74LVTN16245B
3.3 V 16-bit transceiver; 3-state
Rev. 6 — 30 October 2018
Product data sheet
1. General description
The 74LVTN16245B is a high-performance BiCMOS product designed for VCC operation at 3.3 V.
This device is a 16-bit transceiver featuring non-inverting 3-state bus compatible outputs in both
send and receive directions. The control function implementation minimizes external timing
requirements. The device features an output enable input (nOE) for easy cascading and a direction
input (nDIR) for direction control.
2. Features and benefits
16-bit bus interface
3-state buffers
Output capability: +64 mA and -32 mA
TTL input and output switching levels
Input and output interface capability to systems at 5 V supply
Power-up 3-state
Live insertion and extraction permitted
No bus current loading when output is tied to 5 V bus
Latch-up protection
• JESD78B Class II exceeds 500 mA
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
3. Ordering information
Table 1. Ordering information
Type number
Package
74LVTN16245BDGG
Temperature range
Name
Description
Version
-40 °C to +85 °C
TSSOP48
plastic thin shrink small outline package;
48 leads; body width 6.1 mm
SOT362-1
74LVTN16245B
Nexperia
4. Functional diagram
2DIR
1DIR
2OE
1OE
2A0
1A0
1B0
1A1
2B0
2A1
1B1
1A2
2B1
2A2
1B2
1A3
2B2
2A3
1B3
1A4
2B3
2A4
1B4
1A5
2B4
2A5
1B5
1A6
2B5
2A6
1B6
2B6
2A7
1A7
1B7
2B7
001aaa789
Fig. 1.
Logic symbol
74LVTN16245B
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 13
74LVTN16245B
Nexperia
1OE
G3
1DIR
3EN1[BA]
3EN2[AB]
2OE
G6
2DIR
6EN4[BA]
6EN5[AB]
1A0
1
1B0
2
1A1
1B1
1A2
1B2
1A3
1B3
1A4
1B4
1A5
1B5
1A6
1B6
1A7
2A0
1B7
4
2B0
5
2A1
2B1
2A2
2B2
2A3
2B3
2A4
2B4
2A5
2B5
2A6
2B6
2A7
2B7
001aak306
Fig. 2.
IEC logic symbol
74LVTN16245B
Product data sheet
3 / 13
74LVTN16245B
Nexperia
5. Pinning information
5.1. Pinning
74LVTN16245B
1DIR
1
48 1OE
1B0
2
47 1A0
1B1
3
46 1A1
GND
4
45 GND
1B2
5
44 1A2
1B3
6
43 1A3
VCC
7
42 VCC
1B4
8
41 1A4
1B5
9
40 1A5
GND 10
39 GND
1B6 11
38 1A6
1B7 12
37 1A7
2B0 13
36 2A0
2B1 14
35 2A1
GND 15
34 GND
2B2 16
33 2A2
2B3 17
32 2A3
VCC 18
31 VCC
2B4 19
30 2A4
2B5 20
29 2A5
GND 21
28 GND
2B6 22
27 2A6
2B7 23
26 2A7
2DIR 24
25 2OE
001aak307
Fig. 3.
