74LV244-Q100
Octal buffer/line driver (3-state)
Rev. 1 — 19 May 2014
Product data sheet
1. General description
The 74LV244-Q100 is a low-voltage Si-gate CMOS device and is pin and function
compatible with 74HC244-Q100 and 74HCT244-Q100.
The 74LV244-Q100 is an octal non-inverting buffer/line driver with 3-state outputs. The
output enable inputs 1OE and 2OE control the 3-state outputs. A HIGH on nOE causes
the outputs to assume a high impedance OFF-state.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide operating voltage: 1.0 V to 5.5 V
Optimized for low voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical VOLP (output ground bounce) < 0.8 V at VCC = 3.3 V; Tamb = 25 C
Typical VOHV (output VOH undershoot) > 2 V at VCC = 3.3 V; Tamb = 25 C
Complies with JEDEC standard no. 7A
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LV244D-Q100
40 C to +125 C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
74LV244PW-Q100
40 C to +125 C
TSSOP20 plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74LV244-Q100
Nexperia
4. Block diagram
很抱歉,暂时无法提供与“74LV244PW-Q100J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+3.015182500+0.39189
- 5000+2.936965000+0.38172
- 7500+2.897797500+0.37663
- 12500+2.8543812500+0.37099
- 17500+2.8290017500+0.36769
- 25000+2.8045925000+0.36452
- 国内价格 香港价格
- 1+6.528851+0.84856
- 10+4.6576710+0.60536
- 25+4.1852925+0.54397
- 100+3.66469100+0.47630
- 250+3.41728250+0.44415
- 500+3.26801500+0.42475
- 1000+3.227261000+0.41945
