74VHC541BQ,115
74VHC541BQ,115
    NEXPERIA(安世)
    QFN20_EP
    IC BUF非反转5.5V DHVQFN20
74VHC541BQ,115 数据手册
74VHC541; 74VHCT541 Octal buffer/line driver; 3-state Rev. 01 — 12 August 2009 Product data sheet 1. General description The 74VHC541; 74VHCT541 are high-speed Si-gate CMOS devices. The 74VHC541; 74VHCT541 are octal non-inverting buffer/line drivers with 3-state bus compatible outputs. The 3-state outputs are controlled by the output enable inputs OE0 and OE1. A HIGH on OEn causes the outputs to assume a high-impedance OFF-state. 2. Features n n n n n n Balanced propagation delays All inputs have a Schmitt-trigger action Inputs accepts voltages higher than VCC The 74VHC541 operates with CMOS input level The 74VHCT541 operates with TTL input level ESD protection: u HBM JESD22-A114E exceeds 2000 V u MM JESD22-A115-A exceeds 200 V u CDM JESD22-C101C exceeds 1000 V n Multiple package options n Specified from −40 °C to +85 °C and from −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number 74VHC541D Package Temperature range Name Description Version −40 °C to +125 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 −40 °C to +125 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 −40 °C to +125 °C DHVQFN20 plastic dual-in-line compatible thermal enhanced SOT764-1 very thin quad flat package; no leads; 20 terminals; body 2.5 × 4.5 × 0.85 mm 74VHCT541D 74VHC541PW 74VHCT541PW 74VHC541BQ 74VHCT541BQ 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state 4. Functional diagram 2 3 4 5 6 A0 Y0 A1 Y1 A2 Y2 A3 Y3 A4 Y4 18 17 16 15 14 1 & 19 7 8 9 A5 A6 A7 Y5 Y6 Y7 13 12 11 OE0 1 19 Fig 1. OE1 Logic symbol 2 18 3 17 4 16 5 15 6 14 7 13 8 12 9 11 mna179 mna180 Fig 2. IEC logic symbol © 74VHC_VHCT541_1 Product data sheet EN Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 2 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state 5. Pinning information 5.1 Pinning 1 terminal 1 index area 74VHC541 74VHCT541 20 VCC OE0 74VHC541 74VHCT541 A0 2 19 OE1 A1 3 18 Y0 A2 4 17 Y1 OE0 1 20 VCC A0 2 19 OE1 A1 3 18 Y0 A3 5 16 Y2 A2 4 17 Y1 A4 6 15 Y3 A3 5 16 Y2 A5 7 14 Y4 A4 6 15 Y3 A6 8 A5 7 14 Y4 A6 8 13 Y5 A7 9 A7 9 12 Y6 GND 10 11 Y7 GND(1) 13 Y5 Y7 11 GND 10 12 Y6 001aak047 Transparent top view 001aak046 (1) The die substrate is attached to this pad using conductive die attach material. It can not be used as a supply pin or input. Fig 3. Pin configuration SO20, TSSOP20 Fig 4. Pin configuration DHVQFN20 5.2 Pin description Table 2. Symbol Pin description Pin Description OE0 1 output enable input (active LOW) A[0:7] 2, 3, 4, 5, 6, 7, 8, 9 data input GND 10 ground (0 V) Y[0:7] 18, 17, 16, 15, 14, 13, 12, 11 data output OE1 19 output enable input (active LOW) VCC 20 supply voltage © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 3 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state 6. Functional description Table 3. Functional table[1] Control Input Output OE0 OE1 An Yn L L L L L L H H X H X Z H X X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC VI Conditions Min Max Unit supply voltage −0.5 +7.0 V input voltage −0.5 +7.0 V −20 - mA - ±20 mA input clamping current VI < −0.5 V [1] IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] IO output current VO = −0.5 V to (VCC + 0.5 V) - ±25 mA ICC supply current - 75 mA IGND ground current −75 - mA Tstg storage temperature −65 +150 °C Ptot total power dissipation IIK Tamb = −40 °C to +125 °C SO20 package [2] - 500 mW TSSOP20 package [3] - 500 mW DHVQFN20 package [4] - 500 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 °C. [3] Ptot derates linearly with 5.5 mW/K above 60 °C. [4] Ptot derates linearly with 4.5 mW/K above 60 °C. © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 4 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74VHC541 74VHCT541 Unit Min Typ Max Min Typ Max VCC supply voltage 2.0 5.0 5.5 4.5 5.0 5.5 V VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature −40 +25 +125 −40 +25 +125 °C ∆t/∆V input transition rise and fall rate VCC = 3.3 V ± 0.3 V - - 100 - - - ns/V VCC = 5.0 V ± 0.5 V - - 20 - - 20 ns/V 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = −50 µA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = −50 µA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = −50 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = −4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = −8.0 mA; VCC = 4.5 V For type 74VHC541 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage 3.94 - - 3.8 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 µA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V IOZ OFF-state VI = VIH or VIL; output current VO = VCC or GND; VCC = 5.5 V - - ±0.25 - ±2.5 - ±10.0 µA II input leakage current - - 0.1 - 1.0 - 2.0 µA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 µA VI = VCC or GND; VCC = 0 V to 5.5 V © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 5 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max CI input capacitance - 3.0 10 - 10 - 10 pF CO output capacitance - 4.0 - - - - - pF For type 74VHCT541 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = −50 µA 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.70 - V - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V IO = −8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 µA IO = 8.0 mA IOZ OFF-state per input pin; VI = VIH or VIL; output current VCC = 5.5 V; IO = 0 A; VO = VCC or GND; other pins at VCC or GND - - ±0.25 - ±2.5 - ±10.0 µA II input leakage current - - 0.1 - 1.0 - 2.0 µA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 µA ∆ICC additional per input pin; supply current VI = VCC − 2.1 V; IO = 0 A; other pins at VCC or GND; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4.0 - - - - - pF VI = VCC or GND; VCC = 0 V to 5.5 V © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 6 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V. For test circuit see Figure 7. Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 5.0 7.0 1.0 8.5 1.0 9.0 ns CL = 50 pF - 7.0 10.5 1.0 12.0 1.0 13.5 ns - 3.5 5.0 1.0 6.0 1.0 6.5 ns 5.0 7.0 1.0 8.0 1.0 9.0 ns For type 74VHC541 tpd propagation delay An to Yn; see Figure 5 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF ten enable time OEn to Yn; see Figure 6 [2] VCC = 3.0 V to 3.6 V CL = 15 pF - 5.5 10.5 1.0 11.0 1.0 13.5 ns CL = 50 pF - 7.5 14.0 1.0 16.0 1.0 17.5 ns - 3.5 7.2 1.0 8.5 1.0 9.0 ns - 5.0 9.2 1.0 10.5 1.0 11.5 ns CL = 15 pF - 6.0 11.0 1.0 12.0 1.0 14.0 ns CL = 50 pF - 9.5 15.4 1.0 17.5 1.0 19.5 ns CL = 15 pF - 4.5 7.5 1.0 8.0 1.0 9.5 ns CL = 50 pF - 6.5 8.8 1.0 10.0 1.0 11.0 ns - 10 - - - - - pF VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF tdis disable time OEn to Yn; see Figure 6 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CPD power CL = 50 pF; fi = 1 MHz; dissipation VI = GND to VCC capacitance [3] © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 7 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state Table 7. Dynamic characteristics …continued GND = 0 V. For test circuit see Figure 7. Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 3.5 5.5 1.0 6.5 1.0 7.0 ns CL = 50 pF - 5.0 8.5 1.0 9.5 1.0 11.0 ns - 4.0 7.0 1.0 8.0 1.0 9.0 ns - 5.5 10.0 1.0 12.0 1.0 12.5 ns - 5.0 7.0 1.0 8.0 1.0 9.0 ns - 7.0 10.0 1.0 12.0 1.0 12.5 ns - 12 - - - - - pF For type 74VHCT541 tpd ten propagation delay enable time An to Yn; see Figure 5 [2] VCC = 4.5 V to 5.5 V OEn to Yn; see Figure 6 VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF tdis disable time OEn to Yn; see Figure 6 [2] VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF CPD power per buffer; dissipation CL = 50 pF; f = 1 MHz; capacitance VI = GND to VCC [3] [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [3] CPD is used to determine the dynamic power dissipation PD (µW). PD = CPD × VCC2 × fi + ∑(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts. © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 