74LVT162245BDGG:11
74LVT162245BDGG:11
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    IC TXRX NON-INVERT 3.6V 48TSSOP
74LVT162245BDGG:11 数据手册
74LVT162245B 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state Rev. 3 — 1 October 2018 Product data sheet 1. General description The 74LVT162245B is a high-performance BiCMOS product designed for VCC operation at 3.3 V. This device is a 16-bit transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The control function implementation minimizes external timing requirements. The device features an output enable input (nOE) for easy cascading and a direction input (nDIR) for direction control. The 74LVT162245B is designed with 30 Ω series resistance in both the HIGH-state and LOW-state of the output. This design reduces line noise in applications such as memory address drivers, clock drivers and bus transceivers and transmitters. 2. Features and benefits • • • • • • • • • • • • 16-bit bidirectional bus interface 3-state buffers Output capability: +12 mA/–12 mA TTL input and output switching levels Input and output interface capability to systems at 5 V supply Bus-hold data inputs eliminate the need for external pull-up resistors to hold unused inputs Live insertion/extraction permitted Outputs include series resistance of 30 Ω making external termination resistors unnecessary Power-up 3-state No bus current loading when output is tied to 5 V bus Latch-up protection: • JESD78B Class II exceeds 500 mA ESD protection: • HBM: JESD22-A114F exceeds 2000 V • MM: JESD22-A115-A exceeds 200 V 3. Ordering information Table 1. Ordering information Type number Package 74LVT162245BDL Temperature range Name Description Version -40 °C to +85 °C SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74LVT162245BDGG -40 °C to +85 °C 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state 4. Functional diagram 1 1DIR 2DIR 48 1A0 1A1 2A0 20 2A6 22 2A7 12 2B5 27 1B6 37 2B4 29 1B5 38 11 1A7 19 2A5 2B3 30 1B4 40 9 1A6 17 2A4 2B2 32 1B3 41 8 1A5 16 2A3 2B1 33 1B2 43 6 1A4 14 2A2 2B0 35 1B1 44 5 1A3 13 2A1 2OE 36 1B0 46 3 1A2 25 1OE 47 2 24 2B6 26 23 1B7 2B7 mna708 Fig. 1. Logic symbol 1OE 1DIR 48 1 25 2OE 24 2DIR 1A0 1A1 1A2 1A3 1A4 1A5 1A6 1A7 2A0 2A1 2A2 2A3 2A4 2A5 2A6 2A7 G3 3EN1 [BA] 3EN2 [AB] G6 6EN4 [BA] 6EN5 [AB] 47 2 1 2 46 3 44 5 43 6 41 8 40 9 38 11 37 12 36 13 4 35 5 14 33 16 32 17 30 19 29 20 27 22 26 23 1B0 1B1 1B2 1B3 VCC 1B4 1B5 1B6 1B7 2B0 2B1 27 Ω 2B2 output 2B3 27 Ω 2B4 2B5 2B6 2B7 001aac372 mna709 Fig. 2. IEC logic symbol 74LVT162245B Product data sheet VCC Fig. 3. Schematic of each output All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 2 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state 5. Pinning information 5.1. Pinning 74LVT162245B 1DIR 1 48 1OE 1B0 2 47 1A0 1B1 3 46 1A1 GND 4 45 GND 1B2 5 44 1A2 1B3 6 43 1A3 VCC 7 42 VCC 1B4 8 41 1A4 1B5 9 40 1A5 GND 10 39 GND 1B6 11 38 1A6 1B7 12 37 1A7 2B0 13 36 2A0 2B1 14 35 2A1 GND 15 34 GND 2B2 16 33 2A2 2B3 17 32 2A3 VCC 18 31 VCC 2B4 19 30 2A4 2B5 20 29 2A5 GND 21 28 GND 2B6 22 27 2A6 2B7 23 26 2A7 2DIR 24 25 2OE aaa-029123 Fig. 4. Pin configuration SOT370-1 (SSOP48) and SOT362-1 (TSSOP48) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1DIR, 2DIR 1, 24 direction control input 1A0, 1A1, 1A2, 1A3, 1A4, 1A5, 1A6, 1A7 47, 46, 44, 43, 41, 40, 38, 37 data input/output 2A0, 2A1, 2A2, 2A3, 2A4, 2A5, 2A6, 2A7 36, 35, 33, 32, 30, 29, 27, 26 data input/output GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) 1B0, 1B1, 1B2, 1B3, 1B4, 1B5, 1B6, 1B7 2, 3, 5, 6, 8, 9, 11, 12 data input/output 2B0, 2B1, 2B2, 2B3, 2B4, 2B5, 2B6, 2B7 13, 14, 16, 17, 19, 20, 22, 23 data input/output 