12. Test circuit for measuring switching times Table 11. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open GND 2 × VCC 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open GND 2 × VCC 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open GND 6V 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open GND 6V 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open GND 2 × VCC 74LVC3G17 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 8 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input 13. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Fig. 13. Package outline SOT505-2 (TSSOP8) 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 9 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Fig. 14. Package outline SOT765-1 (VSSOP8) 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 10 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Fig. 15. Package outline SOT833-1 (XSON8) 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 11 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1 x 0.5 mm SOT1089 E terminal 1 index area D A A1 detail X (4×)(2) e L (8×)(2) b 4 5 e1 1 terminal 1 index area 8 L1 X 0 0.5 scale Dimensions Unit mm max nom min 1 mm A(1) 0.5 A1 b D E e e1 L L1 0.04 0.20 1.40 1.05 0.35 0.40 0.15 1.35 1.00 0.55 0.35 0.30 0.35 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version SOT1089 sot1089_po References IEC JEDEC JEITA European projection Issue date 10-04-09 10-04-12 MO-252 Fig. 16. Package outline SOT1089 (XSON8) 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 12 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input XQFN8: plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6 x 1.6 x 0.5 mm SOT902-2 X D B A terminal 1 index area E A A1 detail X e v w b 4 3 C C A B C y1 C y 5 e1 terminal 1 index area 2 6 L 1 7 k 8 L2 L k metal area not for soldering L3 L1 0 1 Dimensions Unit(1) mm max nom min 2 mm scale A 0.5 A1 b D E e 0.05 0.25 1.65 1.65 0.20 1.60 1.60 0.55 0.00 0.15 1.55 1.55 e1 0.5 k 0.2 L L1 L2 L3 0.35 0.15 0.25 0.35 0.30 0.10 0.20 0.30 0.25 0.05 0.15 0.25 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT902-2 --- MO-255 --- sot902-2_po European projection Issue date 16-07-14 16-11-08 Fig. 17. Package outline SOT902-2 (XQFN8) 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 13 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.2 x 1.0 x 0.35 mm 1 2 SOT1116 b 4 3 (4×)(2) L L1 e 8 7 6 e1 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e max 0.35 0.04 0.20 1.25 1.05 nom 0.15 1.20 1.00 0.55 min 0.12 1.15 0.95 e1 L L1 0.35 0.40 0.30 0.35 0.27 0.32 0.3 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1116_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1116 Fig. 18. Package outline SOT1116 (XSON8) 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 14 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1.0 x 0.35 mm SOT1203 b 1 2 3 (4×)(2) 4 L L1 e 8 7 6 e1 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.40 1.05 0.35 0.40 nom 0.15 1.35 1.00 0.55 0.35 0.30 0.35 min 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1203_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1203 Fig. 19. Package outline SOT1203 (XSON8) 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 15 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input 14. Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC3G17 v.13 20181127 Product data sheet - Modifications: • • • 74LVC3G17 v.12 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74LVC3G17GD (SOT996-2) removed. 74LVC3G17 v.12 20161215 Modifications: • 74LVC3G17 v.11 20130409 Modifications: • 74LVC3G17 v.10 20120706 Modifications: • 74LVC3G17 v.9 20111123 Modifications: • 74LVC3G17 v.8 20110921 74LVC3G17 v.7 74LVC3G17 v.6 Product data sheet - 74LVC3G17 v.11 Table 7: The maximum limits for leakage current and supply current have changed. Product data sheet - 74LVC3G17 v.10 For type number 74LVC3G17GD XSON8U has changed to XSON8. Product data sheet - 74LVC3G17 v.9 For type number 74LVC3G17GM the SOT code has changed to SOT902-2. - 74LVC3G17 v.8 Product data sheet - 74LVC3G17 v.7 20101104 Product data sheet - 74LVC3G17 v.6 20080606 Product data sheet - 74LVC3G17 v.5 74LVC3G17 v.5 20080313 Product data sheet - 74LVC3G17 v.4 74LVC3G17 v.4 20070521 Product data sheet - 74LVC3G17 v.3 74LVC3G17 v.3 20050131 Product data sheet - 74LVC3G17 v.2 74LVC3G17 v.2 20041103 Product specification - 74LVC3G17 v.1 74LVC3G17 v.1 20040624 Product specification - - 74LVC3G17 Product data sheet Product data sheet Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 16 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC3G17 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 17 / 18 74LVC3G17 Nexperia Triple non-inverting Schmitt trigger with 5 V tolerant input Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Marking.......................................................................... 2 6. Functional diagram.......................................................2 7. Pinning information......................................................3 7.1. Pinning.........................................................................3 7.2. Pin description............................................................. 3 8. Functional description................................................. 3 9. Limiting values............................................................. 4 10. Recommended operating conditions........................4 11. Static characteristics..................................................5 11.1. Transfer characteristics..............................................5 11.2. Waveforms transfer characteristics............................ 6 12. Dynamic characteristics............................................ 7 12.1. Waveforms and test circuit........................................ 8 13. Package outline.......................................................... 9 14. Abbreviations............................................................ 16 15. Revision history........................................................16 16. Legal information......................................................17 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 November 2018 74LVC3G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 27 November 2018 © Nexperia B.V. 2018. All rights reserved 18 / 18 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC3G17GD,125 74LVC3G17GN,115 74LVC3G17GS,115 74LVC3G17DC,125 74LVC3G17DP,125 74LVC3G17GM,125 74LVC3G17GT,115 74LVC3G17GF,115
74LVC3G17GN,115 价格&库存
很抱歉,暂时无法提供与“74LVC3G17GN,115”相匹配的价格&库存,您可以联系我们找货
