74AUP1G18
Low-power 1-of-2 demultiplexer with 3-state deselected
output
Rev. 5 — 3 July 2012
Product data sheet
1. General description
The 74AUP1G18 provides a 1-of-2 non-inverting demultiplexer with 3-state output. The
74AUP1G18 buffers the data on input pin (A) and passes it either to output 1Y or 2Y,
depending on whether the state of the select input pin (S) is LOW or HIGH.
Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V. This device ensures a very low
static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V.
This device is fully specified for partial Power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F Class 3A exceeds 5000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 A (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74AUP1G18
Nexperia
Low-power 1-of-2 demultiplexer with 3-state deselected output
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AUP1G18GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AUP1G18GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AUP1G18GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74AUP1G18GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AUP1G18GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Marking code[1]
Type number
74AUP1G18GW
pW
74AUP1G18GM
pW
74AUP1G18GF
pW
74AUP1G18GN
pW
74AUP1G18GS
pW
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
1Y
1
3
6
S
A
2Y
4
mnb088
Fig 1. Logic symbol
74AUP1G18
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 22
74AUP1G18
Nexperia
6. Pinning information
6.1 Pinning
74AUP1G18
74AUP1G18
S
1
6
S
1
6
1Y
GND
2
5
VCC
74AUP1G18
1Y
GND
2
5
VCC
A
3
4
2Y
A
3
4
2Y
S
1
6
1Y
GND
2
5
VCC
A
3
4
2Y
001aad870
001aad869
Transparent top view
001aae822
Fig 2. Pin configuration SOT363
Fig 3. Pin configuration SOT886
Fig 4.
Pin configuration SOT891,
SOT1115 and SOT1202
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
S
1
data select
GND
2
ground (0 V)
A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
7. Functional description
Table 4.
Function table[1]
Input
Output
S
A
1Y
2Y
L
L
L
Z
L
H
H
Z
H
L
Z
L
H
H
Z
H
[1]
H = HIGH voltage level;
L = LOW voltage level;
Z = high-impedance OFF-state.
74AUP1G18
Product data sheet
3 of 22
74AUP1G18
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
0.5
+4.6
V
50
mA
0.5
+4.6
V
50
mA
0.5
+4.6
V
mA
VO
output voltage
Active mode and Power-down
mode
IO
output current
VO = 0 V to VCC
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
Tamb = 40 C to +125 C
[2]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
VI
VO
output voltage
Conditions
Min
Max
Unit
supply voltage
0.8
3.6
V
input voltage
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
C
VCC = 0.8 V to 3.6 V
ns/V
Tamb
ambient temperature
t/V
input transition rise and fall rate
74AUP1G18
Product data sheet
4 of 22
74AUP1G18
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
VCC = 0.8 V
VCC = 0.9 V to 1.95 V
Typ
Max
Unit
0.70 VCC -
V
0.65 VCC -
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
IO = 20 A; VCC = 0.8 V to 3.6 V
VCC 0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.75 VCC -
V
IO = 1.7 mA; VCC = 1.4 V
1.11
V
Tamb = 25 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VI = VIH or VIL
IO = 1.9 mA; VCC = 1.65 V
1.32
V
IO = 2.3 mA; VCC = 2.3 V
2.05
V
IO = 3.1 mA; VCC = 2.3 V
1.9
V
IO = 2.7 mA; VCC = 3.0 V
2.72
V
IO = 4.0 mA; VCC = 3.0 V
2.6
V
0.1
V
0.3 VCC
V
VI = VIH or VIL
0.31
V
0.31
V
0.31
V
0.44
V
0.31
V
0.44
V
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
0.1
A
IOZ
OFF-state output current
VI = VIH or VIL; VO = 0 V to 3.6 V;
VCC = 0 V to 3.6 V
0.1
A
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
0.2
A
IOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
0.2
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
A
ICC
additional supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 3.3 V
40
A
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
74AUP1G18
Product data sheet
[1]
5 of 22
74AUP1G18
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
VCC = 0.8 V
Typ
Max
Unit
0.70 VCC -
V
0.65 VCC -
V
1.6
V
2.0
V
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
Tamb = 40 C to +85 C
VIH
VIL
VOH
VOL
VI = VIH or VIL
VCC 0.1
V
0.7 VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3 VCC
V
0.37
V
VI = VIH or VIL
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
II
0.5
A
IOZ
VCC = 0 V to 3.6 V
0.5
A
IOFF
0.5
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.6
A
ICC
supply current
0.9
A
ICC
VCC = 3.3 V
50
A
74AUP1G18
Product data sheet
[1]
6 of 22
74AUP1G18
Nexperia
Table 7.