Pin configuration SOT362-1 (TSSOP48)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1DIR, 2DIR
1, 24
direction control input
1B0, 1B1, 1B2, 1B3, 1B4, 1B5, 1B6, 1B7
2, 3, 5, 6, 8, 9, 11, 12
data input/output
2B0, 2B1, 2B2, 2B3, 2B4, 2B5, 2B6, 2B7
13, 14, 16, 17, 19, 20, 22, 23
data input/output
GND
4, 10, 15, 21, 28, 34, 39, 45
ground (0 V)
VCC
7, 18, 31, 42
supply voltage
1OE, 2OE
48, 25
output enable input (active LOW)
2A0, 2A1, 2A2, 2A3, 2A4, 2A5, 2A6, 2A7
36, 35, 33, 32, 30, 29, 27, 26
data input/output
1A0, 1A1, 1A2, 1A3, 1A4, 1A5, 1A6, 1A7
47, 46, 44, 43, 41, 40, 38, 37
data input/output
74LVTN16245B
Product data sheet
4 / 13
74LVTN16245B
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Control
Input/output
nOE
nDIR
nAn
nBn
L
L
output nAn = nBn
input
L
H
input
output nBn = nAn
H
X
Z
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
output in OFF-state or HIGH-state
IIK
input clamping current
IOK
IO
Unit
-0.5
+4.6
V
-0.5
+7.0
V
[1]
-0.5
+7.0
V
VI < 0 V
-50
mA
output clamping current
VO < 0 V
-50
mA
output current
output in LOW-state
128
mA
output in HIGH-state
-64
mA
-65
+150
°C
[2]
150
°C
[3]
500
mW
storage temperature
Tj
junction temperature
Ptot
total power dissipation
[3]
Max
[1]
Tstg
[1]
[2]
Min
Tamb = -40 °C to +85 °C
The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
Above 60 °C the value of Ptot derates linearly with 5.5 mW/K.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC
supply voltage
2.7
3.6
V
VI
input voltage
V
VIH
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
IOH
HIGH-level output current
-32
mA
IOL
LOW-level output current
none
32
mA
current duty cycle ≤ 50 %;
fi ≥ 1 kHz
64
mA
-40
+85
°C
10
ns/V
Tamb
ambient temperature
in free-air
Δt/ΔV
input transition rise and fall rate
outputs enabled
74LVTN16245B
Product data sheet
5 / 13
74LVTN16245B
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; Tamb = -40 °C to +85 °C; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ [1]
Max
VIK
input clamping voltage
VCC = 2.7 V; IIK = -18 mA
-1.2
-0.85
V
VOH
HIGH-level output voltage IOH = -100 μA; VCC = 2.7 V to 3.6 V
VCC - 0.2
VCC
V
IOH = -8 mA; VCC = 2.7 V
2.4
2.5
V
IOH = -32 mA; VCC = 3.0 V
2.0
2.3
V
IOL = 100 μA
0.07
0.2
V
IOL = 24 mA
0.3
0.5
V
IOL = 16 mA
0.25
0.4
V
IOL = 32 mA
0.3
0.5
V
IOL = 64 mA
0.4
0.55
V
VCC = 3.6 V; VI = VCC or GND
0.1
±1
μA
VCC = 0 V or 3.6 V; VI = 5.5 V
0.1
10
μA
VI = 5.5 V
0.1
μA
VI = VCC
0.5
10
μA
VI = 0 V
VOL
LOW-level output voltage
Unit
VCC = 2.7 V
VCC = 3.0 V
II
input leakage current
control pins
input/output data pins; VCC = 3.6 V
[2]
-5
-0.1
μA
IOFF
power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V
0.1
±100
μA
ILO
output leakage current
75
125
μA
40
±100
μA
output HIGH
0.07
0.12
mA
output LOW
4.0
6.0
mA
[4]
0.07
0.12
mA
[5]
0.1
0.2
mA
output in HIGH-state when VO > VCC;
VO = 5.5 V; VCC = 3.0 V
IO(pu/pd) power-up/power-down
output current
VCC ≤ 1.2 V; VO = 0.5 V to VCC;
VI = GND or VCC; nOE = don’t care
ICC
VCC = 3.6 V; VI = GND or VCC; IO = 0 A
supply current
outputs disabled
[3]
ΔICC
additional supply current
per input pin; VCC = 3.0 V to 3.6 V;
one input at VCC - 0.6 V,
other inputs at VCC or GND
CI
input capacitance
pins nDIR and nOE, VO = 0 V or 3.0 V
3
pF
Cio(off)
off-state input/output
capacitance
pins nAn and nBn, outputs disabled;
VO = GND or VCC
9
pF
[1]
[2]
[3]
[4]
[5]
Typical values are measured at VCC = 3.3 V and at Tamb = 25 °C.
Unused pins at VCC or GND.
This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms.
From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only.
ICC is measured with outputs pulled to VCC or GND.
This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
74LVTN16245B
Product data sheet
6 / 13
74LVTN16245B
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); Tamb = -40 °C to +85 °C; for test circuit see Fig. 6.
