74VHCT541BQ-Q100X
74VHCT541BQ-Q100X
    NEXPERIA(安世)
    DHVQFN20_4.5X2.5MM_EP
    八通道缓冲器/线路驱动器;3 态
74VHCT541BQ-Q100X 数据手册
74VHC541-Q100; 74VHCT541-Q100 Octal buffer/line driver; 3-state Rev. 1 — 4 June 2013 Product data sheet 1. General description The 74VHC541-Q100; 74VHCT541-Q100 are high-speed Si-gate CMOS devices. The 74VHC541-Q100; 74VHCT541-Q100 are octal non-inverting buffer/line drivers with 3-state bus compatible outputs. The output enable inputs OE0 and OE1 control the 3-state outputs. A HIGH on OEn causes the outputs to assume a high-impedance OFF-state. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Balanced propagation delays  All inputs have a Schmitt-trigger action  Inputs accept voltages higher than VCC  The 74VHC541-Q100 operates with CMOS input level  The 74VHCT541-Q100 operates with TTL input level  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 74VHC541-Q100; 74VHCT541-Q100 Nexperia Octal buffer/line driver; 3-state 3. Ordering information Table 1. Ordering information Type number Package 74VHC541D-Q100 Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; SOT360-1 body width 4.4 mm 40 C to +125 C DHVQFN20 plastic dual-in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5  4.5  0.85 mm 74VHCT541D-Q100 74VHC541PW-Q100 74VHCT541PW-Q100 74VHC541BQ-Q100 74VHCT541BQ-Q100 SOT764-1 4. Functional diagram 2 3 4 5 6 A0 Y0 A1 Y1 A2 Y2 A3 Y3 A4 Y4 18 17 16 15 14 1 & 19 7 8 9 A5 A6 A7 Y5 Y6 Y7 13 12 11 OE0 1 19 Fig 1. OE1 Logic symbol 74VHC_VHCT541_Q100 Product data sheet EN 2 18 3 17 4 16 5 15 6 14 7 13 8 12 9 11 mna179 mna180 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 June 2013 © Nexperia B.V. 2017. All rights reserved 2 of 17 74VHC541-Q100; 74VHCT541-Q100 Nexperia Octal buffer/line driver; 3-state 5. Pinning information 5.1 Pinning 2(  WHUPLQDO LQGH[DUHD 9+&4 9+&74  9&& 9+&4 9+&74 $   2( $
74VHCT541BQ-Q100X 价格&库存
很抱歉,暂时无法提供与“74VHCT541BQ-Q100X”相匹配的价格&库存,您可以联系我们找货