Symbol Parameter
Conditions
Min
VCC = 0.8 V
Typ
Max
Unit
0.75 VCC -
V
0.70 VCC -
V
1.6
V
2.0
V
VCC = 0.8 V
0.25 VCC V
0.30 VCC V
0.7
V
0.9
V
VIH
VIL
VOH
VOL
VI = VIH or VIL
VCC 0.11 -
V
0.6 VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33 VCC V
0.41
V
VI = VIH or VIL
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
II
0.75
A
IOZ
VCC = 0 V to 3.6 V
0.75
A
IOFF
0.75
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.75
A
ICC
supply current
1.4
A
ICC
VCC = 3.3 V
75
A
[1]
[1]
One input at VCC 0.6 V, other input at VCC or GND.
74AUP1G18
Product data sheet
7 of 22
74AUP1G18
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7.
Symbol Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
(85 C)
Max
(125 C)
20.4
ns
VCC = 1.1 V to 1.3 V
2.7
5.6
10.6
2.4
10.7
10.7
ns
VCC = 1.4 V to 1.6 V
2.4
3.9
6.1
2.2
6.5
6.7
ns
VCC = 1.65 V to 1.95 V
1.8
3.1
4.7
1.6
5.3
5.6
ns
1.6
2.4
3.6
1.4
4.0
4.2
ns
1.4
2.2
3.1
1.2
3.4
3.5
ns
CL = 5 pF
tpd
[2]
propagation delay A to nY; see Figure 5
VCC = 0.8 V
ten
enable time
[3]
S to nY; see Figure 6
VCC = 0.8 V
disable time
46.1
ns
3.1
5.6
9.7
2.9
10.1
11.1
ns
2.5
4.0
6.2
2.2
6.6
7.3
ns
2.1
3.3
5.1
1.8
5.5
6.1
ns
1.7
2.7
3.9
1.4
4.2
4.6
ns
1.5
2.4
3.5
1.2
3.7
4.1
ns
12.6
ns
3.0
4.7
7.5
2.9
7.9
8.7
ns
2.3
3.5
5.2
2.2
5.5
6.1
ns
2.3
3.4
4.8
2.1
5.1
5.6
ns
1.7
2.5
3.6
1.5
3.9
4.3
ns
2.0
2.9
3.8
1.8
4.1
4.5
ns
23.9
ns
2.9
6.4
12.2
2.9
12.3
12.3
ns
2.7
4.5
7.1
2.4
7.6
7.9
ns
2.3
3.7
5.5
2.1
6.0
6.3
ns
1.9
3.0
4.2
1.8
4.6
4.9
ns
1.8
2.7
3.9
1.6
4.1
4.3
ns
tdis
[4]
VCC = 0.8 V
CL = 10 pF
tpd
[2]
VCC = 0.8 V
74AUP1G18
Product data sheet
8 of 22
74AUP1G18
Nexperia
Table 8.
