74CBTLV1G125GN,132
74CBTLV1G125GN,132
    NEXPERIA(安世)
    XSON6_0.9X1MM
    单总线开关 XSON6_0.9X1MM 2.3~3.6V
74CBTLV1G125GN,132 数据手册
74CBTLV1G125 Single bus switch Rev. 5 — 10 November 2016 Product data sheet 1. General description The 74CBTLV1G125 provides a single high-speed line switch. The switch is disabled when the output enable (OE) input is high. To ensure the high-impedance OFF-state during power-up or power-down, tie OE to the VCC through a pull-up resistor. The current-sinking capability of the driver determines the minimum value of the resistor. Schmitt trigger action at control input makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 2.3 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Supply voltage range from 2.3 V to 3.6 V  High noise immunity  Complies with JEDEC standard:  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  5  switch connection between two ports  Rail to rail switching on data I/O ports  CMOS low power consumption  Latch-up performance meets requirements of JESD78 Class I  IOFF circuitry provides partial power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74CBTLV1G125 Nexperia Single bus switch 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74CBTLV1G125GW 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74CBTLV1G125GV 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74CBTLV1G125GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74CBTLV1G125GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 74CBTLV1G125GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74CBTLV1G125GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code[1] 74CBTLV1G125GW bM 74CBTLV1G125GV b25 74CBTLV1G125GM bM 74CBTLV1G125GF bM 74CBTLV1G125GN bM 74CBTLV1G125GS bM [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram $ 2( Fig 1.  Product data sheet  $ % %  Logic symbol 74CBTLV1G125 6:,7&+ 2( DDG DDG Fig 2. Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 2 of 22 74CBTLV1G125 Nexperia Single bus switch 6. Pinning information 6.1 Pinning &%7/9* &%7/9* 2(  $  *1'   9&& 2(   9&& $   QF *1'  %  % 2(   9&& $   QF *1'   % DDG DDI 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ DDG Fig 3.  &%7/9* Pin configuration SOT353-1 and SOT753 Fig 4. Pin configuration SOT886 Fig 5. Pin configuration SOT891, SOT1115 and SOT1202 6.2 Pin description Table 3. Symbol Pin description Pin Description SOT353-1, SOT753 SOT886, SOT891, SOT1115 and SOT1202 OE 1 1 output enable input OE (active LOW) A 2 2 data input or output A GND 3 3 ground (0 V) B 4 4 data input or output B n.c. - 5 not connected VCC 5 6 supply voltage 7. Functional description 7.1 Function table Table 4. Function table[1] Output enable input OE Function switch L ON-state H OFF-state [1] H = HIGH voltage level; L = LOW voltage level. 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 3 of 22 74CBTLV1G125 Nexperia Single bus switch 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +4.6 V VI input voltage 0.5 +4.6 V VSW switch voltage enable and disable mode 0.5 VCC + 0.5 V IIK input clamping current VI/O < 0.5 V 50 - mA ISK switch clamping current VI < 0.5 V or VI > VCC + 0.5 V - 50 mA VSW = 0 V to VCC [1] ISW switch current - 128 mA ICC supply current - +50 mA IGND ground current 50 - mA Tstg storage temperature 65 150 C - 250 mW total power dissipation Ptot [1] [2] Tamb = 40 C to +125 C [2] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VSW switch voltage Tamb ambient temperature t/V [1] Conditions enable and disable mode input transition rise and fall rate VCC = 2.3 V to 3.6 V [1] Min Typ Max Unit 2.3 - 3.6 V 0 - 3.6 V 0 - VCC V 40 - +125 C 0 - 20 ns/V Applies to control signal levels. 