74VHC244; 74VHCT244
Octal buffer/line driver; 3-state
Rev. 01 — 17 August 2009
Product data sheet
1. General description
The 74VHC244; 74VHCT244 are a high-speed Si-gate CMOS devices.
The 74VHC244; 74VHCT244 have octal non-inverting buffer/line drivers with 3-state
outputs. The 3-state outputs are controlled by the output enable inputs (nOE). A HIGH on
nOE causes the outputs to assume a high-impedance OFF-state.
2. Features
n
n
n
n
Balanced propagation delays
All inputs have a Schmitt-trigger action
Inputs accepts voltages higher than VCC
Input levels:
u The 74VHC244 operates with CMOS input level
u The 74VHCT244 operates with TTL input level
n ESD protection:
u HBM JESD22-A114E exceeds 2000 V
u MM JESD22-A115-A exceeds 200 V
u CDM JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
74VHC244D
Package
Temperature range
Name
Description
Version
−40 °C to +125 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
−40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
−40 °C to +125 °C
DHVQFN20
plastic dual-in-line compatible thermal enhanced
SOT764-1
very thin quad flat package; no leads; 20 terminals;
body 2.5 × 4.5 × 0.85 mm
74VHCT244D
74VHC244PW
74VHCT244PW
74VHC244BQ
74VHCT244BQ
74VHC244; 74VHCT244
Nexperia
4. Functional diagram
2
4
6
8
1
17
15
13
11
19
1A0
1Y0
1A1
1Y1
1A2
1Y2
1A3
1Y3
18
16
14
12
1OE
2A0
2Y0
2A1
2Y1
2A2
2Y2
2A3
2Y3
3
5
7
9
2OE
mna170
Fig 1.
Functional diagram
1
1A0
1A1
2
18
4
16
1Y0
2A0
1Y1
2A1
17
15
3
5
2Y0
2
18
4
16
6
14
8
12
2Y1
19
1A2
1A3
1OE
6
14
8
12
1
1Y2
2A2
1Y3
2A3
2OE
13
11
7
9
EN
2Y2
2Y3
19
EN
11
9
13
7
15
5
17
3
mna874
Fig 2.
Logic symbol
mna873
Fig 3.
IEC logic symbol
74VHC_VHCT244_1
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 16
74VHC244; 74VHCT244
Nexperia
5. Pinning information
5.1 Pinning
1
terminal 1
index area
74VHC244
74VHCT244
20 VCC
1OE
74VHC244
74VHCT244
1A0
2
19 2OE
2Y0
3
18 1Y0
1A1
4
17 2A0
1OE
1
20 VCC
1A0
2
19 2OE
2Y0
3
18 1Y0
2Y1
5
16 1Y1
1A1
4
17 2A0
1A2
6
15 2A1
2Y1
5
16 1Y1
2Y2
7
1A2
6
15 2A1
2Y2
7
14 1Y2
1A3
8
13 2A2
2Y3
9
12 1Y3
GND 10
11 2A3
9
13 2A2
12 1Y3
2A3 11
8
2Y3
GND 10
1A3
14 1Y2
GND(1)
001aak058
Transparent top view
001aak057
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as a
supply pin or input.
Fig 4.
Pin configuration SO20, TSSOP20
Fig 5.
Pin configuration DHVQFN20
5.2 Pin description
Table 2.
Symbol
Pin description
Pin
Description
1OE
1
output enable input (active LOW)
1A[0:3]
2, 4, 6, 8
data input
2A[0:3]
17, 15, 13, 11 data input
1Y[0:3]
18, 16, 14, 12 data output
2Y[0:3]
3, 5, 7, 9
data output
GND
10
ground (0 V)
2OE
19
VCC
supply voltage
74VHC_VHCT244_1
Product data sheet
3 of 16
74VHC244; 74VHCT244
Nexperia
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
nOE
nAn
nYn
L
L
L
H
H
X
Z
H
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
IIK
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
Min
Max
Unit
−0.5
+7.0
V
−0.5
+7.0
V
−20
mA
±20
mA
±25
mA
ICC
supply current
75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
Ptot
total power dissipation
[1]
Tamb = −40 °C to +125 °C
SO20 package
[2]
500
mW
TSSOP20 package
[3]
500
mW
DHVQFN20 package
[4]
500
mW
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Ptot derates linearly with 8 mW/K above 70 °C.
[3]
Ptot derates linearly with 5.5 mW/K above 60 °C.
[4]
Ptot derates linearly with 4.5 mW/K above 60 °C.
74VHC_VHCT244_1
Product data sheet
4 of 16
74VHC244; 74VHCT244
Nexperia
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74VHC244
74VHCT244
Unit
Min
Typ
Max
Min
Typ
Max
VCC
supply voltage
2.0
5.0
5.5
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
−40
+25
+125
−40
+25
+125
°C
∆t/∆V
input transition rise
and fall rate
VCC = 3.3 V ± 0.3 V
100
ns/V
VCC = 5.0 V ± 0.5 V
ns/V
9. Static characteristics
Table 6.
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
For type 74VHC244
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
3.94
3.8
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
IOZ
OFF-state
VI = VIH or VIL;
output current VO = VCC or GND;
VCC = 5.5 V
±0.25
±2.5
±10.0
µA
II
input leakage
current
0.1
1.0
2.0
µA
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
4.0
40
80
µA
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
74VHC_VHCT244_1
Product data sheet
5 of 16
74VHC244; 74VHCT244
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
CI
input
capacitance
3.0
10
10
10
pF
CO
output
capacitance
4.0
pF
For type 74VHCT244
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
4.4
4.5
4.4
4.4
V
3.94
3.8
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
±0.25
±2.5
±10.0
µA
0.1
1.0
2.0
µA
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
IOZ
OFF-state
per input pin; VI = VIH or VIL;
output current VCC = 5.5 V; IO = 0 A
VO = VCC or GND;
other pins at VCC or GND
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
VCC = 5.5 V
4.0
40
80
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V; IO = 0 A;
other pins at VCC or GND;
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4.0
pF
74VHC_VHCT244_1
Product data sheet
6 of 16
74VHC244; 74VHCT244
Nexperia
10. Dynamic characteristics
Table 7.
