74LVT16244BDL,118
74LVT16244BDL,118
    NEXPERIA(安世)
    SSOP48
    缓冲器,非反向 4 元件 4 位每元件 三态 Output 48-SSOP
74LVT16244BDL,118 数据手册
74LVT16244B; 74LVTH16244B 3.3 V 16-bit buffer/driver; 3-state Rev. 12 — 19 October 2018 Product data sheet 1. General description The 74LVT16244B; 74LVTH16244B is a high-performance BiCMOS product designed for VCC operation at 3.3 V. This device is a 16-bit buffer and line driver featuring non-inverting 3-state bus outputs. The device can be used as four 4-bit buffers, two 8-bit buffers, or one 16-bit buffer. 2. Features and benefits • • • • • • • • • • • 16-bit bus interface 3-state buffers Output capability: +64 mA and -32 mA TTL input and output switching levels Input and output interface capability to systems at 5 V supply Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs Power-up 3-state Live insertion and extraction permitted No bus current loading when output is tied to 5 V bus Latch-up protection • JESD78B Class II exceeds 500 mA ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V 3. Ordering information Table 1. Ordering information Type number Package 74LVT16244BDL Temperature range Name Description Version -40 °C to +85 °C SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 -40 °C to +85 °C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74LVTH16244BDL 74LVT16244BDGG 74LVTH16244BDGG 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state 4. Functional diagram 1A0 1A1 1A2 1A3 1OE 47 2 46 3 44 5 43 6 1Y0 3A0 1Y1 3A1 1Y2 3A2 1Y3 3A3 1 3OE 36 13 35 14 33 16 32 17 3Y0 3Y1 1 1OE 48 2OE 25 3OE 24 4OE 3Y2 3Y3 1A0 1A1 25 1A2 1A3 2A0 2A1 41 40 8 9 2Y0 2Y1 4A0 4A1 30 29 19 20 2A0 2A1 4Y0 2A2 2A3 3A0 4Y1 3A1 2A2 2A3 2OE 38 37 11 12 48 2Y2 2Y3 4A2 4A3 4OE 27 26 22 23 3A2 4Y2 3A3 4A0 4A1 4Y3 4A2 24 4A3 EN1 EN2 EN3 EN4 47 46 Logic symbol 74LVT_LVTH16244B Product data sheet 2 1 3 44 5 43 6 41 40 1 8 2 9 38 11 37 12 36 35 1 3 13 14 33 16 32 17 30 29 1 4 19 20 27 22 26 23 1Y0 1Y1 1Y2 1Y3 2Y0 2Y1 2Y2 2Y3 3Y0 3Y1 3Y2 3Y3 4Y0 4Y1 4Y2 4Y3 001aae231 mna996 Fig. 1. 1 Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 2 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state 5. Pinning information 5.1. Pinning 74LVT16244B 74LVTH16244B 1OE 1 48 2OE 1Y0 2 47 1A0 1Y1 3 46 1A1 GND 4 45 GND 1Y2 5 44 1A2 1Y3 6 43 1A3 VCC 7 2Y0 8 42 VCC 41 2A0 2Y1 9 40 2A1 GND 10 39 GND 2Y2 11 38 2A2 2Y3 12 37 2A3 3Y0 13 36 3A0 3Y1 14 35 3A1 GND 15 34 GND 3Y2 16 33 3A2 3Y3 17 32 3A3 VCC 18 4Y0 19 31 VCC 30 4A0 4Y1 20 29 4A1 GND 21 28 GND 4Y2 22 27 4A2 4Y3 23 26 4A3 4OE 24 25 3OE 001aae507 Fig. 3. Pin configuration SOT370-1 (SSOP48) and SOT362-1 (TSSOP48) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE,3OE, 4OE 1, 48, 25, 24 output enable input (active LOW) 1Y0, 1Y1, 1Y2, 1Y3 2, 3, 5, 6 data output 2Y0, 2Y1, 2Y2, 2Y3 8, 9, 11, 12 data output 3Y0, 3Y1, 3Y2, 3Y3 13, 14, 16, 17 data output 4Y0, 4Y1, 4Y2, 4Y3 19, 20, 22, 23 data output GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 1A0, 1A1, 1A2, 1A3 47, 46, 44, 43 data input 2A0, 2A1, 2A2, 2A3 41, 40, 38, 37 data input 3A0, 3A1, 3A2, 3A3 36, 35, 33, 32 data input 4A0, 4A1, 4A2, 4A3 30, 29, 27, 26 data input 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 3 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Control Input Output nOE nAn nYn L L L L H H H X Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage output in OFF-state or HIGH-state IIK input clamping current IOK IO Unit -0.5 +4.6 V -0.5 +7.0 V [1] -0.5 +7.0 V VI < 0 V -50 - mA output clamping current VO < 0 V -50 - mA output current output in LOW-state - 128 mA output in HIGH-state -64 - mA -65 +150 °C [2] - 150 °C [3] - 500 mW storage temperature Tj junction temperature Ptot total power dissipation [3] Max [1] Tstg [1] [2] Min Tamb = -40 °C to +85 °C; The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. Above 60 °C the value of Ptot derates linearly with 5.5 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage 2.7 - 3.6 V VI input voltage 0 - 5.5 V VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V IOH HIGH-level output current -32 - - mA IOL LOW-level output current - - 32 mA Tamb ambient temperature in free-air Δt/ΔV input transition rise and fall rate outputs enabled none current duty cycle ≤ 50 %; fi ≥ 1 kHz 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 - - 64 mA -40 - +85 °C - - 10 ns/V © Nexperia B.V. 2018. All rights reserved 4 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); Tamb = -40 °C to +85 °C. Symbol Parameter Conditions Min Typ [1] Max VIK input clamping voltage VCC = 2.7 V; IIK = -18 mA -1.2 -0.85 - V VOH HIGH-level output IOH = -100 μA; VCC = 2.7 V to 3.6 V voltage IOH = -8 mA; VCC = 2.7 V VCC - 0.2 VCC - V 2.4 2.5 - V 2.0 2.3 - V IOL = 100 μA - 0.07 0.2 V IOL = 24 mA - 0.3 0.5 V IOL = 16 mA - 0.25 0.4 V IOL = 32 mA - 0.3 0.5 V IOL = 64 mA - 0.4 0.55 V all input pins; VCC = 0 V or 3.6 V; VI = 5.5 V - 0.1 10 μA control pins; VCC = 3.6 V; VI = VCC or GND - 0.1 ±1.0 μA VI = VCC - 0.1 1 μA VI = 0 V -5 -0.1 - μA IOFF power-off leakage VCC = 0 V; VI or VO = 0 V to 4.5 V current - 0.1 ±100 μA IBHL bus hold LOW current VCC = 3 V; VI = 0.8 V 75 135 - μA IBHH bus hold HIGH current VCC = 3 V; VI = 2.0 V - -135 -75 μA IBHLO bus hold LOW overdrive current nAn input; VCC = 0 V to 3.6 V; VI = 3.6 V 500 - - μA IBHHO bus hold HIGH overdrive current nAn input; VCC = 0 V to 3.6 V; VI = 3.6 V - - -500 μA ILO output leakage current output in HIGH-state when VO ˃ VCC; VO = 5.5 V; VCC = 3.0 V - 50 125 μA - 1 ±100 μA IOH = -32 mA; VCC = 3.0 V VOL LOW-level output voltage Unit VCC = 2.7 V VCC = 3.0 V II input leakage current data pins; VCC = 3.6 V IO(pu/pd) power-up/ power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; nOE = don’t care IOZ VCC = 3.6 V; VI = VIH or VIL ICC OFF-state output current supply current additional supply current 74LVT_LVTH16244B Product data sheet [3] [4] output HIGH: VO = 3.0 V - 0.5 5 μA output LOW: VO = 0.5 V -5 +0.5 - μA output HIGH - 0.07 0.12 mA output LOW - 4.0 6.0 mA [5] - 0.07 0.12 mA [6] - 0.1 0.2 mA VCC = 3.6 V; VI = GND or VCC; IO = 0 A outputs disabled ΔICC [2] per input pin; VCC = 3.0 V to 3.6 V; one input at VCC - 0.6 V, other inputs at VCC or GND All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 5 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state Symbol Parameter Conditions Min Typ [1] Max Unit CI input capacitance VI = 0 V or 3.0 V - 3 - pF CO output capacitance - 9 - pF [1] [2] [3] [4] [5] [6] outputs disabled; VO = 0 V or 3.0 V Typical values are measured at VCC = 3.3 V and at Tamb = 25 °C. Unused pins at VCC or GND. This is the bus hold overdrive current required to force the input to the opposite logic state. This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only. ICC is measured with outputs pulled to VCC or GND. This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); Tamb = -40 °C to +85 °C; for test circuit see Fig. 6. Symbol Parameter Conditions tPLH nAn to nYn; see Fig. 4 LOW to HIGH propagation delay Min VCC = 2.7 V VCC = 3.0 V to 3.6 V tPHL HIGH to LOW propagation delay OFF-state to HIGH propagation delay VCC = 2.7 V VCC = 2.7 V OFF-state to LOW propagation delay nOE to nYn; see Fig. 5 HIGH to OFF-state propagation delay nOE to nYn; see Fig. 5 VCC = 2.7 V VCC = 3.0 V to 3.6 V tPHZ VCC = 2.7 V VCC = 3.0 V to 3.6 V tPLZ LOW to OFF-state propagation delay - - 4.0 ns 0.5 1.8 3.2 ns - - 4.0 ns 0.5 1.7 3.2 ns - - 5.0 ns 1.0 2.3 4.0 ns - - 5.3 ns 1.0 2.1 4.0 ns - - 5.0 ns 1.0 3.2 4.5 ns - - 4.4 ns 1.0 2.9 4.0 ns nOE to nYn; see Fig. 5 VCC = 2.7 V VCC = 3.0 V to 3.6 V [1] Unit nOE to nYn; see Fig. 5 VCC = 3.0 V to 3.6 V tPZL Max nAn to nYn; see Fig. 4 VCC = 3.0 V to 3.6 V tPZH Typ [1] Typical values are measured at VCC = 3.3 V and Tamb = 25 °C. 