74AHC139; 74AHCT139
Dual 2-to-4 line decoder/demultiplexer
Rev. 02 — 9 May 2008
Product data sheet
1. General description
The 74AHC139; 74AHCT139 is a high-speed Si-gate CMOS device and is pin compatible
with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard
No. 7-A.
The 74AHC139; 74AHCT139 is a high-speed, dual 2-to-4 line decoder/demultiplexer. This
device has two independent decoders, each accepting two binary weighted inputs (nA0
and nA1) and providing four mutually exclusive active LOW outputs (nY0 to nY3). Each
decoder has an active LOW enable input (nE). When nE is HIGH, every output is forced
HIGH. The enable input can be used as the data input for a 1-to-4 demultiplexer
application.
The 74AHC139; 74AHCT139 is identical to the HEF4556 of the HE4000B family.
2. Features
n
n
n
n
Balanced propagation delays
All inputs have Schmitt-trigger actions
Inputs accept voltages higher than VCC
Input levels:
u For 74AHC139: CMOS level
u For 74AHCT139: TTL level
n ESD protection:
u HBM EIA/JESD22-A114E exceeds 2000 V
u MM EIA/JESD22-A115-A exceeds 200 V
u CDM EIA/JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74AHC139D
−40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74AHC139PW
−40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74AHC139
74AHC139; 74AHCT139
Nexperia
Table 1.
Ordering information …continued
Type number
Package
Description
Version
74AHCT139D
−40 °C to +125 °C
SO16
body width 3.9 mm
SOT109-1
74AHCT139PW
−40 °C to +125 °C
TSSOP16
body width 4.4 mm
SOT403-1
74AHCT139
4. Functional diagram
1
1E
1Y0
2
3
1A0
1Y1
1A1
1Y2
1Y3
2Y0
14
13
2A0
2Y1
2A1
2Y2
2Y3
4
DX 0
0 1
G
3
1
2
2
5
6
1
3
7
5
6
7
2
3
1
X/Y 0
1
1
2
2
EN
3
4
5
6
7
12
11
DX 0
0 1
G
3
1
2
14
10
9
15
2E
15
4
3
12
11
10
9
14
13
15
X/Y 0
1
2
EN
(a)
mna779
1
2
3
(b)
12
11
10
9
mna781
a = demultiplexer and b = decoder
Fig 1. Logic symbol
Fig 2. IEC logic symbol
2
1A0
3
1A1
1
1E
14
2A0
13
2A1
DECODER
1Y0
4
1Y1
5
1Y2
6
1Y3
7
2Y0 12
2Y1 11
DECODER
2Y2 10
2Y3
15
9
2E
mna780
Fig 3. Functional diagram
74AHC_AHCT139_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 14
74AHC139; 74AHCT139
Nexperia
5. Pinning information
5.1 Pinning
1E
1
16 VCC
1A0
2
15 2E
1A1
3
14 2A0
1Y0
4
13 2A1
139
1Y1
5
12 2Y0
1Y2
6
11 2Y1
1Y3
7
10 2Y2
GND
8
9
2Y3
001aad029
Fig 4.
Pin configuration
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1E
1
enable input (active LOW)
1A0
2
address input
1A1
3
address input
1Y0
4
output
1Y1
5
output
1Y2
6
output
1Y3
7
output
GND
8
ground (0 V)
2Y3
9
output
2Y2
10
output
2Y1
11
output
2Y0
12
output
2A1
13
address input
2A0
14
address input
2E
15
VCC
16
supply voltage
74AHC_AHCT139_2
Product data sheet
3 of 14
74AHC139; 74AHCT139
Nexperia
6. Functional description
Table 3.
Function table[1]
Control
Input
nE
nA0
nA1
nY0
nY1
nY2
nY3
H
X
X
H
H
H
H
L
L
L
L
H
H
H
H
L
H
L
H
H
L
H
H
H
L
H
H
H
H
H
H
L
[1]
Output
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
ICC
IIK
Min
Max
Unit
−0.5
+7.0
V
−0.5
+7.0
V
−20
mA
−20
+20
mA
−25
+25
mA
supply current
+75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
Ptot
total power dissipation
500
mW
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO16 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For TSSOP16 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
74AHC_AHCT139_2
Product data sheet
4 of 14
74AHC139; 74AHCT139
Nexperia
8. Recommended operating conditions
Table 5.
Operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
Unit
2.0
5.0
5.5
V
74AHC139
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHCT139
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
74AHC139
VIH
VIL
VOH
VOL
HIGH-level
input voltage
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
74AHC_AHCT139_2
Product data sheet
5 of 14
74AHC139; 74AHCT139
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
Min
Typ
Max
Min
Max
Min
Max
0.1
1.0
2.0
µA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
4.0
40
80
µA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
VI = VCC or GND
74AHCT139
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
4.4
4.5
4.4
4.4
V
3.94
3.80
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
VCC = 5.5 V
4.0
40
80
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V; other pins
at VCC or GND; IO = 0 A;
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
VI = VCC or GND
74AHC_AHCT139_2
Product data sheet
6 of 14
74AHC139; 74AHCT139
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
5.5
11.0
1.0
13.0
1.0
14.0
ns
CL = 50 pF
7.9
14.5
1.0
16.5
1.0
18.5
ns
3.9
7.2
1.0
8.5
1.0
9.0
ns
5.6
9.2
1.0
10.5
1.0
11.5
ns
CL = 15 pF
4.8
9.2
1.0
11.0
1.0
11.5
ns
CL = 50 pF
6.9
12.7
1.0
14.5
1.0
16.0
ns
3.4
6.3
1.0
7.5
1.0
8.0
ns
4.9
8.3
1.0
9.5
1.0
10.5
ns
26
pF
4.7
7.2
1.0
8.5
1.0
9.0
ns
6.5
9.2
1.0
10.5
1.0
11.5
ns
3.6
6.3
1.0
7.5
1.0
8.0
ns
5.2
8.3
1.0
9.5
1.0
10.5
ns
23
pF
74AHC139
tpd
[2]
propagation nAn to nYn; see Figure 5
delay
CL = 15 pF
CL = 50 pF
[2]
nE to nYn; see Figure 6
CL = 15 pF
CL = 50 pF
CPD
power
fi = 1 MHz; VI = GND to VCC
dissipation
capacitance
[3]
74AHCT139; VCC = 4.5 V to 5.5 V
tpd
[2]
delay
CL = 15 pF
CL = 50 pF
[2]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
[3]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
74AHC_AHCT139_2
Product data sheet
7 of 14
74AHC139; 74AHCT139
Nexperia
11. Waveforms
VI
VM
nAn input
GND
t PHL
t PLH
VOH
VM
nYn output
VOL
mna782
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 5.
Address input to output propagation delays
VI
VM
nE input
GND
tPHL
tPLH
VOH
VM
nYn output
VOL
mna783
Fig 6.
Enable input to output propagation delays
Table 8.
Measurement points
Type
Input
Output
VM
VM
74AHC139
0.5 × VCC
0.5 × VCC
74AHCT139
1.5 V
0.5 × VCC
74AHC_AHCT139_2
Product data sheet
8 of 14
74AHC139; 74AHCT139
Nexperia
VI
negative
pulse
tW
90 %
VM
VM
10 %
GND
tr
tf
tr
VI
positive
pulse
GND
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VO
DUT
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
Fig 7.
Load circuitry for measuring switching times
Table 9.
Test data
Type
Input
Load
Test
VI
tr, tf
CL
74AHC139
VCC
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHCT139
3.0 V
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHC_AHCT139_2
Product data sheet
9 of 14
74AHC139; 74AHCT139
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
detail X
w M
bp
2.5
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.16
0.15
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 8.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT109-1 (SO16)
74AHC_AHCT139_2
Product data sheet
10 of 14
74AHC139; 74AHCT139
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
E
D
A
X
c
y
HE
v M A
Z
9
16
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
8
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
Fig 9.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Package outline SOT403-1 (TSSOP16)
74AHC_AHCT139_2
Product data sheet
11 of 14
74AHC139; 74AHCT139
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT139_2
20080509
Product data sheet
74AHC_AHCT139_1
Modifications:
74AHC_AHCT139_1
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 6: the conditions for input leakage current have been changed.
19990901
Product specification
74AHC_AHCT139_2
Product data sheet
12 of 14
74AHC139; 74AHCT139
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT139_2
Product data sheet
13 of 14
Nexperia
74AHC139; 74AHCT139
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Date of release: 09 May 2008
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC139D,112 74AHC139D,118 74AHC139PW,112 74AHC139PW,118 74AHCT139D,112 74AHCT139D,118
74AHCT139PW,112 74AHCT139PW,118
很抱歉,暂时无法提供与“74AHCT139PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+1.174602500+0.15217
- 5000+1.138675000+0.14752
- 7500+1.120687500+0.14519
- 12500+1.1007412500+0.14260
- 17500+1.0890917500+0.14109
- 25000+1.0778825000+0.13964
- 国内价格 香港价格
- 2500+1.647502500+0.21310
- 5000+1.561905000+0.20200
- 10000+1.4990010000+0.19390
- 25000+1.4700025000+0.19010
- 国内价格 香港价格
- 1+3.518491+0.45582
- 10+2.4353010+0.31549
- 25+2.1731725+0.28153
- 100+1.87862100+0.24338
- 250+1.73850250+0.22522
- 500+1.65409500+0.21429
- 1000+1.584561000+0.20528
