74LVT2245PW,112
74LVT2245PW,112
    NEXPERIA(安世)
    TSSOP-20
    TSSOP20 2.7-3.6V
74LVT2245PW,112 数据手册
74LVT2245; 74LVTH2245 3.3 V octal transceiver with 30 Ω termination resistors; 3-state Rev. 5 — 10 April 2017 1 Product data sheet General description The 74LVT2245; 74LVTH2245 is a high-performance BiCMOS product designed for VCC operation at 3.3 V. This device is an octal transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The control function implementation minimizes external timing requirements. The device features an output enable input (OE) for easy cascading and a direction input (DIR) for direction control. The 74LVT2245; 74LVTH2245 is designed with 30 Ω series resistance in both the HIGHstate and LOW-state of the output. This design reduces line noise in applications such as memory address drivers, clock drivers and bus transceivers and transmitters. 2 Features and benefits • • • • • • • • • • • 30 Ω output termination resistors Octal bidirectional bus interface 3-state buffers Output capability: +12 mA and -12 mA TTL input and output switching levels Input and output interface capability to systems at 5 V supply Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs Live insertion and extraction permitted Power-up 3-state No bus current loading when output is tied to 5 V bus Latch-up protection: – JESD78: exceeds 500 mA • ESD protection: – MIL STD 883 method 3015: exceeds 2000 V – MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state 3 Ordering information Table 1. Ordering information Type number 74LVT2245D Package Temperature range Name Description Version -40 °C to +85 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 -40 °C to +85 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 -40 °C to +85 °C TSSOP20 plastic thin shrink small outline package; 20 leads; SOT360-1 body width 4.4 mm 74LVTH2245D 74LVT2245DB 74LVTH2245DB 74LVT2245PW 74LVTH2245PW 4 Functional diagram DIR 1 19 A0 2 A1 3 A2 A3 A4 A5 A6 A7 18 17 4 16 5 15 6 14 7 13 8 12 9 11 OE B0 B1 74LVT_LVTH2245 Product data sheet 1 G3 3 EN1 (BA) VCC 3 EN2 (AB) VCC B2 2 B3 B4 B5 B6 B7 mna817 Figure 1. Logic symbol 19 3 18 1 2 17 4 16 5 15 6 14 7 13 8 12 9 11 mna818 Figure 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 25 Ω 25 Ω mna819 Figure 3. Schematic of one output © Nexperia B.V. 2017. All rights reserved. 2 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state 5 Pinning information 5.1 Pinning 74LVT2245 74LVTH2245 74LVT2245 75LVTH2245 DIR 1 20 VCC DIR 1 20 VCC A0 2 19 OE A0 2 19 OE A1 3 18 B0 A1 3 18 B0 A2 4 17 B1 A2 4 17 B1 A3 5 16 B2 A3 5 16 B2 A4 6 15 B3 A4 6 15 B3 A5 7 14 B4 A5 7 14 B4 A6 8 13 B5 A6 8 13 B5 A7 9 12 B6 A7 9 12 B6 GND 10 11 B7 GND 10 11 B7 aaa-026622 001aae465 Figure 4. Pin configuration for SO20 Figure 5. Pin configuration for SSOP20 and TSSOP20 5.2 Pin description Table 2. Pin description Symbol Pin Description DIR 1 direction control input A0, A1, A2, A3, A4, A5, A6, A7 2, 3, 4, 5, 6, 7, 8, 9 data input/output GND 10 ground (0 V) B7, B6, B5, B4, B3, B2, B1, B0 11, 12, 13, 14, 15, 16, 17, 18 data input/output OE 19 output enable input VCC 20 supply voltage 6 Functional description Table 3. Function table [1] Control Input/output OE DIR An Bn L L output An = Bn input L H input output Bn = An H X Z Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 74LVT_LVTH2245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions supply voltage Min Max Unit -0.5 +4.6 V input voltage [1] -0.5 +7.0 V VO output voltage output in OFF-state or HIGH-state [1] -0.5 +7.0 V IIK input clamping current VI < 0 V -50 - mA IOK output clamping current VO < 0 V -50 - mA IO output current output in LOW-state - 128 mA output in HIGH-state -64 - mA -65 +150 °C - 150 °C 500 mW VI Tstg storage temperature Tj Ptot [1] [2] [3] junction temperature [2] total power dissipation [3] Tamb = -40 to +85 °C The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. For SO20 package: above 70 °C derate linearly with 8 mW/K. For (T)SSOP20 package: above 60 °C derate linearly with 5.5 mW/K. 