74CBTLV1G125
Single bus switch
Rev. 5 — 10 November 2016
Product data sheet
1. General description
The 74CBTLV1G125 provides a single high-speed line switch. The switch is disabled
when the output enable (OE) input is high.
To ensure the high-impedance OFF-state during power-up or power-down, tie OE to the
VCC through a pull-up resistor. The current-sinking capability of the driver determines the
minimum value of the resistor.
Schmitt trigger action at control input makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 2.3 V to 3.6 V.
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Supply voltage range from 2.3 V to 3.6 V
High noise immunity
Complies with JEDEC standard:
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
5 switch connection between two ports
Rail to rail switching on data I/O ports
CMOS low power consumption
Latch-up performance meets requirements of JESD78 Class I
IOFF circuitry provides partial power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74CBTLV1G125
Nexperia
Single bus switch
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74CBTLV1G125GW
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74CBTLV1G125GV
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74CBTLV1G125GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74CBTLV1G125GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74CBTLV1G125GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74CBTLV1G125GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74CBTLV1G125GW
bM
74CBTLV1G125GV
b25
74CBTLV1G125GM
bM
74CBTLV1G125GF
bM
74CBTLV1G125GN
bM
74CBTLV1G125GS
bM
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
2(
Fig 1.
Product data sheet
Logic symbol
74CBTLV1G125
6:,7&+
2(
DDG
DDG
Fig 2.
Logic diagram
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 22
74CBTLV1G125
Nexperia
Single bus switch
6. Pinning information
6.1 Pinning
&%7/9*
&%7/9*
2(
*1'
9&&
2(
9&&
QF
*1'
2(
9&&
QF
*1'
DDG
DDI
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
DDG
Fig 3.
&%7/9*
Pin configuration
SOT353-1 and SOT753
Fig 4.
Pin configuration SOT886
Fig 5.
Pin configuration SOT891,
SOT1115 and SOT1202
6.2 Pin description
Table 3.
Symbol
Pin description
Pin
Description
SOT353-1, SOT753 SOT886, SOT891, SOT1115 and SOT1202
OE
1
1
output enable input OE (active LOW)
A
2
2
data input or output A
GND
3
3
ground (0 V)
B
4
4
data input or output B
n.c.
5
not connected
VCC
5
6
supply voltage
7. Functional description
7.1 Function table
Table 4.
Function table[1]
Output enable input OE
Function switch
L
ON-state
H
OFF-state
[1]
H = HIGH voltage level; L = LOW voltage level.
74CBTLV1G125
Product data sheet
3 of 22
74CBTLV1G125
Nexperia
Single bus switch
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+4.6
V
VI
input voltage
0.5
+4.6
V
VSW
switch voltage
enable and disable mode
0.5
VCC + 0.5
V
IIK
input clamping current
VI/O < 0.5 V
50
mA
ISK
switch clamping current
VI < 0.5 V or VI > VCC + 0.5 V
50
mA
VSW = 0 V to VCC
[1]
ISW
switch current
128
mA
ICC
supply current
+50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
150
C
250
mW
total power dissipation
Ptot
[1]
[2]
Tamb = 40 C to +125 C
[2]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VSW
switch voltage
Tamb
ambient temperature
t/V
[1]
Conditions
input transition rise and fall rate
VCC = 2.3 V to 3.6 V
[1]
Min
Typ
Max
Unit
2.3
3.6
V
V
VCC
V
40
+125
C
ns/V
Applies to control signal levels.
74CBTLV1G125
Product data sheet
4 of 22
74CBTLV1G125
Nexperia
Single bus switch
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
0.7
V
0.8
V
Unit
Tamb = 40 C to +85 C
HIGH-level input voltage
VIH
LOW-level input voltage
VIL
II
input leakage current
VI = GND to VCC; VCC = 3.6 V
1.0
A
IS(OFF)
OFF-state leakage current
VI = VIH or VIL; VO = VCC GND;
VCC = 3.6 V; see Figure 6
0.1
5
A
IS(ON)
ON-state leakage current
VI = VIH or VIL; VCC = 3.6 V; see Figure 7
0.1
5
A
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
10
A
ICC
supply current
VI = GND or VCC; IO = 0 A; VCC = 3.6 V
10
A
ICC
additional supply current
control input; VI = VCC 0.6 V; VCC = 3.6 V
300
A
CI
input capacitance
control input; VI = 0 V or 3 V
2.5
pF
Csw
switch capacitance
[2]
OFF-state
7.0
pF
ON-state
10.3
pF
V
VIH
1.7
2.0
V
VIL
0.7
V
0.8
V
II
100
A
IS(OFF)
200
A
IS(ON)
200
A
IOFF
10
A
ICC
supply current
200
A
ICC
5000
A
[1]
Typical values are measured at Tamb = 25 C and at VCC = 3.3 V.
