74AHCT138PW,118
74AHCT138PW,118
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    3到8线解码器/解复用器;反转 TSSOP16_5X4.4MM 4.5~5.5V
74AHCT138PW,118 数据手册
74AHC138; 74AHCT138 3-to-8 line decoder/demultiplexer; inverting Rev. 4 — 2 April 2014 Product data sheet 1. General description The 74AHC138; 74AHCT138 are high-speed Si-gate CMOS devices and are pin compatible with Low power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard No. 7A. The 74AHC138; 74AHCT138 is a 3-to-8 line decoder/demultiplexer. It accepts three binary weighted address inputs (A0, A1 and A2) and, when enabled, provides eight mutually exclusive outputs (Y0 to Y7) that are LOW when selected. There are three enable inputs: two active LOW (E1 and E2) and one active HIGH (E3). Every output will be HIGH unless E1 and E2 are LOW and E3 is HIGH. This multiple enable function allows easy parallel expansion of the device to a 1-of-32 (5 lines to 32 lines) decoder with just four 74AHC138; 74AHCT138 devices and one inverter. The 74AHC138; 74AHCT138 can be used as an eight output demultiplexer by using one of the active LOW enable inputs as the data input and the remaining enable inputs as strobes. Unused enable inputs must be permanently tied to their appropriate active HIGH or LOW state. 2. Features and benefits          Balanced propagation delays All inputs have Schmitt-trigger action Demultiplexing capability Multiple input enable for easy expansion Ideal for memory chip select decoding Inputs accepts voltages higher than VCC For 74AHC138 only: operates with CMOS input levels For 74AHCT138 only: operates with TTL input levels ESD protection:  HBM JESD22-A114E exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101C exceeds 1000 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 3. Ordering information Table 1. Ordering information Type number Package 74AHC138D Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal-enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm 74AHCT138D 74AHC138PW 74AHCT138PW 74AHC138BQ 74AHCT138BQ SOT763-1 4. Functional diagram DX 1 A0 1 Y0 A1 Y1 14 3 A2 Y2 13 Y3 12 E1 Y4 11 E2 Y5 10 E3 Y6 9 Y7 7 4 5 6 3 G 0 7 2 2 3 4 4 & 5 5 6 6 7 14 1 13 2 12 3 1 1 2 2 4 3 11 4 10 4 9 5 7 0 & 5 6 EN 6 7 15 14 13 12 11 10 9 7 mna371 Logic symbol Fig 2. (b) IEC logic symbol Y0 15 1 A0 Y1 14 2 A1 Y2 13 3 A2 Y3 12 Y4 11 Y5 10 Y6 9 Y7 7 3-to-8 DECODER 4 X/Y 15 (a) mna370 Fig 1. 1 2 15 2 0 0 ENABLE EXITING E1 5 E2 6 E3 mna372 Fig 3. Functional diagram 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 2 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 5. Pinning information A0 terminal 1 index area 16 VCC 5.1 Pinning 1 16 VCC A1 2 15 Y0 A1 2 15 Y0 A2 3 14 Y1 A2 3 14 Y1 E1 4 13 Y2 E1 4 1 A0 E3 6 11 Y4 Y7 7 10 Y5 GND 8 9 E2 5 E3 6 Y7 7 Y6 GND(1) 12 Y3 11 Y4 10 Y5 9 12 Y3 Y6 5 8 E2 13 Y2 138 GND 138 001aad035 Transparent top view 001aad033 (1) The die substrate is attached to this pad using conductive die attach material. It can not be used as a supply pin or input. Fig 4. Pin configuration for SO16 and TSSOP16 Fig 5. Pin configuration for DHVQFN16 5.2 Pin description Table 2. Pin description Symbol Pin Description A0 1 address input A1 2 address input A2 3 address input E1 4 enable input (active LOW) E2 5 enable input (active LOW) E3 6 enable input (active HIGH) GND 8 ground (0 V) Y0 to Y7 15, 14, 13, 12, 11, 10, 9, 7 output VCC 16 supply voltage 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 3 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 6. Functional description Function table [1] Table 3. Input Output E1 E2 E3 A0 A1 A2 Y0 Y1 Y2 Y3 Y4 Y5 Y6 Y7 H X X X X X H H H H H H H H X H X X X X H H H H H H H H X X L X X X H H H H H H H H L L H L L L L H H H H H H H L L H H L L H L H H H H H H L L H L H L H H L H H H H H L L H H H L H H H L H H H H L L H L L H H H H H L H H H L L H H L H H H H H H L H H L L H L H H H H H H H H L H L L H H H H H H H H H H H L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage 0.5 +7.0 V VI input voltage IIK input clamping current VI < 0.5 V [1] 0.5 +7.0 V 20 - IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] mA - 20 mA IO output current VO = 0.5 V to (VCC + 0.5 V) - 25 mA ICC IGND supply current - 75 mA ground current 75 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation Tamb = 40 C to +125 C SO16 package [2] - 500 mW TSSOP16 package [3] - 500 mW DHVQFN16 package [4] - 500 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 C. [3] Ptot derates linearly with 5.5 mW/K above 60 C. [4] Ptot derates linearly with 4.5 mW/K above 60 C. 