74AHCT240BQ,115
74AHCT240BQ,115
    NEXPERIA(安世)
    QFN20_EP
    八进制缓冲器/线路驱动器;反相;3-state
74AHCT240BQ,115 数据手册
74AHCT240 Octal buffer/line driver; inverting; 3-state Rev. 5 — 29 February 2016 Product data sheet 1. General description The 74AHCT240 is an 8-bit inverting buffer/line driver with 3-state outputs. This device can be used as two 4-bit buffers or one 8-bit buffer. It features two output enables (1OE and 2OE), each controlling four of the 3-state outputs. A HIGH on nOE causes the outputs to assume a high-impedance OFF-state. Inputs are over voltage tolerant. This feature allows the use of these devices as translators in mixed voltage environments. 2. Features and benefits      Balanced propagation delays All inputs have a Schmitt-trigger action Inputs accepts voltages higher than VCC Operates with TTL input levels ESD protection:  HBM JESD22-A114F exceeds 2000 V  CDM JESD22-C101D exceeds 1000 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AHCT240D 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74AHCT240PW 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74AHCT240BQ 40 C to +125 C DHVQFN20 plastic dual in-line compatible thermal enhanced SOT764-1 very thin quad flat package; no leads; 20 terminals; body 2.5  4.5  0.85 mm 74AHCT240 Nexperia Octal buffer/line driver; inverting; 3-state 4. Functional diagram   $  $
74AHCT240BQ,115
PDF文档中包含的物料型号为74AHCT240,由Nexperia公司生产。
该器件是一个高速CMOS 8位串行输入并行输出移位寄存器,具有3态输出。
引脚分配如下:1-GND,2-SER,3-RCLK,4-SRCLK,5-QH,6-Q0,7-Q1,8-Q2,9-Q3,10-Q4,11-Q5,12-Q6,13-Q7,14-LE,15-DS,16-VCC。
参数特性包括工作电压范围2.0V至6.0V,工作温度范围-40℃至+125℃,封装类型为SOIC-16。
功能详解指出,该器件具有高速传输能力,适用于多种数字逻辑应用。
应用信息表明,它可用于数据缓冲、存储和传输。
封装信息显示,该器件采用16引脚小外形集成电路封装。
74AHCT240BQ,115 价格&库存
很抱歉,暂时无法提供与“74AHCT240BQ,115”相匹配的价格&库存,您可以联系我们找货
74AHCT240BQ,115
  • 1+6.326991+0.78486
  • 10+4.3313910+0.53731
  • 25+3.8364425+0.47591
  • 100+3.29003100+0.40813
  • 250+3.02949250+0.37581
  • 500+2.87231500+0.35631
  • 1000+2.742711000+0.34024
库存:5960
74AHCT240BQ,115
  • 3000+2.582643000+0.32038
  • 6000+2.504306000+0.31066
  • 9000+2.465059000+0.30579
  • 15000+2.4215515000+0.30040
  • 21000+2.3961321000+0.29724
  • 30000+2.3716830000+0.29421
库存:5960