GND = 0 V. For test circuit see Figure 8.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
5.0
8.4
1.0
10.0
1.0
10.5
ns
CL = 50 pF
7.0
11.9
1.0
13.5
1.0
15.0
ns
3.4
5.5
1.0
6.5
1.0
7.0
ns
5.0
7.5
1.0
8.5
1.0
9.5
ns
For type 74VHC244
tpd
propagation
delay
[2]
nAn to nYn; see Figure 6
VCC = 3.0 V to 3.6 V
CL = 15 pF
CL = 50 pF
ten
enable time
nOE to nYn; see Figure 7
[2]
CL = 15 pF
6.5
10.6
1.0
12.5
1.0
13.5
ns
CL = 50 pF
7.5
14.1
1.0
16.0
1.0
18.0
ns
4.0
7.3
1.0
8.5
1.0
9.5
ns
5.5
9.3
1.0
10.5
1.0
12.0
ns
CL = 15 pF
5.5
9.7
1.0
11.0
1.0
12.5
ns
CL = 50 pF
10.0
14.0
1.0
16.0
1.0
17.5
ns
CL = 15 pF
4.8
7.2
1.0
8.5
1.0
9.0
ns
CL = 50 pF
7.0
9.2
1.0
10.5
1.0
11.5
ns
10
pF
CL = 15 pF
CL = 50 pF
tdis
disable time
[2]
CPD
power
CL = 50 pF; fi = 1 MHz;
dissipation
VI = GND to VCC
capacitance
[3]
74VHC_VHCT244_1
Product data sheet
7 of 16
74VHC244; 74VHCT244
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
3.5
7.4
1.0
8.5
1.0
9.5
ns
CL = 50 pF
5.0
8.4
1.0
9.5
1.0
10.5
ns
3.5
10.4
1.0
12.0
1.0
13.0
ns
5.5
11.4
1.0
13.0
1.0
14.5
ns
5.0
9.4
1.0
10.0
1.0
12.0
ns
7.0
11.4
1.0
13.0
1.0
14.5
ns
12
pF
For type 74VHCT244
propagation
delay
tpd
enable time
ten
[2]
CL = 15 pF
CL = 50 pF
disable time
tdis
[2]
CL = 15 pF
CL = 50 pF
power
per buffer;
dissipation
CL = 50 pF; f = 1 MHz;
capacitance VI = GND to VCC
CPD
[3]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
[3]
CPD is used to determine the dynamic power dissipation PD (µW).
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts.
11. Waveforms
VI
nAn input
VM
VM
GND
tPLH
tPHL
VOH
VM
nYn output
VM
VOL
mna171
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6.
Propagation delay input (nAn) to output (nYn)
74VHC_VHCT244_1
Product data sheet
8 of 16
74VHC244; 74VHCT244
Nexperia
VI
nOE input
VM
GND
t PLZ
t PZL
VCC
nYn output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PZH
t PHZ
VOH
VY
nYn output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aae014
Fig 7.
enable and disable times
Table 8.
Measurement points
Type
Input
Output
VM
VM
VX
VY
74VHC244
0.5VCC
0.5VCC
VOL + 0.3 V
VOH − 0.3 V
74VHCT244
1.5 V
0.5VCC
VOL + 0.3 V
VOH − 0.3 V
74VHC_VHCT244_1
Product data sheet
9 of 16
74VHC244; 74VHCT244
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
G
VI
VO
RL
S1
open
DUT
CL
RT
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistor
S1 = Test selection switch
Fig 8.
Load circuitry for switching times
Table 9.
Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74VHC244
VCC
3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74VHCT244
3.0 V
3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74VHC_VHCT244_1
Product data sheet
10 of 16
74VHC244; 74VHCT244
Nexperia
12. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
HE
y
v M A
Z
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
10
1
e
bp
detail X
w M
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
inches
0.1
0.012 0.096
0.004 0.089
0.043
0.039
0.01
0.01
Z
(1)
0.9
0.4
0.035
0.004
0.016
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT163-1 (SO20)
74VHC_VHCT244_1
Product data sheet
11 of 16
74VHC244; 74VHCT244
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
SOT360-1
E
D
A
X
c
HE
y
v M A
Z
11
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
10
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig 10. Package outline SOT360-1 (TSSOP20)
74VHC_VHCT244_1
Product data sheet
12 of 16
74VHC244; 74VHCT244
Nexperia
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT764-1
20 terminals; body 2.5 x 4.5 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
9
y
y1 C
v M C A B
w M C
b
L
1
10
Eh
e
19
12
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
mm
c
D (1)
Dh
E (1)
Eh
0.2
4.6
4.4
3.15
2.85
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
3.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT764-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 11. Package outline SOT764-1 (DHVQFN20)
74VHC_VHCT244_1
Product data sheet
13 of 16
74VHC244; 74VHCT244
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charge Device Model
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74VHC_VHCT244_1
20090817
Product data sheet
74VHC_VHCT244_1
Product data sheet
14 of 16
74VHC244; 74VHCT244
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74VHC_VHCT244_1
Product data sheet
15 of 16
Nexperia
74VHC244; 74VHCT244
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 17 August 2009
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74VHC244BQ,115 74VHC244D,118 74VHC244PW,118 74VHCT244BQ,115 74VHCT244D,118
74VHCT244PW,118