[2]
One input at 3 V, other inputs at VCC or GND.
74CBTLV1G125
Product data sheet
[2]
5 of 22
74CBTLV1G125
Nexperia
Single bus switch
Table 8.
Resistance RON
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); see test circuit Figure 8.
Symbol Parameter
40 C to +85 C
Conditions
Unit
Min
Max
Min
Max
ISW = 64 mA; VI = 0 V
4.7
10
15.0
ISW = 24 mA; VI = 0 V
4.5
10
15.0
ISW = 15 mA; VI = 1.7 V
11
25
38.0
4.2
7
11.0
4.1
7
11.0
ISW = 15 mA; VI = 2.4 V
7.3
15
25.5
[2]
ON resistance VCC = 2.3 V; see Figure 9
RON
40 C to +125 C
Typ[1]
VCC = 3.0 V; see Figure 10
[1]
Typical values are measured at Tamb = 25 C.
[2]
Measured by the voltage drop between the A and B terminals at the indicated current through the switch. ON-state resistance is
determined by the lower of the voltages of the two (A or B) terminals.
9&&
9&&
2(
9,+
,6
2(
9,/
,6
,6
9,
9,
92
*1'
*1'
DDG
Fig 6.
QF
DDG
Test circuit for measuring OFF-state leakage
current
Fig 7.
Test circuit for measuring ON-state leakage
current
96:
9&&
2(
9,/
,6:
9,
*1'
DDG
RON = VSW / ISW.
Fig 8.
Test circuit for measuring ON-resistance
74CBTLV1G125
Product data sheet
6 of 22
74CBTLV1G125
Nexperia
Single bus switch
DDG
521
ȍ
DDG
521
ȍ
96:9
96:9
(1) Tamb = 125 C
(1) Tamb = 125 C
(2) Tamb = 85 C
(2) Tamb = 85 C
(3) Tamb = 25 C
(3) Tamb = 25 C
(4) Tamb = 40 C
(4) Tamb = 40 C
a. VCC = 2.5 V; ISW = 15 mA; VSW = 1.7 V
b. VCC = 2.5 V; ISW = 24 mA; VSW = 0 V
DDG
521
ȍ
96:9
(1) Tamb = 125 C
(2) Tamb = 85 C
(3) Tamb = 25 C
(4) Tamb = 40 C
c. VCC = 2.5 V; ISW = 64 mA; VSW = 0 V
Fig 9.
Switch ON-resistance as a function of input voltage at VCC = 2.5 V
74CBTLV1G125
Product data sheet
7 of 22
74CBTLV1G125
Nexperia
Single bus switch
DDG
521
ȍ
DDG
521
ȍ
96:9
96:9
(1) Tamb = 125 C
(1) Tamb = 125 C
(2) Tamb = 85 C
(2) Tamb = 85 C
(3) Tamb = 25 C
(3) Tamb = 25 C
(4) Tamb = 40 C
(4) Tamb = 40 C
a. VCC = 3.3 V; ISW = 15 mA; VSW = 2.4 V
b. VCC = 3.3 V; ISW = 24 mA; VSW = 0 V
DDG
521
ȍ
96:9
(1) Tamb = 125 C
(2) Tamb = 85 C
(3) Tamb = 25 C
(4) Tamb = 40 C
c. VCC = 3.3 V; ISW = 64 mA; VSW = 0 V
Fig 10. Switch ON-resistance as a function of input voltage at VCC = 3.3 V
74CBTLV1G125
Product data sheet
8 of 22
74CBTLV1G125
Nexperia
Single bus switch
11. Dynamic characteristics
Table 9.
