74LVT2241
3.3 V octal buffer/line driver with 30 Ω series termination
resistors; 3-state
Rev. 2 — 3 May 2018
1
Product data sheet
General description
The 74LVT2241 high-performance BiCMOS device combines low static and dynamic
power dissipation with high speed and high output drive.
This device is an octal buffer that is ideal for driving bus lines. The device features two
output enables (1OE, 2OE), each controlling four of the 3-state outputs.
The 74LVT2241 is designed with 30 Ω series resistance in both the HIGH-state and the
LOW-state of the output. This design reduces line noise in applications such as memory
address drivers, clock drivers and bus receivers/transmitters.
2
Features and benefits
Octal bus interface
3-state buffers
Output capability: +12 mA/–12 mA
TTL input and output switching levels
Input and output interface capability to systems at 5 V supply
Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs
Live insertion and extraction permitted
Outputs include series resistance of 30 Ω making external termination resistors
unnecessary
Power-up 3-state
No bus current loading when output is tied to 5 V bus
Latch-up protection
– JESD17 Class II exceeds 500 mA
ESD protection:
– HBM JESD22-A114E exceeds 2000 V
– MM JESD22-A115-A exceeds 200 V
74LVT2241
Nexperia
3.3 V octal buffer/line driver with 30 Ω series termination resistors; 3-state
3
Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVT2241D
-40 °C to +85 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
74LVT2241DB
-40 °C to +85 °C
SSOP20
plastic shrink small outline package; 20 leads;
body width 5.3 mm
SOT339-1
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74LVT2241PW -40 °C to +85 °C
4
Functional diagram
2
4
6
8
1
17
15
13
11
19
1A0
1Y0
1A1
1Y1
1A2
1Y2
1A3
1Y3
18
16
14
12
1
EN
1OE
2A0
2Y0
2A1
2Y1
2A2
2Y2
2A3
2Y3
3
2
18
4
16
6
14
8
12
5
19
7
9
2OE
EN
11
9
13
7
15
5
17
3
mna773
mna772
Figure 1. Logic symbol
74LVT2241
Product data sheet
Figure 2. IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Rev. 2 — 3 May 2018
© Nexperia B.V. 2018. All rights reserved.
2 / 17
74LVT2241
Nexperia
VCC
VCC
27 Ω
output
27 Ω
001aac372
Figure 3. Schematic of each output
5
Pinning information
5.1 Pinning
74LVT2241
74LVT2241
1OE
1
20 VCC
1OE
1
20 VCC
1A0
2
19 2OE
1A0
2
19 2OE
2Y0
3
18 1Y0
2Y0
3
18 1Y0
1A1
4
17 2A0
1A1
4
17 2A0
2Y1
5
16 1Y1
2Y1
5
16 1Y1
1A2
6
15 2A1
1A2
6
15 2A1
2Y2
7
14 1Y2
2Y2
7
14 1Y2
1A3
8
13 2A2
1A3
8
13 2A2
2Y3
9
12 1Y3
2Y3
9
12 1Y3
GND 10
11 2A3
GND 10
11 2A3
aaa-028519
Figure 4. Pin configuration for SO20
74LVT2241
Product data sheet
aaa-028520
Figure 5. Pin configuration for (T)SSOP20
Rev. 2 — 3 May 2018
3 / 17
74LVT2241
Nexperia
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
1OE
1
output enable input (active LOW)
1A0, 1A1, 1A2, 1A3
2, 4, 6, 8
data input
2A0, 2A1, 2A2, 2A3
17, 15, 13, 11
data input
GND
10
ground (0 V)
1Y0, 1Y1, 1Y2, 1Y3
18, 16, 14, 12
data output
2Y0, 2Y1, 2Y2, 2Y3
3, 5, 7, 9
data output
2OE
19
output enable input (active HIGH)
VCC
supply voltage
6
Functional description
Table 3. Function table
[1]
Enable active LOW
Enable active HIGH
Inputs
Outputs
Inputs
Outputs
1OE
1An
1Yn
2OE
2An
2Yn
L
L
L
H
L
L
L
H
H
H
H
H
H
X
Z
L
X
Z
[1] H = HIGH voltage level;
L = LOW voltage level;
X = Don’t care;
Z = High impedance "OFF" state.
