74CBTLV3861
10-bit bus switch with output enable
Rev. 4 — 11 November 2016
Product data sheet
1. General description
The 74CBTLV3861 is a 10-bit bus switch with one output enable (OE) input. When OE is
LOW, the switch is closed and port A is connected to the B port. When OE is HIGH, the
switch is disabled.
To ensure the high-impedance OFF-state during power-up or power-down, OE should be
tied to the VCC through a pull-up resistor. The minimum value of the resistor is determined
by the current-sinking capability of the driver.
Schmitt trigger action at control input makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 2.3 V to 3.6 V.
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Supply voltage range from 2.3 V to 3.6 V
High noise immunity
Complies with JEDEC standard:
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
CDM AEC-Q100-011 revision B exceeds 1000 V
5 switch connection between two ports
Rail to rail switching on data I/O ports
CMOS low power consumption
Latch-up performance exceeds 250 mA per JESD78B Class I level A
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74CBTLV3861
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature
range
74CBTLV3861DK
Name
40 C to +125 C SSOP24[1]
74CBTLV3861PW 40 C to +125 C TSSOP24
74CBTLV3861BQ
[1]
40 C to +125 C DHVQFN24
Description
Version
plastic shrink small outline package; 24 leads;
body width 3.9 mm; lead pitch 0.635 mm
SOT556-1
plastic thin shrink small outline package; 24 leads;
body width 4.4 mm
SOT355-1
plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 24 terminals;
body 3.5 5.5 0.85 mm
SOT815-1
Also known as QSOP24 package
4. Functional diagram
2(
DDQ
Fig 1.
Logic symbol
Q$
Q%
2(
DDQ
Fig 2.
Logic diagram (one switch)
74CBTLV3861
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 19
74CBTLV3861
Nexperia
5. Pinning information
5.1 Pinning
&%7/9
&%7/9
QF
9&&
QF
9&&
2(
2(
*1'
*1'
DDQ
Fig 3.
DDQ
Pin configuration for TSSOP24 (SOT355-1)
Fig 4.
Pin configuration for SSOP24 (SOT556-1)
WHUPLQDO
LQGH[DUHD
9&&
QF
&%7/9
2(
*1'
DDQ
7UDQVSDUHQWWRSYLHZ
(1) This is not a supply pin, the substrate is attached to this pad using conductive die attach material. There is no electrical or
mechanical requirement to solder this pad however if it is soldered the solder land should remain floating or be connected to
GND.
Fig 5.
Pin configuration for DHVQFN24 (SOT815-1)
74CBTLV3861
Product data sheet
3 of 19
74CBTLV3861
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
n.c.
1
not connected
A1 to A10
2, 3, 4, 5, 6, 7, 8, 9, 10, 11
data input/output (A port)
GND
12
ground (0 V)
B1 to B10
22, 21, 20, 19, 18, 17, 16, 15, 14, 13
data input/output (B port)
OE
23
output enable input (active LOW)
VCC
24
positive supply voltage
6. Functional description
Table 3.
Function selection[1]
Input
Input/output
OE
An, Bn
L
An = Bn
H
Z
[1]
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VSW
switch voltage
enable and disable mode
IIK
input clamping current
ISK
ISW
ICC
Min
Max
Unit
0.5
+4.6
V
[1]
0.5
+4.6
V
[1]
0.5
VCC + 0.5
V
VI < 0.5 V
50
switch clamping current
VI < 0.5 V
50
mA
switch current
VSW = 0 V to VCC
128
mA
supply current
+100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
[1]
[2]
Tamb = 40 C to +125 C
[2]
mA
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SSOP24 and TSSOP24 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
For DHVQFN24 package: Ptot derates linearly at 4.5 mW/K above 60 C.
74CBTLV3861
Product data sheet
4 of 19
74CBTLV3861
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VSW
switch voltage
Tamb
ambient temperature
t/V
[1]
Conditions
Min
Max
Unit
2.3
3.6
V
V
input transition rise and fall rate
VCC
V
40
+125
C
200
ns/V
[1]
VCC = 2.3 V to 3.6 V
Applies to control signal levels.
9. Static characteristics
Table 6.
At recommended operating conditions voltages are referenced to GND (ground = 0 V).
Symbol Parameter
HIGH-level
input voltage
VIH
Tamb = 40 C to +85 C
Conditions
Tamb = 40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 3.0 V to 3.6 V
2.0
2.0
V
0.7
V
VIL
LOW-level input VCC = 2.3 V to 2.7 V
voltage
0.7
0.9
0.9
V
II
input leakage
current
pin OE; VI = GND to VCC;
VCC = 3.6 V
1
A
IS(OFF)
OFF-state
VCC = 3.6 V; see Figure 6
leakage current
1
A
IS(ON)
ON-state
VCC = 3.6 V; see Figure 7
leakage current
1
A
IOFF
power-off
VI or VO = 0 V to 3.6 V;
leakage current VCC = 0 V
10
50
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
VSW = GND or VCC;
VCC = 3.6 V
10
50
A
ICC
additional
supply current
pin OE; VI = VCC 0.6 V;
VSW = GND or VCC;
VCC = 3.6 V
300
2000
A
CI
input
capacitance
pin OE; VCC = 3.3 V;
VI = 0 V to 3.3 V
0.9
pF
CS(OFF)
OFF-state
capacitance
VCC = 3.3 V; VI = 0 V to 3.3 V
5.2
pF
CS(ON)
ON-state
capacitance
14.3
pF
[1]
All typical values are measured at Tamb = 25 C.