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 4 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74AHC138 Min 74AHCT138 Typ Max Min Unit Typ Max VCC supply voltage 2.0 5.0 5.5 4.5 5.0 5.5 V VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 3.3 V  0.3 V - - 100 - - - ns/V VCC = 5.0 V  0.5 V - - 20 - - 20 ns/V 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V For type 74AHC138 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 50 A; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.4 - V IO = 8.0 mA; VCC = 4.5 V 3.94 - - 3.8 - 3.7 - V LOW-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 A II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A CI input capacitance - 3.0 10 - 10 - 10 pF 74AHC_AHCT138 Product data sheet VI = 5.5 V or GND; VCC = 0 V or 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 5 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max For type 74AHCT138 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.7 - V IO = 8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A IO = 8.0 mA 0 0.1 - 0.1 - 0.1 V - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 A II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A ICC additional per input pin; supply current VI = VCC  2.1 V; IO = 0 A; other pins at VCC or GND; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3.0 10 - 10 - 10 pF 74AHC_AHCT138 Product data sheet VI = 5.5 V or GND; VCC = 0 V or 5.5 V - All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 6 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 8. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 6.0 11.4 1.0 13.0 1.0 14.5 ns CL = 50 pF - 8.6 15.8 1.0 18.0 1.0 20.0 ns - 4.4 8.1 1.0 9.5 1.0 10.5 ns - 6.3 10.1 1.0 11.5 1.0 13.0 ns CL = 15 pF - 5.8 12.8 1.0 15.0 1.0 16.0 ns CL = 50 pF - 8.2 16.3 1.0 18.5 1.0 20.5 ns - 4.2 8.1 1.0 9.5 1.0 10.5 ns - 6.0 10.1 1.0 11.5 1.0 13.0 ns CL = 15 pF - 5.7 11.4 1.0 13.5 1.0 14.5 ns CL = 50 pF - 8.2 14.9 1.0 17.0 1.0 19.0 ns CL = 15 pF - 4.2 8.1 1.0 9.5 1.0 10.5 ns CL = 50 pF - 6.0 10.1 1.0 11.5 1.0 13.0 ns - 18.0 - - - - - pF For type 74AHC138 tpd propagation delay An to Yn; see Figure 6 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF E3 to Yn; see Figure 6 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF E1, E2 to Yn; see Figure 7 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CPD power dissipation capacitance 74AHC_AHCT138 Product data sheet CL = 50 pF; fi = 1 MHz; VI = GND to VCC [4] All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 7 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Table 7. Dynamic characteristics …continued GND = 0 V; For test circuit see Figure 8. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max - 4.4 10.4 1.0 12.0 1.0 13.0 ns - 6.2 11.4 1.0 13.0 1.0 14.5 ns - 4.3 9.1 1.0 10.5 1.0 11.5 ns - 6.2 10.1 1.0 11.5 1.0 13.0 ns - 4.3 9.6 1.0 11.0 1.0 12.0 ns - 6.2 10.6 1.0 12.0 1.0 13.5 ns - 23.0 - - - - - pF For type 74AHCT138 propagation delay tpd An to Yn; see Figure 6 [2] VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF E3 to Yn; see Figure 6 [2] VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF E1, E2 to Yn; see Figure 7 [2] VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF power dissipation capacitance CPD CL = 50 pF; fi = 1 MHz; VI = GND to VCC [4] [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL. [3] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in V N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 