74LVT16240A
3.3 V 16-bit inverting buffer/driver; 3-state
Rev. 4 — 1 October 2018
Product data sheet
1. General description
The 74LVT16240A is a high-performance BiCMOS product designed for VCC operation at 3.3 V.
This device is an inverting 16-bit buffer that is ideal for driving bus lines. The device features four
output enable inputs (1OE, 2OE, 3OE, 4OE), each controlling four of the 3-state outputs.
2. Features and benefits
16-bit bus interface
3-state buffers
Output capability: +64 mA/–32 mA
TTL input and output switching levels
Input and output interface capability to systems at 5 V supply
Bus-hold data inputs eliminate the need for external pull-up resistors to hold unused inputs
Live insertion/extraction permitted
Power-up 3-state
No bus current loading when output is tied to 5 V bus
Latch-up protection:
• JESD78B Class II exceeds 500 mA
ESD protection:
• HBM: JESD22-A114F exceeds 2000 V
• MM: JESD22-A115-A exceeds 200 V
3. Ordering information
Table 1. Ordering information
Type number
Package
74LVT16240ADGG
Temperature range Name
Description
Version
-40 °C to +85 °C
plastic thin shrink small outline package; 48 leads;
body width 6.1 mm
SOT362-1
TSSOP48
74LVT16240A
Nexperia
4. Functional diagram
47
46
44
43
1
1A0
1Y0
1A1
1Y1
1A2
1Y2
1A3
1Y3
2
41
3
40
5
38
6
1OE
37
48
2A0
2Y0
2A1
2Y1
2A2
2Y2
2A3
2Y3
8
9
11
1OE
2OE
25
3OE
24
4OE
12
2OE
1A0
1A1
1A2
36
35
3A0
3A1
3Y0
3Y1
13
14
30
29
4A0
4A1
4Y0
4Y1
1A3
19
2A0
2A1
2A2
2A3
33
3A2
3Y2
16
27
4A2
4Y2
3A0
22
3A1
3A2
32
3A3
3Y3
17
26
4A3
4Y3
3A3
23
4A0
4A1
25
Fig. 1.
3OE
Logic symbol
74LVT16240A
Product data sheet
24
1
48
4A2
4OE
4A3
aaa-029128
Fig. 2.
EN1
EN2
EN3
EN4
47
46
1
2
1
3
44
5
43
6
41
40
1
8
2
9
38
11
37
12
36
35
1
3
13
14
33
16
32
17
30
29
1
4
19
22
26
23
1Y0
1Y1
1Y2
1Y3
2Y0
2Y1
2Y2
2Y3
3Y0
3Y1
3Y2
3Y3
4Y0
4Y1
4Y2
4Y3
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 12
74LVT16240A
Nexperia
5. Pinning information
5.1. Pinning
74LVT16240A
1OE
1
48 2OE
1Y0
2
47 1A0
1Y1
3
46 1A1
GND
4
45 GND
1Y2
5
44 1A2
1Y3
6
43 1A3
VCC
7
42 VCC
2Y0
8
41 2A0
2Y1
9
40 2A1
GND 10
39 GND
2Y2 11
38 2A2
2Y3 12
37 2A3
3Y0 13
36 3A0
3Y1 14
35 3A1
GND 15
34 GND
3Y2 16
33 3A2
3Y3 17
32 3A3
VCC 18
31 VCC
4Y0 19
30 4A0
4Y1 20
29 4A1
GND 21
28 GND
4Y2 22
27 4A2
4Y3 23
26 4A3
4OE 24
25 3OE
aaa-029130
Fig. 3.