1OE, 2OE 48, 25 output enable input VCC 7, 18, 31, 42 supply voltage 74LVT162245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 3 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Control Input/output nOE nDIR nAn nBn L L output nAn = nBn input L H input output nBn = nAn H X Z Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage output in OFF-state or HIGH-state IIK input clamping current IOK IO Min Max Unit -0.5 +4.6 V [1] -0.5 +7.0 V [1] -0.5 +7.0 V VI < 0 V -50 - mA output clamping current VO < 0 V -50 - mA output current output in LOW-state - 128 mA output in HIGH-state -64 - mA -65 +150 °C - 150 °C Tstg storage temperature Tj junction temperature [1] [2] Conditions [2] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. 8. Recommended operating conditions Table 5. Operating conditions Symbol Parameter Conditions VCC supply voltage VI input voltage Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate outputs enabled Min Typ Max Unit 2.7 - 3.6 V 0 - 5.5 V -40 - +85 °C - - 10 ns/V Min Typ[1] Max Unit - 0.8 -1.2 V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VIK input clamping voltage VCC = 2.7 V; IIK = -18 mA VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V 74LVT162245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 4 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state Symbol Parameter Conditions Min Typ[1] Max Unit VOH HIGH-level output voltage VCC = 3.0 V; IOH = -12 mA 2.0 2.5 - V VOL LOW-level output voltage VCC = 3.0 V; IOL = 12 mA - 0.3 0.8 V IOH HIGH-level output current - - -12 mA IOL LOW-level output current - - 12 mA II input leakage current VCC = 0 V or 3.6 V; VI = 5.5 V - 0.1 10 μA VCC = 3.6 V; VI = VCC or GND - 0.1 ±1 μA VI = VCC - 0.5 10 μA VI = 0 V - 0.1 -5 μA - 0.1 ±100 μA 75 130 - μA control pins I/O data pins; VCC = 3.6 V [2] IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V IBHL bus hold LOW current VCC = 3 V; VI = 0.8 V IBHH bus hold HIGH current VCC = 3 V; VI = 2.0 V -75 -130 - μA IBHLO bus hold LOW overdrive current VCC = 3.6 V; VI = 0 V to 3.6 V [3] 500 - - μA IBHHO bus hold HIGH overdrive current VCC = 3.6 V; VI = 0 V to 3.6 V [3] - - -500 μA ICEX output high leakage current output in HIGH-state when VO > VCC; VO = 5.5 V; VCC = 3.0 V - 75 125 μA IO(pu/pd) power-up/power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; nOE = don’t care - 40 ±100 μA IOZ OFF-state output current VCC = 3.6 V; VI = VIL or VIH output HIGH: VO = 3.0 V - 0.5 5 μA output LOW: VO = 0.5 V - 0.5 -5 μA outputs HIGH - 0.07 0.12 mA outputs LOW - 4.2 6 mA [5] - 0.07 0.12 mA [6] - 0.1 0.2 mA ICC supply current [4] VCC = 3.6 V; VI = GND or VCC; IO = 0 A outputs disabled ΔICC additional supply current per input pin; VCC = 3 V to 3.6 V; one input at VCC - 0.6 V and other inputs at VCC or GND CI input capacitance nDIR and nOE; VI = 0 V or 3.0 V - 3 - pF CI/O input/output capacitance VI/O = 0 V or 3.0 V - 9 - pF [1] [2] [3] [4] [5] [6] Typical values are measured at VCC = 3.3 V and Tamb = 25 °C. Unused pins at VCC or GND. This is the bus hold overdrive current required to force the input to the opposite logic state. This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only. Measured with outputs pulled to VCC or GND. This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 74LVT162245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 5 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7. Symbol Parameter Conditions tPLH LOW to HIGH propagation delay nAn to nBn or nBn to nAn; see Fig. 5 HIGH to LOW propagation delay nAn to nBn or nBn to nAn; see Fig. 5 OFF-state to HIGH propagation delay OFF-state to LOW propagation delay HIGH to