74LVT245BPW,112
74LVT245BPW,112
    NEXPERIA(安世)
    TSSOP20_6.6X4.5MM
    TSSOP20 2.7-3.6V
74LVT245BPW,112 数据手册
74LVT245B 3.3 V octal transceiver with direction pin (3-state) Rev. 02 — 8 May 2008 Product data sheet 1. General description The 74LVT245B is a high-performance BiCMOS product designed for VCC operation at 3.3 V. This device is an octal transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The control function implementation minimizes external timing requirements. The device features an output enable (OE) input for easy cascading and a direction (DIR) input for direction control. 2. Features n n n n n n n n n n n 3-state buffers Octal bidirectional bus interface Input and output interface capability to systems at 5 V supply TTL input and output switching levels Output capability: +64 mA/−32 mA Latch-up protection exceeds 500 mA per JEDEC Std 17 ESD protection: u HBM JESD22-A114E exceeds 2000 V u MM JESD22-A115-A exceeds 200 V Bus-hold data inputs eliminate the need for external pull-up resistors for unused inputs Live insertion/extraction permitted Power-up 3-state No bus current loading when output is tied to 5 V bus 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVT245BD −40 °C to +85 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74LVT245BDB −40 °C to +85 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74LVT245BPW −40 °C to +85 °C 74LVT245BBQ −40 °C to +85 °C DHVQFN20 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 × 4.5 × 0.85 mm SOT764-1 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) 4. Functional diagram 1 DIR OE 2 B0 3 19 3EN1 3EN2 1 14 3 17 13 4 16 5 15 6 14 7 13 8 12 A6 12 A7 B7 11 9 mna174 Fig 1. 18 2 A5 B6 9 G3 2 B5 8 15 A4 B4 7 1 16 A3 B3 6 17 A2 B2 5 18 A1 B1 4 19 A0 Logic diagram Fig 2. IEC logic symbol © 74LVT245B_2 Product data sheet 11 mna175 Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 2 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) 5. Pinning information 5.1 Pinning 1 terminal 1 index area 20 VCC DIR 74LVT245B A0 2 19 OE A1 3 18 B0 A2 4 17 B1 DIR 1 A0 2 20 VCC 19 OE A1 3 18 B0 A3 5 16 B2 A2 4 17 B1 A4 6 15 B3 A3 5 16 B2 A5 7 A4 6 A6 8 A5 7 14 B4 A6 8 13 B5 A7 9 A7 9 12 B6 GND 10 11 B7 14 B4 GND(1) 13 B5 12 B6 B7 11 15 B3 GND 10 74LVT245B 001aah724 Transparent top view 001aah723 (1) The die substrate is attached to this pad using conductive die attach material. It can not be used as a supply pin or input. Fig 3. Pin configuration for SO20 and (T)SSOP20 Fig 4. Pin configuration for DHVQFN20 5.2 Pin description Table 2. Pin description Symbol Pin Description DIR 1 direction control A0 to A7 2, 3, 4, 5, 6, 7, 8, 9 data input/output GND 10 ground (0 V) B0 to B7 18, 17, 16, 15, 14, 13, 12, 11 data input/output OE 19 output enable input (active LOW) VCC 20 supply voltage © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 3 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) 6. Functional description Table 3. Function selection Inputs Inputs/outputs OE DIR An Bn L L An = Bn inputs L H inputs Bn = An H X Z Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).[1][2] Symbol Parameter VCC supply voltage Conditions Min Max Unit −0.5 +4.6 V [3] −0.5 +7.0 V [3] −0.5 +7.0 V VI input voltage VO output voltage output in OFF or HIGH state IIK input clamping current VI < 0 −50 - mA IOK output clamping current VO < 0 −50 - mA IO output current output in LOW state - 128 mA output in HIGH state −64 - mA −65 +150 °C [2] - 150 °C [4] - 500 mW storage temperature Tstg junction temperature Tj total power dissipation Ptot Tamb = −40 °C to +85 °C [1] Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 °C. [3] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. [4] For SO20 packages: above 70 °C derate linearly with 8 mW/K. For SSOP20 and TSSOP20 packages: above 60 °C derate linearly with 5.5 mW/K. For DHVQFN20 packages: above 60 °C derate linearly with 4.5 mW/K. © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 