74HCT126PW-Q100J
74HCT126PW-Q100J
    NEXPERIA(安世)
    TSSOP-14
    缓冲器/驱动器 TSSOP14 Buffer, Non Reverse 4.5~5.5V 3-State
74HCT126PW-Q100J 数据手册
74HC126-Q100; 74HCT126-Q100 Quad buffer/line driver; 3-state Rev. 1 — 20 March 2013 Product data sheet 1. General description The 74HC126-Q100; 74HCT126-Q100 is a quad buffer/line driver with 3-state outputs controlled by the output enable inputs (nOE). A LOW on nOE causes the outputs to assume a high impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Inverting outputs  Complies with JEDEC standard no. 7A  Input levels:  For 74HC126-Q100: CMOS level  For 74HCT126-Q100: TTL level  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Ordering information Table 1. Ordering information Type number 74HC126D-Q100 Package Temperature range Name Description 40 C to +125 C SO14 plastic small outline package; 14 leads; body SOT108-1 width 3.9 mm 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm 74HCT126D-Q100 74HC126PW-Q100 74HCT126PW-Q100 Version SOT402-1 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state 4. Functional diagram 2 1A 1 1OE 1Y 3 2 1 5 2A 4 2OE 9 3A 10 3OE 12 4A 13 4OE 2Y 6 1 5 6 4 3Y 8 9 8 10 4Y 11 12 11 13 mna235 Fig 1. 3 EN1 mna236 Logic symbol Fig 2. IEC logic symbol nY nA nOE mna234 Fig 3. Logic diagram 5. Pinning information 5.1 Pinning +&4 +&74 2(   9&& $   2( <   $ 2(   < $   2( <   $ *1'   < +&4 +&74 2(   9&& $   2( <   $ 2(   < $   2( <   $ *1'   < DDD DDD Fig 4. Pin configuration for SO14 74HC_HCT126_Q100 Product data sheet Fig 5. Pin configuration for TSSOP14 All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 2 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE, 3OE, 4OE 1, 4, 10, 13 data enable input (active HIGH) 1A, 2A, 3A, 4A 2, 5, 9, 12 data input 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function selection[1] Inputs Output nOE nA nY H L L H H H L X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current 0.5 V < VO < VCC + 0.5 V ICC IGND Tstg storage temperature Max Unit 0.5 +7 V - 20 mA - 20 mA - 35 mA supply current - 70 mA ground current 70 - mA 65 +150 C - 500 mW total power dissipation Ptot Conditions SO14 and TSSOP14 packages Min [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 74HC_HCT126_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 3 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC126-Q100 Min Typ 74HCT126-Q100 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 25 C Conditions Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V LOW-level input voltage VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level output voltage VI = VIH or VIL IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V 74HC126-Q100 VIH VIL VOH VOL II HIGH-level input voltage LOW-level output voltage input leakage current 74HC_HCT126_Q100 Product data sheet V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V VI = VIH or VIL IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 4 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 25 C Conditions Tamb = 40 C to +85 C Tamb = 40 C to +125 C Min Typ Max Min Max Min Max Unit IOZ OFF-state output current per input pin; VI = VIH or VIL; VO = VCC or GND; other inputs at VCC or GND; VCC = 6.0 V; IO = 0 A - 0.5 - 5.0 - 10 - A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A CI input capacitance - 3.5 - - - - - pF 74HCT126-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 6.0 mA 3.98 4.32 - 3.84 - 3.7 - V IO = 20 A; - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA; - 0.16 0.26 - 0.33 - 0.4 V A VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 IOZ OFF-state output current per input pin; VI = VIH or VIL; VO = VCC or GND; other inputs at VCC or GND; VCC = 5.5 V; IO = 0 A - - 0.5 - 5.0 - 10 ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 A ICC additional supply current per input pin; IO = 0 A; VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - 100 360 - 450 - 490 A - 3.5 - - - - - pF nA, nOE inputs CI input capacitance 74HC_HCT126_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © A Nexperia B.V. 2017. All rights reserved 5 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Figure 