OFF-state propagation delay LOW to OFF-state propagation delay 3.9 ns 1.0 2.5 3.5 ns - - 3.9 ns 1.0 2.2 3.5 ns - - 6.4 ns 1.5 3.5 5.3 ns - - 5.0 ns 1.5 3.2 4.4 ns - - 5.1 ns 1.5 3.5 4.8 ns - - 5.9 ns 1.5 4.3 6.7 ns VCC = 2.7 V nOE to nAn or nBn; see Fig. 6 VCC = 2.7 V nOE to nAn or nBn; see Fig. 6 VCC = 2.7 V VCC = 3.0 V to 3.6 V [1] - nOE to nAn or nBn; see Fig. 6 VCC = 3.0 V to 3.6 V tPLZ - VCC = 2.7 V VCC = 3.0 V to 3.6 V tPHZ Unit nOE to nAn or nBn; see Fig. 6 VCC = 3.0 V to 3.6 V tPZL Max VCC = 2.7 V VCC = 3.0 V to 3.6 V tPZH Typ[1] VCC = 2.7 V VCC = 3.0 V to 3.6 V tPHL Min Typical values are measured at VCC = 3.3 V and Tamb = 25 °C. 10.1. Waveforms and test circuit VI nAn, nBn input VM GND t PHL t PLH VOH nBn, nAn output VM VOL mna477 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 5. Input (An or Bn) to output (Bn or An) propagation delays 74LVT162245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 6 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state VI nOE input VM 0V tPZL tPLZ 3.0 V nAn or nBn output VM VX VOL tPHZ tPZH VOH VY nBn or nAn output VM 0V 001aaj658 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. 3-state output enable and disable times Table 8. Measurement points Input Output VI VM VM VX VY 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V VI negative pulse tW 90 % 90 % VM 0V tf tr tr tf VI positive pulse 0V VM 10 % VEXT VCC G 90 % VM VI VM 10 % DUT RT 10 % tW RL VO CL RL mna616 001aac221 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Fig. 7. Test circuit for measuring switching times Table 9. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.7 V ≤ 10 MHz 500 ns ≤ 2.5 ns 50 pF 500 Ω GND 6V open 74LVT162245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 7 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state 11. Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3 ) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 Fig. 8. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-118 Package outline SOT370-1 (SSOP48) 74LVT162245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 8 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit max nom min mm A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 Fig. 9. References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Package outline SOT362-1 (TSSOP48) 74LVT162245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 9 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge MIL Military MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVT162245B v.3 20181001 Product data sheet - 74LVT162245B v.2 Modifications: • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74LVT162245B v.2 19980219 Product specification - 74LVT162245B v.1 74LVT162245B v.1 19950822 Product specification - - 74LVT162245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 10 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVT162245B Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 11 / 12 74LVT162245B Nexperia 3.3 V 16-bit transceiver with 30 Ω termination resistors; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 6 11. Package outline.......................................................... 8 12. Abbreviations............................................................ 10 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 1 October 2018 74LVT162245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 October 2018 © Nexperia B.V. 2018. All rights reserved 12 / 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVT162245BDL 74LVT162245BDGG,11 74LVT162245BDGG:11 74LVT162245BDL,112 74LVT162245BDL,118
74LVT162245BDGG:11 价格&库存
很抱歉,暂时无法提供与“74LVT162245BDGG:11”相匹配的价格&库存,您可以联系我们找货