Symbol Parameter
Conditions
tPLH
LOW to HIGH
propagation delay
nAn to nBn or nBn to nAn; see Fig. 4
HIGH to LOW
propagation delay
VCC = 2.7 V
tPHL
VCC = 2.7 V
tPZH
OFF-state to HIGH
propagation delay
OFF-state to LOW
propagation delay
VCC = 2.7 V
HIGH to OFF-state
propagation delay
VCC = 2.7 V
LOW to OFF-state
propagation delay
VCC = 2.7 V
3.5
ns
1.0
1.9
3.3
ns
3.5
ns
1.0
1.7
3.3
ns
5.3
ns
1.0
2.8
4.5
ns
5.1
ns
1.0
2.8
4.1
ns
5.7
ns
1.5
3.2
5.1
ns
4.6
ns
1.5
3.0
4.6
ns
nOE to nAn or nBn; see Fig. 5
VCC = 2.7 V
[1]
Unit
tPLZ
Max
tPHZ
Typ [1]
tPZL
Min
Typical values are measured at VCC = 3.3 V and Tamb = 25 °C.
74LVTN16245B
Product data sheet
7 / 13
74LVTN16245B
Nexperia
10.1. Waveforms and test circuit
VI
nAn, nBn
input
VM
GND
t PHL
t PLH
VOH
nBn, nAn
output
VM
VOL
mna477
Measurements points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 4.
Propagation delay input (nAn, nBn) to output (nBn, nAn)
VI
nOE input
VM
0V
tPZL
tPLZ
3.0 V
nAn or nBn
output
VM
VX
VOL
tPHZ
tPZH
VOH
nBn or nAn
output
VY
VM
0V
001aaj658
Fig. 5.
Enable and disable times
Table 8. Measurement points
Input
Output
VM
VM
VX
VY
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
74LVTN16245B
Product data sheet
8 / 13
74LVTN16245B
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
VI
PULSE
GENERATOR
RL
VO
DUT
RT
CL
RL
001aae235
Test data is given in Table 9.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 6.
Test circuit for measuring switching times
Table 9. Test data
Input
Load
VEXT
VI
fi
tW
tr, tf
CL
RL
tPHZ, tPZH
tPLZ, tPZL
tPLH, tPHL
2.7 V
≤ 10 MHz
500 ns
≤ 2.5 ns
50 pF
500 Ω
GND
6V
open
74LVTN16245B
Product data sheet
9 / 13
74LVTN16245B
Nexperia
11. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
D
E
A
X
c
v
HE
y
A
Z
48
25
Q
A2
A1
(A3)
pin 1 index
A
θ
Lp
1
L
24
bp
e
detail X
w
5 mm
2.5
scale
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A
1.2
A1
A2
0.15 1.05
0.05 0.85
A3
0.25
bp
c
D(1)
E(2)
0.28
0.2
12.6
6.2
0.17
0.1
12.4
6.0
e
HE
0.5
8.3
7.9
L
1
Lp
Q
0.8
0.50
0.4
0.35
v
w
0.25 0.08
y
0.1
Z
θ
0.8
8°
0.4
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT362-1
Fig. 7.
References
IEC
JEDEC
JEITA
sot362-1_po
European
projection
Issue date
03-02-19
13-08-05
MO-153
Package outline SOT362-1 (TSSOP48)
74LVTN16245B
Product data sheet
10 / 13
74LVTN16245B
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
BiCMOS
Bipolar Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVTN16245B v.6
20181030
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74LVTN16245BBX (SOT1134-2) removed.
Package outline drawing SOT362-1 updated.
74LVTN16245B v.5
20120405
Modifications:
74LVTN16245B v.4
20111122
Modifications:
74LVTN16245B v.3
20110615
74LVTN16245B v.2
74LVTN16245B v.1
74LVTN16245B
Product data sheet
74LVTN16245B v.5
Product data sheet
74LVTN16245B v.4
For type number 74LVTN16245BBX the SOT code has changed to SOT1134-2
Product data sheet
74LVTN16245B v.3
Product data sheet
74LVTN16245B v.2
20100323
Product data sheet
74LVTN16245B v.1
20090729
Product data sheet
Legal pages updated.
11 / 13
74LVTN16245B
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LVTN16245B
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
12 / 13
74LVTN16245B
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................4
5.1. Pinning.........................................................................4
5.2. Pin description............................................................. 4
6. Functional description................................................. 5
7. Limiting values............................................................. 5
8. Recommended operating conditions..........................5
9. Static characteristics....................................................6
10. Dynamic characteristics............................................ 7
10.1. Waveforms and test circuit........................................ 8
11. Package outline........................................................ 10
12. Abbreviations............................................................ 11
13. Revision history........................................................11
14. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 30 October 2018
74LVTN16245B
Product data sheet
13 / 13
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVTN16245BBX,518 74LVTN16245BDGG,12 74LVTN16245BDGG,11