GND = 0 V; see Figure 13.
Symbol Parameter
40 C to +85 C
Conditions
Min
Max
Min
Max
0.21
0.32
ns
0.16
0.25
0.39
ns
1.0
2.50
4.00
1.0
5.00
ns
1.0
2.05
4.00
1.0
5.00
ns
1.0
2.80
5.00
1.0
6.30
ns
VCC = 3.0 V to 3.6 V
1.0
3.40
4.10
1.0
5.40
ns
enable time
ten
OE to A or B; see Figure 12;
RL = 500
[4]
disable time
tdis
Unit
[2][3]
propagation delay A to B or B to A;
see Figure 11; RL =
tpd
40 C to +125 C
Typ[1]
RL = 500
[5]
[1]
All typical values are measured at Tamb = 25 C and at nominal VCC.
[2]
The propagation delay is the calculated RC time constant of the maximum on-state resistance of the switch and the load capacitance,
when driven by an ideal voltage source (zero output impedance).
[3]
tpd is the same as tPLH and tPHL.
[4]
ten is the same as tPZH and tPZL.
[5]
tdis is the same as tPHZ and tPLZ.
12. Waveforms
9,
$RU%
LQSXW
90
90
*1'
W 3/+
W 3+/
92+
%RU$
RXWSXW
90
90
92/
DDG
Measurement points are given in Table 10.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig 11. The data input (A or B) to output (B or A) propagation delays
Table 10.
Measurement points
Supply voltage
Output
Inputs
VCC
VM
VM
VI
tr = tf
2.3 V to 3.6 V
0.5 VCC
0.5 VCC
VCC
2.0 ns
74CBTLV1G125
Product data sheet
9 of 22
74CBTLV1G125
Nexperia
Single bus switch
9,
2(LQSXW
90
*1'
W 3/=
RXWSXW
$RU% /2:WR2))
2))WR/2:
W 3=/
9&&
90
9;
92/
W 3+=
92+
W 3=+
9<
RXWSXW
$RU% +,*+WR2))
2))WR+,*+
90
*1'
VZLWFK
HQDEOHG
VZLWFK
GLVDEOHG
VZLWFK
HQDEOHG
DDG
Measurement points are given in Table 11.
Fig 12. Enable and disable times
Table 11.
Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
2.3 V to 2.7 V
0.5 VCC
0.5 VCC
VOL + 0.15 V
VOH 0.15 V
3.0 V to 3.6 V
0.5 VCC
0.5 VCC
VOL + 0.3 V
VOH 0.3 V
74CBTLV1G125
Product data sheet
10 of 22
74CBTLV1G125
Nexperia
Single bus switch
9(;7
9&&
9,
5/
92
'87
57
5/
PQD
Test data is given in Table 12.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = Test voltage for switching times.
Fig 13. Test circuit for measuring switching times
Table 12.
Test data
Supply voltage
Load
VEXT
VCC
CL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
2.3 V to 2.7 V
30 pF
open
GND
2 VCC
3.0 V to 3.6 V
50 pF
open
GND
2 VCC
74CBTLV1G125
Product data sheet
11 of 22
74CBTLV1G125
Nexperia
Single bus switch
12.1 Additional dynamic characteristics
Table 13. Additional dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); VI = GND or VCC (unless otherwise
specified); tr = tf 2.5 ns.
Symbol Parameter
f(3dB)
[1]
Tamb = 25 C
Conditions
3 dB frequency response VCC = 3.3 V; RL = 50 ; see Figure 14
[1]
Unit
Min
Typ
Max
263
MHz
fi is biased at 0.5VCC.
12.2 Test circuits
9&&
9&&
2(
9,/
5/
IL
*1'
G%
DDD
OE connected to GND; Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads 3 dB.
