74LVC827A
10-bit buffer/line driver with 5 V tolerant inputs/outputs;
3-state
Rev. 4 — 25 November 2011
Product data sheet
1. General description
The 74LVC827A is a 10-bit buffer/line driver with 3-state outputs. The 3-state outputs are
controlled by the output enable pins OE1 and OE2. A HIGH on pin OEn causes the
outputs to assume a high-impedance OFF-state.
Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be
applied to the outputs. These features allow the use of these devices as translators in
mixed 3.3 V and 5 V applications.
2. Features and benefits
5 V tolerant inputs/outputs for interfacing with 5 V logic
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low power consumption
Direct interface with TTL levels
Complies with JEDEC standard:
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A (2.3 V to 2.7 V)
JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115B exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC827AD
40 C to +125 C
SO24
plastic small outline package; 24 leads;
body width 7.5 mm
SOT137-1
74LVC827ADB
40 C to +125 C
SSOP24
plastic shrink small outline package; 24 leads;
body width 5.3 mm
SOT340-1
74LVC827APW
40 C to +125 C
TSSOP24
plastic thin shrink small package outline package;
24 leads; body width 4.4 mm
SOT355-1
74LVC827A
Nexperia
10-bit buffer/line driver with 5 V tolerant inputs/outputs; 3-state
4. Functional diagram
2
3
4
5
6
7
A0
Y0
A1
Y1
A2
Y2
A3
Y3
A4
Y4
A5
Y5
23
22
21
18
1
8
9
10
11
A6
Y6
A7
Y7
A8
A9
Y8
Y9
16
15
14
1
OE2
2
23
3
22
4
21
5
19
7
18
8
17
9
16
10
15
11
14
001aaa616
Fig 1.
Logic diagram
74LVC827A
Product data sheet
EN
17
OE1
13
13
001aaa617
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 16
74LVC827A
Nexperia
5. Pinning information
5.1 Pinning
74LVC827A
OE1
1
24 VCC
A0
2
23 Y0
A1
3
22 Y1
A2
4
21 Y2
A3
5
20 Y3
A4
6
19 Y4
A5
7
18 Y5
A6
8
17 Y6
A7
9
16 Y7
A8 10
15 Y8
A9 11
14 Y9
GND 12
13 OE2
001aaa615
Fig 3.
Pin configuration SO24 and (T)SSOP24
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
OE1
1
output enable input 1 (active LOW)
OE2
13
output enable input 2 (active LOW)
A[0:9]
2, 3, 4, 5, 6, 7, 8, 9, 10, 11
data input
Y[0:9]
23, 22, 21, 20, 19, 18, 17, 16, 15, 14
data output
GND
12
ground (0 V)
VCC
24
supply voltage
74LVC827A
Product data sheet
3 of 16
74LVC827A
Nexperia
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
OE1
OE2
An
Yn
L
L
L
L
L
L
H
H
X
H
X
Z
H
X
X
Z
[1]
H = HIGH voltage level
L = LOW voltage level
X = don’t care
Z = high-impedance OFF-state
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Min
Max
Unit
0.5
+6.5
V
[1]
0.5
+6.5
V
output HIGH or LOW state
[2]
0.5
VCC + 0.5
V
output 3-state
[2]
0.5
+6.5
V
IIK
input clamping current
VI < 0 V
50
mA
IOK
output clamping current
VO > VCC or VO < 0 V
50
mA
IO
output current
VO = 0 V to VCC
50
mA
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[3]
[1]
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
[2]
The output voltage ratings may be exceeded if the output current ratings are observed.
[3]
SO24 package: Ptot derates linearly with 8 mW/K above 70 C.
(T)SSOP24 package: Ptot derates linearly with 5.5 mW/K above 60 C.