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit 2.7 - 3.6 V 0 - 5.5 V VCC supply voltage VI input voltage IOH HIGH-level output current -12 - - mA IOL LOW-level output current - - 12 mA Δt/ΔV input transition rise and fall rate outputs enabled - - 10 ns/V Tamb ambient temperature in free-air -40 +25 +85 °C 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter [1] Conditions Min Typ Max Unit VCC = 2.7 V; IIK = -18 mA -1.2 -0.9 - V Tamb = -40 °C to +85 °C VIK input clamping voltage VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V VOH HIGH-level output voltage 2.0 2.2 - V 74LVT_LVTH2245 Product data sheet VCC = 3.0 V; IOH = -12 mA All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state Symbol Parameter Conditions VOL LOW-level output voltage VCC = 3.0 V; IOL = 12 mA II input leakage current control pins [1] Min Typ - - 0.8 V - 1 10 μA - ±0.1 ±1 μA VI = 5.5 V - 1 20 μA VI = VCC - 0.1 1 μA VI = 0 V - -1 -5 μA - 1 75 150 - μA VCC = 0 V or 3.6 V; VI = 5.5 V VCC = 3.6 V; VI = VCC or GND I/O data pins; VCC = 3.6 V IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V IBHL bus hold LOW current VCC = 3 V; VI = 0.8 V IBHH bus hold HIGH current VCC = 3 V; VI = 2.0 V IBHLO bus hold LOW overdrive current Max Unit [2] ±100 μA - -150 -75 μA VCC = 0 V to 3.6 V; VI = 3.6 V [3] - - 500 μA [3] -500 - - μA - 60 125 μA - 15 ±100 μA - 0.13 0.19 mA IBHHO bus hold HIGH overdrive current VCC = 0 V to 3.6 V; VI = 3.6 V ICEX output high leakage current output in HIGH-state when VO > VCC; VO = 5.5 V; VCC = 3.0 V IO(pu/pd) power-up/power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; OE = don’t care ICC supply current [4] VCC = 3.6 V; VI = GND or VCC; IO = 0 A outputs HIGH outputs LOW outputs disabled - 3 12 mA [5] - 0.13 0.19 mA [6] - 0.1 0.2 mA ΔICC additional supply current per input pin; VCC = 3 V to 3.6 V; one input at VCC - 0.6 V; other inputs at VCC or GND CI input capacitance DIR and OE; VI = 0 V or 3.0 V - 4 - pF CI/O input/output capacitance An and Bn; outputs disabled; VI/O = 0 V or 3.0 V - 10 - pF [1] [2] [3] [4] [5] [6] Typical values are measured at VCC = 3.3 V and Tamb = 25 °C. Unused pins at VCC or GND. This is the bus hold overdrive current required to force the input to the opposite logic state. This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.0 V to 3.6 V a transition time of 100 μs is permitted. ICC is measured with outputs pulled to VCC or GND. This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 74LVT_LVTH2245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8. Symbol Parameter Conditions Min Typ [1] Max Unit Tamb = -40 °C to +85 °C tPLH LOW to HIGH propagation delay An to Bn or Bn to An; see Figure 6 VCC = 2.7 V VCC = 3.0 V to 3.6 V tPHL HIGH to LOW propagation delay tPZL tPHZ tPLZ [1] - 5.3 ns 1.0 3.2 4.6 ns - - 4.9 ns 1.0 3.1 4.5 ns - - 9.1 ns 1.1 4.5 7.0 ns - - 7.6 ns 1.5 4.3 6.5 ns - - 5.6 ns 2.2 3.7 5.2 ns - - 5.0 ns 2.0 3.6 5.0 ns An to Bn or Bn to An; see Figure 6 VCC = 2.7 V VCC = 3.0 V to 3.6 V tPZH - OFF-state to HIGH propagation delay see Figure 7 OFF-state to LOW propagation delay see Figure 7 HIGH to OFF-state propagation delay see Figure 7 LOW to OFF-state propagation delay see Figure 7 VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 2.7 V VCC = 3.0 V to 3.6 V Typical values are measured at VCC = 3.3 V and Tamb = 25 °C. 74LVT_LVTH2245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state 10.1 Waveforms and test circuit VI An or Bn input VM GND t PLH t PHL VOH Bn or An output VM VOL mna820 VM = 1.5 V VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. Input (An or Bn) to output (Bn or An) propagation delays 2.7 V OE input 1.5 V 0V tPZL tPLZ 3.0 V 1.5 V An or Bn output VOL tPZH VOL + 0.3 V tPHZ VOH Bn or An output 1.5 V VOH - 0.3 V 0V mna821 VOL and VOH are typical voltage output levels that occur with the output load. Figure 7. 