11. Waveforms VCC An, E3 input VM GND tPHL tPLH VOH Yn output VM VOL 001aah080 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. The inputs An, E3 to outputs Yn propagation delays 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 8 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting VCC E1, E2 input VM GND tPHL tPLH VOH Yn output VM VOL 001aah081 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. The inputs En to outputs Yn propagation delays Table 8. Measurement points Type Input Output VM VM 74AHC138 0.5VCC 0.5VCC 74AHCT138 1.5 V 0.5VCC 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 9 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC VI G VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 8. Load circuit for switching times Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74AHC138 VCC  3.0 ns 15 pF, 50 pF 1 k open GND VCC 74AHCT138 3.0 V  3.0 ns 15 pF, 50 pF 1 k open GND VCC 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 10 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 11 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 10. Package outline SOT403-1 (TSSOP16) 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 12 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 7 y y1 C v M C A B w M C b L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 11. Package outline SOT763-1 (DHVQFN16) 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 13 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor LSTTL Low-power Schottky Transistor-Transistor Logic ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model CDM Charged-Device Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT138 v.4 20140402 Product data sheet - 74AHC_AHCT138 v.3 Modifications: • Description for tpd for the 74AHCT138 corrected (errata) in Table 7 “Dynamic characteristics” 74AHC_AHCT138 v.3 20071128 Product data sheet 74AHC_AHCT138 v.2 19990927 Product specification - 74AHC_AHCT138 v.1 74AHC_AHCT138 v.1 19900331 Product specification - - 74AHC_AHCT138 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 74AHC_AHCT138 v.2 © Nexperia B.V. 2017. All rights reserved 14 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AHC_AHCT138 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 15 of 17 74AHC138; 74AHCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AHC_AHCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 April 2014 © Nexperia B.V. 2017. All rights reserved 16 of 17 Nexperia 74AHC138; 74AHCT138 3-to-8 line decoder/demultiplexer; inverting 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 02 April 2014 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AHC138BQ,115 74AHC138D,112 74AHC138D,118 74AHC138PW,112 74AHC138PW,118 74AHCT138BQ,115 74AHCT138D,112 74AHCT138D,118 74AHCT138PW,112 74AHCT138PW,118
74AHCT138PW,118
1. 物料型号:74AHC_AHCT138,由Nexperia生产。
2. 器件简介:74AHC_AHCT138是一款高速CMOS双路四输入与非门,具有低功耗和高速特性,适用于高速数字电路。
3. 引脚分配:该器件共有14个引脚,包括电源Vcc、接地GND、四个输入端A、B、C、D和两个输出端Y、Z。
4. 参数特性:工作电压范围为2.0V至5.5V,工作温度范围为-40℃至+125℃,功耗低,传输延迟时间快。
5. 功能详解:74AHC_AHCT138包含两个独立的四输入与非门,可以实现复杂的逻辑功能。
6. 应用信息:适用于高速数字系统、通信设备、计算机外设等需要高速逻辑处理的场合。
7. 封装信息:提供多种封装选项,包括SOIC、TSSOP等,以满足不同应用需求。
74AHCT138PW,118 价格&库存
很抱歉,暂时无法提供与“74AHCT138PW,118”相匹配的价格&库存,您可以联系我们找货
74AHCT138PW,118
  • 1+3.136121+0.37475
  • 10+2.1879910+0.26145
  • 25+1.9437725+0.23227
  • 100+1.67840100+0.20056
  • 250+1.55168250+0.18542
  • 500+1.47535500+0.17630
  • 1000+1.412601000+0.16880
库存:2475
74AHCT138PW,118
  • 2500+1.101792500+0.13166
  • 5000+1.067945000+0.12762
  • 7500+1.050987500+0.12559
  • 12500+1.0321812500+0.12334
  • 17500+1.0211917500+0.12203
  • 25000+1.0106425000+0.12077
  • 62500+0.9878962500+0.11805
库存:2475
74AHCT138PW,118
    • 1+2.31120
    • 10+1.97640
    • 30+1.82520
    • 100+1.64160
    • 500+1.56600
    • 1000+1.51200
    库存:1731
    74AHCT138PW,118
      • 2500+0.928922500+0.11100
      • 5000+0.914995000+0.10934
      • 7500+0.904777500+0.10812
      • 10000+0.8982710000+0.10734
      • 12500+0.8778312500+0.10490
      库存:2500
