74LVT2244
3.3 V octal buffer/line driver with 30 termination resistors;
3-state
Rev. 3 — 1 September 2016
Product data sheet
1. General description
The 74LVT2244 is a high-performance BiCMOS product designed for VCC operation at
3.3 V.
This device is an octal buffer that is ideal for driving bus lines. The device features two
output enables (1OE, 2OE), each controlling four of the 3-state outputs.
The 74LVT2244 is designed with 30 series resistance in both the HIGH and LOW states
of the output. This design reduces line noise in applications such as memory address
drivers, clock drivers, and bus receivers/transmitters.
2. Features and benefits
Octal bus interface
3-state buffers
Output capability: +12 mA and 12 mA
TTL input and output switching levels
Input and output interface capability to systems at 5 V supply
Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs
Power-up 3-state
Live insertion and extraction permitted
No bus current loading when output is tied to 5 V bus
Latch-up protection
JESD78 Class II exceeds 500 mA
ESD protection:
HBM JESD22-A114E exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
74LVT2244D
40 C to +85 C
SO20
plastic small outline package; 20 leads; body width 7.5 mm SOT163-1
74LVT2244DB
40 C to +85 C
SSOP20
plastic shrink small outline package; 20 leads;
body width 5.3 mm
74LVT2244PW 40 C to +85 C
TSSOP20 plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
Version
SOT339-1
SOT360-1
74LVT2244
Nexperia
3.3 V octal buffer/line driver with 30 termination resistors; 3-state
4. Functional diagram
很抱歉,暂时无法提供与“74LVT2244PW,112”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.95243
- 10+1.54160
- 30+1.36556
- 100+1.14588
- 500+1.04804
- 1000+0.98928