74LVC827A
Product data sheet
4 of 16
74LVC827A
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Min
Max
Unit
1.65
3.6
V
functional
1.2
V
VCC
V
output 3-state
V
40
+125
C
ns/V
ns/V
Tamb
ambient temperature
t/V
input transition rise and fall rate VCC = 1.65 V to 2.7 V
VCC = 2.7 V to 3.6 V
V
9. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
40 C to +85 C
Conditions
Min
VIH
VIL
VOH
VOL
II
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output
voltage
LOW-level
output
voltage
Product data sheet
40 C to +125 C
Max
Min
Unit
Max
VCC = 1.2 V
1.08
1.08
V
VCC = 1.65 V to 1.95 V
0.65 VCC -
0.65 VCC -
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
0.12
V
VCC = 1.2 V
0.12
0.35 VCC -
0.35 VCC V
0.7
0.7
V
0.8
0.8
V
IO = 100 A;
VCC = 1.65 V to 3.6 V
VCC 0.2
VCC 0.3
V
IO = 4 mA; VCC = 1.65 V
1.2
1.05
V
IO = 8 mA; VCC = 2.3 V
1.8
1.65
V
IO = 12 mA; VCC = 2.7 V
2.2
2.05
V
IO = 18 mA; VCC = 3.0 V
2.4
2.25
V
IO = 24 mA; VCC = 3.0 V
2.2
2.0
V
IO = 100 A;
0.2
0.3
V
0.45
0.65
V
VI = VIH or VIL
VI = VIH or VIL
0.6
0.8
V
0.4
0.6
V
0.55
0.8
V
0.1
5
A
input leakage VCC = 3.6 V; VI = 5.5 V or GND current
74LVC827A
Typ[1]
5 of 16
74LVC827A
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
40 C to +85 C
Conditions
Typ[1]
Min
40 C to +125 C
Max
Min
Unit
Max
IOZ
OFF-state
output
current
VI = VIH or VIL; VCC = 3.6 V;
VO = 5.5 V or GND;
0.1
5
A
IOFF
power-off
leakage
current
VCC = 0 V; VI or VO = 5.5 V
0.1
10
A
ICC
supply
current
VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.1
10
40
A
ICC
additional
supply
current
per input pin; VCC = 2.7 V to 3.6 V; VI = VCC 0.6 V; IO = 0 A
5
500
5000
A
CI
input
capacitance
VCC = 0 V to 3.6 V;
VI = GND to VCC
5.0
pF
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C.
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 6.
Symbol Parameter
tpd
propagation
delay
Tamb = 40 C to +85 C 40 C to +125 C Unit
Conditions
Min
Typ[1]
Max
Min
Max
15
ns
1.5
6.4
15.5
1.5
17.9
ns
1.0
3.4
8.0
1.0
9.3
ns
VCC = 2.7 V
1.5
3.4
7.1
1.5
9.0
ns
1.0
2.9
6.7
1.0
8.5
ns
ns
1.8
7.9
16.7
1.8
19.3
ns
1.5
4.4
9.2
1.5
10.6
ns
VCC = 2.7 V
1.5
4.5
8.5
1.5
11.0
ns
VCC = 3.0 V to 3.6 V
1.0
3.5
7.3
1.0
9.5
ns
10.0
ns
2.5
4.3
11.3
2.5
13.0
ns
1.0
2.4
6.4
1.0
7.4
ns
VCC = 2.7 V
1.5
3.2
7.3
1.5
9.5
ns
1.5
3.0
6.7
1.5
8.5
ns
1.0
1.5
ns
An to Yn; see Figure 4
[2]
VCC = 1.2 V
ten
enable time
OEn to Yn; see Figure 5
[2]
VCC = 1.2 V
tdis
disable time
[2]
VCC = 1.2 V
tsk(o)
output skew
time
74LVC827A
Product data sheet
[3]
6 of 16
74LVC827A
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
CPD
[1]
[2]
power
dissipation
capacitance
Conditions
per input; VI = GND to VCC
Min
Typ[1]
Max
Min
Max
[4]
5.5
pF
8.8
pF
11.7
pF
Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
[3]
[4]
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs
74LVC827A
Product data sheet
7 of 16
74LVC827A
Nexperia
11. Waveforms
VI
nAn input
VM
VM
GND
tPLH
tPHL
VOH
VM
nYn output
VM
VOL
mna171
VM = 1.5 V at VCC 2.7 V.
