74HCT1G125GV-Q100H
74HCT1G125GV-Q100H
    NEXPERIA(安世)
    SC-74A
    缓冲器/驱动器 Buffer, Non Reverse 4.5~5.5V 3-State
74HCT1G125GV-Q100H 数据手册
74HC1G125-Q100; 74HCT1G125-Q100 Bus buffer/line driver; 3-state Rev. 1 — 18 June 2013 Product data sheet 1. General description The 74HC1G125-Q100; 74HCT1G125-Q100 is a single buffer/line driver with 3-state output. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Input levels:  For 74HC1G125-Q100: CMOS level  For 74HCT1G125-Q100: TTL level  Symmetrical output impedance  High noise immunity  Low power consumption  Balanced propagation delays  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 3. Ordering information Table 1. Ordering information Type number 74HC1G125GW-Q100 Package Temperature range Name Description 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; SOT353-1 body width 1.25 mm 40 C to +125 C SC-74A plastic surface mounted package; 5 leads 74HCT1G125GW-Q100 74HC1G125GV-Q100 74HCT1G125GV-Q100 Version SOT753 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state 4. Marking Table 2. Marking Type number Marking code[1] 74HC1G125GW-Q100 HM 74HCT1G125GW-Q100 TM 74HC1G125GV-Q100 H25 74HCT1G125GV-Q100 T25 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 2 A Y 4 2 4 1 1 OE EN mna119 mna118 Fig 1. Logic symbol Fig 2. IEC logic symbol Y A OE mna120 Fig 3. Logic diagram 6. Pinning information 6.1 Pinning +&*4 +&7*4 2(  $  *1'   9&&  < DDD Fig 4. Pin configuration 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 2 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state 6.2 Pin description Table 3. Pin description Symbol Pin Description OE 1 output enable input (active LOW) A 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage 7. Functional description 7.1 Function table Table 4. Function table[1] Control Input Output OE A Y L L L L H H H X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V output clamping current IO output current ICC supply current IGND ground current Tstg storage temperature IOK Ptot total power dissipation Conditions Min Max Unit 0.5 +7.0 V [1] - 20 mA VO < 0.5 V or VO > VCC + 0.5 V [1] - 20 mA VO = 0.5 V to (VCC + 0.5 V) [1] - 35 mA - 70 mA 70 - mA 65 +150 C - 200 mW Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 55 C the value of Ptot derates linearly with 2.5 mW/K. 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 3 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC1G125-Q100 Min Typ 74HCT1G125-Q100 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - - 139 - - 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 10. Static characteristics Table 7. Static characteristics 74HC1G125-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 VIH VIL VOH VOL Conditions Min Typ Max Unit VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V C[1] HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - V IO = 6.0 mA; VCC = 4.5 V 3.84 4.32 - V IO = 7.8 mA; VCC = 6.0 V 5.34 5.81 - V IO = 20 A; VCC = 2.0 V - 0 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 V VI = VIH or VIL VI = VIH or VIL IO = 20 A; VCC = 6.0 V - 0 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.33 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.33 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 5 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 10 A CI input capacitance - 1.5 - pF 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 4 of 16 Nexperia 74HC1G125-Q100; 74HCT1G125-Q100 Bus buffer/line driver; 3-state Table 7. Static characteristics 74HC1G125-Q100 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL VOH VOL HIGH-level output voltage LOW-level output voltage VI = VIH or VIL IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 6.0 mA; VCC = 4.5 V 3.7 - - V IO = 7.8 mA; VCC = 6.0 V 5.2 - - V IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 6.0 mA; VCC = 4.5 V - - 0.4 V VI = VIH or VIL IO = 7.8 mA; VCC = 6.0 V - - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 20 A [1] All typical values are measured at Tamb = 25 C. 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 5 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state Table 8. Static characteristics 74HCT1G125-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 Conditions Min Typ Max Unit C[1] VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage VOL IO = 20 A 4.4 4.5 - V IO = 6.0 mA 3.84 4.32 - V IO = 20 A - 0 0.1 V IO = 6.0 mA VI = VIH or VIL; VCC = 4.5 V - 0.16 0.33 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - 5 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 10 A ICC additional supply current VI = VCC  2.1 V; IO = 0 A; VCC = 4.5 V to 5.5 V - - 500 A CI input capacitance - 1.5 - pF Tamb = 40 C to +125 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 - - V IO = 6.0 mA 3.7 - - V IO = 20 A - - 0.1 V IO = 6.0 mA - - 0.4 V LOW-level output voltage VOL VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20 A ICC additional supply current VI = VCC  2.1 V; IO = 0 A; VCC = 4.5 V to 5.5 V - - 850 A [1] All typical values are measured at Tamb = 25 C. 