8. Symbol Parameter Tamb = 25 C Conditions Tamb = 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) VCC = 2.0 V - 30 100 125 150 ns VCC = 4.5 V - 11 20 25 30 ns VCC = 5.0 V; CL = 15 pF - 9 - - - ns VCC = 6.0 V - 9 17 21 26 ns VCC = 2.0 V - 41 125 155 190 ns VCC = 4.5 V - 15 25 31 38 ns VCC = 6.0 V - 12 21 26 32 ns VCC = 2.0 V - 41 125 155 190 ns VCC = 4.5 V - 15 25 31 38 ns VCC = 6.0 V - 12 21 26 32 ns VCC = 2.0 V - 14 60 75 90 ns VCC = 4.5 V - 5 12 15 18 ns VCC = 6.0 V - 4 10 13 15 ns - 23 - - - pF - 14 24 30 36 ns - 11 - - - ns - 13 25 31 38 ns - 18 28 35 42 ns - 5 12 15 18 ns 74HC126-Q100 tpd ten tdis tt CPD propagation delay nA to nY; see Figure 6 enable time disable time transition time power dissipation capacitance nOE to nY; see Figure 7 nOE to nY; see Figure 7 [1] [1] [1] [1] see Figure 6 [2] per package; VI = GND to VCC 74HCT126-Q100 tpd propagation delay nA to nY; see Figure 6 [1] VCC = 4.5 V VCC = 5.0 V; CL = 15 pF ten enable time nOE to nY; see Figure 7 [1] VCC = 4.5 V tdis disable time nOE to nY; see Figure 7 [1] VCC = 4.5 V tt transition time 74HC_HCT126_Q100 Product data sheet VCC = 4.5 V; see Figure 6 [1] All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 6 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Figure 8. Symbol Parameter CPD [1] power dissipation capacitance Tamb = 25 C Conditions Min Typ Max Max (85 C) Max (125 C) - 24 - - - [2] per package; VI = GND to VCC  1.5 V Tamb = 40 C to +125 C Unit pF tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. tt is the same as tTHL and tTLH. [2] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 11. Waveforms VI VM nA input GND tPHL VOH tPLH VI 90% VM nY output VOL 10% tTHL tTLH mna948 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Input to output propagation delays 74HC_HCT126_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 7 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state VI VM nOE input GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled mna684 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Table 8. 3-state enable and disable times Measurement points Type Input Output VM VM VX VY 74HC126-Q100 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT126-Q100 1.3 V 1.3 V 0.1VCC 0.9VCC 74HC_HCT126_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 8 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistance S1 = Test selection switch Fig 8. Table 9. Test circuit for measuring switching times Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC126-Q100 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT126-Q100 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT126_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 9 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74HC_HCT126_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 10 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 10. Package outline SOT402-1 (TSSOP14) 74HC_HCT126_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 11 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MIL Military MM Machine Model 14. Revision history Table 11. Revision history Document ID Release date 74HC_HCT126_Q100 v.1 20130320 74HC_HCT126_Q100 Product data sheet Data sheet status Change notice Supersedes Product data sheet - - All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 12 of 15 74HC126-Q100; 74HCT126-Q100 Nexperia Quad buffer/line driver; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT126_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 13 of 15 Nexperia 74HC126-Q100; 74HCT126-Q100 Quad buffer/line driver; 3-state No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT126_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2013 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia 74HC126-Q100; 74HCT126-Q100 Quad buffer/line driver; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 March 2013 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HCT126PW-Q100J 74HCT126D-Q100J 74HC126PW-Q100J 74HC126D-Q100J
74HCT126PW-Q100J 价格&库存
很抱歉,暂时无法提供与“74HCT126PW-Q100J”相匹配的价格&库存,您可以联系我们找货
74HCT126PW-Q100J
  • 2500+1.715072500+0.22167