VM = 0.5 VCC at VCC < 2.7 V.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 4.
Propagation delay input (An) to output (Yn)
VI
OEn input
VM
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
VOH
tPZH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
001aaa619
Measurement points are given in Table 8.
Fig 5.
Table 8.
3-state enable and disable times
Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
< 2.7 V
0.5 VCC
0.5 VCC
VOL + 0.1 V
VOH 0.1 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH 0.3 V
74LVC827A
Product data sheet
8 of 16
74LVC827A
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
VI
RL
VO
G
DUT
RT
RL
CL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 6.
Table 9.
Test circuit for measuring switching times
Test data
Supply voltage
Input
Load
VEXT
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.2 V
VCC
2 ns
30 pF
1 k
open
2 VCC
GND
1.65 V to 1.95 V
VCC
2 ns
30 pF
1 k
open
2 VCC
GND
2.3 V to 2.7 V
VCC
2 ns
30 pF
500
open
2 VCC
GND
2.7 V
2.7 V
2.5 ns
50 pF
500
open
2 VCC
GND
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500
open
2 VCC
GND
74LVC827A
Product data sheet
9 of 16
74LVC827A
Nexperia
12. Package outline
SO24: plastic small outline package; 24 leads; body width 7.5 mm
SOT137-1
D
E
A
X
c
HE
y
v M A
Z
13
24
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
1
12
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
15.6
15.2
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.01
0.019 0.013
0.014 0.009
0.61
0.60
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
inches
0.1
0.012 0.096
0.004 0.089
0.043
0.039
0.01
0.01
Z
(1)
0.9
0.4
0.035
0.004
0.016
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 7.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT137-1
075E05
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT137-1 (SO24)
74LVC827A
Product data sheet
10 of 16
74LVC827A
Nexperia
SSOP24: plastic shrink small outline package; 24 leads; body width 5.3 mm
D
SOT340-1
E
A
X
c
HE
y
v M A
Z
24
13
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
1
12
bp
e
detail X
w M
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
8.4
8.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
0.8
0.4
8o
o
Note
1. Plastic or metal protrusions of 0.2 mm maximum per side are not included.
OUTLINE
VERSION
SOT340-1
Fig 8.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Package outline SOT340-1 (SSOP24)
74LVC827A
Product data sheet
11 of 16
74LVC827A
Nexperia
TSSOP24: plastic thin shrink small outline package; 24 leads; body width 4.4 mm
D
SOT355-1
E
A
X
c
HE
y
v M A
Z
13
24
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
12
bp
e
detail X
w M
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
7.9
7.7
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT355-1
Fig 9.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Package outline SOT355-1 (TSSOP24)
74LVC827A
Product data sheet
12 of 16
74LVC827A
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC827A v.4
20111125
Product data sheet
74LVC827A v.3
Modifications:
74LVC827A v.3
Modifications:
Value changes for tpd, ten and tdis in Table 7 “Dynamic characteristics”
Corrected typographical errors
20111103
Product data sheet
74LVC827A v.2
The format of this document has been redesigned to comply with the new identity guidelines of
NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 4, Table 5, Table 6, Table 7, and Table 9: values added for lower voltage ranges.
Added: type number 74LVC827ABQ (DHVQFN24 package)
74LVC827A v.2
20040408
Product specification
74LVC827A v.1
74LVC827A v.1
19980904
74LVC827A
Product data sheet
13 of 16
74LVC827A
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
74LVC827A
Product data sheet
14 of 16
74LVC827A
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LVC827A
Product data sheet
15 of 16
74LVC827A
Nexperia
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 25 November 2011
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC827AD,112 74LVC827ADB,112 74LVC827ADB,118 74LVC827AD,118 74LVC827APW,112
74LVC827APW,118