Dynamic characteristics …continued
Symbol Parameter
ten
enable time
25 C
Conditions
Max
Min
Max
(85 C)
Max
(125 C)
50.1
ns
3.6
6.5
11.1
3.3
11.6
12.8
ns
2.9
4.6
7.0
2.6
7.6
8.4
ns
2.5
3.9
5.8
2.2
6.3
6.9
ns
2.1
3.2
4.6
1.7
4.9
5.4
ns
2.0
2.9
4.2
1.6
4.4
4.8
ns
[3]
disable time
Unit
Min
VCC = 0.8 V
tdis
40 C to +125 C
Typ[1]
[4]
14.5
ns
VCC = 0.8 V
4.1
5.8
8.7
3.9
9.1
10.0
ns
3.2
4.4
6.1
3.0
6.5
7.2
ns
3.3
4.5
6.0
3.2
6.3
6.9
ns
2.4
3.3
4.4
2.2
4.7
5.2
ns
3.1
4.1
5.2
3.0
5.5
6.1
ns
CL = 15 pF
tpd
[2]
VCC = 0.8 V
ten
enable time
27.4
3.4
7.2
13.7
3.2
13.9
13.9
ns
3.2
5.0
7.9
2.8
8.7
9.1
ns
2.5
4.2
6.3
2.4
7.0
7.4
ns
2.3
3.4
4.9
2.2
5.3
5.7
ns
2.2
3.2
4.4
1.9
4.8
5.0
ns
53.9
[3]
VCC = 0.8 V
disable time
4.1
7.3
12.4
3.6
12.9
14.2
ns
3.3
5.2
7.8
2.9
8.4
9.2
ns
2.9
4.4
6.4
2.5
7.0
7.7
ns
2.5
3.6
5.2
2.1
5.5
6.1
ns
2.3
3.4
4.8
1.9
4.9
5.4
ns
16.3
5.1
6.9
10.0
[4]
VCC = 0.8 V
74AUP1G18
Product data sheet
ns
tdis
ns
ns
4.9
10.4
11.4
ns
4.0
5.3
7.1
3.8
7.4
8.1
ns
4.3
5.6
7.3
4.2
7.6
8.4
ns
3.1
4.1
5.3
3.0
5.6
6.2
ns
4.2
5.3
6.6
4.1
6.9
7.6
ns
9 of 22
74AUP1G18
Nexperia
Table 8.
Symbol Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
(85 C)
Max
(125 C)
37.8
ns
4.1
9.5
18.0
4.1
18.5
18.9
ns
CL = 30 pF
tpd
[2]
VCC = 0.8 V
3.7
6.6
10.4
3.8
11.5
12.1
ns
3.4
5.5
8.3
3.3
9.2
9.8
ns
3.2
4.5
6.3
3.0
6.8
7.3
ns
3.1
4.2
5.8
2.9
6.6
7.0
ns
66.3
ns
5.3
9.6
16.4
4.7
17.0
18.7
ns
4.4
6.8
10.0
3.9
10.9
12.0
ns
4.0
5.7
8.2
3.4
8.9
9.8
ns
3.4
4.8
6.6
2.9
7.0
7.7
ns
3.2
4.5
6.1
2.8
6.5
7.2
ns
ten
enable time
[3]
VCC = 0.8 V
tdis
disable time
[4]
VCC = 0.8 V
74AUP1G18
Product data sheet
21.8
ns
8.2
10.4
14.3
8.0
14.7
16.2
ns
6.5
8.0
10.0
6.3
10.4
11.4
ns
7.4
9.0
11.0
7.3
11.3
12.4
ns
5.3
6.5
7.9
5.2
8.2
9.0
ns
7.6
9.0
10.7
7.4
11.0
12.1
ns
10 of 22
74AUP1G18
Nexperia
Table 8.
Symbol Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
(85 C)
Max
(125 C)
VCC = 0.8 V
2.8
pF
2.9
pF
3.0
pF
3.2
pF
3.7
pF
4.2
pF
CL = 5 pF, 10 pF, 15 pF and 30 pF
power dissipation
capacitance
CPD
[1]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL.
[3]
ten is the same as tPZH and tPZL.
[4]
tdis is the same as tPHZ and tPLZ.
[5]
[5]
fi = 1 MHz;
VI = GND to VCC
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
12. Waveforms
VI
VM
A input
VM
GND
tPLH
tPHL
VOH
VM
nY output
VM
VOL
mnb089
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage drop that occur with the output load.
Fig 5. The data input (A) to output (nY) propagation delays
Table 9.