4 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC supply voltage 2.7 3.6 V VI input voltage 0 5.5 V IOH HIGH-level output current - −32 mA IOL LOW-level output current - 32 mA current duty cycle ≤ 50 %; fi ≥ 1 kHz - 64 mA Tamb ambient temperature in free air −40 +85 °C ∆t/∆V input transition rise and fall rate output enabled 0 10 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter −40 °C to +85 °C Conditions VCC = 2.7 V; IIK = −18 mA Unit Min Typ[1] Max −1.2 −0.9 - V V VIK input clamping voltage VIH HIGH-level input voltage 2.0 - - VIL LOW-level input voltage - - 0.8 VOH HIGH-level output voltage VOL II LOW-level output voltage input leakage current VCC = 2.7 V to 3.6 V; IOH = −100 µA VCC − 0.2 VCC − 0.1 - V VCC = 2.7 V; IOH = −8 mA 2.4 2.5 VCC = 3.0 V; IOH = −32 mA 2.0 2.2 - V 0.1 0.2 V VCC = 2.7 V; IOL = 100 µA - VCC = 2.7 V; IOL = 24 mA - 0.3 0.5 V VCC = 3.0 V; IOL = 16 mA - 0.25 0.4 V VCC = 3.0 V; IOL = 32 mA - 0.3 0.5 V VCC = 3.0 V; IOL = 64 mA - 0.4 0.55 V - 1 10 µA - ±0.1 ±1 µA VCC = 3.6 V; VI = 5.5 V - 1 20 µA VCC = 3.6 V; VI = VCC - 0.1 1 µA VCC = 3.6 V; VI = 0 V −5 −1 - µA - 1 ±100 µA control pins VCC = 0 V or 3.6 V; VI = 5.5 V VCC = 3.6 V; VI = VCC or GND [2] I/O data pins IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V ILO output leakage current VO = 5.5 V; VCC = 3.6 V; output HIGH IO(pu/pd) power-up/power-down output current IBHL µA - 60 125 VCC ≤ 1.2 V VO = 0.5 V to VCC; VI = GND or VCC; OE = don’t care [3] - 15 ±100 µA bus hold LOW current VCC = 3.0 V; VI = 0.8 V [4] 75 150 - µA IBHH bus hold HIGH current VCC = 3.0 V; VI = 2.0 V −150 −75 - µA IBHLO bus hold LOW overdrive current VCC = 0 V to 3.0 V; VI = 3.6 V 500 - - µA © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 5 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) Table 6. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter −40 °C to +85 °C Conditions Unit Min Typ[1] - - outputs HIGH - 0.13 0.19 mA outputs LOW - 3 12 mA - 0.13 0.19 mA - 0.1 0.2 mA IBHHO bus hold HIGH overdrive current VCC = 0 V to 3.0 V; VI = 3.6 V ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A outputs disabled Max −500 µA ∆ICC additional supply current per input pin; VCC = 3.0 V to 3.6 V; one input = VCC − 0.6 V others = VCC or GND CI input capacitance DIR and OE inputs; VI = 0 V or 3.0 V - 4 - pF CI/O input/output capacitance at input/output data pins, outputs disabled; VI/O = 0 V or 3.0 V - 10 - pF [5] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. [1] [2] Unused pins at VCC or GND. [3] This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.6 V a transition time of 100 ms is permitted. This parameter is valid for Tamb = +25 °C only. [4] This is the bus hold overdrive current required to force the input to the opposite logic state. [5] This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 7. Symbol Parameter tPLH LOW to HIGH propagation delay VCC = 3.3 V ± 0.3 V HIGH to LOW propagation delay VCC = 3.3 V ± 0.3 V VCC = 3.3 V ± 0.3 V - - 4.0 ns 1.2 2.4 3.5 ns - - 4.0 ns 1.2 2.4 3.5 ns - - 7.1 ns 1.3 3.3 5.5 ns OFF-state to LOW propagation delay see Figure 6 VCC = 2.7 V VCC = 3.3 V ± 0.3 V tPHZ Max OFF-state to HIGH propagation delay see Figure 6 VCC = 2.7 V tPZL Typ[1] An to Bn or Bn to An VCC = 2.7 V tPZH Unit Min An to Bn or Bn to An VCC = 2.7 V tPHL −40 °C to +85 °C Conditions - - 6.5 ns 1.7 3.2 5.5 ns - - 6.5 ns 2.2 3.6 5.9 ns HIGH to OFF-state propagation delay see Figure 6 VCC = 2.7 V VCC = 3.3 V ± 0.3 V © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 6 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 7. Symbol Parameter −40 °C to +85 °C Conditions Max - - 5.1 ns 2.2 3.4 5.0 ns Min tPLZ LOW to OFF-state propagation delay see Figure 6 VCC = 2.7 V VCC = 3.3 V ± 0.3 V [1] Unit Typ[1] Typical values are measured at Tamb = 25 °C and VCC = 3.3 V 11. Waveforms VI VM An, Bn input VM GND tPHL tPLH VOH VM Bn, An output VM VOL 001aah732 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Fig 5. Input (An, Bn) to output (Bn, An) propagation delays and output transition times VI VM OE input GND tPLZ tPZL 3.0 V output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled 001aah733 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. 