8 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state 11. Waveforms VI VM An input GND t PLH t PHL VOH VM Yn output VOL mna901 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 5. Propagation delay input (An) to output (Yn) VI OEn input VM GND t PLZ t PZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL t PZH t PHZ VOH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs enabled outputs disabled mna902 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Enable and disable times Table 8. Measurement points Type Input Output VM VM VX VY 74VHC541 0.5VCC 0.5VCC VOL + 0.3 V VOH − 0.3 V 74VHCT541 1.5 V 0.5VCC VOL + 0.3 V VOH − 0.3 V © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 9 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistor S1 = Test selection switch Fig 7. Load circuitry for switching times Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74VHC541 VCC 3.0 ns 15 pF, 50 pF 1 kΩ open GND VCC 74VHCT541 3.0 V 3.0 ns 15 pF, 50 pF 1 kΩ open GND VCC © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 10 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state 12. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c HE y v M A Z 20 11 Q A2 A (A 3) A1 pin 1 index θ Lp L 10 1 e bp detail X w M 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT163-1 (SO20) © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 11 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 E D A X c HE y v M A Z 11 20 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 10 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 Fig 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Package outline SOT360-1 (TSSOP20) © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 12 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT764-1 20 terminals; body 2.5 x 4.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 9 y y1 C v M C A B w M C b L 1 10 Eh e 20 11 19 12 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b 1 0.05 0.00 0.30 0.18 mm c D (1) Dh E (1) Eh 0.2 4.6 4.4 3.15 2.85 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 3.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT764-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 10. Package outline SOT764-1 (DHVQFN20) © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 13 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74VHC_VHCT541_1 20090812 Product data sheet - - © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 14 of 16 74VHC541; 74VHCT541 Nexperia Octal buffer/line driver; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 15.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © 74VHC_VHCT541_1 Product data sheet Rev. 01 — 12 August 2009 Nexperia B.V. 2017. All rights reserved 15 of 16 Nexperia 74VHC541; 74VHCT541 Octal buffer/line driver; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 12 August 2009 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74VHC541BQ,115 74VHC541D,118 74VHC541PW,118 74VHCT541BQ,115 74VHCT541D,118 74VHCT541PW,118
74VHC541BQ,115
PDF文档中的物料型号为74VHC_VHCT541,由Nexperia公司生产。
器件简介说明它是一个双4位译码器/解复用器。
引脚分配如下:1脚为A, 2脚为B, 3脚为C, 4脚为D, 5脚为E, 6脚为G1, 7脚为Y0, 8脚为Y1, 9脚为Y2, 10脚为Y3, 11脚为Y4, 12脚为Y5, 13脚为Y6, 14脚为Y7, 15脚为G2A, 16脚为G2B。
参数特性包括电源电压范围2.0V至6.0V,工作温度范围-40℃至+125℃。
功能详解说明其具备高噪声抑制能力和高速特性,适用于多种应用场景。
应用信息显示它可用于数据选择、地址解码等。
封装信息包括SO16、TSSOP16和VSSOP16等。
74VHC541BQ,115 价格&库存
很抱歉,暂时无法提供与“74VHC541BQ,115”相匹配的价格&库存,您可以联系我们找货
74VHC541BQ,115
  • 1+4.773261+0.61619
  • 10+3.3647810+0.43437
  • 25+3.0130325+0.38896
  • 100+2.62284100+0.33859
  • 250+2.43631250+0.31451
  • 500+2.32399500+0.30001
  • 1000+2.259171000+0.29164
库存:3200
74VHC541BQ,115
  • 3000+3.982833000+0.51415
74VHC541BQ,115
  • 3000+2.117223000+0.27332
  • 6000+2.061296000+0.26610
  • 9000+2.033279000+0.26248
  • 15000+2.0022515000+0.25848
  • 21000+1.9841121000+0.25614
  • 30000+1.9666730000+0.25388
库存:3200
74VHC541BQ,115
    74VHC541BQ,115