Measurement points
Supply voltage
Output
Input
VCC
VM
VM
VI
tr = tf
0.8 V to 3.6 V
0.5 VCC
0.5 VCC
VCC
3.0 ns
74AUP1G18
Product data sheet
11 of 22
74AUP1G18
Nexperia
VI
S input
VM
GND
t PLZ
t PZL
VCC
nY output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PZH
t PHZ
VOH
VY
nY output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
output
enabled
output
enabled
output
disabled
mnb090
Measurement points are given in Table 10.
Fig 6. Enable and disable times
Table 10.
Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
0.8 V to 1.6 V
0.5 VCC
0.5 VCC
VOL + 0.1 V
VOH 0.1 V
1.65 V to 2.7 V
0.5 VCC
0.5 VCC
VOL + 0.15 V
VOH 0.15 V
3.0 V to 3.6 V
0.5 VCC
0.5 VCC
VOL + 0.3 V
VOH 0.3 V
74AUP1G18
Product data sheet
12 of 22
74AUP1G18
Nexperia
VCC
VEXT
5 kΩ
G
VI
VO
DUT
RT
CL
RL
001aac521
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 7.
Table 11.
Test circuit for measuring switching times
Test data
Supply voltage
Load
VEXT
VCC
CL
0.8 V to 3.6 V
5 pF, 10 pF, 15 pF and 30 pF 5 k or 1 M
[1]
RL
[1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
open
GND
2 VCC
For measuring enable and disable times RL = 5 k, for measuring propagation delays, setup and hold times and pulse width RL = 1 M.
74AUP1G18
Product data sheet
13 of 22
74AUP1G18
Nexperia
13. Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
E
B
y
X
A
HE
6
5
v M A
4
Q
pin 1
index
A
A1
1
2
e1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
SC-88
Fig 8. Package outline SOT363 (SC-88)
74AUP1G18
Product data sheet
14 of 22
74AUP1G18
Nexperia
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Fig 9. Package outline SOT886 (XSON6)
74AUP1G18
Product data sheet
15 of 22
74AUP1G18
Nexperia
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
e1
4
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Fig 10. Package outline SOT891 (XSON6)
74AUP1G18
Product data sheet
16 of 22
74AUP1G18
Nexperia
XSON6: extremely thin small outline package; no leads;
6 terminals; body 0.9 x 1.0 x 0.35 mm
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
scale
Dimensions
Unit
mm
1 mm
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Fig 11. Package outline SOT1115 (XSON6)
74AUP1G18
Product data sheet
17 of 22
74AUP1G18
Nexperia
6 terminals; body 1.0 x 1.0 x 0.35 mm
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
scale
Dimensions
Unit
mm
1 mm
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Fig 12. Package outline SOT1202 (XSON6)
74AUP1G18
Product data sheet
18 of 22
74AUP1G18
Nexperia
14. Abbreviations
Table 12.
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
15. Revision history
Table 13.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AUP1G18 v.5
20120703
Product data sheet
74AUP1G18 v.4
Modifications:
74AUP1G18 v.4
Modifications:
74AUP1G18 v.3
Package outline drawing of SOT886 (Figure 9) modified.
20111124
Product data sheet
74AUP1G18 v.3
74AUP1G18 v.2
Legal pages updated.
20100927
Product data sheet
74AUP1G18 v.2
20080403
Product data sheet
74AUP1G18 v.1
74AUP1G18 v.1
20061013
Product data sheet
74AUP1G18
Product data sheet
19 of 22
74AUP1G18
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AUP1G18
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
20 of 22
74AUP1G18
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AUP1G18
Product data sheet
21 of 22
74AUP1G18
Nexperia
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 19
Legal information. . . . . . . . . . . . . . . . . . . . . . . 20
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 20
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Contact information. . . . . . . . . . . . . . . . . . . . . 21
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Date of release: 03 July 2012
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AUP1G18GF,132 74AUP1G18GM,115 74AUP1G18GM,132 74AUP1G18GW,125 74AUP1G18GN,132
74AUP1G18GS,132