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
4 / 17
74LVT2241
Nexperia
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
-0.5
+4.6
V
input voltage
[1]
-0.5
+7.0
V
VO
output voltage
output in OFF or HIGH state
[1]
-0.5
+7.0
V
IIK
input clamping current
VI < 0 V
-50
mA
IOK
output clamping current
VO < 0 V
-50
mA
IO
output current
output in LOW state
128
mA
output in HIGH state
-64
mA
-65
+150
°C
+150
°C
VI
Tstg
storage temperature
Tj
[2]
junction temperature
[1] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
[2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are
detrimental to reliability.
8
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
IOH
Min
Max
Unit
2.7
3.6
V
V
HIGH-level output current
-12
mA
IOL
LOW-level output current
12
mA
Tamb
ambient temperature
in free air
-40
+85
°C
Δt/ΔV
input transition rise and fall rate
outputs enabled
10
ns/V
9
Conditions
Static characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
[1]
Symbol
Parameter
Conditions
Min
VIK
input clamping voltage
VCC = 2.7 V; IIK = –18 mA
-1.2
-0.9
V
VIH
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
VOH
HIGH-level output voltage
VCC = 3.0 V; IOH = -12 mA
2.0
2.2
V
VOL
LOW-level output voltage
VCC = 3.0 V; IOL = 12 mA
0.8
V
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
Typ
Max
Unit
5 / 17
74LVT2241
Nexperia
Symbol
Parameter
Conditions
Min
II
input leakage current
all input pins
VCC = 0 V or 3.6 V; VI = 5.5 V
[1]
Typ
Max
Unit
1
10
μA
±0.1
±1
μA
VCC = 3.6 V; VI = VCC
0.1
1
μA
VCC = 3.6 V; VI = 0 V
-5
-1
μA
1
±100
μA
75
150
μA
control pins
VCC = 3.6 V; VI = VCC or GND
[2]
data pins
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 0 V to 4.5 V
IBHL
bus hold LOW current
VCC = 3.0 V; VI = 0.8 V
IBHH
bus hold HIGH current
VCC = 3.0 V; VI = 2.0 V
-150
-75
μA
500
μA
-500
μA
60
125
μA
±1
±100
μA
IBHLO
bus hold LOW overdrive
current
VCC = 3.6 V; VI = 0 V to 3.6 V
[3]
IBHHO
bus hold HIGH overdrive
current
[3]
IEX
external current
nYn output in HIGH-state when VO > VCC;
VO = 5.5 V; VCC = 3.0 V
IO(pu/pd)
power-up/power-down
output current
VCC ≤ 1.2 V; VO = 0.5 V to VCC;
VI = GND or VCC; 1OE, 2OE = don’t care
IOZ
OFF-state output current
VCC = 3.6 V; VO = 3.0 V
1
5
μA
VCC = 3.6 V; VO = 0.5 V
-5
-1
μA
0.12
0.19
mA
ICC
supply current
[4]
VCC = 3.6 V; VI = VCC or GND; IO = 0 A
outputs HIGH
outputs LOW
outputs disabled
3
12
mA
[5]
0.12
0.19
mA
[6]
0.1
0.25
mA
ΔICC
additional supply current
per input pin; VCC = 3.0 V to 3.6 V;
one input = VCC - 0.6 V;
other inputs at VCC or GND
CI
input capacitance
VI = 0 V or 3.0 V
4
pF
CO
output capacitance
outputs disabled; VO = 0 V or 3.0 V
8
pF
[1]
[2]
[3]
[4]
All typical values are measured at Tamb = 25 °C.
Unused pins at VCC or GND.
This is the bus hold overdrive current required to force the input to the opposite logic state.
This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms.
From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V a transition time of 100 ms is permitted. This parameter is valid for Tamb = +25 °C only.
[5] ICC with the outputs disabled is measured with outputs pulled to VCC or GND.
[6] This is the increase in supply current for each input at VCC - 0.6 V.
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
6 / 17
74LVT2241
Nexperia
10 Dynamic characteristics
Table 7. Dynamic characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 9.