Pin configuration SOT362-1 (TSSOP48)
74LVT16240A
Product data sheet
3 / 12
74LVT16240A
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1OE, 2OE, 3OE, 4OE
1, 48, 25, 24
output enable inputs (active LOW)
1A0, 1A1, 1A2, 1A3
47, 46, 44, 43
data inputs
2A0, 2A1, 2A2, 2A3
41, 40, 38, 37
data inputs
3A0, 3A1, 3A2, 3A3
36, 35, 33, 32
data inputs
4A0, 4A1, 4A2, 4A3
30, 29, 27, 26
data inputs
1Y0, 1Y1, 1Y2, 1Y3
2, 3, 5, 6
data outputs
2Y0, 2Y1, 2Y2, 2Y3
8, 9, 11, 12
data outputs
3Y0, 3Y1, 3Y2, 3Y3
13, 14, 16, 17
data outputs
4Y0, 4Y1, 4Y2, 4Y3
19, 20, 22, 23
data outputs
GND
4, 10, 15, 21, 28, 34, 39, 45
ground (0 V)
VCC
7, 18, 31, 42
supply voltage
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Output
Input
nOE
nAn
nYn
L
L
H
L
H
L
H
X
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
output in OFF-state or HIGH-state
IIK
input clamping current
VI < 0 V
IOK
output clamping current
VO < 0 V
IO
output current
Tstg
storage temperature
Tj
junction temperature
[1]
[2]
Conditions
Min
Max
Unit
-0.5
+4.6
V
[1]
-0.5
+7.0
V
[1]
-0.5
+7.0
V
-50
mA
-50
mA
output in LOW-state
128
mA
output in HIGH-state
-64
mA
-65
+150
°C
+150
°C
[2]
The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
74LVT16240A
Product data sheet
4 / 12
74LVT16240A
Nexperia
8. Recommended operating conditions
Table 5. Operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
VI
input voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate outputs enabled
in free air
Min
Typ
Max
Unit
2.7
3.6
V
V
-40
+85
°C
10
ns/V
Min
Typ[1]
Max
Unit
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VIK
input clamping voltage
VCC = 2.7 V; IIK = -18 mA
-0.85
-1.2
V
VIH
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
VOH
HIGH-level output voltage VCC = 2.7 V to 3.6 V; IOH = -100 μA
VCC - 0.2
VCC
V
VCC = 2.7 V; IOH = -8 mA
2.4
2.5
V
VCC = 3.0 V; IOH = -32 mA
VOL
2.0
2.3
V
LOW-level output voltage VCC = 2.7 V; IOL = 100 μA
0.07
0.2
V
VCC = 2.7 V; IOL = 24 mA
0.3
0.5
V
VCC = 3.0 V; IOL = 16 mA
0.25
0.4
V
VCC = 3.0 V; IOL = 32 mA
0.3
0.5
V
VCC = 3.0 V; IOL = 64 mA
0.4
0.55
V
IOH
HIGH-level output current
-32
mA
IOL
LOW-level output current
32
mA
64
mA
0.4
10
μA
±0.1
±1
μA
1
μA
current duty cycle ≤ 50%; f ≥ 1kHz
II
input leakage current
all input pins
VCC = 0 V or 3.6 V; VI = 5.5 V
control pins
VCC = 3.6 V; VI = VCC or GND
data pins
[2]
0.1
VCC = 3.6 V; VI = 0 V
[2]
-0.4
-5
μA
0.1
±100
μA
IOFF
power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V
IBHL
bus hold LOW current
nAn input; VCC = 3 V; VI = 0.8 V
75
135
μA
IBHH
bus hold HIGH current
nAn input; VCC = 3 V; VI = 2.0 V
-75
-135
μA
IBHLO
bus hold LOW
overdrive current
nAn input; VCC = 3.6 V; VI = 0 V to 3.6 V
[3]
500
μA
IBHHO
bus hold HIGH
overdrive current
[3]
-500
μA
ICEX
output high leakage
current
output in HIGH-state when VO > VCC;
VO = 5.5 V; VCC = 3.0 V
50
125
μA
IO(pu/pd)
power-up/power-down
output current
VCC ≤ 1.2 V; VO = 0.5 V to VCC;
VI = GND or VCC; nOE = don’t care
1
±100
μA
74LVT16240A
Product data sheet
[4]
5 / 12
74LVT16240A
Nexperia
Symbol
Parameter
Conditions
IOZ
OFF-state output current
VCC = 3.6 V; VI = VIL or VIH
ICC
supply current
Min
Typ[1]
Max
Unit
output HIGH: VO = 3.0 V
0.5
5
μA
output LOW: VO = 0.5 V
0.5
-5
μA
outputs HIGH
0.07
0.12
mA
outputs LOW
4.0
6
mA
[5]
0.07
0.12
mA
[6]
0.1
0.2
mA
VCC = 3.6 V; VI = GND or VCC; IO = 0 A
outputs disabled
ΔICC
additional supply current
per input pin; VCC = 3 V to 3.6 V;
one input at VCC - 0.6 V and
other inputs at VCC or GND
CI
input capacitance
nOE; VI = 0 V or 3 V
3
pF
CO
output capacitance
Outputs disabled; VO = 0 V or 3.0 V
9
pF
[1]
[2]
[3]
[4]
[5]
[6]
All typical values are at VCC = 3.3 V and Tamb = 25 °C.
Unused pins at VCC or GND.
This is the bus hold overdrive current required to force the input to the opposite logic state.
This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.3 V ± 0.3
V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only.
Measured with outputs pulled up to VCC or GND.
