74CBTLV3253DS,118
74CBTLV3253DS,118
    NEXPERIA(安世)
    SSOP16_4.9X3.9MM
    双1/4多路复用器/多路译码器 SSOP16_4.9X3.9MM 2.3~3.6V
74CBTLV3253DS,118 数据手册
74CBTLV3253 Dual 1-of-4 multiplexer/demultiplexer Rev. 5 — 11 November 2016 Product data sheet 1. General description The 74CBTLV3253 provides a dual 1-of-4 high-speed multiplexer/demultiplexer with two common select inputs (S0, S1) and two output enable inputs (1OE, 2OE). The low ON resistance of the switch allows inputs to be connected to outputs without adding propagation delay or generating additional ground bounce noise. When pin nOE = LOW, one of the four switches is selected (low-impedance ON-state) with pins S0 and S1. When pin nOE = HIGH, all switches are in the high-impedance OFF-state, independent of pins S0 and S1. To ensure the high-impedance OFF-state during power-up or power-down, nOE should be tied to the VCC through a pull-up resistor. The minimum value of the resistor is determined by the current-sinking capability of the driver. Schmitt trigger action at control input makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 2.3 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Supply voltage range from 2.3 V to 3.6 V  High noise immunity  Complies with JEDEC standard:  JESD8-5 (2.3 V to 2.7 V)  JESD8-B/JESD36 (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  CDM AEC-Q100-011 revision B exceeds 1000 V  5  switch connection between two ports  Rail to rail switching on data I/O ports  CMOS low power consumption  Latch-up performance exceeds 250 mA per JESD78B Class I level A  IOFF circuitry provides partial Power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74CBTLV3253D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74CBTLV3253DS 40 C to +85 C SSOP16[1] plastic shrink small outline package; 16 leads; body width 3.9 mm; lead pitch 0.635 mm SOT519-1 74CBTLV3253PW 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74CBTLV3253BQ 40 C to +125 C DHVQFN16 plastic dual-in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm [1] SOT763-1 Also known as QSOP16. 4. Functional diagram $      $      6 6 2( 2( % % % % % % % %     DDO Fig 1. Logic diagram 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 2 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 5. Pinning information 5.1 Pinning %   6 %   % %   % %   % $   % *1'   2(  2(   &%7/9 $ 6   2( 2(   9&& %   6 6   2( %   % %   6 %   % %   % %  %   % $  %   % $   % *1'    %  % $ DDO 7UDQVSDUHQWWRSYLHZ DDO DDO *1'   6 WHUPLQDO LQGH[DUHD   9&& $  *1' 2(  9&& &%7/9 &%7/9 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 2. Pin configuration SOT109-1 (SO16) and SOT519-1 (SSOP16) Fig 3. Pin configuration SOT403-1 (TSSOP16) Fig 4. Pin configuration SOT763-1 (DHVQFN16) 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 15 output enable input (active LOW) S0, S1 14, 2 select input 1B1 to 1B4 6, 5, 4, 3 B input/output 2B1 to 2B4 10, 11, 12, 13 B input/output GND 8 ground (0 V) 1A, 2A 7, 9 A input/output VCC 16 supply voltage 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 3 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 6. Functional description Table 3. Function table[1] Inputs Function switch 1OE 2OE S1 S0 X H X X H X X X disconnect 1A and 1Bn L L L L 1A to 1B1 and 2A to 2B1 L L L H 1A to 1B2 and 2A to 2B2 L L H L 1A to 1B3 and 2A to 2B3 L L H H 1A to 1B4 and 2A to 2B4 [1] disconnect 2A and 2Bn H = HIGH voltage level; L = LOW voltage level. