74LVT125; 74LVTH125
3.3 V quad buffer; 3-state
Rev. 7 — 31 May 2016
Product data sheet
1. General description
The 74LVT125; 74LVTH125 is a high-performance BiCMOS product designed for VCC
operation at 3.3 V.
This device combines low static and dynamic power dissipation with high speed and high
output drive. The 74LVT125; 74LVTH125 device is a quad buffer that is ideal for driving
bus lines. The device features four output enable inputs (1OE, 2OE, 3OE and 4OE), each
controlling one of the 3-state outputs.
2. Features and benefits
Quad bus interface
3-state buffers
Output capability: +64 mA and 32 mA
TTL input and output switching levels
Input and output interface capability to systems at 5 V supply
Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs
Live insertion and extraction permitted
No bus current loading when output is tied to 5 V bus
Power-up 3-state
Latch-up protection:
JESD78: exceeds 500 mA
ESD protection:
MIL STD 883 method 3015: exceeds 2000 V
Machine model: exceeds 200 V
74LVT125; 74LVTH125
Nexperia
3. Ordering information
Table 1.
Type number
Package
74LVT125D
Temperature range
Name
Description
Version
40 C to +85 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
40 C to +85 C
SSOP14
plastic shrink small outline package; 14 leads;
body width 5.3 mm
SOT337-1
40 C to +85 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
40 C to +85 C
DHVQFN14
plastic dual in-line compatible thermal enhanced very SOT762-1
thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
74LVTH125D
74LVT125DB
74LVTH125DB
74LVT125PW
74LVTH125PW
74LVT125BQ
74LVTH125BQ
4. Functional diagram
2(
2(
(1
2(
2(
Q<
Q$
Q2(
PQD
Fig 1.
Logic symbol
74LVT_LVTH125
Product data sheet
PQD
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
PQD
Fig 3.
Logic diagram (one buffer)
Nexperia B.V. 2017. All rights reserved
2 of 16
74LVT125; 74LVTH125
Nexperia
5. Pinning information
9&&
WHUPLQDO
LQGH[DUHD
2(
2(
*1'
*1'
2(
2(
2(
2(
*1'
2(
9&&
2(
5.1 Pinning
DDF
7UDQVSDUHQWWRSYLHZ
DDF
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 4.
Pin configuration SO14, SSOP14 and
TSSOP14
Fig 5.
Pin configuration DHVQFN14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1OE
1
1 output enable input (active LOW)
1A
2
1 data input
1Y
3
1 data output
2OE
4
2 output enable input (active LOW)
2A
5
2 data input
2Y
6
2 data output
GND
7
ground (0 V)
3Y
8
3 data output
3A
9
3 data input
3OE
10
3 output enable input (active LOW)
4Y
11
4 data output
4A
12
4 data input
4OE
13
4 output enable input (active LOW)
VCC
14
supply voltage
74LVT_LVTH125
Product data sheet
3 of 16
74LVT125; 74LVTH125
Nexperia
6. Functional description
6.1 Function table
Table 3.
Function table[1]
Control
Input
Output
nOE
nA
nY
L
L
L
L
H
H
H
X
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
output in OFF-state or HIGH-state
IIK
input clamping current
IOK
IO
Min
0.5
+4.6
V
0.5
+7.0
V
[1]
0.5
+7.0
V
VI < 0 V
50
mA
output clamping current
VO < 0 V
50
mA
output current
output in LOW-state
128
mA
output in HIGH-state
64
mA
65
+150
C
150
C
[2]
junction temperature
Tj
Unit
[1]
storage temperature
Tstg
Max
[1]
The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
[2]
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VIH
Conditions
Min
Typ
Max
Unit
2.7
3.6
V
V
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
IOH
HIGH-level output current
32
mA
IOL
LOW-level output current
none
32
mA
current duty cycle 50 %;
f 1 kHz
64
mA
ns/V
40
+85
C
t/V
input transition rise and fall rate
Tamb
ambient temperature
74LVT_LVTH125
Product data sheet
in free air