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 4 of 22 74CBTLV1G125 Nexperia Single bus switch 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V Unit Tamb = 40 C to +85 C HIGH-level input voltage VIH LOW-level input voltage VIL II input leakage current VI = GND to VCC; VCC = 3.6 V - - 1.0 A IS(OFF) OFF-state leakage current VI = VIH or VIL; VO = VCC  GND; VCC = 3.6 V; see Figure 6 - 0.1 5 A IS(ON) ON-state leakage current VI = VIH or VIL; VCC = 3.6 V; see Figure 7 - 0.1 5 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 10 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 3.6 V - - 10 A ICC additional supply current control input; VI = VCC  0.6 V; VCC = 3.6 V - - 300 A CI input capacitance control input; VI = 0 V or 3 V - 2.5 - pF Csw switch capacitance [2] OFF-state - 7.0 - pF ON-state - 10.3 - pF - V Tamb = 40 C to +125 C VIH HIGH-level input voltage VCC = 2.3 V to 2.7 V 1.7 - VCC = 2.7 V to 3.6 V 2.0 - - V VIL LOW-level input voltage VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V II input leakage current VI = GND to VCC; VCC = 3.6 V - - 100 A IS(OFF) OFF-state leakage current VI = VIH or VIL; VO = VCC  GND; VCC = 3.6 V; see Figure 6 - - 200 A IS(ON) ON-state leakage current VI = VIH or VIL; VCC = 3.6 V; see Figure 7 - - 200 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 10 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 3.6 V - - 200 A ICC additional supply current control input; VI = VCC  0.6 V; VCC = 3.6 V - - 5000 A [1] Typical values are measured at Tamb = 25 C and at VCC = 3.3 V. [2] One input at 3 V, other inputs at VCC or GND. 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 [2] © Nexperia B.V. 2017. All rights reserved 5 of 22 74CBTLV1G125 Nexperia Single bus switch Table 8. Resistance RON At recommended operating conditions; voltages are referenced to GND (ground = 0 V); see test circuit Figure 8. Symbol Parameter 40 C to +85 C Conditions Unit Min Max Min Max ISW = 64 mA; VI = 0 V - 4.7 10 - 15.0  ISW = 24 mA; VI = 0 V - 4.5 10 - 15.0  ISW = 15 mA; VI = 1.7 V - 11 25 - 38.0  ISW = 64 mA; VI = 0 V - 4.2 7 - 11.0  ISW = 24 mA; VI = 0 V - 4.1 7 - 11.0  ISW = 15 mA; VI = 2.4 V - 7.3 15 - 25.5  [2] ON resistance VCC = 2.3 V; see Figure 9 RON 40 C to +125 C Typ[1] VCC = 3.0 V; see Figure 10 [1] Typical values are measured at Tamb = 25 C. [2] Measured by the voltage drop between the A and B terminals at the indicated current through the switch. ON-state resistance is determined by the lower of the voltages of the two (A or B) terminals. 9&& 9&& 2( 9,+ ,6 2( 9,/ $ % ,6 ,6 9, $ % 9, 92 *1' *1' DDG Fig 6. QF DDG Test circuit for measuring OFF-state leakage current Fig 7. Test circuit for measuring ON-state leakage current 96: 9&& 2( 9,/ % $ ,6: 9, *1' DDG RON = VSW / ISW. Fig 8. Test circuit for measuring ON-resistance 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 6 of 22 74CBTLV1G125 Nexperia Single bus switch DDG  521 ȍ DDG  521 ȍ                         96: 9 96: 9 (1) Tamb = 125 C (1) Tamb = 125 C (2) Tamb = 85 C (2) Tamb = 85 C (3) Tamb = 25 C (3) Tamb = 25 C (4) Tamb = 40 C (4) Tamb = 40 C a. VCC = 2.5 V; ISW = 15 mA; VSW = 1.7 V b. VCC = 2.5 V; ISW = 24 mA; VSW = 0 V DDG  521 ȍ            96: 9 (1) Tamb = 125 C (2) Tamb = 85 C (3) Tamb = 25 C (4) Tamb = 40 C c. VCC = 2.5 V; ISW = 64 mA; VSW = 0 V Fig 9. Switch ON-resistance as a function of input voltage at VCC = 2.5 V 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 7 of 22 74CBTLV1G125 Nexperia Single bus switch DDG  521 ȍ DDG  521 ȍ                          96: 9  96: 9 (1) Tamb = 125 C (1) Tamb = 125 C (2) Tamb = 85 C (2) Tamb = 85 C (3) Tamb = 25 C (3) Tamb = 25 C (4) Tamb = 40 C (4) Tamb = 40 C a. VCC = 3.3 V; ISW = 15 mA; VSW = 2.4 V b. VCC = 3.3 V; ISW = 24 mA; VSW = 0 V DDG  521 ȍ              96: 9 (1) Tamb = 125 C (2) Tamb = 85 C (3) Tamb = 25 C (4) Tamb = 40 C c. VCC = 3.3 V; ISW = 64 mA; VSW = 0 V Fig 10. Switch ON-resistance as a function of input voltage at VCC = 3.3 V 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 8 of 22 74CBTLV1G125 Nexperia Single bus switch 11. Dynamic characteristics Table 9. Dynamic characteristics GND = 0 V; see Figure 13. Symbol Parameter 40 C to +85 C Conditions Min Max Min Max - - 0.21 - 0.32 ns - 0.16 0.25 - 0.39 ns 1.0 2.50 4.00 1.0 5.00 ns 1.0 2.05 4.00 1.0 