74LV244D-Q100J
74LV244D-Q100J
    NEXPERIA(安世)
    SOIC20_12.8X7.5MM
    缓冲器/驱动器 SO-20 Buffer, Non Reverse 1~5.5V 3-State
74LV244D-Q100J 数据手册
74LV244-Q100 Octal buffer/line driver (3-state) Rev. 1 — 19 May 2014 Product data sheet 1. General description The 74LV244-Q100 is a low-voltage Si-gate CMOS device and is pin and function compatible with 74HC244-Q100 and 74HCT244-Q100. The 74LV244-Q100 is an octal non-inverting buffer/line driver with 3-state outputs. The output enable inputs 1OE and 2OE control the 3-state outputs. A HIGH on nOE causes the outputs to assume a high impedance OFF-state. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide operating voltage: 1.0 V to 5.5 V  Optimized for low voltage applications: 1.0 V to 3.6 V  Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V  Typical VOLP (output ground bounce) < 0.8 V at VCC = 3.3 V; Tamb = 25 C  Typical VOHV (output VOH undershoot) > 2 V at VCC = 3.3 V; Tamb = 25 C  Complies with JEDEC standard no. 7A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV244D-Q100 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74LV244PW-Q100 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74LV244-Q100 Nexperia Octal buffer/line driver (3-state) 4. Block diagram           $
74LV244D-Q100J 价格&库存
很抱歉,暂时无法提供与“74LV244D-Q100J”相匹配的价格&库存,您可以联系我们找货