Symbol
Parameter
Conditions
Min
tPLH
LOW to HIGH
propagation delay
1An to 1Yn, 2An to 2Yn; see Figure 6
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
tPHL
HIGH to LOW
propagation delay
OFF-state to HIGH
propagation delay
Max
Unit
5.0
ns
1.0
3.0
4.2
ns
4.7
ns
1.0
3.3
4.3
ns
8.5
ns
1.0
4.4
6.2
ns
7.9
ns
1.0
4.4
6.2
ns
6.8
ns
1.0
4.3
5.9
ns
6.2
ns
1.0
4.1
5.5
ns
5.2
ns
1.0
3.4
5.0
ns
6.4
ns
1.0
3.9
5.7
ns
4.5
ns
1.6
3.2
4.5
ns
5.8
ns
1.0
3.8
5.1
ns
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
tPZH
[1]
Typ
1OE to 1Yn; see Figure 7
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
2OE to 2Yn; see Figure 8
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
tPZL
OFF-state to LOW
propagation delay
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
tPHZ
HIGH to OFF-state
propagation delay
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
tPLZ
LOW to OFF-state
propagation delay
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
VCC = 2.7 V
VCC = 3.3 V ± 0.3 V
[1] Typical values are measured at Tamb = 25 °C and VCC = 3.3 V.
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
7 / 17
74LVT2241
Nexperia
10.1 Waveforms and test circuit
VI
VM
1An, 2An input
GND
tPHL
tPLH
VOH
VM
1Yn, 2Yn output
VOL
mna774
See Table 8 for measurement points.
VOL and VOH are typical output voltage levels that occur with the output load.
Figure 6. Input (1An, 2An) to output (1Yn, 2Yn) propagation delays
VI
1OE input
VM
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
3.0 V
VM
VX
VOL
tPZH
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aah813
Figure 7. 3-state output (1Yn) enable and disable times
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
8 / 17
74LVT2241
Nexperia
VI
2OE input
VM
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
3.0 V
VM
VX
VOL
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aah814
Figure 8. 3-state output (2Yn) enable and disable times
Table 8. Measurement points
Input
Output
VM
VM
VX
VY
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
9 / 17
74LVT2241
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VDD
G
VI
RL
VO
DUT
RT
CL
RL
001aai546
Test data is given in Table 9.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 9. Test circuit for measuring switching times
Table 9. Test data
Input
Load
VEXT
VI
fi
tW
tr, tf
RL
CL
tPHZ, tPZH
tPLZ, tPZL
tPLH, tPHL
2.7 V
≤ 10 MHz
500 ns
≤ 2.5 ns
500 Ω
50 pF
GND
6V
open
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
10 / 17
74LVT2241
Nexperia
11 Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
y
HE
v M A
Z
Q
A2
A
(A 3 )
A1
pin 1 index
θ
Lp
L
1
10
e
bp
detail X
w M
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.9
0.4
inches
0.1
0.012 0.096
0.004 0.089
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
0.043
0.039
0.01
0.01
0.004
0.035
0.016
Z
(1)
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Figure 10. Package outline SOT163-1 (SO20)
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
11 / 17
74LVT2241
Nexperia
SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm
D
SOT339-1
E
A
X
c
HE
y
v M A
Z
Q
A2
pin 1 index
A
(A 3)
A1
θ
Lp
L
1
10
bp
e
detail X
w M
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
7.4
7.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
0.9
0.5
8o
0o
Note
1. Plastic or metal protrusions of 0.2 mm maximum per side are not included.
OUTLINE
VERSION
SOT339-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Figure 11. Package outline SOT339-1 (SSOP20)
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
12 / 17
74LVT2241
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
D
SOT360-1
E
A
X
c
HE
y
v M A
Z
11
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
10
detail X
w M
bp
e
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Figure 12. Package outline SOT360-1 (TSSOP20)
74LVT2241
Product data sheet
Rev. 2 — 3 May 2018
13 / 17
74LVT2241
Nexperia
12 Abbreviations
Table 10. Abbreviations
Acronym
Description
BiCMOS
Bipolar Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13 Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVT2241 v.2
20180503
Product data sheet
74LVT2241 v.1
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
74LVT2241 v.1
19960529
74LVT2241
Product data sheet
Product specification
Rev. 2 — 3 May 2018
14 / 17
74LVT2241
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74LVT2241
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Rev. 2 — 3 May 2018
15 / 17
74LVT2241
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74LVT2241
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Rev. 2 — 3 May 2018
16 / 17
74LVT2241
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 4
Functional description ........................................4
Limiting values .................................................... 5
Recommended operating conditions ................ 5
Static characteristics .......................................... 5
Dynamic characteristics .....................................7
Waveforms and test circuit ................................ 8
Package outline .................................................11
Abbreviations .................................................... 14
Revision history ................................................ 14
Legal information .............................................. 15
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 3 May 2018
Document identifier: 74LVT2241
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVT2241D,112 74LVT2241DB,112 74LVT2241DB,118 74LVT2241D,118 74LVT2241PW,112
74LVT2241PW,118