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage input voltage VI Conditions Min Max Unit 0.5 +4.6 V control inputs [1] 0.5 +4.6 V [2] V VSW switch voltage enable and disable mode 0.5 VCC + 0.5 IIK input clamping current VI < 0.5 V 50 - mA ISK switch clamping current VI < 0.5 V 50 - mA ISW switch current VSW = 0 V to VCC - 128 mA ICC supply current - +100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot Tamb = 40 C to +125 C [3] [1] The minimum input voltage rating may be exceeded if the input clamping current ratings are observed. [2] The switch voltage ratings may be exceeded if switch clamping current ratings are observed [3] For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN16 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VSW switch voltage Tamb ambient temperature t/V [1] Conditions Min enable and disable mode input transition rise and fall rate VCC = 2.3 V to 3.6 V [1] Max Unit 2.3 3.6 V 0 3.6 V 0 VCC V 40 +125 C 0 200 ns/V Applies to control signal levels. 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 4 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 9. Static characteristics Table 6. Static characteristics At recommended operating conditions voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Tamb = 40 C to +125 C Unit Min Typ[1] Max Min Max VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 3.0 V to 3.6 V 2.0 - - 2.0 - V LOW-level input VCC = 2.3 V to 2.7 V voltage VCC = 3.0 V to 3.6 V - - 0.7 - 0.7 V - - 0.9 - 0.9 V II input leakage current - - 1 - 20 A IS(OFF) OFF-state VCC = 3.6 V; see Figure 5 leakage current - - 1 - 20 A IS(ON) ON-state VCC = 3.6 V; see Figure 6 leakage current - - 1 - 20 A IOFF power-off VI or VO = 0 V to 3.6 V; leakage current VCC = 0 V - - 10 - 50 A ICC supply current VI = GND or VCC; IO = 0 A; VSW = GND or VCC; VCC = 3.6 V - - 10 - 50 A ICC additional supply current pin nOE; VI = VCC  0.6 V; VSW = GND or VCC; VCC = 3.6 V - - 300 - 2000 A CI input capacitance pin nOE; VCC = 3.3 V; VI = 0 V to 3.3 V - 0.9 - - - pF CS(OFF) OFF-state capacitance VCC = 3.3 V; VI = 0 V to 3.3 V - 5.2 - - - pF CS(ON) ON-state capacitance VCC = 3.3 V; VI = 0 V to 3.3 V - 20.0 - - - pF HIGH-level input voltage VIH VIL pin nOE; VI = GND to VCC; VCC = 3.6 V [1] All typical values are measured at Tamb = 25 C. [2] One input at 3 V, other inputs at VCC or GND. [2] 9.1 Test circuits 9&& 9&& Q2( 9,+ ,V $ 9O Q%Q Q$ Q2( 9,/ ,V ,V $ $ *1' 92 9O Q$ Q%Q *1' 92 DDL DDL VI = VCC or GND and VO = GND or VCC. Fig 5. VI = VCC or GND and VO = open circuit. Test circuit for measuring OFF-state leakage current (one switch) 74CBTLV3253 Product data sheet Fig 6. Test circuit for measuring ON-state leakage current (one switch) All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 5 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 9.2 ON resistance Table 7. Resistance RON At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7. Symbol Parameter RON Tamb = 40 C to +85 C Conditions Tamb = 40 C to +125 C Unit Min Typ[1] Max Min Max ISW = 64 mA; VI = 0 V - 4.2 8.0 - 15.0  ISW = 24 mA; VI = 0 V - 4.2 8.0 - 15.0  ISW = 15 mA; VI = 1.7 V - 8.4 40.0 - 60.0  ISW = 64 mA; VI = 0 V - 4.0 7.0 - 11.0  ISW = 24 mA; VI = 0 V - 4.0 7.0 - 11.0  ISW = 15 mA; VI = 2.4 V - 6.2 15.0 - 25.5  ON resistance VCC = 2.3 V to 2.7 V; see Figure 8 to Figure 10 [2] VCC = 3.0 V to 3.6 V; see Figure 11 to Figure 13 [1] Typical values are measured at Tamb = 25 C and nominal VCC. [2] Measured by the voltage drop between the A and B terminals at the indicated current through the switch. ON-state resistance is determined by the lower of the voltages of the two (A or B) terminals. 