74AHC257; 74AHCT257
Quad 2-input multiplexer; 3-state
Rev. 02 — 9 May 2008
Product data sheet
1. General description
The 74AHC257; 74AHCT257 is a high-speed Si-gate CMOS device and is pin compatible
with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard
No. 7-A.
The 74AHC257; 74AHCT257 has four identical 2-input multiplexers with 3-state outputs,
which select 4 bits of data from two sources and are controlled by a common data select
input (S). The data inputs from source 0 (1I0 to 4I0) are selected when input S is LOW and
the data inputs from source 1 (1I1 to 4I1) are selected when input S is HIGH. Data
appears at the outputs (1Y to 4Y) in true (non-inverting) form from the selected inputs.
The 74AHC257; 74AHCT257 is the logic implementation of a 4-pole 2-position switch,
where the position of the switch is determined by the logic levels applied to input S. The
outputs are forced to a high-impedance OFF-state when OE is HIGH.
The logic equations for the outputs are:
1Y = OE × (1I1 × S + 1I0 × S)
2Y = OE × (2I1 × S + 2I0 × S)
3Y = OE × (3I1 × S + 3I0 × S)
4Y = OE × (4I1 × S + 4I0 × S)
The 74AHC257; 74AHCT257 is identical to the 74AHC258; 74AHCT258, but has
non-inverting (true) outputs.
2. Features
n
n
n
n
n
Balanced propagation delays
All inputs have Schmitt-trigger actions
Non-inverting data path
Inputs accept voltages higher than VCC
Input levels:
u For 74AHC257: CMOS level
u For 74AHCT257: TTL level
n ESD protection:
u HBM EIA/JESD22-A114E exceeds 2000 V
u MM EIA/JESD22-A115-A exceeds 200 V
u CDM EIA/JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
74AHC257; 74AHCT257
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74AHC257D
−40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74AHC257PW
−40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74AHCT257D
−40 °C to +125 °C
SO16
body width 3.9 mm
SOT109-1
74AHCT257PW
−40 °C to +125 °C
TSSOP16
body width 4.4 mm
SOT403-1
74AHC257
74AHCT257
4. Functional diagram
2
3
5
1I0 1I1
1 S
15 OE
Fig 1.
6
2I0 2I1
11
10
3I0 3I1
14
13
4I0 4I1
SELECTOR
3-STATE MULTIPLEXER OUTPUTS
1Y
2Y
3Y
4Y
4
7
9
12
mgr280
Functional diagram
74AHC_AHCT257_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 16
74AHC257; 74AHCT257
Nexperia
1
G1
15
EN
1
1I0
2
3
1I1
5
2I0
6
2I1
11
3I0
10
3I1
14
4I0
13
4I1
15
OE
S
2
4
1Y
MUX
4
1
5
7
2Y
1
3
7
6
9
3Y
11
9
10
12
4Y
14
12
13
001aad467
mga835
Fig 2.
Logic symbol
Fig 3.
IEC logic symbol
1I0
1Y
1I1
2I0
2Y
2I1
3I0
3Y
3I1
4I0
4Y
4I1
OE
S
Fig 4.
001aad468
Logic diagram
74AHC_AHCT257_2
Product data sheet
3 of 16
74AHC257; 74AHCT257
Nexperia
5. Pinning information
5.1 Pinning
S
1
16 VCC
1I0
2
15 OE
1I1
3
14 4I0
1Y
4
2I0
5
2I1
6
11 3I0
2Y
7
10 3I1
GND
8
13 4I1
257
12 4Y
9
3Y
001aad499
Fig 5.
Pin configuration SO16 and TSSOP16
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
S
1
common data select input
1I0
2
data input from source 0
1I1
3
data input from source 1
1Y
4
multiplexer output
2I0
5
2I1
6
2Y
7
multiplexer output
GND
8
ground (0 V)
3Y
9
multiplexer output
3I1
10
3I0
11
4Y
12
multiplexer output
4I1
13
4I0
14
OE
15
output enable input (active LOW)
VCC
16
supply voltage
74AHC_AHCT257_2
Product data sheet
4 of 16
74AHC257; 74AHCT257
Nexperia
6. Functional description
Table 3.
Function table[1]
Control
Input
Output
OE
S
nI0
nI1
nY
H
X
X
X
Z
L
H
X
L
L
X
H
H
L
X
L
H
X
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
Min
Max
Unit
−0.5
+7.0
V
−0.5
+7.0
V
−20
mA
−20
+20
mA
−25
+25
mA
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
ICC
supply current
+75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
Ptot
total power dissipation
500
mW
IIK
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO16 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For TSSOP16 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
74AHC_AHCT257_2
Product data sheet
5 of 16
74AHC257; 74AHCT257
Nexperia
8. Recommended operating conditions
Table 5.
Operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
74AHC257
VCC
supply voltage
2.0
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHCT257
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
74AHC257
VIH
VIL
VOH
VOL
HIGH-level
input voltage
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
74AHC_AHCT257_2
Product data sheet
6 of 16
74AHC257; 74AHCT257
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
µA
IOZ
OFF-state
VI = VIH or VIL;
output current VO = VCC or GND;
VCC = 5.5 V
±0.25
±2.5
±10.0
µA
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
4.0
40
80
µA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
VI = VCC or GND
74AHCT257
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
4.4
4.5
4.4
4.4
V
3.94
3.80
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
OFF-state
VI = VIH or VIL;
output current VO = VCC or GND per input
pin; other inputs at
VCC = 5.5 V
±0.25
±2.5
±10.0
µA
ICC
VCC = 5.5 V
4.0
40
80
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V;
other pins at VCC or GND;
IO = 0 A; VCC = 4.5 V to 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
II
input leakage
current
IOZ
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
VI = VCC or GND
74AHC_AHCT257_2
Product data sheet
7 of 16
74AHC257; 74AHCT257
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
4.2
9.3
1.0
11.0
1.0
12.0
ns
CL = 50 pF
6.0
12.8
1.0
14.5
1.0
16.0
ns
2.9
5.9
1.0
7.0
1.0
7.5
ns
4.2
7.9
1.0
9.0
1.0
11.5
ns
CL = 15 pF
5.2
11.0
1.0
13.0
1.0
14.0
ns
CL = 50 pF
7.4
14.5
1.0
16.5
1.0
18.5
ns
3.5
6.8
1.0
8.0
1.0
8.5
ns
5.0
8.8
1.0
10.0
1.0
12.5
ns
CL = 15 pF
4.5
10.5
1.0
12.5
1.0
13.5
ns
CL = 50 pF
6.4
14.0
1.0
16.0
1.0
17.5
ns
CL = 15 pF
3.2
6.8
1.0
8.0
1.0
8.5
ns
CL = 50 pF
4.5
8.8
1.0
10.0
1.0
12.5
ns
CL = 15 pF
5.1
9.5
1.0
11.0
1.0
11.5
ns
CL = 50 pF
7.2
12.0
1.0
13.5
1.0
14.5
ns
3.4
6.5
1.0
7.0
1.0
8.5
ns
4.9
7.9
1.0
9.0
1.0
9.5
ns
45
pF
15
pF
74AHC257
tpd
propagation nI0, nI1 to nY; see Figure 6
delay
[2]
CL = 15 pF
CL = 50 pF
[2]
S to nY; see Figure 6
CL = 15 pF
CL = 50 pF
ten
enable time
[3]
OE to nY; see Figure 7
tdis
[4]
disable time OE to nY; see Figure 7
CL = 15 pF
CL = 50 pF
CPD
power
fi = 1 MHz; VI = GND to VCC
dissipation
4 outputs switching via
capacitance
input S
1 output switching via
input I
[5]
74AHC_AHCT257_2
Product data sheet
8 of 16
74AHC257; 74AHCT257
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
3.7
6.5
1.0
8.0
1.0
9.0
ns
4.9
8.5
1.0
10.0
1.0
11.0
ns
CL = 15 pF
5.1
9.0
1.0
10.5
1.0
11.5
ns
CL = 50 pF
6.4
10.5
1.0
12.5
1.0
13.5
ns
3.9
8.0
1.0
9.0
1.0
10.0
ns
5.1
10.0
1.0
11.0
1.0
12.0
ns
4.5
7.5
1.0
8.0
1.0
8.5
ns
6.5
9.5
1.0
10.5
1.0
11.5
ns
51
pF
15
pF
74AHCT257; VCC = 4.5 V to 5.5 V
tpd
delay
CL = 15 pF
[2]
CL = 50 pF
[2]
ten
enable time
[3]
CL = 15 pF
CL = 50 pF
tdis
[4]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
input S
input I
[5]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
ten is the same as tPZL and tPZH.
[4]
tdis is the same as tPLZ and tPHZ.
[5]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
74AHC_AHCT257_2
Product data sheet
9 of 16
74AHC257; 74AHCT257
Nexperia
11. Waveforms
VI
nI0, nI1, S
VM
input
GND
t PHL
t PLH
VOH
VM
nY output
mna486
VOL
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6.
Data inputs and common data select input to output propagation delays
VI
OE input
VM
GND
t PLZ
t PZL
VCC
Qn output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PZH
t PHZ
VOH
VY
Qn output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
mna813
Fig 7.
Enable and disable times
Table 8.
Measurement points
Type
Input
Output
VM
VM
VX
VY
74AHC257
0.5 × VCC
0.5 × VCC
VOL + 0.3 V
VOH − 0.3 V
74AHCT257
1.5 V
0.5 × VCC
VOL + 0.3 V
VOH − 0.3 V
74AHC_AHCT257_2
Product data sheet
10 of 16
74AHC257; 74AHCT257
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
G
VI
VO
RL
S1
open
DUT
CL
RT
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
RL = load resistance.
S1 = test selection switch.
Fig 8.
Test circuitry for measuring switching times
Table 9.
Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74AHC257
VCC
≤ 3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74AHCT257
3.0 V
≤ 3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74AHC_AHCT257_2
Product data sheet
11 of 16
74AHC257; 74AHCT257
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
detail X
w M
bp
2.5
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.16
0.15
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT109-1 (SO16)
74AHC_AHCT257_2
Product data sheet
12 of 16
74AHC257; 74AHCT257
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
E
D
A
X
c
y
HE
v M A
Z
9
16
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
8
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 10. Package outline SOT403-1 (TSSOP16)
74AHC_AHCT257_2
Product data sheet
13 of 16
74AHC257; 74AHCT257
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT257_2
20080509
Product data sheet
74AHC_AHCT257_1
Modifications:
74AHC_AHCT257_1
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 6: the conditions for input leakage current have been changed.
20000403
Product specification
74AHC_AHCT257_2
Product data sheet
14 of 16
74AHC257; 74AHCT257
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT257_2
Product data sheet
15 of 16
Nexperia
74AHC257; 74AHCT257
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 09 May 2008
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC257D,112 74AHC257D,118 74AHC257PW,112 74AHC257PW,118 74AHCT257D,112 74AHCT257D,118
74AHCT257PW,112 74AHCT257PW,118
