74VHC245; 74VHCT245
Octal bus transceiver; 3-state
Rev. 01 — 25 August 2009
Product data sheet
1. General description
The 74VHC245; 74VHCT245 are high-speed Si-gate CMOS devices.
The 74VHC245; 74VHCT245 are octal transceivers featuring non-inverting 3-state bus
compatible outputs in both send and receive directions.
The 74VHC245; 74VHCT245 feature an output enable input (OE), for easy cascading,
and a send and receive direction control input (DIR).
OE controls the outputs so that the buses are effectively isolated.
2. Features
n
n
n
n
Balanced propagation delays
All inputs have Schmitt-trigger action
Inputs accept voltages higher than VCC
Input levels:
u The 74VHC245 operates with CMOS input level
u The 74VHCT245 operates with TTL input level
n ESD protection:
u HBM JESD22-A114E exceeds 2000 V
u MM JESD22-A115-A exceeds 200 V
u CDM JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
74VHC245D
Package
Temperature range
Name
Description
Version
−40 °C to +125 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
−40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
−40 °C to +125 °C
DHVQFN20
plastic dual-in-line compatible thermal enhanced
SOT764-1
very thin quad flat package; no leads; 20 terminals;
body 2.5 × 4.5 × 0.85 mm
74VHCT245D
74VHC245PW
74VHCT245PW
74VHC245BQ
74VHCT245BQ
74VHC245; 74VHCT245
Nexperia
4. Functional diagram
1
DIR
OE
2
B0
3
19
3EN1
3EN2
1
14
3
17
4
16
13
5
15
6
14
7
13
8
12
A6
12
A7
B7
11
9
Logic symbol
Fig 2.
IEC logic symbol
74VHC_VHCT245_1
Product data sheet
11
mna175
mna174
Fig 1.
18
2
A5
B6
9
G3
2
B5
8
15
A4
B4
7
1
16
A3
B3
6
17
A2
B2
5
18
A1
B1
4
19
A0
Nexperia B.V. 2017. All rights reserved
2 of 16
74VHC245; 74VHCT245
Nexperia
5. Pinning information
5.1 Pinning
1
terminal 1
index area
74VHC245
74VHCT245
20 VCC
DIR
74VHC245
74VHCT245
A0
2
19 OE
A1
3
18 B0
A2
4
17 B1
DIR
1
20 VCC
A0
2
19 OE
A1
3
18 B0
A3
5
16 B2
A2
4
17 B1
A4
6
15 B3
A3
5
16 B2
A5
7
14 B4
A4
6
15 B3
A6
8
A5
7
14 B4
A6
8
13 B5
A7
9
A7
9
12 B6
GND 10
11 B7
GND(1)
13 B5
B7 11
GND 10
12 B6
001aak060
Transparent top view
001aak059
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as
a supply pin or input.
Fig 3. Pin configuration SO20, TSSOP20
Fig 4. Pin configuration DHVQFN20
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
DIR
1
A0
2
data input/output
A1
3
data input/output
A2
4
data input/output
A3
5
data input/output
A4
6
data input/output
A5
7
data input/output
A6
8
data input/output
A7
9
data input/output
GND
10
ground (0 V)
B7
11
data input/output
B6
12
data input/output
B5
13
data input/output
B4
14
data input/output
B3
15
data input/output
B2
16
data input/output
74VHC_VHCT245_1
Product data sheet
3 of 16
74VHC245; 74VHCT245
Nexperia
Table 2.
Pin description …continued
Symbol
Pin
Description
B1
17
data input/output
B0
18
data input/output
OE
19
output enable input (active LOW)
VCC
supply voltage
6. Functional description
Table 3.
Function table[1]
Control
Input/output
OE
DIR
An
Bn
L
L
A=B
inputs
L
H
inputs
B=A
H
X
Z
Z
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
Min
Max
Unit
−0.5
+7.0
V
−0.5
+7.0
V
−20
mA
−20
+20
mA
−25
+25
mA
mA
IIK
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
ICC
supply current
+75
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
Ptot
total power dissipation
500
mW
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO20 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For TSSOP20 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
For DHVQFN20 packages: above 60 °C the value of Ptot derates linearly at 4.5 mW/K.
74VHC_VHCT245_1
Product data sheet
4 of 16
74VHC245; 74VHCT245
Nexperia
8. Recommended operating conditions
Table 5.
Operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
Unit
2.0
5.0
5.5
V
74VHC245
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74VHCT245
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
74VHC245
VIH
VIL
VOH
VOL
HIGH-level
input voltage
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
74VHC_VHCT245_1
Product data sheet
5 of 16
74VHC245; 74VHCT245
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
µA
IOZ
OFF-state
VI = VIH or VIL;
output current VO = VCC or GND;
VCC = 5.5 V
±0.25
±2.5
±10.0
µA
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
4.0
40
80
µA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
VI = VCC or GND
74VHCT245
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
4.4
4.5
4.4
4.4
V
3.94
3.80
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
OFF-state
VI = VIH or VIL;
output current VO = VCC or GND per input
pin; other inputs at
VCC = 5.5 V
±0.25
±2.5
±10.0
µA
ICC
VCC = 5.5 V
4.0
40
80
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V;
other pins at VCC or GND;
IO = 0 A; VCC = 4.5 V to 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
II
input leakage
current
IOZ
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
VI = VCC or GND
74VHC_VHCT245_1
Product data sheet
6 of 16
74VHC245; 74VHCT245
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
CL = 15 pF
CL = 50 pF
Max
Min
Max
Min
Max
5.0
8.4
1.0
10.0
1.0
10.5
ns
6.5
11.9
1.0
13.5
1.0
15.0
ns
3.5
5.5
1.0
6.5
1.0
7.0
ns
5.0
7.5
1.0
8.5
1.0
9.5
ns
74VHC245
tpd
propagation
delay
An to Bn; Bn to An;
see Figure 5
[2]
CL = 15 pF
CL = 50 pF
ten
enable time
OE to An; OE to Bn;
signal name DIR;
see Figure 6
[3]
CL = 15 pF
6.5
13.2
1.0
15.5
1.0
16.5
ns
CL = 50 pF
9.0
16.7
1.0
19.0
1.0
21.0
ns
CL = 15 pF
4.0
8.5
1.0
10.0
1.0
11.0
ns
CL = 50 pF
5.0
10.6
1.0
12.0
1.0
13.5
ns
CL = 15 pF
7.5
12.5
1.0
15.5
1.0
16.0
ns
CL = 50 pF
10.0
15.8
1.0
18.0
1.0
20.0
ns
4.5
7.8
1.0
9.2
1.0
10.0
ns
6.0
9.7
1.0
11.0
1.0
12.5
ns
12
pF
3.5
7.7
1.0
8.5
1.0
10.0
ns
4.5
8.7
1.0
9.5
1.0
11.0
ns
CL = 15 pF
5.0
13.8
1.0
15.0
1.0
17.5
ns
CL = 50 pF
6.0
14.8
1.0
16.0
1.0
18.5
ns
tdis
disable time
OE to An; OE to Bn;
signal name DIR;
see Figure 6
[4]
CL = 15 pF
CL = 50 pF
CPD
power
fi = 1 MHz;
dissipation
VI = GND to VCC
capacitance
[5]
74VHCT245; VCC = 4.5 V to 5.5 V
tpd
propagation
delay
An to Bn; Bn to An;
see Figure 5
[2]
CL = 15 pF
CL = 50 pF
ten
enable time
OE to An; OE to Bn;
signal name DIR;
see Figure 6
[3]
74VHC_VHCT245_1
Product data sheet
7 of 16
74VHC245; 74VHCT245
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
tdis
disable time
25 °C
Conditions
Min
Max
Min
Max
Min
Max
5.0
14.4
1.0
15.5
1.0
18.0
ns
6.0
15.4
1.0
16.5
1.0
19.5
ns
15
pF
[4]
OE to An; OE to Bn;
signal name DIR;
see Figure 6
CL = 15 pF
CL = 50 pF
[5]
power
fi = 1 MHz;
dissipation
VI = GND to VCC
capacitance
CPD
Typ[1]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
ten is the same as tPZL and tPZH.
[4]
tdis is the same as tPLZ and tPHZ.
[5]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
10.1 Waveforms
VI
An, Bn input
VM
VM
GND
tPLH
tPHL
VOH
Bn, An output
VM
VM
VOL
mna176
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 5.
Input to output propagation delays
74VHC_VHCT245_1
Product data sheet
8 of 16
74VHC245; 74VHCT245
Nexperia
VI
OE input
VM
GND
t PLZ
t PZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PHZ
VOH
t PZH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
mna367
Fig 6.
Enable and disable times
Table 8.
Measurement points
Type
Input
Output
VM
VM
VX
VY
74VHC245
0.5VCC
0.5VCC
VOL + 0.3 V
VOH − 0.3 V
74VHCT245
1.5 V
0.5VCC
VOL + 0.3 V
VOH − 0.3 V
74VHC_VHCT245_1
Product data sheet
9 of 16
74VHC245; 74VHCT245
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
G
VI
VO
RL
S1
open
DUT
CL
RT
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig 7.
Load circuitry for measuring switching times
Table 9.
Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74VHC245
VCC
≤ 3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74VHCT245
3.0 V
≤ 3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74VHC_VHCT245_1
Product data sheet
10 of 16
74VHC245; 74VHCT245
Nexperia
11. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
HE
y
v M A
Z
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
10
1
e
bp
detail X
w M
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
inches
0.1
0.012 0.096
0.004 0.089
0.043
0.039
0.01
0.01
Z
(1)
0.9
0.4
0.035
0.004
0.016
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 8. Package outline SOT163-1 (SO20)
74VHC_VHCT245_1
Product data sheet
11 of 16
74VHC245; 74VHCT245
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
SOT360-1
E
D
A
X
c
HE
y
v M A
Z
11
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
10
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig 9. Package outline SOT360-1 (TSSOP20)
74VHC_VHCT245_1
Product data sheet
12 of 16
74VHC245; 74VHCT245
Nexperia
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT764-1
20 terminals; body 2.5 x 4.5 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
9
y
y1 C
v M C A B
w M C
b
L
1
10
Eh
e
19
12
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
mm
c
D (1)
Dh
E (1)
Eh
0.2
4.6
4.4
3.15
2.85
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
3.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT764-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 10. Package outline SOT764-1 (DHVQFN20)
74VHC_VHCT245_1
Product data sheet
13 of 16
74VHC245; 74VHCT245
Nexperia
12. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74VHC_VHCT245_1
20090825
Product data sheet
74VHC_VHCT245_1
Product data sheet
14 of 16
74VHC245; 74VHCT245
Nexperia
14. Legal information
14.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
14.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
14.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
15. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74VHC_VHCT245_1
Product data sheet
15 of 16
Nexperia
74VHC245; 74VHCT245
16. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
14.1
14.2
14.3
14.4
15
16
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 25 August 2009
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74VHC245BQ,115 74VHC245D,118 74VHC245PW,118 74VHCT245BQ,115 74VHCT245D,118
74VHCT245PW,118 74VHCT245PW/AUJ