This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
10. Dynamic characteristics
Table 7. Dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6.
Symbol
Parameter
Conditions
Min
tPLH
LOW to HIGH
propagation delay
nAn to nYn; see Fig. 4
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
tPHL
HIGH to LOW
propagation delay
OFF-state to HIGH
propagation delay
VCC = 2.7 V
VCC = 2.7 V
OFF-state to LOW
propagation delay
nOE to nYn; see Fig. 5
HIGH to OFF-state
propagation delay
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
tPHZ
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
tPLZ
LOW to OFF-state
propagation delay
4.0
ns
0.5
1.8
3.2
ns
4.0
ns
0.5
2.0
3.2
ns
5.0
ns
1.0
2.3
4.0
ns
4.8
ns
1.0
2.1
4.4
ns
5.0
ns
1.0
3.2
4.5
ns
4.8
ns
1.0
3.0
4.4
ns
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
[1]
Unit
VCC = 3.3 V ± 0.3 V
tPZL
Max
VCC = 3.3 V ± 0.3 V
tPZH
Typ[1]
Typical values are at VCC = 3.3 V and Tamb = 25 °C.
74LVT16240A
Product data sheet
6 / 12
74LVT16240A
Nexperia
10.1. Waveforms and test circuit
VI
nAn input
VM
VM
GND
tPHL
tPLH
VOH
VM
nYn output
VM
VOL
aaa-029131
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 4.
Input (nAn) to output (nYn) propagation delay
VI
VM
nOE input
GND
tPLZ
tPZL
3.0 V
nYn output
VM
VX
VOL
tPHZ
VOH
tPZH
VY
nYn output
VM
GND
aaa-028621
Fig. 5.
Enable and disable times of 3-state outputs
Table 8. Measurement points
Input
Output
VCC
VM
VM
VX
VY
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
74LVT16240A
Product data sheet
7 / 12
74LVT16240A
Nexperia
VI
negative
pulse
tW
90 %
90 %
VM
10 %
0V
tf
tr
tr
tf
VI
positive
pulse
0V
VM
VEXT
VCC
G
90 %
VM
VI
VM
10 %
DUT
RT
10 %
tW
RL
VO
CL
RL
mna616
001aac221
Test data is given in Table 9.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = Test voltage for switching times.
Fig. 6.
Test circuit for measuring switching times
Table 9. Test data
Input
Load
VEXT
VI
fi
tW
tr, tf
CL
RL
tPHZ, tPZH
tPLZ, tPZL
tPLH, tPHL
2.7 V
≤ 10 MHz
500 ns
≤ 2.5 ns
50 pF
500 Ω
GND
6V
open
74LVT16240A
Product data sheet
8 / 12
74LVT16240A
Nexperia
11. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
D
E
A
X
c
v
HE
y
A
Z
48
25
Q
A2
A1
(A3)
pin 1 index
A
θ
Lp
1
L
24
bp
e
detail X
w
5 mm
2.5
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A
1.2
A1
A2
0.15 1.05
0.05 0.85
A3
0.25
bp
c
D(1)
E(2)
0.28
0.2
12.6
6.2
0.17
0.1
12.4
6.0
e
HE
0.5
8.3
7.9
L
1
Lp
Q
0.8
0.50
0.4
0.35
v
w
0.25 0.08
y
0.1
Z
θ
0.8
8°
0.4
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT362-1
Fig. 7.
References
IEC
JEDEC
JEITA
sot362-1_po
European
projection
Issue date
03-02-19
13-08-05
MO-153
Package outline TSSOP48 (SOT362-1)
74LVT16240A
Product data sheet
9 / 12
74LVT16240A
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
BiCMOS
Bipolar Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVT16240A v.4
20181001
Product data sheet
74LVT16240A v.3
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74LVT16240ADL (SOT370-1) removed.
74LVT16240A v.3
20030221
Modifications:
74LVT16240A v.2
19980219
Product specification
74LVT16240A v.1
74LVT16240A v.1
19941215
74LVT16240A
Product data sheet
Product data sheet
74LVT16240A v.2
Table 1 corrected: removed ‘North America’ column.
Fig. 2 modified to correct pin names
10 / 12
74LVT16240A
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LVT16240A
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
11 / 12
74LVT16240A
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 4
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................5
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 7
11. Package outline.......................................................... 9
12. Abbreviations............................................................ 10
13. Revision history........................................................10
14. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 1 October 2018
74LVT16240A
Product data sheet
12 / 12
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVT16240ADL 74LVT16240ADGG,112 74LVT16240ADGG,118 74LVT16240ADL,112 74LVT16240ADL,118