[2]
One input at 3 V, other inputs at VCC or GND.
74CBTLV3861
Product data sheet
[2]
5 of 19
74CBTLV3861
Nexperia
9.1 Test circuits
9&&
9&&
2(
9,+
,V
%Q
$Q
,V
*1'
9,
2(
9,/
,V
$Q
%Q
*1'
9,
92
92
DDQ
DDQ
VI = VCC or GND and VO = GND or VCC.
Fig 6.
VI = VCC or GND and VO = open circuit.
Test circuit for measuring OFF-state leakage
current (one switch)
Fig 7.
Test circuit for measuring ON-state leakage
9.2 ON resistance
Table 7.
Resistance RON
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8.
Symbol Parameter
RON
Conditions
Unit
Min
Typ[1]
Max
Min
Max
ISW = 64 mA; VI = 0 V
4.2
8.0
15.0
ISW = 24 mA; VI = 0 V
4.2
8.0
15.0
ISW = 15 mA; VI = 1.7 V
8.4
40
60.0
4.0
7.0
11.0
4.0
7.0
11.0
ISW = 15 mA; VI = 2.4 V
6.2
15
25.5
ON resistance VCC = 2.3 V to 2.7 V;
see Figure 9 to Figure 11
[2]
VCC = 3.0 V to 3.6 V;
see Figure 12 to Figure 14
[1]
Typical values are measured at Tamb = 25 C and nominal VCC.
[2]
Measured by the voltage drop between the A and B terminals at the indicated current through the switch. ON-state resistance is
determined by the lower of the voltages of the two (A or B) terminals.
74CBTLV3861
Product data sheet
6 of 19
74CBTLV3861
Nexperia
9.3 ON resistance test circuit and graphs
DDL
521
ȍ
96:
9
9&&
2(
9,/
$Q
%Q
*1'
9,
,6:
9,9
DDQ
(1) Tamb = 125 C.
RON = VSW / ISW.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
Fig 8.
Test circuit for measuring ON resistance
(one switch)
DDL
521
ȍ
Fig 9.
ON resistance as a function of input voltage;
VCC = 2.5 V; ISW = 15 mA
DDL
521
ȍ
9,9
(1) Tamb = 125 C.
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
(4) Tamb = 40 C.
Fig 10. ON resistance as a function of input voltage;
VCC = 2.5 V; ISW = 24 mA
74CBTLV3861
Product data sheet
9,9
Fig 11. ON resistance as a function of input voltage;
VCC = 2.5 V; ISW = 64 mA
7 of 19
74CBTLV3861
Nexperia
DDL
DDL
521
ȍ
521
ȍ
9,9
9,9
(1) Tamb = 125 C.
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
(4) Tamb = 40 C.
Fig 12. ON resistance as a function of input voltage;
VCC = 3.3 V; ISW = 15 mA
Fig 13. ON resistance as a function of input voltage;
VCC = 3.3 V; ISW = 24 mA
DDL
521
ȍ
9,9
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
Fig 14. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 64 mA
74CBTLV3861
Product data sheet
8 of 19
74CBTLV3861
Nexperia
10. Dynamic characteristics
Table 8.
GND = 0 V; for test circuit see Figure 17
Symbol Parameter
Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit
Conditions
Min
Typ[1]
Max
Min
Max
0.13
0.20
ns
0.20
0.31
ns
1.0
2.9
5.5
1.0
8.0
ns
1.0
2.4
4.9
1.0
7.0
ns
1.0
2.6
5.5
1.0
8.0
ns
1.0
3.1
5.8
1.0
8.5
ns
[2][3]
propagation delay An to Bn or Bn to An;
see Figure 15
tpd
enable time
ten
[4]
OE to An or Bn;
see Figure 16
disable time
tdis
[5]
OE to An or Bn;
see Figure 16
[1]
All typical values are measured at Tamb = 25 C and at nominal VCC.
[2]
The propagation delay is the calculated RC time constant of the typical on-state resistance of the switch and the load capacitance, when
driven by an ideal voltage source (zero output impedance).
[3]
tpd is the same as tPLH and tPHL.
[4]
ten is the same as tPZH and tPZL.
[5]
tdis is the same as tPHZ and tPLZ.
11. Waveforms
9,
LQSXW
90
90
9
W3+/
W3/+
92+
RXWSXW
90
90
92/
DDL
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig 15. The data input (An, Bn) to output (Bn, An) propagation delay times
Table 9.
