74AUP1G19GS,132
74AUP1G19GS,132
    NEXPERIA(安世)
    XSON6_1X1MM
    低功耗1/2解码器/解复用器 XSON6_1X1MM 0.8~3.6V
74AUP1G19GS,132 数据手册
74AUP1G19 Low-power 1-of-2 decoder/demultiplexer Rev. 5 — 6 November 2014 Product data sheet 1. General description The 74AUP1G19 provides a 1-of-2 decoder/demultiplexer with a common output enable. It buffers the data on input pin A and passes it either to output pin 1Y (true) or 2Y (complement), depending on whether the state of the enable input pin E is LOW or HIGH, respectively. Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. This device ensures a very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  Complies with JEDEC standards:  JESD8-12 (0.8 V to 1.3 V)  JESD8-11 (0.9 V to 1.65 V)  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8-B (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Low static power consumption; ICC = 0.9 A (maximum)  Latch-up performance exceeds 100 mA per JESD 78 Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial Power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74AUP1G19 Nexperia Low-power 1-of-2 decoder/demultiplexer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP1G19GW 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74AUP1G19GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AUP1G19GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 74AUP1G19GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AUP1G19GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Marking code[1] Type number 74AUP1G19GW pY 74AUP1G19GM pY 74AUP1G19GF pY 74AUP1G19GN pY 74AUP1G19GS pY [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $  ( <  <  PQE Fig 1. Logic symbol 74AUP1G19 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 November 2014 © Nexperia B.V. 2017. All rights reserved 2 of 20 74AUP1G19 Nexperia Low-power 1-of-2 decoder/demultiplexer 6. Pinning information 6.1 Pinning 74AUP1G19 74AUP1G19 A 1 6 A 1 6 1Y GND 2 5 VCC 1Y GND 2 5 VCC E 3 4 2Y E 3 4 2Y A 1 6 1Y GND 2 5 VCC E 3 4 2Y 001aai074 001aai073 Transparent top view Transparent top view 001aai072 Fig 2. 74AUP1G19 Pin configuration SOT363 Fig 3. Pin configuration SOT886 Fig 4. Pin configuration SOT891, SOT1115 and SOT1202 6.2 Pin description Table 3. Pin description Symbol Pin Description A 1 data input GND 2 ground (0 V) E 3 enable input (active LOW) 2Y 4 data output (complement) VCC 5 supply voltage 1Y 6 data output (true) 7. Functional description Table 4. Function table[1] Input Output E A 1Y 2Y L L L H L H H L H L H H H H H H [1] H = HIGH voltage level; L = LOW voltage level. 74AUP1G19 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 November 2014 © Nexperia B.V. 2017. All rights reserved 3 of 20 74AUP1G19 Nexperia Low-power 1-of-2 decoder/demultiplexer 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +4.6 V 50 - mA 0.5 +4.6 V 50 - mA 0.5 +4.6 V VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot Tamb = 40 C to +125 C [2] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate 74AUP1G19 Product data sheet Min Max Unit 0.8 3.6 V 0 3.6 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 3.6 V 40 +125 C 0 200 ns/V VCC = 0.8 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 November 2014 © Nexperia B.V. 2017. All rights reserved 4 of 20 74AUP1G19 Nexperia Low-power 1-of-2 decoder/demultiplexer 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V VCC = 0.9 V to 1.95 V Typ Max Unit 0.70  VCC - - V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - V Tamb = 25 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL - IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V VI = VIH or VIL IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.2 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.2 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 40 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND or VCC - 0.8 - pF CO output capacitance VO = GND; VCC = 0 V - 1.7 - pF 74AUP1G19 Product data sheet [1] All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 November 2014 © Nexperia B.V. 2017. All rights reserved 5 of 20 74AUP1G19 Nexperia Low-power 1-of-2 decoder/demultiplexer Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V Typ Max Unit 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V Tamb = 40 C to +85 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V VI = VIH or VIL IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.5 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.5 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.6 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 50 A 74AUP1G19 Product data sheet [1] All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 November 2014 © Nexperia B.V. 2017. All rights reserved 6 of 20 74AUP1G19 Nexperia Low-power 1-of-2 decoder/demultiplexer Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V