9.3 ON resistance test circuit and graphs DDL  521 ȍ  96: 9  9&&  Q2( 9,/   Q$ 9O Q%Q *1'   ,6:        9, 9 DDL (1) Tamb = 125 C. RON = VSW / ISW. (2) Tamb = 85 C. (3) Tamb = 25 C. (4) Tamb = 40 C. Fig 7. Test circuit for measuring ON resistance (one switch) 74CBTLV3253 Product data sheet Fig 8. ON resistance as a function of input voltage; VCC = 2.5 V; ISW = 15 mA All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 6 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer DDL  521 ȍ DDL  521 ȍ                            9, 9 (1) Tamb = 125 C. (1) Tamb = 125 C. (2) Tamb = 85 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (3) Tamb = 25 C. (4) Tamb = 40 C. (4) Tamb = 40 C. Fig 9. ON resistance as a function of input voltage; VCC = 2.5 V; ISW = 24 mA DDL   9, 9 521 ȍ Fig 10. ON resistance as a function of input voltage; VCC = 2.5 V; ISW = 64 mA DDL  521 ȍ                        9, 9 (1) Tamb = 125 C. (1) Tamb = 125 C. (2) Tamb = 85 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (3) Tamb = 25 C. (4) Tamb = 40 C. (4) Tamb = 40 C. Fig 11. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 15 mA 74CBTLV3253 Product data sheet  9, 9 Fig 12. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 24 mA All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 7 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer DDL  521 ȍ               9, 9 (1) Tamb = 125 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (4) Tamb = 40 C. Fig 13. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 64 mA 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 8 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 10. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; for test circuit see Figure 16 Symbol Parameter Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit Conditions Min Typ[1] Max Min Max - - 0.15 - 0.25 ns - - 0.15 - 0.25 ns 1.0 2.2 6.8 1.0 7.5 ns 1.0 2.0 5.5 1.0 6.1 ns 1.0 2.1 5.0 1.0 5.5 ns 1.0 1.9 4.8 1.0 5.3 ns VCC = 2.3 V to 2.7 V 1.0 2.1 4.3 1.0 4.7 ns VCC = 3.0 V to 3.6 V 1.0 1.9 4.0 1.0 4.4 ns VCC = 2.3 V to 2.7 V 1.0 2.6 5.5 1.0 6.1 ns VCC = 3.0 V to 3.6 V 1.0 3.2 5.4 1.0 5.9 ns VCC = 2.3 V to 2.7 V 0.8 2.0 4.8 0.8 5.3 ns VCC = 3.0 V to 3.6 V 1.0 2.0 4.5 1.0 5.0 ns propagation delay nA to nBn or nBn to nA; see Figure 14 tpd [2][3] VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V Sn to nA; see Figure 14 [3] VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V enable time ten nOE to nA or nBn; see Figure 15 [4] VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V Sn to nBn; see Figure 15 disable time tdis nOE to nA or nBn; see Figure 15 Sn to nBn; see Figure 15 [4] [5] [5] [1] All typical values are measured at Tamb = 25 C and at nominal VCC. [2] The propagation delay is the calculated RC time constant of the typical on-state resistance of the switch and the load capacitance, when driven by an ideal voltage source (zero output impedance). [3] tpd is the same as tPLH and tPHL. [4] ten is the same as tPZH and tPZL. [5] tdis is the same as tPHZ and tPLZ. 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 9 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 11. Waveforms 9, LQSXW 90 90 9 W3+/ W3/+ 92+ 90 RXWSXW 90 92/ DDL Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 14. The data input (nA or nBn) to output (nBn or nA) propagation delays Table 9. Measurement points Supply voltage Input Output VCC VM VI tr = tf VM VX VY 2.3 V to 2.7 V 0.5VCC VCC  2.0 ns 0.5VCC VOL + 0.15 V VOH  0.15 V 3.0 V to 3.6 V 0.5VCC VCC  2.0 ns 0.5VCC VOL + 0.3 V VOH  0.3 V 9, 90 Q2(6QLQSXW 90 *1' W3=/ W3/= 9&& RXWSXW /2:WR2)) 2))WR/2: 90 9; 92/ W3=+ W3+= 92+ RXWSXW +,*+WR2)) 2))WR+,*+ 9< 90 *1' VZLWFK HQDEOHG VZLWFK GLVDEOHG VZLWFK HQDEOHG DDO Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 15. Enable and disable times 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 10 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer W: 9,  QHJDWLYH SXOVH 90 90  9 WI WU WU WI 9,  SRVLWLYH SXOVH 90 90  9 W: 9(;7 9&& * 9, 5/ 92 '87 57 5/ &/ DDH Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 16. Test circuit for measuring switching times Table 10. Test data Supply voltage Load VCC CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 2.3 V to 2.7 V 30 pF 500  open GND 2VCC 3.0 V to 3.6 V 50 pF 500  open GND 2VCC 74CBTLV3253 Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 11 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 11.1 Additional dynamic characteristics Table 11. Additional dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); VI = GND or VCC (unless otherwise specified); tr = tf 2.5 ns. Symbol Parameter f(3dB) [1] Tamb = 25 C Conditions 3 dB frequency response VCC = 3.3 V; RL = 50 ; see Figure 17 [1] Unit Min Typ Max - 302 - MHz fi is biased at 0.5VCC. 11.2 Test circuits 9&& 9&& 6Q 9,/RU9,+ 5/ Q%Q Q2( Q$ *1' 9,/ G% IL DDD nOE connected to GND; Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads 3 dB. Fig 17. Test circuit for measuring the frequency response when channel is in ON-state 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 12 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 18. Package outline SOT109-1 (SO16) 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 13 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPPOHDGSLWFKPP ' ( 627 $ ; F \ +( Y 0 $ =   $ $ $   $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S Y Z \ =   ș PP                           R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(    Fig 19. Package outline SOT519-1 (SSOP16) 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 14 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 20. Package outline SOT403-1 (TSSOP16) 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 15 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer '+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV 627 WHUPLQDOVERG\[[PP % ' $ $ $ ( F GHWDLO; WHUPLQDO LQGH[DUHD WHUPLQDO LQGH[DUHD & H H E   \ \ & Y 0 & $ % Z 0 & /   (K H     'K ;   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 PP $   PD[ $ E      F '   'K (   (K          H / Y Z \ \        H  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& -(,7$ 627  02  (8523($1 352-(&7,21 ,668('$7(    Fig 21. Package outline SOT763-1 (DHVQFN16) 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 16 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 13. Abbreviations Table 12. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74CBTLV3253 v.5 20161111 Product data sheet - 74CBTLV3253 v.4 - 74CBTLV3253 v.3 Modifications: 74CBTLV3253 v.4 Modifications: • Section 11.1 and Section 11.2 added. 20111215 • Product data sheet Legal pages updated. 74CBTLV3253 v.3 20110107 Product data sheet - 74CBTLV3253 v.2 74CBTLV3253 v.2 20101125 Product data sheet - 74CBTLV3253 v.1 74CBTLV3253 v.1 20100108 Product data sheet - - 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 17 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74CBTLV3253 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 18 of 20 74CBTLV3253 Nexperia Dual 1-of-4 multiplexer/demultiplexer Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74CBTLV3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 November 2016 © Nexperia B.V. 2017. All rights reserved 19 of 20 Nexperia 74CBTLV3253 Dual 1-of-4 multiplexer/demultiplexer 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 9.1 9.2 9.3 10 11 11.1 11.2 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 ON resistance . . . . . . . . . . . . . . . . . . . . . . . . . . 6 ON resistance test circuit and graphs. . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Additional dynamic characteristics . . . . . . . . . 12 Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 November 2016 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74CBTLV3253BQ,115 74CBTLV3253D,118 74CBTLV3253DS,118 74CBTLV3253PW,118
74CBTLV3253DS,118 价格&库存
很抱歉,暂时无法提供与“74CBTLV3253DS,118”相匹配的价格&库存,您可以联系我们找货