Measurement points
Supply voltage
Input
Output
VCC
VM
VI
tr = tf
VM
VX
VY
2.3 V to 2.7 V
0.5VCC
VCC
2.0 ns
0.5VCC
VOL + 0.15 V
VOH 0.15 V
3.0 V to 3.6 V
0.5VCC
VCC
2.0 ns
0.5VCC
VOL + 0.3 V
VOH 0.3 V
74CBTLV3861
Product data sheet
9 of 19
74CBTLV3861
Nexperia
9,
2(LQSXW
90
90
*1'
W3=/
W3/=
9&&
RXWSXW
/2:WR2))
2))WR/2:
90
9;
92/
W3+=
92+
W3=+
9<
RXWSXW
+,*+WR2))
2))WR+,*+
90
*1'
VZLWFK
HQDEOHG
VZLWFK
GLVDEOHG
VZLWFK
HQDEOHG
DDQ
Fig 16. Enable and disable times
74CBTLV3861
Product data sheet
10 of 19
74CBTLV3861
Nexperia
9,
W:
QHJDWLYH
SXOVH
90
9
WI
WU
WU
WI
9,
SRVLWLYH
SXOVH
9
90
90
90
W:
9(;7
9&&
9,
5/
92
'87
57
5/
DDH
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 17. Test circuit for measuring switching times
Table 10.
Test data
Supply voltage
Load
VCC
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
2.3 V to 2.7 V
30 pF
500
open
GND
2VCC
3.0 V to 3.6 V
50 pF
500
open
GND
2VCC
74CBTLV3861
Product data sheet
VEXT
11 of 19
74CBTLV3861
Nexperia
11.1 Additional dynamic characteristics
Table 11. Additional dynamic characteristics
GND = 0 V.
Symbol Parameter
f(3dB)
[1]
3 dB frequency response
Tamb = 25 C
Conditions
VCC = 3.3 V; RL = 50 ; see Figure 18
Unit
Min
Typ
Max
406
[1]
MHz
fi is biased at 0.5VCC.
11.2 Test circuit
9&&
9&&
2(
9,/
5/
%Q
IL
$Q
*1'
G%
DDQ
Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads 3 dB.
Fig 18. Test circuit for measuring the frequency response when channel is in ON-state
74CBTLV3861
Product data sheet
12 of 19
74CBTLV3861
Nexperia
12. Package outline
6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPPOHDGSLWFKPP
627
F
Y 0 $
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216PLOOLPHWUHGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOLQFKGLPHQVLRQV
81,7
PD[
ES
F
H
/S
Y
Z
ș
PP
R
R
R
R
LQFKHV
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 19. Package outline SOT556-1 (SSOP24)
74CBTLV3861
Product data sheet
13 of 19
74CBTLV3861
Nexperia
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
ES
H
GHWDLO;
Z 0
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 20. Package outline SOT355-1 (TSSOP24)
74CBTLV3861
Product data sheet
14 of 19
74CBTLV3861
Nexperia
'+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJH
QROHDGVWHUPLQDOVERG\[[PP
627
F
GHWDLO;
WHUPLQDO
LQGH[DUHD
H
WHUPLQDO
LQGH[DUHD
H
Y 0 & $ %
Z 0 &
E
H
(K
'K
PP
VFDOH
81,7
PD[
E
F
' K
( K
H
H
H
Y
Z
PP
1RWH
5()(5(1&(6
287/,1(
9(56,21
-(,7$
627
(8523($1
352-(&7,21
,668('$7(
Fig 21. Package outline SOT815-1 (DHVQFN24)
74CBTLV3861
Product data sheet
15 of 19
74CBTLV3861
Nexperia
13. Abbreviations
Table 12.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
14. Revision history
Table 13.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74CBTLV3861 v.4
20161111
Product data sheet
74CBTLV3861 v.3
74CBTLV3861 v.2
Modifications:
74CBTLV3861 v.3
Modifications:
Section 11.1 and Section 11.2 added.
20111216
Product data sheet
Legal pages updated.
74CBTLV3861 v.2
20110120
Product data sheet
74CBTLV3861 v.1
74CBTLV3861 v.1
20101206
Product data sheet
74CBTLV3861
Product data sheet
16 of 19
74CBTLV3861
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74CBTLV3861
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
17 of 19
74CBTLV3861
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74CBTLV3861
Product data sheet
18 of 19
Nexperia
74CBTLV3861
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
9.1
9.2
9.3
10
11
11.1
11.2
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
ON resistance . . . . . . . . . . . . . . . . . . . . . . . . . . 6
ON resistance test circuit and graphs. . . . . . . . 7
Dynamic characteristics . . . . . . . . . . . . . . . . . . 9
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Additional dynamic characteristics . . . . . . . . 12
Test circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16
Legal information. . . . . . . . . . . . . . . . . . . . . . . 17
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Contact information. . . . . . . . . . . . . . . . . . . . . 18
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Date of release: 11 November 2016
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74CBTLV3861DK,118 74CBTLV3861PW,118 74CBTLV3861BQ,118