Fig 14. Test circuit for measuring the frequency response when channel is in ON-state
74CBTLV1G125
Product data sheet
12 of 22
74CBTLV1G125
Nexperia
Single bus switch
13. Package outline
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
ș
/S
H
Z 0
ES
GHWDLO;
H
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
H
PP
/S
Y
Z
ș
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
02
6&$
(8523($1
352-(&7,21
,668('$7(
Fig 15. Package outline SOT353-1 (TSSOP5)
74CBTLV1G125
Product data sheet
13 of 22
74CBTLV1G125
Nexperia
Single bus switch
3ODVWLFVXUIDFHPRXQWHGSDFNDJHOHDGV
627
Y 0 $
4
F
/S
GHWDLO;
ES
H
Z 0 %
PP
VFDOH
81,7
ES
F
H
/S
4
Y
Z
PP
287/,1(
9(56,21
5()(5(1&(6
627
-(,7$
6&$
(8523($1
352-(&7,21
,668('$7(
Fig 16. Package outline SOT753
74CBTLV1G125
Product data sheet
14 of 22
74CBTLV1G125
Nexperia
Single bus switch
627
;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP
E
H
H
H
WHUPLQDO
LQGH[DUHD
PP
VFDOH
'LPHQVLRQVPPDUHWKHRULJLQDOGLPHQVLRQV
8QLW
PD[
QRP
PLQ
PP
E
H
H
1RWHV
,QFOXGLQJSODWLQJWKLFNQHVV
&DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV
2XWOLQH
YHUVLRQ
627
VRWBSR
5HIHUHQFHV
-(,7$
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
02
Fig 17. Package outline SOT886 (XSON6)
74CBTLV1G125
Product data sheet
15 of 22
74CBTLV1G125
Nexperia
Single bus switch
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
PP
VFDOH
81,7
PD[
PD[
E
H
H
PP
1RWH
5()(5(1&(6
287/,1(
9(56,21
627
-(,7$
(8523($1
352-(&7,21
,668('$7(
Fig 18. Package outline SOT891 (XSON6)
74CBTLV1G125
Product data sheet
16 of 22
74CBTLV1G125
Nexperia
Single bus switch
;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
VFDOH
'LPHQVLRQV
8QLW
E
H
H
PD[
QRP
PLQ
PP
PP
1RWH
9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 19. Package outline SOT1115 (XSON6)
74CBTLV1G125
Product data sheet
17 of 22
74CBTLV1G125
Nexperia
Single bus switch
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
VFDOH
'LPHQVLRQV
8QLW
PP
E
H
H
PD[
QRP
PLQ
PP
1RWH
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 20. Package outline SOT1202 (XSON6)
74CBTLV1G125
Product data sheet
18 of 22
74CBTLV1G125
Nexperia
Single bus switch
14. Abbreviations
Table 14.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
15. Revision history
Table 15.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74CBTLV1G125 v.5
20161110
Product data sheet
74CBTLV1G125 v.4
74CBTLV1G125 v.3
Modifications:
74CBTLV1G125 v.4
Modifications:
74CBTLV1G125 v.3
Modifications:
Section 12.1 and Section 12.2 added.
20120905
Package outline drawing of SOT886 (Figure 17) modified.
20111215
Product data sheet
Product data sheet
74CBTLV1G125 v.2
Legal pages updated.
74CBTLV1G125 v.2
20100729
Product data sheet
74CBTLV1G125 v.1
74CBTLV1G125 v.1
20070223
Product data sheet
74CBTLV1G125
Product data sheet
19 of 22
74CBTLV1G125
Nexperia
Single bus switch
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74CBTLV1G125
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
20 of 22
74CBTLV1G125
Nexperia
Single bus switch
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74CBTLV1G125
Product data sheet
21 of 22
Nexperia
74CBTLV1G125
Single bus switch
18. Contents
1
2
3
4
5
6
6.1
6.2
7
7.1
8
9
10
11
12
12.1
12.2
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 9
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Additional dynamic characteristics . . . . . . . . . 12
Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 19
Legal information. . . . . . . . . . . . . . . . . . . . . . . 20
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 20
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Contact information. . . . . . . . . . . . . . . . . . . . . 21
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Date of release: 10 November 2016
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74CBTLV1G125GM,115 74CBTLV1G125GV,125 74CBTLV1G125GW,125 74CBTLV1G125GN,132
74CBTLV1G125GF,132 74CBTLV1G125GS,132
