74AHCT139D-Q100J
74AHCT139D-Q100J
    NEXPERIA(安世)
    SOIC-16
    双2对4线解码器/多路分解器 SOIC16_150MIL 4.5~5.5V
74AHCT139D-Q100J 数据手册
74AHC139-Q100; 74AHCT139-Q100 Dual 2-to-4 line decoder/demultiplexer Rev. 1 — 5 June 2013 Product data sheet 1. General description The 74AHC139-Q100; 74AHCT139-Q100 is a high-speed Si-gate CMOS device and is pin compatible with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7A. The 74AHC139-Q100; 74AHCT139-Q100 is a high-speed, dual 2-to-4 line decoder/demultiplexer. This device has two independent decoders. Each decoder accepts two binary weighted inputs (nA0 and nA1) and provides four mutually exclusive active LOW outputs (nY0 to nY3). Each decoder has an active LOW enable input (nE). When nE is HIGH, every output is forced HIGH. The enable input can be used as the data input for a 1-to-4 demultiplexer application. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Balanced propagation delays  All inputs have Schmitt-trigger actions  Inputs accept voltages higher than VCC  Input levels:  For 74AHC139-Q100: CMOS level  For 74AHCT139-Q100: TTL level  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 74AHC139-Q100; 74AHCT139-Q100 Nexperia Dual 2-to-4 line decoder/demultiplexer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AHC139D-Q100 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74AHC139PW-Q100 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74AHC139-Q100 74AHCT139-Q100 74AHCT139D-Q100 74AHCT139PW-Q100 40 C to +125 C 4. Functional diagram 1 1E 1Y0 2 3 1A0 1Y1 1A1 1Y2 1Y3 2Y0 14 13 2A0 2Y1 2A1 2Y2 2Y3 4 5 6 2 3 1 DX 0 0 1 G 3 1 2 0 3 7 5 6 7 2 3 1 X/Y 0 1 1 2 2 EN 3 4 5 6 7 12 11 14 10 13 9 15 DX 0 0 1 G 3 1 2 0 2E 15 4 3 12 11 10 9 14 13 15 X/Y 0 1 2 2 EN (a) mna779 1 3 (b) 12 11 10 9 mna781 a = demultiplexer and b = decoder Fig 1. Logic symbol 74AHC_AHCT139_Q100 Product data sheet Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 June 2013 © Nexperia B.V. 2017. All rights reserved 2 of 16 74AHC139-Q100; 74AHCT139-Q100 Nexperia Dual 2-to-4 line decoder/demultiplexer 2 1A0 3 1A1 1 1E 14 2A0 DECODER 1Y0 4 1Y1 5 1Y2 6 1Y3 7 2Y0 12 13 2A1 2Y1 11 DECODER 2Y2 10 2Y3 15 9 2E mna780 Fig 3. Functional diagram 5. Pinning information 5.1 Pinning $+&4 $+&74 (   9&& $   ( $   $
74AHCT139D-Q100J
物料型号: - 74AHC139-Q100 - 74AHCT139-Q100
器件简介: - 高速Si-gate CMOS设备,与低功耗Schottky TTL (LSTTL)引脚兼容。 - 双2至4线解码器/解多路复用器,具有两个独立的解码器。
引脚分配: - 1E (使能输入,低电平有效) - 1A0, 1A1 (地址输入) - 1Y0 至 1Y3 (输出) - GND (地) - 2Y0 至 2Y3 (输出) - 2A0, 2A1 (地址输入) - 2E (使能输入,低电平有效) - Vcc (供电电压)
参数特性: - 工作温度范围:-40°C 至 +85°C 或 -40°C 至 +125°C - 输入电压:CMOS级别或TTL级别 - ESD保护:MIL-STD-883, method 3015超过2000V,HBM JESD22-A114F超过2000V - 多种封装选项:SO16, TSSOP16等
功能详解: - 每个解码器接收两个二进制加权输入,并提供四个相互独立的低电平有效输出。 - 当使能输入nE为高电平时,所有输出被强制为高电平。
应用信息: - 产品已通过汽车电子委员会(AEC)标准Q100认证,适用于汽车应用。
封装信息: - SO16:塑料小外形封装,16个引脚,体宽3.9毫米。 - TSSOP16:塑料薄收缩小外形封装,16个引脚,体宽4.4毫米。
74AHCT139D-Q100J 价格&库存
很抱歉,暂时无法提供与“74AHCT139D-Q100J”相匹配的价格&库存,您可以联系我们找货
74AHCT139D-Q100J
  • 2500+1.453862500+0.18864
