74LVC2G07GV-Q100H
74LVC2G07GV-Q100H
    NEXPERIA(安世)
    TSOP6_2.9X1.5MM
    缓冲器/驱动器 TSOP-6 Buffer, Non Reverse 1.65~5.5V Open Drain
74LVC2G07GV-Q100H 数据手册
74LVC2G07-Q100 Buffers with open-drain outputs Rev. 2 — 13 December 2016 Product data sheet 1. General description The 74LVC2G07-Q100 provides two non-inverting buffers. The output of this device is an open drain and can be connected to other open-drain outputs to implement active-LOW wired-OR or active-HIGH wired-AND functions. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. Schmitt trigger action at all inputs makes the circuit tolerant for slower input rise and fall time. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 1.65 V to 5.5 V  5 V tolerant input/output for interfacing with 5 V logic  High noise immunity  Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V)  24 mA output drive (VCC = 3.0 V)  CMOS low power consumption  Latch-up performance exceeds 250 mA  Direct interface with TTL levels  Inputs accept voltages up to 5 V  Multiple package options  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 ) 74LVC2G07-Q100 Nexperia Buffers with open-drain outputs 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name 74LVC2G07GW-Q100 40 C to +125 C 74LVC2G07GV-Q100 40 C to +125 C Description Version SC-88 plastic surface-mounted package; 6 leads SOT363 TSOP6 plastic surface-mounted package (TSOP6); 6 leads SOT457 4. Marking Table 2. Marking Type number Marking code[1] 74LVC2G07GW-Q100 V7 74LVC2G07GV-Q100 V07 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $ < $    < <  $ <  $  Logic symbol < $ *1' PQE PQE Fig 1.  Fig 2. IEC logic symbol Fig 3. PQD Logic diagram (one driver) 6. Pinning information 6.1 Pinning /9&*4 $   < *1'   9&& $   < DDD Fig 4. Pin configuration SOT363 and SOT457 74LVC2G07_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 13 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 13 74LVC2G07-Q100 Nexperia Buffers with open-drain outputs 6.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 7. Functional description Table 4. Function table[1] Input nA Output nY L L H Z [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current output voltage VO Conditions VI < 0 V [1] Max Unit 0.5 +6.5 V 50 - 0.5 +6.5 mA V 50 - [1] 0.5 +6.5 V [1][2] 0.5 +6.5 V - 50 mA VO < 0 V Active mode Power-down mode Min VO = 0 V to 6.5 V mA IO output current ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW Tamb = 40 C to +125 C [3] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For SC-88 and TSOP6 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 74LVC2G07_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 13 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 13 74LVC2G07-Q100 Nexperia Buffers with open-drain outputs 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - 5.5 V Power-down mode; VCC = 0 V 0 - 5.5 V 40 - +125 C - - 20 ns/V - - 10 ns/V Tamb ambient temperature t/V input transition rise and VCC = 1.65 V to 2.7 V fall rate VCC = 2.7 V to 5.5 V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 VIH VIL VOL Conditions Min Typ Max Unit 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - C[1] HIGH-level input voltage LOW-level input voltage LOW-level output voltage VCC = 1.65 V to 1.95 V 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.30 V IO = 12 mA; VCC = 2.7 V - - 0.40 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V - 0.1 1 A 0.3  VCC V VI = VIH or VIL [2] II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - 0.1 2 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - 0.1 2 A ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - 0.1 4 A ICC additional supply current per pin; VI = VCC  0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V - 5 500 A CI input capacitance - 2.5 - pF 74LVC2G07_Q100 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 2 — 13 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 13 74LVC2G07-Q100 Nexperia Buffers with open-drain outputs Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL LOW-level output voltage VOL VCC = 1.65 V to 1.95 V 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V 0.3  VCC V VI = VIH or VIL II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 1 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - 2 A IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - - 2 A ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - - 4 A ICC additional supply current per pin; VI = VCC  0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V - - 500 A [1] All typical values are measured at Tamb = 25 C. [2] These typical values are measured at VCC = 3.3 V. 74LVC2G07_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 13 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 13 74LVC2G07-Q100 Nexperia Buffers with open-drain outputs 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6. Symbol Parameter 40 C to +85 C Conditions power dissipation capacitance CPD Unit Min Max Min Max VCC = 1.65 V to 1.95 V 1.0 3.5 6.7 1.0 8.4 ns VCC = 2.3 V to 2.7 V 0.5 2.4 4.3 0.5 5.5 ns VCC = 2.7 V 1.0 2.3 4.2 1.0 5.3 ns VCC = 3.0 V to 3.6 V 0.5 2.6 3.7 0.5 4.7 ns VCC = 4.5 V to 5.5 V 0.5 1.5 2.9 0.5 3.7 ns - 6.5 - - - pF [2] propagation delay nA to nY; see Figure 5 tpd 40 C to +125 C Typ[1] [3] VI = GND to VCC; VCC = 3.3 V [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLZ and tPZL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 12. Waveforms 9, 90 Q$LQSXW 90 *1' W 3=/ W 3/= 9&& Q
74LVC2G07GV-Q100H 价格&库存
很抱歉,暂时无法提供与“74LVC2G07GV-Q100H”相匹配的价格&库存,您可以联系我们找货
74LVC2G07GV-Q100H
  • 3000+0.899373000+0.11197
  • 6000+0.870586000+0.10838
74LVC2G07GV-Q100H
  • 1+4.956201+0.63120
  • 10+3.0553010+0.38910
  • 50+2.2040050+0.28070
  • 100+1.92420100+0.24510
  • 1000+1.387701000+0.17670
  • 3000+0.845503000+0.10770
  • 6000+0.819806000+0.10440
库存:365
