74HC126; 74HCT126
Quad buffer/line driver; 3-state
Rev. 4 — 1 December 2015
Product data sheet
1. General description
The 74HC126; 74HCT126 is a quad buffer/line driver with 3-state outputs controlled by
the output enable inputs (nOE). A LOW on nOE causes the outputs to assume
a high-impedance OFF-state. Inputs include clamp diodes. This enables the use of
current limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Inverting outputs
Complies with JEDEC standard no. 7A
Input levels:
For 74HC126: CMOS level
For 74HCT126: TTL level
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
74HC126D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads;
body width 5.3 mm
SOT337-1
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74HCT126D
74HC126DB
74HCT126DB
74HC126PW
74HCT126PW
74HC126; 74HCT126
Nexperia
4. Functional diagram
2(
2(
2(
2(
PQD
Fig 1.
(1
PQD
Logic symbol
Fig 2.
IEC logic symbol
Q<
Q$
Q2(
PQD
Fig 3.
Logic diagram (one buffer/line driver)
5. Pinning information
5.1 Pinning
+&7
2(
9&&
2(
2(
2(
*1'
+&7
2(
9&&
2(
2(
2(
*1'
DDD
DDD
Fig 4.
Pin configuration for SOT108-1
74HC_HCT126
Product data sheet
Fig 5.
Pin configuration for SOT337-1 and SOT402-1
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
74HC126; 74HCT126
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1OE, 2OE, 3OE, 4OE
1, 4, 10, 13
data enable input (active HIGH)
1A, 2A, 3A, 4A
2, 5, 9, 12
data input
1Y, 2Y, 3Y, 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
nOE
nA
nY
H
L
L
H
H
H
L
X
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
0.5
+7
V
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
mA
IO
output current
0.5 V < VO < VCC + 0.5 V
35
mA
ICC
supply current
70
mA
IGND
ground current
70
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
Tamb = 40 C to +125 C
SO14 and (T)SSOP14 packages
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
74HC_HCT126
Product data sheet
3 of 15
74HC126; 74HCT126
Nexperia
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC126
Min
Typ
74HCT126
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Tamb = 25 C
Conditions
Tamb = 40 C
to +85 C
Tamb = 40 C
to +125 C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
LOW-level
input voltage
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
HIGH-level
output voltage
VI = VIH or VIL
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
74HC126
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
output voltage
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 6.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 7.8 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
VI = VIH or VIL
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
0.1
1.0
1.0
A
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 6.0 V;
VO = VCC or GND
0.5
5.0
10
A
74HC_HCT126
Product data sheet
4 of 15
74HC126; 74HCT126
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
ICC
supply current
CI
input
capacitance
Tamb = 25 C
Conditions
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
Tamb = 40 C
to +85 C
Tamb = 40 C
to +125 C
Unit
Min
Typ
Max
Min
Max
Min
Max
8.0
80
160
A
3.5
pF
74HCT126
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
4.4
4.4
V
IO = 6.0 mA
3.98
4.32
3.84
3.7
V
IO = 20 A
0.1
0.1
V
IO = 6.0 mA
0.16
0.26
0.33
0.4
V
VOL
LOW-level
output voltage
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
0.1
1.0
1.0
A
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 5.5 V;
VO = VCC or GND
0.5
5.0
10
A
ICC
supply current
VCC = 5.5 V
8.0
80
160
A
ICC
additional
supply current
per input pin; IO = 0 A;
VI = VCC 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V;
nA, nOE inputs
100
360
450
490
A
CI
input
capacitance
3.5
pF
10. Dynamic characteristics
Table 7.
GND = 0 V; CL = 50 pF; for test circuit, see Figure 8.
Symbol Parameter
Tamb = 25 C
Conditions
Unit
Min
Typ
Max
Max (85 C)
Max (125 C)
VCC = 2.0 V
30
100
125
150
ns
VCC = 4.5 V
11
30
ns
VCC = 5.0 V; CL = 15 pF
9
ns
VCC = 6.0 V
9
17
21
26
ns
74HC126
tpd
propagation delay nA to nY; see Figure 6
74HC_HCT126
Product data sheet
[1]
5 of 15
74HC126; 74HCT126
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
ten
enable time
Tamb = 25 C
Conditions
disable time
Min
Typ
Max
Max (85 C)
Max (125 C)
VCC = 2.0 V
41
125
155
190
ns
VCC = 4.5 V
15
25
31
38
ns
12
21
26
32
ns
VCC = 2.0 V
41
125
155
190
ns
VCC = 4.5 V
15
25
31
38
ns
12
21
26
32
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
4
10
13
15
ns
23
pF
14
24
30
36
ns
nOE to nY; see Figure 7
[1]
VCC = 6.0 V
transition time
tt
[1]
see Figure 6
VCC = 6.0 V
power dissipation
capacitance
CPD
Unit
[1]
VCC = 6.0 V
tdis
[2]
per package;
VI = GND to VCC
74HCT126
tpd
[1]
VCC = 4.5 V
11
ns
ten
enable time
nOE to nY; see Figure 7;
VCC = 4.5 V
[1]
13
25
31
38
ns
tdis
disable time
VCC = 4.5 V
[1]
18
28
35
42
ns
tt
transition time
VCC = 4.5 V; see Figure 6
[1]
5
12
15
18
ns
per package;
VI = GND to VCC 1.5 V
[2]
24
pF
power dissipation
capacitance
CPD
[1]
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
tt is the same as tTHL and tTLH.
[2]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC_HCT126
Product data sheet
6 of 15
74HC126; 74HCT126
Nexperia
11. Waveforms and test circuit
9,
90
Q$LQSXW
*1'
W3/+
W3+/
92+
9,
90
Q
很抱歉,暂时无法提供与“74HCT126PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.066401+0.39540
- 10+2.1441010+0.27650
- 25+1.9165025+0.24710
- 100+1.65300100+0.21310
- 250+1.52120250+0.19620
- 500+1.44930500+0.18690
- 1000+1.389401000+0.17920
- 2500+1.353502500+0.17450
- 5000+1.317605000+0.16990
- 国内价格
- 5+4.11716
- 10+2.58657
- 100+2.05265
- 500+1.95773
- 1000+1.87467
- 5000+1.85094
- 10000+1.66110
- 国内价格
- 5+1.78640
- 50+1.43260
- 150+1.28120
- 500+1.09210
- 2500+0.88100
- 5000+0.83040