5.00 ns VCC = 2.3 V to 2.7 V 1.0 2.80 5.00 1.0 6.30 ns VCC = 3.0 V to 3.6 V 1.0 3.40 4.10 1.0 5.40 ns VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V enable time ten OE to A or B; see Figure 12; RL = 500  [4] VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V disable time tdis Unit [2][3] propagation delay A to B or B to A; see Figure 11; RL =   tpd 40 C to +125 C Typ[1] OE to A or B; see Figure 12; RL = 500  [5] [1] All typical values are measured at Tamb = 25 C and at nominal VCC. [2] The propagation delay is the calculated RC time constant of the maximum on-state resistance of the switch and the load capacitance, when driven by an ideal voltage source (zero output impedance). [3] tpd is the same as tPLH and tPHL. [4] ten is the same as tPZH and tPZL. [5] tdis is the same as tPHZ and tPLZ. 12. Waveforms 9, $RU% LQSXW 90 90 *1' W 3/+ W 3+/ 92+ %RU$ RXWSXW 90 90 92/ DDG Measurement points are given in Table 10. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 11. The data input (A or B) to output (B or A) propagation delays Table 10. Measurement points Supply voltage Output Inputs VCC VM VM VI tr = tf 2.3 V to 3.6 V 0.5  VCC 0.5  VCC VCC  2.0 ns 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 9 of 22 74CBTLV1G125 Nexperia Single bus switch 9, 2(LQSXW 90 *1' W 3/= RXWSXW $RU% /2:WR2)) 2))WR/2: W 3=/ 9&& 90 9; 92/ W 3+= 92+ W 3=+ 9< RXWSXW $RU% +,*+WR2)) 2))WR+,*+ 90 *1' VZLWFK HQDEOHG VZLWFK GLVDEOHG VZLWFK HQDEOHG DDG Measurement points are given in Table 11. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 12. Enable and disable times Table 11. Measurement points Supply voltage Input Output VCC VM VM VX VY 2.3 V to 2.7 V 0.5  VCC 0.5  VCC VOL + 0.15 V VOH  0.15 V 3.0 V to 3.6 V 0.5  VCC 0.5  VCC VOL + 0.3 V VOH  0.3 V 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 10 of 22 74CBTLV1G125 Nexperia Single bus switch 9(;7 9&& * 9, 5/ 92 '87 57 &/ 5/ PQD Test data is given in Table 12. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Fig 13. Test circuit for measuring switching times Table 12. Test data Supply voltage Load VEXT VCC CL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 2.3 V to 2.7 V 30 pF open GND 2  VCC 3.0 V to 3.6 V 50 pF open GND 2  VCC 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 11 of 22 74CBTLV1G125 Nexperia Single bus switch 12.1 Additional dynamic characteristics Table 13. Additional dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); VI = GND or VCC (unless otherwise specified); tr = tf 2.5 ns. Symbol Parameter f(3dB) [1] Tamb = 25 C Conditions 3 dB frequency response VCC = 3.3 V; RL = 50 ; see Figure 14 [1] Unit Min Typ Max - 263 - MHz fi is biased at 0.5VCC. 12.2 Test circuits 9&& 9&& 2( 9,/ 5/ % IL $ *1' G% DDD OE connected to GND; Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads 3 dB. Fig 14. Test circuit for measuring the frequency response when channel is in ON-state 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 12 of 22 74CBTLV1G125 Nexperia Single bus switch 13. Package outline 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ( ' 627 $ ; F \ +( Y 0 $ =   $ $ $  $ ș  /S  H / Z 0 ES GHWDLO; H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H H +( PP                      / /S Y Z \ =   ș      ƒ ƒ 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ 02  6&$ (8523($1 352-(&7,21 ,668('$7(   Fig 15. Package outline SOT353-1 (TSSOP5) 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 13 of 22 74CBTLV1G125 Nexperia Single bus switch 3ODVWLFVXUIDFHPRXQWHGSDFNDJHOHDGV 627 ' % $ ( \ ; +(  Y 0 $  4 $ $ F    /S GHWDLO; ES H Z 0 %   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV 81,7 $ $ ES F ' ( H +( /S 4 Y Z \ PP                       287/,1( 9(56,21 5()(5(1&(6 ,(& 627 -('(& -(,7$  6&$ (8523($1 352-(&7,21 ,668('$7(   Fig 16. Package outline SOT753 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 14 of 22 74CBTLV1G125 Nexperia Single bus switch 627 ;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP E    [  / / H   H  H [ $  $ ' ( WHUPLQDO LQGH[DUHD   PP VFDOH 'LPHQVLRQV PPDUHWKHRULJLQDOGLPHQVLRQV 8QLW PD[ QRP PLQ PP $   $ E ' (           H H   / /       1RWHV ,QFOXGLQJSODWLQJWKLFNQHVV &DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV 2XWOLQH YHUVLRQ 627 VRWBSR 5HIHUHQFHV ,(& -('(& -(,7$ (XURSHDQ SURMHFWLRQ ,VVXHGDWH   02 Fig 17. Package outline SOT886 (XSON6) 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 15 of 22 74CBTLV1G125 Nexperia Single bus switch ;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP  627 E   î  / / H    H H î $  $ ' ( WHUPLQDO LQGH[DUHD   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV 81,7 $ PD[ $ PD[ E ' ( H H / / PP               1RWH &DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV 5()(5(1&(6 287/,1( 9(56,21 ,(& 627  -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(    Fig 18. Package outline SOT891 (XSON6) 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 16 of 22 74CBTLV1G125 Nexperia Single bus switch ;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV WHUPLQDOVERG\[[PP  627 E   î  / / H    H H î  $ $ ' ( WHUPLQDO LQGH[DUHD   VFDOH 'LPHQVLRQV 8QLW $  $ E ' ( H / H PD[      QRP     PLQ    PP PP /        1RWH ,QFOXGLQJSODWLQJWKLFNQHVV 9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\ VRWBSR 5HIHUHQFHV 2XWOLQH YHUVLRQ ,(& -('(& -(,7$ 627    (XURSHDQ SURMHFWLRQ ,VVXHGDWH   Fig 19. Package outline SOT1115 (XSON6) 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 17 of 22 74CBTLV1G125 Nexperia Single bus switch ;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV WHUPLQDOVERG\[[PP  627 E   î  / / H    H H î  $ $ ' ( WHUPLQDO LQGH[DUHD   VFDOH 'LPHQVLRQV 8QLW PP $  $ E ' ( H / H / PD[        QRP        PLQ      PP 1RWH ,QFOXGLQJSODWLQJWKLFNQHVV 9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\ VRWBSR 5HIHUHQFHV 2XWOLQH YHUVLRQ ,(& -('(& -(,7$ 627    (XURSHDQ SURMHFWLRQ ,VVXHGDWH   Fig 20. Package outline SOT1202 (XSON6) 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 18 of 22 74CBTLV1G125 Nexperia Single bus switch 14. Abbreviations Table 14. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15. Revision history Table 15. Revision history Document ID Release date Data sheet status Change notice Supersedes 74CBTLV1G125 v.5 20161110 Product data sheet - 74CBTLV1G125 v.4 - 74CBTLV1G125 v.3 Modifications: 74CBTLV1G125 v.4 Modifications: 74CBTLV1G125 v.3 Modifications: • Section 12.1 and Section 12.2 added. 20120905 • Package outline drawing of SOT886 (Figure 17) modified. 20111215 • Product data sheet Product data sheet - 74CBTLV1G125 v.2 Legal pages updated. 74CBTLV1G125 v.2 20100729 Product data sheet - 74CBTLV1G125 v.1 74CBTLV1G125 v.1 20070223 Product data sheet - - 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 19 of 22 74CBTLV1G125 Nexperia Single bus switch 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74CBTLV1G125 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 20 of 22 74CBTLV1G125 Nexperia Single bus switch Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74CBTLV1G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 10 November 2016 © Nexperia B.V. 2017. All rights reserved 21 of 22 Nexperia 74CBTLV1G125 Single bus switch 18. Contents 1 2 3 4 5 6 6.1 6.2 7 7.1 8 9 10 11 12 12.1 12.2 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Additional dynamic characteristics . . . . . . . . . 12 Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 19 Legal information. . . . . . . . . . . . . . . . . . . . . . . 20 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 20 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Contact information. . . . . . . . . . . . . . . . . . . . . 21 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 November 2016 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74CBTLV1G125GM,115 74CBTLV1G125GV,125 74CBTLV1G125GW,125 74CBTLV1G125GN,132 74CBTLV1G125GF,132 74CBTLV1G125GS,132
74CBTLV1G125GN,132 价格&库存
很抱歉,暂时无法提供与“74CBTLV1G125GN,132”相匹配的价格&库存,您可以联系我们找货