Typ Max Unit 0.75  VCC - - V VCC = 0.9 V to 1.95 V 0.70  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.25  VCC V VCC = 0.9 V to 1.95 V - - 0.30  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL VOH HIGH-level output voltage LOW-level output voltage VOL VI = VIH or VIL IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - V IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - 0.33  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V VI = VIH or VIL IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.75 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.75 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 75 A [1] [1] One input at VCC  0.6 V, other input at VCC or GND. 74AUP1G19 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 November 2014 © Nexperia B.V. 2017. All rights reserved 7 of 20 74AUP1G19 Nexperia Low-power 1-of-2 decoder/demultiplexer 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter Tamb = 25 C Conditions Tamb =40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 15.9 - - - - VCC = 1.1 V to 1.3 V 2.3 5.3 11.5 2.1 11.9 12.0 ns VCC = 1.4 V to 1.6 V 2.1 3.8 6.8 2.0 7.5 7.8 ns VCC = 1.65 V to 1.95 V 1.6 3.1 5.4 1.5 6.1 6.4 ns VCC = 2.3 V to 2.7 V 1.4 2.3 4.0 1.2 4.2 4.5 ns 1.3 2.0 3.4 1.0 3.8 4.1 ns - 17.8 - - - - ns 2.4 5.8 11.6 2.1 12.0 12.1 ns CL = 5 pF tpd propagation delay A to nY; see Figure 5 [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V E to nY; see Figure 5 ns [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 1.4 V to 1.6 V 2.0 4.2 6.9 1.9 7.5 7.8 ns VCC = 1.65 V to 1.95 V 1.6 3.4 5.6 1.5 6.2 6.5 ns VCC = 2.3 V to 2.7 V 1.4 2.6 4.0 1.3 4.5 4.8 ns VCC = 3.0 V to 3.6 V 1.3 2.2 3.4 1.2 3.7 3.9 ns - 18.9 - - - - ns 2.5 6.2 13.8 2.5 13.9 14.1 ns CL = 10 pF tpd propagation delay A to nY; see Figure 5 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 1.4 V to 1.6 V 2.3 4.5 8.2 2.1 8.5 8.9 ns VCC = 1.65 V to 1.95 V 2.1 3.7 6.3 2.0 6.8 7.2 ns VCC = 2.3 V to 2.7 V 1.7 2.9 4.7 1.6 5.0 5.3 ns 1.6 2.6 4.0 1.4 4.4 4.7 ns - 21.0 - - - - ns VCC = 1.1 V to 1.3 V 2.6 6.7 13.4 2.5 13.9 14.1 ns VCC = 1.4 V to 1.6 V 2.3 4.8 8.2 2.1 8.8 9.1 ns VCC = 3.0 V to 3.6 V E to nY; see Figure 5 VCC = 0.8 V 74AUP1G19 Product data sheet [2] VCC = 1.65 V to 1.95 V 2.1 4.0 6.4 1.9 7.0 7.3 ns VCC = 2.3 V to 2.7 V 1.8 3.1 4.7 1.6 5.1 5.5 ns VCC = 3.0 V to 3.6 V 1.6 2.8 4.2 1.4 4.4 4.7 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 November 2014 © Nexperia B.V. 2017. All rights reserved 8 of 20 74AUP1G19 Nexperia Low-power 1-of-2 decoder/demultiplexer Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter Tamb = 25 C Conditions Tamb =40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 21.8 - - - - ns VCC = 1.1 V to 1.3 V 3.0 7.0 15.2 2.7 15.8 16.1 ns CL = 15 pF tpd propagation delay A to nY; see Figure 5 [2] VCC = 0.8 V VCC = 1.4 V to 1.6 V 2.8 5.0 9.0 2.5 9.8 10.2 ns VCC = 1.65 V to 1.95 V 2.3 4.2 7.0 2.2 7.8 8.2 ns VCC = 2.3 V to 2.7 V 2.1 3.4 5.3 1.9 5.6 6.0 ns 1.9 3.0 4.6 1.7 5.2 5.4 ns - 24.2 - - - - ns VCC = 1.1 V to 1.3 V 3.0 7.5 15.1 2.8 15.7 16.0 ns VCC = 1.4 V to 1.6 V 2.8 5.4 9.1 2.5 10.0 10.4 ns VCC = 3.0 V to 3.6 V E to nY; see Figure 5 [2] VCC = 0.8 V VCC = 1.65 V to 1.95 V 2.3 4.5 7.2 2.2 8.0 8.4 ns VCC = 2.3 V to 2.7 V 2.1 3.6 5.4 2.0 5.8 6.2 ns VCC = 3.0 V to 3.6 V 1.9 3.2 4.7 1.8 5.1 5.4 ns - 30.4 - - - - ns VCC = 1.1 V to 1.3 V 3.6 9.2 20.5 3.6 21.3 21.7 ns VCC = 1.4 V to 1.6 V 3.2 6.6 11.5 3.3 12.8 13.4 ns VCC = 1.65 V to 1.95 V 3.1 5.5 9.5 3.0 10.0 10.6 ns VCC = 2.3 V to 2.7 V 2.9 4.6 6.3 2.6 7.2 7.7 ns 2.7 4.2 5.9 2.5 7.0 7.4 ns CL = 30 pF tpd propagation delay A to nY; see Figure 5 [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V E to nY; see Figure 5 VCC = 0.8 V 74AUP1G19 Product data sheet [2] - 33.6 - - - - ns VCC = 1.1 V to 1.3 V 3.6 9.8 20.0 3.5 20.9 21.3 ns VCC = 1.4 V to 1.6 V 3.2 7.0 11.6 3.3 12.8 13.5 ns VCC = 1.65 V to 1.95 V 3.1 5.8 9.3 3.0 10.3 10.9 ns VCC = 2.3 V to 2.7 V 2.9 4.7 6.8 2.7 7.4 7.9 ns VCC = 3.0 V to 3.6 V 2.7 4.3 6.0 2.5 7.0 7.4 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 November 2014 © Nexperia B.V. 2017. All rights reserved 9 of 20 74AUP1G19 Nexperia Low-power 1-of-2 decoder/demultiplexer Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter Tamb = 25 C Conditions Tamb =40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) VCC = 0.8 V - 5.0 - - - - pF VCC = 1.1 V to 1.3 V - 5.3 - - - - pF VCC = 1.4 V to 1.6 V - 5.5 - - - - pF VCC = 1.65 V to 1.95 V - 5.8 - - - - pF VCC = 2.3 V to 2.7 V - 6.7 - - - - pF VCC = 3.0 V to 3.6 V - 7.6 - - - - pF CL = 5 pF, 10 pF, 15 pF and 30 pF power dissipation capacitance CPD fi = 1 MHz; VI = GND to VCC [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 12. Waveforms 9, 90 $(LQSXW 90 *1' W 3+/ W 3/+ 92+ Q
74AUP1G19GS,132 价格&库存
很抱歉,暂时无法提供与“74AUP1G19GS,132”相匹配的价格&库存,您可以联系我们找货