3-state output enable and disable times © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 7 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) Table 8. Measurement points VCC Input 2.7 V to 3.6 V Output VIN VM VM Vx Vy GND to 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH − 0.3 V tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC PULSE GENERATOR VI RL VO DUT RT CL RL 001aae235 Test data is given in Table 9. Definitions test circuit: RL = Load resistance; CL = Load capacitance including jig and probe capacitance; RT = Termination resistance should be equal to output impedance Zo of the pulse generator; VEXT = External voltage for measuring switching times. Fig 7. Table 9. Test circuit for switching times Test data Input Load VEXT VI fi tW tr, tf RL CL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.7 V ≤ 10 MHz 500 ns ≤ 2.5 ns 500 Ω 50 pF GND 6V open © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 8 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) 12. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c HE y v M A Z 11 20 Q A2 A (A 3) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT163-1 (SO20) © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 9 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm D SOT339-1 E A X c HE y v M A Z 20 11 Q A2 A (A 3) A1 pin 1 index θ Lp L 1 10 w M bp e detail X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 7.4 7.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.9 0.5 8o o 0 Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT339-1 Fig 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Package outline SOT339-1 (SSOP20) © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 10 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 E D A X c HE y v M A Z 11 20 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 10 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig 10. Package outline SOT360-1 (TSSOP20) © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 11 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT764-1 20 terminals; body 2.5 x 4.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 9 y y1 C v M C A B w M C b L 1 10 Eh e 20 11 19 12 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 4.6 4.4 3.15 2.85 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 3.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT764-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 11. Package outline SOT764-1 (DHVQFN20) © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 12 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) 13. Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVT245B_2 20080508 Product data sheet ECN07_046 74LVT245B_1 Modifications: 74LVT245B_1 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. DHVQFN20 package added to Section 3 “Ordering information” and Section 12 “Package outline” 19990319 Product specification - © 74LVT245B_2 Product data sheet - Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 13 of 15 74LVT245B Nexperia 3.3 V octal transceiver with direction pin (3-state) 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 15.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © 74LVT245B_2 Product data sheet Rev. 02 — 8 May 2008 Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia 74LVT245B 3.3 V octal transceiver with direction pin (3-state) 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 08 May 2008 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVT245BBQ,115 74LVT245BD,112 74LVT245BDB,112 74LVT245BDB,118 74LVT245BD,118 74LVT245BPW,112 74LVT245BPW,118
74LVT245BPW,112 价格&库存
很抱歉,暂时无法提供与“74LVT245BPW,112”相匹配的价格&库存,您可以联系我们找货
74LVT245BPW,112