3-state output enable and disable times 74LVT_LVTH2245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state VI negative pulse tW 90 % VM VM 10 % 0V tf tr VI positive pulse 0V tr tf 90 % VM VM 10 % tW VEXT VDD G VI RL VO DUT RT CL RL 001aai546 Test data is given in Table 8. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Figure 8. Test circuit for measuring switching times Table 8. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.7 V ≤ 10 MHz 500 ns ≤ 2.5 ns 50 pF 500 Ω GND 6V open 74LVT_LVTH2245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state 11 Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 0.043 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 9. Package outline SOT163-1 (SO20) 74LVT_LVTH2245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm D SOT339-1 E A X c HE y v M A Z 20 11 Q A2 pin 1 index A (A 3) A1 θ Lp L 1 10 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 7.4 7.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.9 0.5 8o 0o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT339-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 10. Package outline SOT339-1 (SSOP20) 74LVT_LVTH2245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 11. Package outline SOT360-1 (TSSOP20) 74LVT_LVTH2245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state 12 Abbreviations Table 9. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 13 Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVT_LVTH2245 v.5 20170410 Product data sheet - 74LVT_LVTH2245 v.4 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74LVT_LVTH2245 v.4 20060424 Modifications: • Text changes have been made to the parameter descriptions of tPLH and tPHL in the Quick reference and Dynamic characteristics tables. 74LVT_LVTH2245 v.3 20060323 Product data sheet - 74LVT2245 v.2 74LVT2245 v.2 19980219 Product specification - 74LVT2245 v.1 74LVT2245 v.1 19960311 Product specification - - 74LVT_LVTH2245 Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 74LVT_LVTH2245 v.3 © Nexperia B.V. 2017. All rights reserved. 12 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVT_LVTH2245 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVT_LVTH2245 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 April 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 15 74LVT2245; 74LVTH2245 Nexperia 3.3 V octal transceiver with 30 Ω termination resistors; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 4 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 7 Package outline ...................................................9 Abbreviations .................................................... 12 Revision history ................................................ 12 Legal information .............................................. 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 April 2017 Document identifier: 74LVT_LVTH2245 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVT2245D,112 74LVT2245DB,112 74LVT2245DB,118 74LVT2245D,118 74LVT2245PW,112 74LVT2245PW,118 74LVTH2245D,112 74LVTH2245DB,112 74LVTH2245DB,118 74LVTH2245D,118 74LVTH2245PW,112 74LVTH2245PW,118
74LVT2245PW,112
物料型号:74LVT2245; 74LVTH2245
器件简介: - 这些是高性能的双极互补金属氧化物半导体(BiCMOS)产品,设计用于3.3V的VCC操作。 - 该设备是一个八位收发器,具有在发送和接收方向上均为非反相3态总线兼容输出。
引脚分配: - 引脚包括DIR(方向控制输入)、A0-A7与B0-B7(数据输入/输出)、GND(地)、OE(输出使能输入)和VCC(供电电压)。
参数特性: - 设备在输出的高电平状态和低电平状态下都设计有30Ω串联电阻。 - 具有+12 mA和-12 mA的输出能力,以及TTL输入和输出切换电平。 - 能够在5V供电的系统中进行输入和输出接口。
功能详解: - 具有输出使能输入(OE)以便轻松级联。 - 方向输入(DIR)用于方向控制。 - 具有3态缓冲器,允许在输出被禁用时呈现高阻态。
应用信息: - 适用于内存地址驱动器、时钟驱动器和总线收发器等应用。
封装信息: - 提供多种封装选项,包括SO20、SSOP20和TSSOP20。
74LVT2245PW,112 价格&库存
很抱歉,暂时无法提供与“74LVT2245PW,112”相匹配的价格&库存,您可以联系我们找货
74LVT2245PW,112
    74LVT2245PW,112
      • 1+0.91606
      • 10+0.72728
      • 30+0.63299
      • 100+0.56214
      • 500+0.50555
      • 1000+0.47726