4 of 16
74LVT125; 74LVTH125
Nexperia
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Tamb = 40 C to +85
Conditions
VIK
input clamping voltage
IIK = 18 mA; VCC = 2.7 V
VOH
HIGH-level output voltage
IOH = 100 A;
VCC = 2.7 V to 3.6 V
VOL
Min
Typ
Max
Unit
0.9
1.2
V
V
C[1]
LOW-level output voltage
VCC 0.2 VCC 0.1
IOH = 8 mA; VCC = 2.7 V
2.4
2.5
V
IOH = 32 mA; VCC = 3.0 V
2.0
2.2
V
IOL = 100 A
0.1
0.2
V
IOL = 24 mA
0.3
0.5
V
IOL = 16 mA
0.25
0.4
V
IOL = 32 mA
0.3
0.5
V
IOL = 64 mA
0.4
0.55
V
1
10
A
0.1
1
A
VCC = 3.6 V; VI = VCC
0.1
1
A
VCC = 3.6 V; VI = 0 V
1
5
A
1
100
A
VCC = 2.7 V
VCC = 3.0 V
II
input leakage current
all input pins
VCC = 0 V or 3.6 V; VI = 5.5 V
control pins
VCC = 3.6 V; VI = VCC or GND
[2]
data pins
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 0 V to 4.5 V
75
150
A
150
75
A
VCC = 3.6 V; VI = 0 V to 3.6 V
500
A
bus hold HIGH
overdrive current
500
A
ILO
output leakage current
output in HIGH-state when
VO > VCC; VO = 5.5 V;
VCC = 3.0 V
60
125
A
IO(pu/pd)
power-up/power-down output VCC 1.2 V; VO = 0.5 V to VCC;
current
VI = GND or VCC;
nOE = don’t care
1
100
A
IOZ
OFF-state output current
output HIGH: VO = 3.0 V
1
5
A
output LOW: VO = 0.5 V
1
5
A
IBHL
bus hold LOW current
VCC = 3 V; VI = 0.8 V
IBHH
bus hold HIGH current
VCC = 3 V; VI = 2.0 V
IBHLO
bus hold LOW
overdrive current
IBHHO
74LVT_LVTH125
Product data sheet
[3]
[4]
VCC = 3.6 V; VI = VIH or VIL
5 of 16
74LVT125; 74LVTH125
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
Conditions
ICC
VCC = 3.6 V; VI = GND or VCC;
IO = 0 A
supply current
Min
Typ
Max
Unit
outputs HIGH
0.13
0.19
mA
outputs LOW
2
7
mA
[5]
0.13
0.19
mA
[6]
0.1
0.2
mA
outputs disabled
ICC
additional supply current
per input pin; VCC = 3 V to 3.6 V;
one input at VCC 0.6 V and
other inputs at VCC or GND
CI
input capacitance
VI = 0 V or 3.0 V
4
pF
CO
output capacitance
outputs disabled;
VO = 0 V or 3.0 V
8
pF
[1]
Typical values are measured at VCC = 3.3 V and Tamb = 25 C.
[2]
Unused pins at VCC or GND.
[3]
This is the bus hold overdrive current required to force the input to the opposite logic state.
[4]
This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.0 V to
3.6 V a transition time of 100 s is permitted. This parameter is valid for Tamb = 25 C only.
[5]
ICC is measured with outputs pulled to VCC or GND.
[6]
This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8.
Symbol Parameter
Tamb = 40 C to +85
tPLH
Conditions
LOW to HIGH propagation delay
VCC = 2.7 V
HIGH to LOW propagation delay
VCC = 3.0 V to 3.6 V
OFF-state to HIGH propagation delay
OFF-state to LOW propagation delay
HIGH to OFF-state propagation delay
VCC = 2.7 V
Product data sheet
4.5
ns
2.7
4.0
ns
4.9
ns
1.0
2.9
3.9
ns
6.0
ns
1.0
3.4
4.7
ns
6.5
ns
1.1
3.4
4.7
ns
5.7
ns
1.8
3.7
5.1
ns
nOE to nY; see Figure 7
74LVT_LVTH125
1.0
VCC = 2.7 V
tPHZ
Unit
VCC = 2.7 V
tPZL
Max
nAn to nY; see Figure 6
VCC = 2.7 V
tPZH
Typ
tPHL
Min
C[1]
6 of 16
74LVT125; 74LVTH125
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
Conditions
tPLZ
LOW to OFF-state propagation delay
Min
Typ
Max
Unit
4.0
ns
1.3
2.6
4.5
ns
VCC = 2.7 V
[1]
Typical values are at VCC = 3.3 V and Tamb = 25 C.
11. Waveforms
9,
Q$LQSXW
90
90
*1'
W3/+
W3+/
92+
90
Q
很抱歉,暂时无法提供与“74LVT125BQ,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+1.381223000+0.17251
- 6000+1.374776000+0.17171
- 9000+1.374739000+0.17170
- 12000+1.3747112000+0.17170
- 15000+1.3746715000+0.17170
- 国内价格 香港价格
- 3000+1.442413000+0.18016
- 6000+1.435676000+0.17932
- 9000+1.435649000+0.17931
- 12000+1.4356112000+0.17931
- 15000+1.4355715000+0.17930
