74LVTH244APW-Q100J
74LVTH244APW-Q100J
    NEXPERIA(安世)
    TSSOP20_6.5X4.4MM
    IC BUF NON-INVERT 3.6V 20TSSOP
74LVTH244APW-Q100J 数据手册
74LVT244A-Q100; 74LVTH244A-Q100 3.3 V octal buffer/line driver; 3-state Rev. 1 — 22 April 2013 Product data sheet 1. General description The 74LVT244A-Q100; 74LVTH244A-Q100 is a high-performance BiCMOS product designed for VCC operation at 3.3 V. This device is an octal buffer that is ideal for driving bus lines. The device features two output enables (1OE, 2OE), each controlling four of the 3-state outputs. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 3) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 3)  Specified from 40 C to +85 C  Octal bus interface  3-state buffers  Output capability: +64 mA and 32 mA  TTL input and output switching levels  Input and output interface capability to systems at 5 V supply  Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs  Live insertion and extraction permitted  Power-up 3-state  No bus current loading when output is tied to 5 V bus  Latch-up protection  JESD78 Class II exceeds 500 mA  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 74LVT244A-Q100; 74LVTH244A-Q100 Nexperia 3.3 V octal buffer/line driver; 3-state 3. Ordering information Table 1. Ordering information Type number Package 74LVT244AD-Q100 Temperature range Name Description Version 40 C to +85 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +85 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 40 C to +85 C DHVQFN20 plastic dual in-line compatible thermal enhanced SOT764-1 very thin quad flat package; no leads; 20 terminals; body 2.5  4.5  0.85 mm 74LVTH244AD-Q100 74LVT244APW-Q100 74LVTH244APW-Q100 74LVT244ABQ-Q100 74LVTH244ABQ-Q100 4. Functional diagram 2 4 1A0 1Y0 1A1 1Y1 1A2 1Y2 1A3 1Y3 18 16 1 6 8 1 11 13 15 17 19 12 1OE 2A0 2A1 2A2 2A3 2Y0 2Y1 2Y2 2Y3 EN 14 9 2 18 4 16 6 14 8 12 19 7 5 EN 11 9 13 7 15 5 17 3 3 mna826 2OE mna825 Fig 1. Logic symbol 74LVT_LVTH244A_Q100 Product data sheet Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 April 2013 © Nexperia B.V. 2017. All rights reserved 2 of 15 74LVT244A-Q100; 74LVTH244A-Q100 Nexperia 3.3 V octal buffer/line driver; 3-state 5. Pinning information 5.1 Pinning 2( WHUPLQDO LQGH[DUHD  /97$4 /97+$4  9&& /97$4 /97+$4 $   2(
74LVTH244APW-Q100J 价格&库存
很抱歉,暂时无法提供与“74LVTH244APW-Q100J”相匹配的价格&库存,您可以联系我们找货
74LVTH244APW-Q100J
    • 1+1.81246
    • 10+1.43111
    • 30+1.26771
    • 100+1.06370
    • 500+0.97287
    • 1000+0.91844
    74LVTH244APW-Q100J
    • 1+5.294401+0.67430
    • 10+3.6851010+0.46930
    • 25+3.3002025+0.42030
    • 100+2.86880100+0.36540
    • 250+2.65880250+0.33860
    • 500+2.53060500+0.32230
    • 1000+2.437301000+0.31040
    • 2500+2.344002500+0.29850
    • 5000+2.309005000+0.29410