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 6 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state 11. Dynamic characteristics Table 9. Dynamic characteristics 74HC1G125-Q100 Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 7 Symbol Parameter Tamb = 40 C to +85 tpd Conditions Min Typ Max Unit VCC = 2.0 V - 24 125 ns VCC = 4.5 V - 10 25 ns VCC = 5 V; CL = 15 pF - 9 - ns - 8 21 ns VCC = 2.0 V - 19 155 ns VCC = 4.5 V - 9 31 ns - 7 26 ns VCC = 2.0 V - 18 155 ns VCC = 4.5 V - 12 31 ns C[1] propagation delay A to Y; see Figure 5 [2] VCC = 6.0 V ten enable time OE to Y; see Figure 6 [2] VCC = 6.0 V tdis disable time OE to Y; see Figure 6 [2] VCC = 6.0 V CPD power dissipation capacitance VI = GND to VCC [3] A to Y; see Figure 5 [2] - 11 26 ns - 30 - pF Tamb = 40 C to +125 C tpd propagation delay VCC = 2.0 V - - 150 ns VCC = 4.5 V - - 30 ns - - 26 ns VCC = 6.0 V ten enable time OE to Y; see Figure 6 [2] VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns - - 32 ns VCC = 6.0 V tdis [1] [2] disable time OE to Y; see Figure 6 [2] VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns VCC = 6.0 V - - 32 ns All typical values are measured at Tamb = 25 C. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 7 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state Table 10. Dynamic characteristics 74HCT1G125-Q100 Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 7 Symbol Parameter Conditions Min Typ[1] Max Unit - 11 30 ns Tamb = 40 C to +85 C tpd propagation delay A to Y; see Figure 5 [2] VCC = 4.5 V VCC = 5 V; CL = 15 pF - 10 - ns - 10 35 ns ten enable time VCC = 4.5 V; OE to Y; see Figure 6 [2] tdis disable time VCC = 4.5 V; OE to Y; see Figure 6 [2] - 11 31 ns CPD power dissipation capacitance VI = GND to VCC  1.5 V [3] - 27 - pF VCC = 4.5 V; A to Y; see Figure 5 [2] - - 36 ns - - 42 ns - - 38 ns Tamb = 40 C to +125 C tpd propagation delay ten enable time VCC = 4.5 V; OE to Y; see Figure 6 [2] tdis disable time VCC = 4.5 V; OE to Y; see Figure 6 [2] [1] [2] All typical values are measured at Tamb = 25 C. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 8 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state 12. Waveforms VI VM A input GND t PLH t PHL VM Y output 001aad070 Measurement points are given in Table 11. Fig 5. Propagation delay data input (A) to output (Y) VI OE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled mna644 Measurement points are given in Table 11. Logic levels: VOL and VOH are typical output voltage drop that occur with the output load. Fig 6. Table 11. Enable and disable times Measurement points Type Input Output VM VM VX VY 74HC1G125-Q100 0.5VCC 0.5VCC VOL  0.3 V VOH  0.3 V 74HCT1G125-Q100 1.3 V 1.3 V VOL  0.3 V VOH  0.3 V 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 9 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 12. Definitions for test circuit: RT = Termination resistance should be equal to the output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistor S1 = Test selection switch Fig 7. Table 12. Test circuit for measuring switching times Test data Type Input VI tr, tf CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 74HC1G125-Q100 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT1G125-Q100 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT1G125_Q100 Product data sheet Load S1 position All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 10 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state 13. Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm E D SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 L e w M bp detail X e1 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 Fig 8. REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Package outline SOT353-1 (TSSOP5) 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 11 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state Plastic surface-mounted package; 5 leads SOT753 D E B y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT753 Fig 9. JEITA EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 SC-74A Package outline SOT753 (SC-74A) 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 12 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state 14. Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor ESD ElectroStatic Discharge HBM Human Body Model TTL Transistor-Transistor Logic MM Machine Model 15. Revision history Table 14. Revision history Document ID Release date 74HC_HCT1G125_Q100 v.1 20130618 74HC_HCT1G125_Q100 Product data sheet Data sheet status Change notice Supersedes Product data sheet - - All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 13 of 16 74HC1G125-Q100; 74HCT1G125-Q100 Nexperia Bus buffer/line driver; 3-state 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT1G125_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 14 of 16 Nexperia 74HC1G125-Q100; 74HCT1G125-Q100 Bus buffer/line driver; 3-state No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT1G125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 18 June 2013 © Nexperia B.V. 2017. All rights reserved 15 of 16 Nexperia 74HC1G125-Q100; 74HCT1G125-Q100 Bus buffer/line driver; 3-state 18. Contents 1 2 3 4 5 6 6.1 6.2 7 7.1 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 June 2013
74HCT1G125GV-Q100H 价格&库存
很抱歉,暂时无法提供与“74HCT1G125GV-Q100H”相匹配的价格&库存,您可以联系我们找货