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 6 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state 10.1. Waveforms and test circuit VI nAn input VM VM GND tPLH tPHL VOH VM nYn output VM VOL mna171 Measurements points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 4. Propagation delay input (nAn) to output (nYn) VI nOE input VM GND tPZL tPLZ 3.0 V VM nYn output VOL VX t PZH t PHZ VOH nYn output VY VM 0V 001aae464 Measurements points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 5. 3-state output enable and disable times Table 8. Measurement points Input Output VM VM VX VY 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 7 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state VI negative pulse tW 90 % VM 0V VI tf tr tr tf 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC PULSE GENERATOR VI RL VO DUT RT CL RL 001aae235 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 6. Test circuit for measuring switching times Table 9. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.7 V ≤ 10 MHz 500 ns ≤ 2.5 ns 50 pF 500 Ω GND 6V open 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 8 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state 11. Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3 ) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 Fig. 7. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-118 Package outline SOT370-1 (SSOP48) 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 9 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit mm max nom min A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 Fig. 8. References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Package outline SOT362-1 (TSSOP48) 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 10 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVT_LVTH16244B v.12 20181019 Product data sheet - Modifications: • • • • 74LVT_LVTH16244B v.11 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74LVT16244BEV (SOT702-1), 74LVT16244BBX (SOT1134-2) and 74LVTH16244BBX (SOT1134-2) removed. Package outline drawing SOT362-1 updated 74LVT_LVTH16244B v.11 20120301 Modifications: • 74LVT_LVTH16244B v.10 20111122 Modifications: • 74LVT_LVTH16244B v.9 20110620 74LVT_LVTH16244B v.8 20100322 74LVT_LVTH16244B v.7 Product data sheet - 74LVT_LVTH16244B v.10 For type number 74LVT16244BBX and 74LVTH16244BBX the sot code has changed to SOT1134-2. - 74LVT_LVTH16244B v.9 Product data sheet - 74LVT_LVTH16244B v.8 Product data sheet - 74LVT_LVTH16244B v.7 20090326 Product data sheet - 74LVT_LVTH16244B v.6 74LVT_LVTH16244B v.6 20081113 Product data sheet - 74LVT_LVTH16244B v.5 74LVT_LVTH16244B v.5 20060321 Product data sheet - 74LVT16244B v.4 74LVT16244B v.4 20021031 Product specification - 74LVT16244B v.3 74LVT16244B v.3 19981007 Product specification - 74LVT16244B v.2 74LVT16244B v.2 19980219 Product specification - - 74LVT_LVTH16244B Product data sheet Product data sheet Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 11 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVT_LVTH16244B Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 12 / 13 74LVT16244B; 74LVTH16244B Nexperia 3.3 V 16-bit buffer/driver; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 7 11. Package outline.......................................................... 9 12. Abbreviations............................................................ 11 13. Revision history........................................................11 14. Legal information......................................................12 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 October 2018 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 19 October 2018 © Nexperia B.V. 2018. All rights reserved 13 / 13 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVT16244BDGG,112 74LVT16244BDGG,118 74LVTH16244BDGG,11 74LVT16244BBX,518 74LVTH16244BBX,518 74LVT16244BDGG,518 74LVT16244BDL,112 74LVT16244BDL,118 74LVT16244BEV,157 74LVT16244BEV/G,55 74LVT16244BEV/G:55 74LVT16244BEV/G,51 74LVT16244BEV,151 74LVT16244BEV,118 74LVTH16244BDL,112 74LVTH16244BDL,118 74LVTH16244BDGG,18 74LVT16244BEV,518 74LVT16244BEVE 74LVT16244BEVK
74LVT16244BDL,118 价格&库存
很抱歉,暂时无法提供与“74LVT16244BDL,118”相匹配的价格&库存,您可以联系我们找货
